Hi all!
I have some problems with retrofit VW Sharan 2011 (7N) from halogen to bi-xenon headligt with AFS and led drl.
Installed :
Headlights 7N1 941 034 D / 7N1 941 033 D
Headlight Range 5M0 907 357 F with slave modules 1T0 941 329 A .
Level sensors, front and rear
There is no 11 pin in headlights, witch control hi-beam shutter. So I have problem, it’s not work. I think shutter in this headlight controlled by slave module by CAN messages, not by wire from j519.
Anybody knows the type of control: wire or /can message coded in BCM? I tried different variants of coding, but it not work. Also I try this variant: http://forums.ross-tech.com/showthr...rofit-(No-AFS)&p=115875&viewfull=1#post115875
But I can’t code 55-xenon range (051A00100B000200). It does not accept any coding : Coding rejected/ Error 22: Conditions not correct or request of sequence error.
I try non zero Work Shop Code, but still not work/
Thanks for the help.
Autoscan
Installed :
Autoscan
Saturday,17,February,2018,08:34:18:17679
VCDS Version: 17.12.0.1 (x64) HEX-NET CB: 0.4417.4
Data version: 20171213 DS285.1
VIN: WVWZZZ7NZBVzzzzzz License Plate:
Mileage: 130990km-81393mi Repair Order:
Chassis Type: 7N-VW36 (7N0)
Scan: 01 02 03 05 08 09 10 15 16 17 18 19 25 2B 37 42 44 46 52 53
55 56 61 62 69 6D 72 77 BE BF
VIN: WVWZZZ7NZBVzzzzzz Mileage: 130990km-81393miles
BE-Slid. Door Rear Left -- Status: OK 0000
BF-Slid. Door Rear Right -- Status: OK 0000
Address 01: Engine (J623-CFFB) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 HJ HW: 03L 907 309 Q
Component: R4 2,0L EDC X23 9957
Revision: 44X23--- Serial number:
Coding: 001D001A043401080000
Shop #: WSC 92521 052 00000
ASAM Dataset: EV_ECM20TDI01103L906018HJ 003010
ROD: EV_ECM20TDI01103L906018HJ.rod
VCID: 79BA2860F89C5DE288C-802C
10065 - Mass Air Flow Sensor (G70)
P0104 00 [167] - Intermittent
Mileage: 130993 km
Date: 2018.02.17
Time: 22:50:48
Coolant temperature: 17 °C
Intake air temperature: 18 °C
Voltage terminal 30: 11.680 V
Air mass: actual value (mg/stroke): 0.0 mg/stroke
Standardised airflow ratio: 3.9999
EGR Solen.val.: actual value: 101.77 %
Throttle valve adapter: actual value: 109.61 %
Charge air pressure specified value: 1023 hPa
Charge air pressure: actual value: 995 hPa
Mean injection quantity: 0.00 mg/stroke
Part No SW: 02E 300 054 Q HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2602
Revision: 05151112 Serial number: 00001009170074
Shop #: WSC 00020 790 00000
VCID: 24042914E79EF00A8BA-8070
Address 03: ABS Brakes Labels: 7N0-614-109.clb
Part No SW: 7N0 614 109 L HW: 7N0 614 109 L
Component: J104 C3 450M VDEA 0008
Revision: --H07--- Serial number: 00000003315480
Coding: 0027162
VCID: 3620E35C4102729A25E-8062
Address 05: Acc/Start Auth. (J518) Labels:| 5K0-959-434.clb
Part No SW: 5K0 959 434 A HW: 5K0 959 434 A
Component: VWKESSYPQ35GP 085 0708
Revision: 00085000 Serial number: 0140004123
Coding: 03100C
Shop #: WSC 00020 999 00000
ASAM Dataset: EV_KESSY_PQ35GP A01010
ROD: EV_KESSY_PQ35GP.rod
VCID: 3326DA489A7067B2020-8066
Part No SW: 5K0 907 044 G HW: 5K0 907 044 G
Component: Clima-Sharan H11 0104
Coding: 0000000009
VCID: 2F2ED63876584352668-807A
Part No SW: 5K0 937 086 J HW: 5K0 937 086 J
Component: BCM PQ35 M 011 0045
Revision: BC011001
Coding: 40510A3B89251AC0500800C1740081E443050008476D25F2E484C704A2C9
Shop #: WSC 00020 790 12345
VCID: 3B36F268BA20AFF2DA0-806E
Subsystem 1 - Part No SW: 7N1 955 119 A HW: 7N1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 110919 31 0032
Serial number: 110922150344
Coding: 000D9D
Subsystem 2 - Part No SW: 7N0 955 559 HW: 7N0 955 559 Labels: 7N0-955-559.CLB
