- Joined
- Feb 16, 2018
- Messages
- 10
- Reaction score
- 4
- Location
- Switzerland
- VCDS Serial number
- C?ID=324274
Greetings awesome people of VCDS,
I am retrofitting ACC on my 2009 VW Touareg 7L6 V6 3.6L FSI. I am not sure about my coding (engine coding in particular). Would you please take a look at the scan and tell me the right coding. Thanks a ton in advance.
Best Regards,
Karim
Best Regards,
Karim
Friday,16,February,2018,14:52:53:16283
VCDS Version: 18.1.0.2 (x64) HEX-V2 CB: 0.4411.4
VIN: WVGZZZ7LZ9D027940 License Plate:
Mileage: 90830km-56439mi Repair Order:
Chassis Type: 7L (6N0)
Scan: 01 02 03 05 06 08 09 13 15 16 17 19 22 2E 34 36 37 46 47 55
56 68 69 76 77
VIN: WVGZZZ7LZ9D027940 Mileage: 90830km-56439miles
68-Wiper Electr. -- Status: OK 0000
Address 01: Engine (BHK) Labels: 03H-906-032-BLV.clb
Part No SW: 03H 906 032 CC HW: 03H 906 032 S
Component: T-GP EU4 A 1953
Revision: 5FH04--- Serial number: VWX3Z0H1815734
Coding: 0011175
Shop #: WSC 31414 790 00001
VCID: 6596415639723F9FFB3-5184
005717 - Please check DTC Memory of Auto. Distance Controller
P1655 - 004 -
Mileage: 90838 km
Temperature: 3.0°C
Temperature: 15.0°C
Absolute Pres.: 970.0 mbar
Voltage: 12.192 V
Readiness: 0110 0101
Address 02: Auto Trans Labels: 09D-927-750.lbl
Part No SW: 09D 927 750 HJ HW: 09D 927 750 HJ
Component: AL 750 6A 1406
Revision: 00H75000 Serial number:
Coding: 0004200
VCID: 7DA60936B1E2975F033-5160
18272 - Powertrain Data Bus
P1864 - 000 - Missing Message from Auto Distance Controller - Intermittent
Address 03: ABS Brakes Labels: 7L0-907-379-MK25E1.clb
Part No SW: 7L0 907 379 P HW: 7L0 614 517 C
Component: ESP ALLRAD MK25E1 0304
Revision: 00H53001
Coding: 0006530
VCID: 46D4A6DAA4E41487129-8012
Reset counter: 61
Mileage: 90838 km
Date: 2018.02.10
Time: 18:18:19
Count: 128
Count: 13057
Count: 294
Count: 3
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 139 D HW: 3D0 909 139 D
Component: Kessy 6850
Revision: 00H22071 Serial number: VWX3Z0H1815734
Coding: 0000232
VCID: 2A0CF26A10BCD0E7161-807E
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: None
Part No: 7L0 959 760
Component: Sitzverstellung 0701
VCID: 77AA1B1E938EBD0F59F-8022
Address 08: Auto HVAC Labels: 7L6-907-040.clb
Part No: 7L6 907 040 AH
Component: CLIMAtronic R/L 4334
Coding: 0001020
VCID: 76B4161A9484C407429-8022
Address 09: Cent. Elect. Labels:. 7Lx-937-049-V2.clb
Part No SW: 7L6 937 049 AF HW: 7L6 937 049 AF
Component: J519 2002
Revision: -0004--- Serial number: --------------
Coding: 600004003B261C000000000000000000
VCID: 005870C2C640FAB7685-8054
Address 13: Auto Dist. Reg Labels: None
Part No SW: 7L6 907 567 B HW: 7L6 907 567 B
Component: AC201 RDW 1 036 0391
Revision: 00036000 Serial number: 00000000597907
Coding: 0010000
Shop #: WSC 00046 000 00000
VCID: 3D26C936F132575F433-8068
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 61
Mileage: 90838 km
Date: 2018.02.10
Time: 18:23:36
Count: 34
Address 15: Airbags Labels: 7L0-959-655.lbl
Part No SW: 7L0 959 655 HW: 7L0 959 655
Component: J234__3Q VW8T 0250
Revision: 92012025 Serial number: 0039P006HS57
Coding: 0013137
VCID: 7AAC022AA09CA067261-802E
