Hello to all. I have almost finished an update for Audi a3 8v 2016(pre facelift) xenon to LED conversion. Changed headlights, range control J431 to J745 AFS unit, did all the wiring and coding. Now i have working drls, parking lights, turn signals, low beam, high beaam and cornering lights. Can not figure out how to make "All weather lighs" working. p.s. I changed light switch also, with "all weather lights" button.
Maybe anyone has an advice? And could anyone confirm that my bcm supports LED lights?
Thanks in advance!
And
Thanks in advance!
And
Tuesday,13,February,2018,22:25:53:54234
VCDS Version: 17.8.1.0
Workshop Code: 552 08316 000000
VIN: WAUA7GFF1G1026550 License Plate: A3_ALL_WEATHER
Mileage: 34546km-21465mi Repair Order:
Chassis Type: FF-AU37 (5Q0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 2B 42 44 52 55 5F 6C BB BC
VIN: WAUA7GFF1G1026550 Mileage: 34546km-21465miles
Address 01: Engine (J623-CNSB) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 264 F HW: 06K 907 425 B
Component: 1.8l R4 TFSI H13 0003
Revision: --H13---
Coding: 0A1D00122424000F3000
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM18TFS0208V0906264F 001003
ROD: EV_ECM18TFS0208V0906264F.rod
VCID: 3F8D31A7A6AE66BEA8-806A
Readiness: 1110 1101
Part No SW: 0D9 300 042 C HW: 02E 927 770 AQ
Component: DQ250-6F MQB H53 4906
Revision: 06253104 Serial number: TFK01506040359
Shop #: WSC 04742 780 00200
ROD: EV_TCMDQ250021_VW37.rod
VCID: 1939BF3F184A688E76-804C
P1734 00 [002] - -
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-IPB-V1.clb
Part No SW: 3Q0 907 379 AA HW: 3Q0 907 379 F
Component: ESC H42 0623
Revision: 00000000 Serial number: 62015000001070
Coding: 13FF6A9234220A72017C020581C329C8562C5080408194B4024100548208
ROD: EV_Brake1UDSContiMK100IPB_034_VW48.rod
VCID: 79F99FBFF80A888ED6-802C
Revision: 00021000 Serial number: 0374987175
Coding: 030C0C
ROD: EV_KessyHellaMQBAB_002_VW37.rod
VCID: 3A7B40B3BD8C43969F-806E
Part No SW: 8V0 820 043 C HW: 8V0 820 043 C
Component: AC Automat H13 0060
Revision: 20027000 Serial number: 00000000695207
Coding: 03000014010000000000000000001400
VCID: 326B689365FCBBD657-8066
Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: A2998BB7000000000001
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 085 AH HW: 5Q0 937 085 AE
Component: BCM MQBAB MNA H24 0175
Serial number: 01061519800050
Coding: 04151C42C04122FD41C04004511007000800000000000000000000000000
Shop #: WSC 08316 552 00000
ROD: EV_BCMBOSCH_015_VW37.rod
VCID: 7F0D71A7E62EA6BEE8-802A
Subsystem 1 - Part No SW: 8V1 955 119 C HW: 8V1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 150710 042 0585
Serial number: 150715213512
Coding: 0A47F7
Component: G397_RLFS H06 0002
Serial number: 24098735
Coding: 00006C
Light switch:
Subsystem 3 - Part No SW: 8V0 941 531 G HW: 8V0 941 531 G
Component: E1 - LDS MQB H05 0032
Serial number: 23 11 2012 00000047
Subsystem 4 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000063211765
Sun Roof:
Subsystem 5 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
Component: J245 PS73.404 H03 0004
Serial number: 0000FST000FJNI300000
Coding: 101F00
Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0054
Revision: -------- Serial number: 39331519803516
Coding: 0010150011
VCID: 43853D57CA46025ECC-8016
Component: AirbagVW20 010 0830
Serial number: 003GCR02UDN/
Coding: 9DCCFCC0000000005000001AC24800000065
VCID: 479D2947FE7E2E7E10-8012
Belt Pretensioner left:
Component: BeltPretRevFL H36 0350
Serial number: 34230167A21071571217
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H36 0350
Serial number: 34230168A22071540107
Coding: 333135
Occupant Detection:
Subsystem 3 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Serial number: 694000000000001DCUYN
Coding: 303332
Subsystem 4 - Part No SW: ----------- HW: 480 001 507 15
Serial number: 357000000008F010851A