Component: RLFS 021 0022
Serial number: Y10M10D19h19m22s35S1
Coding: 0380BB
00984 - Left Tail Light (M4)
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 234
Mileage: 130993 km
Date: 2012.07.10
Time: 22:50:50
Voltage: 11.70 V
00985 - Right Tail Light (M2)
Reset counter: 234
Mileage: 130993 km
Date: 2012.07.10
Time: 22:50:50
Voltage: 11.70 V
Reset counter: 234
Mileage: 130993 km
Date: 2012.07.10
Time: 22:50:48
Voltage: 11.70 V
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
002 - Lower Limit Exceeded
Fault Status: 01100010
Reset counter: 234
Mileage: 130993 km
Date: 2012.07.10
Time: 22:50:47
Voltage: 11.70 V
02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
Reset counter: 234
Mileage: 130993 km
Date: 2012.07.10
Time: 22:50:49
Voltage: 11.70 V
Address 10: Park/Steer Assist (J446) Labels:| 1Q0-919-475.clb
Part No SW: 7N0 919 475 HW: 7N0 919 475
Component: PARKHILFE 8K H04 0010
Revision: -------- Serial number: 80231030008450
Coding: 118101
ASAM Dataset: EV_EPHVA18VW4280000 001005
ROD: EV_EPHVA18VW4280000.rod
VCID: 78BC2D64C39644EAF72-802C
Part No SW: 7N0 959 655 B HW: 7N0 959 655 B
Component: VW10Airbag01P H07 0013
Serial number: 003GFPLVW81N
Coding: 003150
ASAM Dataset: EV_AirbaVW10TS6VW428 A01002
ROD: EV_AirbaVW10TS6VW428.rod
VCID: 3E30FB7CA132BADAFDE-806A
Subsystem 1 - Part No SW: --- HW: ---
Component: S.Sens.Fahr.V --- ---
Serial number: 3493ETS60348EF30C9D5
Subsystem 2 - Part No SW: --- HW: ---
Component: S.Sens.Beif.V --- ---
Serial number: 3503ETS60CB97F8129D3
Subsystem 3 - Part No SW: --- HW: ---
Component: S.Sens.Fahr.H --- ---
Serial number: 3513ETS6005B6F30C9DY
Subsystem 4 - Part No SW: --- HW: ---
Component: S.Sens.Beif.H --- ---
Serial number: 3523ETS60FB4CF7129D7
Subsystem 5 - Part No SW: --- HW: ---
Component: F.Sens.Fahr --- ---
Serial number: 35540TS608303FC129DH
Part No SW: 5K0 953 501 BM HW: 5K0 953 569 L
Component: LENKS.MODUL 009 0136
Revision: FF010039 Serial number: 20101016300439
Coding: 110A240000
VCID: 76A0235CC982329AE5E-8022
Component: E221__MFL-TK6 H06 0022
Coding: E20000
Part No SW: 7N0 920 870 A HW: 7N0 920 870 A
Component: KOMBI H20 0420
Coding: 140B00
VCID: 302CD5446B665CAA7F2-8064
Address 18: Aux. Heat Labels: 1K0-815-071.clb
Part No: 7N0 963 271 A
Component: Zuheizer 051 2630
Revision: 00051000 Serial number: 09022126000000
Coding: 0000041
VCID: 3228DF4CAD6A6EBA096-8066
Part No SW: 7N0 907 530 D HW: 1K0 907 951
Component: J533 Gateway H35 0614
Revision: H35 Serial number: 290810F2000618
Coding: 468002
VCID: 312AD040686C55A270C-8064
Reset counter: 234
Mileage: 130993 km
Date: 2012.07.10
Time: 22:50:50
Component: IMMO H20 0420
Coding: 000007
VCID: 6A98072C8D3AE67A716-803E
Address 2B: Steer. Col. Lock (J764) Labels:| 5K0-905-861.clb
Part No SW: 5K0 905 861 A HW: 5K0 905 861 A
Component: ELV-PQ35 H20 0220
Revision: 00000000 Serial number: 10000046261004
Coding: 4900000000000000
ROD: EV_ELVMarquMPVW36X.rod
VCID: 2E10CB3C71524A5A6DE-807A
Address 37: Navigation
Address 42: Door Elect, Driver (J386) Labels:. 7N0-959-793.clb
Part No SW: 7N0 959 793 E HW: 7N0 959 793 A
Component: TSG FA H04 0400
Revision: Serial number: 0000109579735
Coding: 01153E20D000411011
VCID: 44C48994C7DED00AABA-8010
02123 - Door Warning Light / Entry Light
Reset counter: 234
Mileage: 130993 km
Date: 2012.07.10
Time: 22:50:44
Part No SW: 5N1 909 144 L HW: 5N1 909 148 G
Component: J500__APA-BS KL.324 0802
Revision: 1AH03729 Serial number: 00102790228101
Coding: 0000258
VCID: 3B36F2687A20AFF2DA0-806E
Address 52: Door Elect, Pass. (J387) Labels:. 7N0-959-792.clb
