Hey Guys Im having an issue with a Golf TDI 1.9 , i checked the vaccuum lines from the Solenoid Valve Block, wastegate actuator but still i am having this issue
any help thanks, below is an AutoScan of the car,
Saturday,10,February,2018,12:57:45:17560
VCDS Version: 18.1.0.2 (x64)
VIN: WVWZZZ1KZ8W554216 License Plate:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ8W554216 Mileage: 90650km-56327miles
Address 01: Engine Labels: 03G-906-016-BKC.clb
Part No SW: 03G 906 021 QA HW: 03G 906 021 AN
Component: R4 1,9L EDC G000AG 1139
Revision: --H07--- Serial number: VWX7Z0GN3N57WA
Coding: 0000078
Shop #: WSC 01392 785 00200
VCID: 6ED9E3BE79D39D3557-803A
001025 - EGR System
P0401 - 000 - Insufficient Flow
Mileage: 89480 km
Time: 00:43:09
RPM: 1386 /min
Speed: 41.0 km/h
Load: 6.3 %
Duty Cycle: 14.6 %
Duty Cycle: 100.2 %
Mass Air / Rev.: 240.0 mg/str
Mass Air / Rev.: 455.0 mg/str
000564 - Boost Pressure Regulation
P0234 - 000 - Limit Exceeded (Overboost Condition) - Intermittent
Fault Status: 00110000
Mileage: 89836 km
Time: 09:08:49
RPM: 3780 /min
Speed: 76.0 km/h
Load: 100.0 %
Voltage: 14.44 V
Bin. Bits: 00101000
Absolute Pres.: 2019.6 mbar
Absolute Pres.: 2519.4 mbar
006481 - Radiator Fan 2 (V177)
P1951 - 000 - Movement Restricted / Jammed - Intermittent
Fault Frequency: 7
Mileage: 90043 km
Time: 09:08:38
RPM: 798 /min
Load: 0.0 %
Voltage: 14.06 V
Bin. Bits: 00101000
Temperature: 56.7°C
Duty Cycle: 53.5 %
Readiness: 1 1 0 0 0
Part No SW: 02E 300 044 G HW: 02E 927 770 AE
Component: GSG DSG 081 1404
Revision: 04508010 Serial number: 00000704191465
VCID: 1933E062D0DD2A8D52-804C
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0017025
VCID: 3F876EFA6E3924BD8C-806A
Part No SW: 1K0 907 044 CP HW: 1K0 907 044 CP
Component: ClimatronicPQ35 130 1212
Revision: 00130022 Serial number: 00000000000000
VCID: 77F7C6DA0689DCFD84-8022
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-M.lbl
Part No SW: 3C0 937 049 AH HW: 3C0 937 049 AH
Revision: 00H54000 Serial number: 01000007698278
Coding: 00890F2700041800470A00000F000000000959035C000100000000000000
Shop #: WSC 01287 785 00200
VCID: 6FE7FEBA7ED9943D5C-803A
Subsystem 1 - Part No: 5M0 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer 241007 021 0501
Coding: 00038805
Shop #: WSC 01287
01502 - Bulb for Rear Fog; Left (L46)
Fault Status: 00101100
Reset counter: 141
Mileage: 89449 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 12.40 V
Reset counter: 141
Mileage: 89472 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 12.55 V
00532 - Supply Voltage B+
Fault Status: 00100001
Reset counter: 138
Mileage: 89449 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 15.50 V
01598 - Drive Battery Voltage
Fault Frequency: 20
Reset counter: 169
Mileage: 90203 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 14.05 V
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: 1D AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD1KUEF0
Coding: 0012612
Shop #: WSC 01373 785 00200
VCID: 3D7B14F2643536AD9E-8068
Subsystem 1 - Serial number: 6332MSME33350E425
Subsystem 2 - Serial number: 6342MSME3204086FA
Subsystem 3 - Serial number: 6351HSME0F150235+
Subsystem 4 - Serial number: 6361HSME1246206F4
Part No SW: 1K0 953 549 BF HW: 1K0 953 549 BF
Component: J0527 051 0100
Coding: 0010042
00576 - Terminal 15
00885 - Ignition Switch (D) Terminal 50
Part No SW: 1K0 920 864 B HW: 1K0 920 864 B
Component: KOMBIINSTRUMENT VDD 1212
Revision: V0002000 Serial number: VWX7Z0GN3N57WA
Coding: 0003103
Shop #: WSC 04057 202 58160
VCID: 2B5F2AAA8A41A81D30-807E
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533__Gateway H15 0180
Revision: H15 Serial number: 1400K07720849A
Coding: ED807F060002029002
VCID: 30653DC6A367CBC505-8064
Component: IMMO VDD 1212
Component: Tuer-SG 006 1213
Coding: 0000180
VCID: 387505E64B1713854D-806C
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.070 H08 1901
Shop #: WSC 00000 028 00001
VCID: 356B0CD25C05EEED56-8060
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Coding: 989002005103087F2D04840560084F03E0FCA0
Shop #: WSC 04057 202 06088
VCID: 030FA20A4251805DA8-8056
Fault Frequency: 57
Reset counter: 157
Mileage: 90232 km
Time: 10:25:23
Coding: 0000180
VCID: 397300E2701D0A8DB2-806C
01553 - Motor for Central Locking; Passenger Door (V57); Lock
Part No: 5M0 035 186 C
Component: Radio GR0 034 0033
Revision: 0003404S Serial number: VWZ2Z2G3192600
Coding: 0040400
VCID: 2C5D29B68F4FAF2539-8078
Part No SW: 1K0 959 703 K HW: 1K0 959 703 K
Component: Tuer-SG 006 1203
Coding: 0000144
Shop #: WSC 01392 785 1012552
Part No SW: 1K0 959 704 K HW: 1K0 959 704 K
Coding: 0000144
End-------------------------(Elapsed Time: 01:41)--------------------------
