Hi guys seat mii came in for 2 front wheel bearings and abs sensors hub nuts were left loose after possible gearbox rebuild have replaced both front wheel bearings and abs sensors abs light on traction light on steering wheel light on speedo not working any help thx
Saturday,17,February,2018,18:15:47:31334
VCDS Version: 17.8.1.0
VIN: VSSZZZAAZED305383 License Plate: SEAT MII
Mileage: 16380km-10178mi Repair Order:
Chassis Type: AA-VW12 (6N0)
Scan: 01 03 09 10 15 17 19 25 44 56
VIN: VSSZZZAAZED305383 Mileage: 16380km-10178miles
Address 01: Engine (------CHYA) Labels:. 04C-906-020-CHY.clb
Part No SW: 04C 906 020 AK HW: 04C 907 309 N
Component: 1.0l R3 MPI H23 5971
Revision: UOH23---
Coding: 00110012020400000000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_ECM10MPI01104C906020AK 001006
ROD: EV_ECM10MPI01104C906020AK.rod
VCID: 64C7DB856F21D96615-8030
12888 - Implausible Data Received from ABS Control Module
U0415 00 [047] - -
Mileage: 16380 km
Date: 2018.02.17
Time: 00:44:13
Vehicle speed: 255 km/h
Coolant temperature: 86 °C
Intake air temperature: 15 °C
Voltage terminal 30: 12.392 V
CAN status - engine control module-Bit 0: 0
4675 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 00 [047] - -
Mileage: 16380 km
Date: 2018.02.17
Time: 00:44:13
4278 - Implausible Data Received from ABS Control Module
U0415 00 [175] - -
Mileage: 16380 km
Date: 2018.02.17
Time: 00:44:13
Readiness: 0000 0001
Address 03: ABS Brakes (J104) Labels:. 1S0-614-517.clb
Part No SW: 1S0 614 517 E HW: 1S0 614 517 E
Component: EBC 460 ESP H08 0012
Serial number: A00E49D
Coding: 21BF247189AD02F684FD24FD91AC4080590100
ASAM Dataset: EV_Brake1ESPMP1TRWVW120 016035
ROD: EV_Brake1ESPMP1TRWVW120.rod
VCID: 316962D160533CCE2E-8064
0017 - Front Left Wheel Speed Sensor
C101A 29 [137] - Signal Implausible
Reset counter: 228
Mileage: 16380 km
Date: 2018.02.17
Time: 00:46:02
DTC: 00 00 11
0018 - Front Right Wheel Speed Sensor
C101B 29 [137] - Signal Implausible
Reset counter: 228
Mileage: 16380 km
Date: 2018.02.17
Time: 00:46:02
DTC: 00 00 12
Address 09: Cent. Elect. (J519) Labels:. 1S0-937-08x-09.clb
Part No SW: 1S0 937 086 D HW: 1S0 937 086 D
Component: PQ25 BCM H30 0561
Revision: -A------ Serial number: --------------
Coding: 62B82B0000010000000000002C28ACC00040400C60020000200000000000
VCID: 39795AF1B023F48E96-806C
00157 - Terminal X
Reset counter: 228
Mileage: 16380 km
Date: 2018.02.17
Time: 12:05:31
Address 10: Park/Steer Assist (J446) Labels:| 1Sx-919-475.clb
Part No SW: 1SL 919 475 HW: 1Q0 919 475
Component: PARKHILFE 3K H03 0005
Revision: -------- Serial number: 32931321900611
Coding: 100001
ASAM Dataset: EV_EPHVA14SE1200000 001001
ROD: EV_EPHVA14SE1200000.rod
VCID: 1325C859FA0FEEDE3C-8046
Part No SW: 1S0 959 655 B HW: 1S0 959 655 B
Component: VW10Airbag00Q H03 0006
Revision: -------- Serial number: 003MY003U2FN
Coding: 000000000000000000000000000000003051
ASAM Dataset: EV_AirbaVW10BPAVW12X 001001
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3D714EE1AC0BC8AEBA-8068
Serial number: 3495RRB401850LKOE12E
Serial number: 3505RRB401450KR6IQ4L
Serial number: 3555NRB400G50JB6F8H8
12850432 - Implausible Data Received from ABS Control Module
U0415 00 [009] - -
Reset counter: 227
Mileage: 16380 km
Date: 2018.02.17
Time: 00:46:02
Address 17: Instruments (J285) Labels:| 1Sx-920-xxx-17.clb
Part No SW: 1SL 920 960 M HW: 1SL 920 960 M
Component: KOMBI H31 0205
Revision: X0031012 Serial number: 00000000000000
Coding: 414200
ASAM Dataset: EV_KombiUDSMM9RM10 A04752
ROD: EV_KombiUDSMM9RM10_A04_VW12.rod
VCID: 57BDFC492E7702FE80-8002
13637376 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 00 [009] - -
Reset counter: 227
Mileage: 16380 km
Date: 2018.02.17
Time: 00:46:02
Part No SW: 6N0 909 901 HW: 1S0 937 086 D
Component: GW-K-CAN TP20 H30 0561
Revision: -A------
Coding: 021300
VCID: 70EFA7D5A3D975C661-8024
Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 1SL 920 960 M
Component: IMMO H31 0205
ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
ROD: EV_ImmoUDSMM9RM10_VW01.rod
VCID: 6ADBB5BD8D058F162F-803E
Address 44: Steering Assist (J792) Labels:| 1Sx-909-144-44.clb
Part No SW: 1S2 909 144 L HW: 1S2 909 144 G
Component: EPS_ECU H45 1503
Coding: 0001000101000000
ASAM Dataset: EV_SteerAssisNSK 009004
ROD: EV_SteerAssisNSK_009.rod
0213 - Function Restriction due to Faults in Other Modules
U1113 00 [137] - -
Reset counter: 227
Mileage: 16380 km
Date: 2018.02.17
Time: 00:41:49
Voltage terminal 15: 13.764 V
Voltage terminal 30: 14.466 V
Engine speed: 1930.50 /min
Vehicle speed: 50 km/h
Status: Release
Part No SW: 1SL 035 156 E HW: 1SL 035 156 E
Component: Radio H35 0063
Revision: R0000000 Serial number: SEZAZ1N0407104
Coding: 0000040802
VCID: 49992A31E0C3640E06-801C
End-------------------------(Elapsed Time: 02:01)--------------------------
