Results 1 to 10 of 13
Thread: Audi SQ5 2013 parking sensors turn on automatically at low speed
    Mar 2015
    Australia
    Hi, apologies if this has been asked before, but we have a new to us SQ5, our last 3 Audis all turned on the parking sensors at low speed which was great in our tight carport, the sensors in the SQ5 only seem to work if you put in reverse or hit the button. Is there somewhere to turn this on in the VCDS?
    Cheers, paul
    Please post an Auto-Scan so people can see how the vehicle is equipped and configured.
  3. Likes paulmac liked this post
    Mar 2015
    Australia
    Oh sorry - here you go.
    Sunday,04,February,2018,21:04:09:57105
    VCDS Version: 18.1.0.2 (x64)
    VIN: WAUZZZ8R4EA043761   License Plate:
    Chassis Type: 8R-AU48 (8R0)
    Scan: 01 02 03 05 08 09 15 16 17 19 36 42 44 46 52 53 56 5F 62 6C
              6D 72 A9 C0
    VIN: WAUZZZ8R4EA043761   Mileage: 50160km-31167miles
    Address 01: Engine (J623-CGQB)       Labels:. 059-907-401-V2.clb
       Part No SW: 8K5 907 589     HW: 4G0 907 589
       Component: 3.0BTD EDC17  H25 0002
       Revision: 57H25---
       Coding: 2A2A4032252603020000
       Shop #: WSC 06208 000 00000
       ASAM Dataset: EV_ECM30BTD0118K5907589 001005
       ROD: EV_ECM30BTD0118K5907589.rod
       VCID: 7EF3185BE12864B5C7-802A
       Part No SW: 8R0 927 158 AE    HW: 0BK 927 156 AM
       Component: 0BK 30RTDIRdW H16 1005
       Revision: --H16---
       Coding: 000001
       VCID: 000F66A39BDC1245B5-8054
    Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V2.clb
       Part No SW: 8R0 907 379 AF    HW: 8R0 907 379 AF
       Component: ESP8 quattro  H09 0030
       Coding: 245D0C01
       Shop #: WSC 06335 000 00000
       VCID: 04076AB387C40E6591-8050
    02214 - Tire Pressure Warning
                000 -  -  - Intermittent
                        Reset counter: 108
                        Mileage: 50114 km
                        Date: 2018.02.03
                        Time: 16:15:52
                        Hex Value: 0x3800
                        Hex Value: 0x4006
                        Hex Value: 0x1221
                        Hex Value: 0x1FB0
                        Hex Value: 0x0000
       Part No SW: 8K0 907 064 HR    HW: 8K0 907 064 GR
       Component: BCM2 2.0      H13 0641
       Coding: 05B54000000000000000
       VCID: 071D7DBFB6F2257DF4-8052
       Subsystem 1 - Part No SW: 8K0 959 754 BN    HW: 8K0 959 754 BN
       Serial number: 0813000126717018
       Part No SW: 8K2 820 043 S    HW: 8K2 820 043 S
       Revision: D0000000    Serial number: 01200920132171
       Coding: 3625628080
       VCID: 3979CB47B086838DB2-806C
       Part No SW: 8K0 907 063 DG    HW: 8K0 907 063 DG
       Revision: 07016001    Serial number: 00000679307601
       Coding: 260000108134AFE0018140C000001D0D0F9DC70827090201000008004401030100000034000000
       VCID: 77FD0D7FC61255FD84-8022
       Subsystem 1 - Part No SW: 8R2 955 119 A    HW: 8R2 955 119   Labels: 1KX-955-119.CLB
       Component: WWS416 130904  H11 0050
       Serial number: 90243015130819161354
       Coding: 01DD13
       Serial number: 21735978
       Coding: 02005C
       Component: E1 - LDS  H03 0031
       Serial number: 00000000001409130346
       Serial number: 88784CC6000000000001
    Address 15: Airbags (J234)       Labels:| 8R0-959-655.clb
       Part No SW: 8R0 959 655 G    HW: 8R0 959 655 G
       Component: AirbagVW-AU10 H47 0610
       Serial number: 003JPDB0NLN9
       Coding: 304A3431313030303030554A305238523053
       ROD: EV_AirbaAU10SMEAU416.rod
       VCID: 489FBE83F36CEA053D-801C
       Serial number: 6334MSME7E20731BI
       Serial number: 6344MSME7F307476N
       Serial number: 6352QSME053838509
       Serial number: 6362QSME05382C4AM
       Serial number: 63732SME7A381C4CD
       Serial number: 63832SME7C3802740
       Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
       Component: Lenks.Modul   H03 0003
       Revision: C0062331    Serial number: 90862MI1000IY
       Coding: 000037
       VCID: 489FBE83FB6CEA053D-801C
    Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
       Part No SW: 8R0 920 931 F    HW: 8R0 920 931 F
       Component: KOMBIINSTR.   H35 0563
       Revision: 00300000    Serial number: WYB45ZL9E
       Coding: B3A7220003010008010000
       VCID: 387FCE438B8C9A854D-806C
       Component: GW-BEM 4CAN-M H11 0056
       Revision: 1Y070028    Serial number: 2841Y1390404EF
       Coding: 80CD07FF00
       VCID: 4A9B848BE56018152B-801E
       Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
       Component: J367-BDM  H07 0141
       Serial number: 30254I58551461074594
       Serial number: 13260003766021200181
       Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
