I am looking to disable the phone and NAV speed related blocks in my new 2017 Jetta GLI. I found some information on a post:
http://www.golfmk7.com/forums/showthread.php?t=26057
My Jetta is similar, but had more "locked menu contents" to disable and it opened up the ability to tap a gas station and have the map appear, but left two items I am still unable to do: 1) input an address - not really a big deal, except the voice command is useless as it often does not seem to recognize even distinct speech. 2) Dial a phone number - I do have a need to be able to tap in extension or voice mail code numbers and are blocked by almost any movement and have to fumble around on the phone. I didn't have this issue on my 2016 GLI.
Thank you for your help!
Below is the most recent scan:
Tuesday,13,February,2018,10:56:57:06246
VCDS Version: 18.1.0.2 (x64)
VIN: 3VW5T7AJ1HM331527 License Plate: AXD2199
Mileage: 4910km-3050mi Repair Order: 2017gli - nav&phone4
Chassis Type: AJ-VW36 (7N0)
Scan: 01 03 05 08 09 10 15 16 17 19 25 2B 3C 42 44 46 47 4F 52 5F
62 72 75
VIN: 3VW5T7AJ1HM331527 Mileage: 4910km-3050miles
Address 01: Engine (J623-CPPA) Labels:. 06K-907-425-V2.clb
Part No SW: 06K 906 071 BL HW: 06K 907 425 C
Component: R4 2.0l TFS H13 3686
Revision: --H13---
Coding: 00190012242400171000
Shop #: WSC 00066 790 00209
ASAM Dataset: EV_ECM20TFS02006K906071BL 001005
ROD: EV_ECM20TFS02006K906071BL.rod
VCID: 76E90862C9DF5BF59F-8022
15125 - Cylinder 1
P0301 00 [096] - Misfire Detected
15128 - Cylinder 2
P0302 00 [096] - Misfire Detected
15137 - Random/Multiple Cylinder Misfire Detected
P0300 00 [096] - -
Part No SW: 1K0 907 379 CC HW: 1K0 907 379 CC
Component: ESP MK60EC1 H46 0175
Revision: 00H46001
Coding: A14B600C492500FB851006E6922000412118F02A
VCID: 75EB0F6EDCD950ED96-8020
Address 05: Acc/Start Auth. (J518) Labels:| 5K0-959-434.clb
Part No SW: 5K0 959 434 G HW: 5K0 959 434
Component: VWKESSYPQ35GP 092 1305
Revision: 00092000 Serial number: 0425409799
Coding: 032C0C
Shop #: WSC 00066 000 00294
VCID: 3973C35EB841F48DB2-806C
Part No SW: 1K8 907 044 CN HW: 1K8 907 044 CN
Component: Climatronic H08 0405
Revision: 00001K05
Coding: 0050019002
Shop #: WSC 00066 790 00318
VCID: 7DFB174EECE908ADDE-8028
Part No SW: 5K0 937 087 AJ HW: 5K0 937 087 AJ
Component: BCM PQ35 H+ 122 0184
Revision: BL122001
Coding: EB200A3A902F06D4018800812400054C0070000845A08DB2E4802000A040
Shop #: WSC 00066 123 12345
VCID: 7DFB174EE4E908ADDE-8028
Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 071216 04 42 0106
Coding: 0228DD
Part No SW: 1K8 919 472 C HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0480
Revision: -------- Serial number: 39361635507638
Coding: 0071155001
ASAM Dataset: EV_EPHVA18VW364GP00 001007
VCID: 3777C5668E55E2FD44-8062
Address 15: Airbags (J234) Labels:* 561-959-655.clb
Part No SW: 561 959 655 HW: 561 959 655
Component: AirbagVW11 008 0210
Serial number: 003RXM0AZ4EJ
Coding: 8CCCF000000000005000001AC20800000065
ASAM Dataset: EV_AirbaVW11SMEVW411 001002
ROD: EV_AirbaVW11SMEVW411.rod
VCID: 63CF41366A4DDE5DC8-8036
Component: BF-Gewichtss. H13 0022
Serial number: IBH000000000006K7YM6
Coding: 30314C
Subsystem 2 - Part No SW: ----------- HW: 480 002 012 16
Serial number: 35700000000E3101FF1M
Subsystem 3 - Part No SW: ----------- HW: 480 002 012 16
Serial number: 35800000000959F4002H
Subsystem 4 - Part No SW: ----------- HW: 480 021 912 16
Component: SideSensor_Dr 000 0148
Serial number: 3510001B3237EE3414C2
Subsystem 5 - Part No SW: ----------- HW: 480 021 912 16
Component: SideSensor_Pr 000 0148
Serial number: 3520001AF237EE3593DN
Subsystem 6 - Part No SW: ----------- HW: 480 021 201 17
Component: FrontSensor_D 000 0189
Serial number: 3550001C723D98C2F30E
Subsystem 7 - Part No SW: ----------- HW: 480 021 201 17
Component: FrontSensor_P 000 0189
Serial number: 3560001C723D98C2837F