Subsystem 5 - Part No SW: ----------- HW: 480 001 507 15
Serial number: 3580000000026D20851A
Subsystem 6 - Part No SW: ----------- HW: 480 400 907 15
Serial number: 3510002A11B7E8F3A39H
Subsystem 7 - Part No SW: ----------- HW: 480 401 607 15
Serial number: 3520002B71C52F41C242
Subsystem 8 - Part No SW: ----------- HW: 480 400 805 15
Serial number: 3550002BF1A2DCD3712J
Front Sensor Passenger:
Subsystem 9 - Part No SW: ----------- HW: 480 400 805 15
Serial number: 3560002A31A91E71633+
Part No SW: 8V0 953 521 FH HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0110
Revision: -------- Serial number: 23071508490747
Coding: A018
ROD: EV_SMLSKLOMQB_009_AU37.rod
VCID: 0501E34F84F2FC6EA2-8050
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb
Part No SW: 8V0 920 960 M HW: 8V0 920 960 M
Component: KOMBI H03 6420
Coding: 0BED19192B80D7050200A8001800000000000000
VCID: 4581234FC4723C6EE2-8010
Part No SW: 5Q0 907 530 AF HW: 5Q0 907 530 M
Component: GW MQB High 212 2223
Revision: -------- Serial number: 17071510800707
Coding: 0101000830085A005B00020C180B00000001010000000000000000000000
ROD: EV_GatewConti_013_VW37.rod
VCID: 75E1938FD412ECEEB2-8020
Subsystem 2 - Part No SW: 8U0 951 528 A HW: 8U0 951 528 A
Component: E221 - MFL H02 0014
Serial number: 03 07 2015 C0013266
Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000173143005
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB_004_VW37.rod
VCID: 34676E8B9FE8B5E645-8060
Part No SW: 5Q0 959 393 E HW: 5Q0 959 393 B
Component: TSG FS 020 0041
Serial number: 040715BG317548
Coding: 00101B204000048000000002
VCID: 4189375FD05A104EDE-8014
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 126 1061
Coding: 0102
ROD: EV_SteerAssisMQB.rod
Part No SW: 5Q0 959 392 E HW: 5Q0 959 392 B
Component: TSG BFS 020 0041
Serial number: 100715BGA08623
Coding: 001013204000048000000002
VCID: 408F325BDB501946D1-8014
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0091
Coding: 011E000020220200
ROD: EV_HeadlRegulAFSMQBMLB_AU37.rod
Subsystem 1 - Part No SW: 7PP 941 472 A HW: 7PP 941 472 A Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H06 5050
Coding: E00100
Subsystem 2 - Part No SW: 7PP 941 472 A HW: 7PP 941 472 A Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H06 5050
Coding: E00100
Subsystem 3 - Part No SW: 7PP 941 329 C HW: 7PP 941 329 C Labels: 3D0-941-329.CLB
Component: LeiMo links H01 4000
Coding: E00100
Subsystem 4 - Part No SW: 7PP 941 329 C HW: 7PP 941 329 C Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 4000
Coding: E00100
Address 5F: Information Electr. (J794) Labels:| 8V0-035-MIB-STD1.clb
Part No SW: 8V0 035 844 C HW: 8V0 035 844
Component: MU-S-S-US 013 0660
Serial number: A7A01207150603
Coding: 01730100FF0A000011220001001A00002F0001440100010002
ASAM Dataset: EV_MUStd6C3PASE 002020
ROD: EV_MUStd6C3PASE_AU37.rod
VCID: 39795FBFB88A488E96-806C
Subsystem 1 - Part No SW: 8V0 919 603 C HW: 8V0 919 603 C
Component: DU Std H49 0014
Serial number: AUZ8Z9FY30C77Z
Multimedia Operating Unit:
Subsystem 2 - Part No SW: 8V0 919 614 Q HW: 8V0 919 614 Q
Component: ControlUnit_B H41 0054
Serial number: C1000013051500030284
B11CF 53 [009] - Deactivated
Reset counter: 8
Mileage: 34546 km
Date: 2018.02.07
Time: 06:33:02
Voltage terminal 30: 12.3 V
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-907-441.clb
Part No SW: 5Q0 907 441 A HW: 5Q0 907 441 A
Component: MQB RVC Mid H07 0140
Coding: 027300010201000300
ASAM Dataset: EV_2CamSysRearPASE 006016
ROD: EV_CamSysRearPANAVW428.rod
VCID: 306F629B6BF089C621-8064
Part No SW: 5Q0 959 395 E HW: 5Q0 959 395 B
Component: TSG HFS 020 0041
Serial number: 020715BG20801B
Coding: 000013204000048000000002
ROD: EV_DCURearDriveMAXCONT_VW37.rod
Component: TSG HBFS 020 0041
Serial number: 020715BG208018
ROD: EV_DCURearPasseMAXCONT_VW37.rod
End-------------------------(Elapsed Time: 04:53)--------------------------