       Component: MEM-FS        H07 0076
       Revision: AA000000    Serial number: 00000073446404
       Coding: 01781B00000000000000
       VCID: 428BACABDD50C055E3-8016
       Component: TSG FA        H02 0510
       Revision:             Serial number: 0000075661591
       Coding: 011D12205E01440004
       VCID: 4FAD959F1E023D3D7C-801A
       Part No SW: 8R0 909 144 F    HW: 8R0 909 144 B
       Component: RCEPS         H38 0507
       Revision: 00001000    Serial number: 0005741957
       Coding: 100000010001
       Shop #: WSC 06334 000 00000
       ROD: EV_RCEPSAU48X_008.rod
       VCID: 3B75D14FB2BAB19DA0-806E
       Revision: 00002001    Serial number: 0314765472
       Coding: 01000E2A20B930818420053680040047
       Revision:             Serial number: 0000075685258
       VCID: 4E93889B1908343577-801A
       Part No SW: 8K0 907 801 M    HW: 8K0 907 801 J
       Component: EPB-4         H01 0004
       Revision: --------    Serial number: 10000000265886
       ROD: EV_ParkiBrake_AU48.rod
       VCID: 3979CB47B886838DB2-806C
       Part No SW: 4G0 035 056 J    HW: 4G0 035 056
       Component: Radio U STD   H60 0133
       Revision: AB001007    Serial number: 230I-0D2893911
       Coding: 040003020100000001
       VCID: 285F1E035B2C0A05DD-807C
    03029 - Subwoofer (R157)
                        Reset counter: 68
                        Mileage: 50103 km
                        Date: 2018.02.03
                        Time: 15:58:46
                        Voltage: 12.10 V
       Part No SW: 8R2 035 754 F    HW: 8R2 035 754 C
       Component: H-BN-RW       H46 0739
       Revision: --------    Serial number: 210IU0D7516532
       Coding: 1A0A01060205A1EF45808B4E00000403FC0000020000000000
       VCID: 3A7BD44BB5808895BB-806E
       Subsystem 1 - Part No: 8R0 060 884 AS
       Component: ROW 2013  0506
       Component: DU7 High  H42 0104
       Serial number: A130IW0D2826435
       Serial number: 00000001621788
       Component: CD-Database  5298
       Component: TSG HL        H01 0510
       Revision:             Serial number: 0000075697363
       Coding: 010C12204001240004
       VCID: 4683B0BBF178FC75CF-8012
       Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
       Revision: --H08---    Serial number: 525PA8-J37A4XW
       Coding: 1020010
       VCID: 3467FA7357E47EE561-8060
       Part No SW: 8R0 827 851 B    HW: 8R0 827 851 B
       Revision: --------    Serial number: 8R0827851B
       VCID: 3B75D14FBABAB19DA0-806E
       Subsystem 1 - Part No SW: 8R0 827 852 B    HW: 8R0 827 852 B
       Serial number: 8R0827852B
       Component: TSG HR        H01 0510
       Revision:             Serial number: 0000075697440
       Part No SW: 8R0 907 159     HW: 4H0 907 159 A
       Component: SAS-GEN 2     H06 0007
       Serial number: 130814200445
       VCID: 79F90B47F806438DF2-802C
    Address C0: Act. for Ext. Noise (J943)       Labels: 4G0-907-160.clb
       Part No SW: 8R0 907 160     HW: 4G0 907 160 B
       Component: SAS-GEN 2 AGA H09 0002
       Serial number: 130724200885
       VCID: 71E93367A0760BCD4A-8024
  5. Likes Boki Ar, Uwe liked this post
  6. #4
    Mar 2015
    Australia
    Hi, is there any update on this - TIA
    Jun 2017
    I don't think that's possible.
  8. Likes paulmac liked this post
  9. #6
    May 2017
    yes, Audi is a bit different beast than MQB cars. Parking assistant is integrated into BCM module.
    Can you post an adaptation map from your 09 : Central electronics module as well?
  10. Likes paulmac liked this post
  11. #7
    Jun 2017
    Adpmaps of non-UDS modules do not contain documented channel descriptions. Or do they? I'm not sure.
  12. Likes paulmac liked this post
  13. #8
    May 2017
    Hmmm.. I think in Audi's case the BCM has documented adaptation channels. I modified some settings on my neighbors Q5 two years ago and back then VCDS showed descriptions for the channels. Of course, never took adaptation map from it so I don't know if the descriptions follow all the way to the output file
  14. Likes paulmac liked this post
  15. #9
    Dec 2016
    DE
    Nope, only UDS (up to now) AdpMaps will have a description in them. For other modules (TP2.0 etc.) it is just the channel number. Also all numbers will be checked (0-255), while for UDS only those in the ASAM/ODX dataset will be regarded.
    However in VCDS there is documentation available, but it will never be piped to the AdpMap.
  16. Likes downtime, paulmac liked this post
  17. #10
    May 2017
    Ok, that explains it. VCDS did show adaptation channel descriptions yes. But as I wrote, we never needed to do adaptation map from BCM so that part is mystery.
    Now it's clear, so no point to do the adaptation map
  18. Likes paulmac liked this post