Part No SW: 1K5 953 521 CR HW: 5K0 953 569 BF
Component: LENKS.MODUL 018 0230
Revision: FF010042 Serial number: 20161223100934
Coding: 0002440008
Shop #: WSC 00066 790 00088
ROD: EV_SMLSNGVOLWSR8C.rod
VCID: 7F07ED46E6E51ABDCC-802A
Subsystem 1 - Part No SW: 6C0 959 442 C HW: 6C0 959 442 C Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H04 0103
Serial number: 29160003091550076476
Coding: B0FFFF
Part No SW: 5C6 920 986 C HW: 5C6 920 986 C
Component: KOMBI H02 1104
Coding: 221E010000
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
VCID: 336FF1769A2D0EDD78-8066
Part No SW: 7N0 907 530 BL HW: 7N0 907 530 AN
Component: J533 Gateway H56 1682
Revision: H56 Serial number: 07021703010239
Coding: 351032
VCID: 7BFF1956FAFD069DE0-802E
Component: IMMO H02 1104
Coding: 000007
VCID: 6AD12C128D678F150B-803E
Address 2B: Steer. Col. Lock (J764) Labels:| 5K0-905-861.clb
Part No SW: 5K0 905 861 D HW: 5K0 905 861 D
Component: ELV-PQ35 H22 0240
Revision: 00000000 Serial number: 16000220562003
Coding: 4100000000000000
ROD: EV_ELVMarquMPVW36X.rod
VCID: 3163FB7E60313CCD0A-8064
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 B HW: 5Q0 907 686 B
Component: HRE_Master H12 0071
Serial number: 0423360622
Coding: 02011102
Shop #: WSC 00066 790 00294
ROD: EV_HREntryHella_VW27.rod
VCID: 3C7DDA4AB773C1A5A9-8068
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 5Q0 907 685 B HW: 5Q0 907 685 B
Component: HRE_Slave H12 0071
Serial number: 0423630498
Coding: 020111
Part No SW: 561 959 701 B HW: 3C0 959 793 H
Component: TUER-SG FT 002 0631
Revision: 13100010 Serial number: 0010819294
Coding: 0404BD
Shop #: WSC 00066 790 00079
ASAM Dataset: EV_TSGFPQ35BRFVW46X A04004
VCID: 1D3B37CE0CA9A8ADBE-8048
Slave Driver:
Subsystem 1 - Part No SW: 6R0 959 811 T HW: 6R0 959 811 T
Component: J388__TSG_HL 022 1467
Serial number: 14202745170122224129
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 306 3501
Revision: 00H22000
VCID: 3973C35E7041F48DB2-806C
Part No SW: 5C6 035 456 C HW: 5C6 035 456 C
Component: KonzernAmp10K H09 6831
Revision: -------- Serial number: EAA098C0117369
VCID: 2855161A53EB7D05DD-807C
Part No SW: 7N0 907 532 HW: 7N0 907 530 AN
Component: EZE_2 H56 1682
Coding: 01030100
VCID: 6FE73D06BE856A3D5C-803A
Subsystem 1 - Part No SW: 5K0 959 591 A HW: 6R0 959 591 D
Component: J245 PS41.402 H03 0004
Serial number: 0000FST001DFN1H00000
Coding: 180000
Part No SW: 561 959 702 B HW: 3C0 959 792 H
Component: TUER-SG BT 002 0631
Revision: 15100010 Serial number: 0010801169
Coding: 0404BC
ASAM Dataset: EV_TSGBPQ35BRFVW46X A04004
VCID: 1E3930C201AFB3B5A7-804A
Slave Passenger:
Subsystem 1 - Part No SW: 6R0 959 812 T HW: 6R0 959 812 T
Component: J389__TSG_HR 022 1467
Serial number: 14102744170120023939
Part No SW: 5C0 035 684 B HW: 5C0 035 684 B
Component: MU-S-NS-US H31 0359
Serial number: VWZAZ2S0726338
Coding: 02630102AA00000051220003001808009F0100D400200101C6
ROD: EV_MUStd4CTSAT_VW27.rod
VCID: 244D022A2FC39965F1-8070
Subsystem 1 - Part No SW: 3G0 919 866 BB HW: -----------
Component: NAR 2017 --- 0525
0009 - Antenna for Satelite Radio
B10F4 13 [008] - Open Circuit
Reset counter: 194
Mileage: 4568 km
Date: 2018.02.06
Time: 15:04:09
Voltage terminal 30: 14.5 V
SDARS_tuner_status_2-Antenna current: 0 mA
SDARS_tuner_status_2-Reception quality: Not available
SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: Initial_value_forMPFA_not_coded
SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: FF
Address 75: Telematics (J949) Labels:| 12E-035-284.clb
Part No SW: 561 035 285 A HW: 561 035 285 A
Component: OCULowUSA 020 0160
Serial number: 000003554140560
Coding: 02630102C24232107F1606000000
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_OCULow 002010
ROD: EV_OCULow_002.rod
VCID: 142D52EAFF63E9E501-8040
End-------------------------(Elapsed Time: 03:41)--------------------------