Address 16: Steering wheel Labels: 7L6-953-549.lbl
Part No: 7L6 953 549 F
Component: J527 3601
Coding: 0010022
VCID: 42DCBACA88CC28A73E1-8016
Address 17: Instruments Labels: 7L6-920-xxx-7L6.lbl
Part No SW: 7L6 920 890 B HW: 7L6 920 890 B
Component: J285 KOMBI-INST. 9533
Revision: KHH06V36
Coding: 0007101
Shop #: WSC 00011 888 06946
VCID: 372ADB1ED34E7D0F99F-8062
Address 19: CAN Gateway Labels:. 6N0-909-901-7L.clb
Part No SW: 6N0 909 901 HW: 7L6 920 890 B
Component: J533 GW-K-CAN TP20 9533
Coding: FFE2EF8FCA846002
VCID: 70B82002F6A0EA37985-8024
Address 22: AWD Labels: None
Part No: 0AD 927 755 BG
Component: TRANSFERCASE 0126
VCID: 015E75C6CD1AF3BF67B-5184
Address 2E: Media Player 3
Address 34: Level Control Labels: 7Lx-907-553-34.clb
Part No: 7L0 907 553 J
Component: LUFTFDR.-CDC- 3C3P1 3125
Coding: 0015521
VCID: 3A2CC22AE01C6067661-806E
Component: Sitzverstellung 0703
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 7L6 035 680 C HW: 7L6 035 680 B
Component: RNS-MID H03 5238
Revision: AB001001 Serial number: VWZ6Z7H7276096
Coding: 02010000010000220000
VCID: 323CEA0A342C9827AE1-8066
00857 - CD Changer Unit (R41)
Reset counter: 61
Mileage: 90832 km
Date: 2018.02.10
Time: 18:23:56
Address 46: Central Conv. Labels: 7L0-959-933.lbl
Part No: 7L6 959 933 A
Component: 23 HSG 0601
Coding: 0000069
Shop #: WSC 50024 001 1048576
VCID: 40D8B0C286903AB7285-4B1E
Subsystem 1 - Part No: 7L0 959 701 N
Component: Tuersteuergeraet FS 6304
Subsystem 2 - Part No: 7L0 959 702 N
Component: Tuersteuergeraet BF 6304
Subsystem 3 - Part No: 7L6 959 703
Component: Tuersteuergeraet HL 0202
Subsystem 4 - Part No: 7L6 959 704
Component: Tuersteuergeraet HR 0202
Address 47: Sound System Labels: 7Lx-035-4xx-47.lbl
Part No SW: 7L6 035 456 C HW: 7L6 035 456 C
Component: 08K Audioverst. 0001
Revision: 00001000 Serial number: 00000000207444
VCID: 3332EF0EC736912FA57-8066
Address 55: Headlight Range Labels: 7L6-907-357-A.lbl
Part No SW: 7L6 907 357 C HW: 7L6 907 357 C
Component: AFS-Steuergeraet 0132
Coding: 1288323
VCID: 3B22C72EEF26596F7D7-806E
Subsystem 1 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l S004
Coding: 00000019
Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r S004
Coding: 00000019
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
Reset counter: 61
Mileage: 90832 km
Date: 2018.02.10
Time: 18:23:56
Address 68: Wiper Electr. Labels: 7L0-955-119-V2.clb
Part No: 7L6 955 119 B
Component: J400__ Front Wiper 5301
Coding: 0001397
VCID: 392EDD26E55A6B7F6FB-806C
Component: RLS 300908 054 0402
Coding: 00208941
Shop #: WSC 31414
Address 69: Trailer Labels: 7L0-907-383-1D2.lbl
Part No SW: 7L0 907 383 N HW: 7L0 907 383 N
Component: J345 Anhaenger 0050
Revision: 4A007002 Serial number: 00000114062988
Coding: 0016385
VCID: 3FDAB33EFB3E454F51F-806A
Address 76: Park Assist Labels: Redir Fail!
Part No: 7L0 919 283 F
Component: 0L Einparkhilfe 1108
VCID: 392EDD26E51A6B7F6FB-806C
Address 77: Telephone Labels: RETROFIT77.lbl
Part No SW: KTC 364 96P HW: KTC 364 96P
Component: SWP:3.21.9 H24 0198
Shop #: WSC 21977 142 74100
VCID: 3E24CE3AFC744C475A9-806A
End----------(Elapsed Time: 02:29, VBatt start/end: 12.1V/12.1V)-----------