Part No SW: 7N0 959 792 E HW: 7N0 959 792 A
Component: TSG BF H04 0400
Revision: Serial number: 0000109585860
Coding: 01153E20DE00411011
VCID: 43C68A88C2D0D732920-8016
Part No SW: 3AA 907 801 D HW: 3AA 907 801 D
Component: J540 EPB4 VW-53083 0006
Revision: H18 Serial number: 00000000116265
Coding: 0024067
Address 55: Headlight Range (J745) Labels:. 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 F HW: 7L6 907 357 C
Component: AFS-ECU H04 0111
Coding: 0000000000000000
ROD: EV_HeadlRegulVWAFSPt_VW32.rod
VCID: 373EEE588E088B923E8-8062
Subsystem 1 - Part No: 1T0 941 329 A Labels: 3D0-941-329.CLB
Subsystem 2 - Part No: 1T0 941 329 A Labels: 3D0-941-329.CLB
10490624 - No End-of-Line Programming
B2013 00 [137] - -
Reset counter: 234
Mileage: 130993 km
Date: 2018.02.17
Time: 22:50:46
13636352 - Control module not coded
U1013 00 [137] - -
[Steuergeraet nicht kodiert]
Reset counter: 234
Mileage: 130993 km
Date: 2018.02.17
Time: 22:50:46
5276144 - Power Output Module for Left Headlamp
U4E3B50 F0 [137] - Not Coded
Reset counter: 234
Mileage: 130993 km
Date: 2018.02.17
Time: 22:50:46
5276400 - Power Output Module for Right Headlamp
U4E3C50 F0 [137] - Not Coded
Reset counter: 234
Mileage: 130993 km
Date: 2018.02.17
Time: 22:50:46
5275220 - Headlight
Reset counter: 234
Mileage: 130993 km
Date: 2018.02.17
Time: 22:50:46
Address 56: Radio
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H35 0614
Coding: 030B185A
VCID: 71AA1040A8EC15A230C-8024
Subsystem 1 - Part No SW: 1K0 915 181 F HW: 1K0 915 181 A
Component: J367-BDM H07 0150
Serial number: 00000000009370150497
Address 62: Door, Rear Left (J388) Labels:. 7N0-959-794.clb
Part No SW: 7N0 959 794 F HW: 7N0 959 795 B
Component: TSG HL H03 0400
Revision: Serial number: 0000109722341
Coding: 01007C200000411001
VCID: 46C0939CF1E2E21AB5E-8012
Address 69: Trailer (J345) Labels:. 7N0-907-383.clb
Part No SW: 7N0 907 383 HW: 7N0 907 383
Component: Anhaenger H07 0101
Revision: 3I001002 Serial number: 00000136922828
Coding: 410C040001000000
VCID: 73A61A48D2F027B2C20-8026
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 7N0 959 107 B HW: 7N0 959 107 A
Component: HDSG-Modul H11 0803
Revision: 41011001 Serial number: 290000079
Coding: 0733334003
ASAM Dataset: EV_HDSGVW428 201133
ROD: EV_HDSGVW428_VW36.rod
VCID: 3620E35C8902729A25E-8062
Address 72: Door, Rear Right (J389) Labels:. 7N0-959-794.clb
Component: TSG HR H03 0400
Revision: Serial number: 0000109724040
Address 77: Telephone (J412) Labels:| 3C8-035-730-A.clb
Part No SW: 3C8 035 730 A HW: 3C8 035 730 A
Component: Telefon 007 0078
Revision: -------- Serial number: 35909603055534
Coding: 020000000100000000010000
ASAM Dataset: EV_UHVPremi A01005
ROD: EV_UHVPremi_A01.rod
VCID: 210A2000308CE522E0C-8074
9457427 - Left audio channel for speech/telephone
B104F 13 [009] - Short to GND
Reset counter: 234
Mileage: 130993 km
Date: 2018.02.17
Time: 22:50:40
9457171 - Right audio channel for speech/telephone
B104E 13 [009] - Short to GND
Reset counter: 234
Mileage: 130993 km
Date: 2018.02.17
Time: 22:50:40
9455635 - Telephone Microphone
B1048 13 [009] - Open Circuit
Reset counter: 234
Mileage: 130993 km
Date: 2018.02.17
Time: 22:50:40
Address BE: Slid. Door Rear Left (J558) Labels: 7N0-959-244.clb
Part No SW: 7N0 959 244 HW: 7N0 959 244
Component: Schiebetuer_l 005 2213
Serial number: 10358920
ASAM Dataset: EV_AST A03002
ROD: EV_AST.rod
Address BF: Slid. Door Rear Right (J731) Labels: 7N0-959-244.clb
Component: Schiebetuer_r 005 2213
Serial number: 10358795
ROD: EV_AST.rod
End----(Elapsed Time: 02:05, VBatt start/end: 11.8V/11.8V. VIgn 11.7V)-----
