Greetings all!
Been meaning to scan my car for a while now, but put it off until I finally had an idiot light that required some attention/research (engine light - solid yellow (new to Audi electronic codes/repairs so I'm unsure if it goes red or blinks to indicate severity of issue)). Any assistance in identifying necessity of repair/how to remove fault is greatly appreciated.
First, the car is acting normally (i.e. no odd shifting, hesitation, acceleration, etc), however I would like to de-illuminate the engine light.
Found below, in order of importance are the faults (see Auto Scan for additional info):
1. Shift solenoid 1 Malfunction - No fault mileage, intermittent, not confirmed, tested since memory clear
Does "tested since memory clear" mean it is working currently? What function does the shift solenoid perform, from what I understand there is more than one...and where is it located (or better still is there a repair guide?
2. Fuel tank cap - Unlock, Open, blah blah...happened over 600 miles ago which means I already filled up and corrected that issue. To verify I rechecked the cap anyway and the engine light did not de-illuminate. Therefore I assume this is not the culprit.
3. Bank 1; system too lean at idle - MIL ON (what does this mean?) Not super concerned about this causing an engine light illumination especially considering the date is well before I noticed the light (I'm typically quite observant of changes in my vehicle's operation and idiot lights).
Faults unrelated to engine light:
1. Key 2 - no or incorrect Basic setting. Can someone elucidate what this indicates? Perhaps new battery? Is there a way to identify which is Key 1 and Key 2?
2. Seat Memory Driver - Component Protection Active. What does this mean? No noticeable difference in seat controls and happened about 14k miles/over a year ago.
3. Door Locking unit (Passenger and Rear Right): I replaced the lock actuator units over two years ago and bought aftermarket; with them installed the car never was happy again in respect to it will not remain auto-locked during driving and it locks when stopped but I don't think it is engaging the alarm...I'm just confused as to why this would only be logged one time and not ongoing. I will probably buy OEM and replace soon, but I was mostly curious.
4. Tire Pressure- No signal/Communication: I see n. erkannt (assume that means not recognized) and assume it is simply a dead battery. I hate the fact the tire pressure monitoring is being forced and I have to buy a whole new sensor rather than replace a battery. If I had my druthers I would disable the tire pressure sensor system (as I am sick of the mind penetrating beeeep every time the car is turned on due to this fault) is that a possibility with VCDS?
5. El Radio (lol) - I assume this is simply the Sirius satellite radio being not activated?
TIA for feedback/assistance. I'm guessing/hopeful a few of these will be resolved simply by clearing fault codes, but again most important to me is resolving the engine light (which I'm guessing is the shift solenoid?).
Wednesday,14,February,2018,14:16:24:33086
VCDS Version: 17.1.3.0 (x64) HEX-V2 CB: 0.4336.4
VIN: WAUCF78K49N048317 License Plate: DR6M463
Mileage: 160940km-100003mi Repair Order:
Chassis Type: 8K (8T0)
Scan: 01 02 03 05 08 09 15 16 17 19 2E 36 42 46 47 52 53 55 56 62
65 72 77
VIN: WAUCF78K49N048317 Mileage: 160940km-100003miles
Address 01: Engine (DL0MA-CAEB) Labels: 06H-907-115-CAB.clb
Part No SW: 8K2 907 115 AL HW: 8K2 907 115 D
Revision: E1H14---
Coding: 0104010A02070160
Shop #: WSC 42508 444 96599
VCID: 79ACE48D0951412F6A7-802C
4105 - Bank 1; System too Lean at Idle
P2187 00 [236] - -
Mileage: 160911 km
Date: 2018.02.12
Time: 16:54:51
Engine speed: 838.00 /min
Normed load value: 14.1 %
Coolant temperature: 99 °C
Intake air temperature: 31 °C
Voltage terminal 30: 14.418 V
Address 02: Auto Trans (J217) Labels: 0AW-927-156.clb
Part No SW: 8K0 927 155 AD HW: 0AW 927 156 H
Component: 0AW 20TFSIUSA H01 0002
Revision: --H01--- Serial number: 0000001131
Shop #: WSC 02145 785 00200
ASAM Dataset: EV_TCMVL381 A02002
ROD: EV_TCMVL381_AU57.rod
VCID: 75B4E8BD2549254F0EF-8020
2274 - Shift Solenoid 1 (N88)
P0750 00 [032] - Malfunction
Address 03: ABS Brakes (J104) Labels: 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 AE HW: 8K0 907 379 AE
Component: ESP8 front H04 0240
Coding: 080500
Shop #: WSC 02391 823 56573
VCID: 7CA2FD9906E37407711-8028
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 F HW: 8K0 907 064 F
Component: BCM2 1.1 H80 0145
Coding: 090100
Shop #: WSC 02399 823 56573
VCID: 333016A56B3D7B7FE0B-8066
Subsystem 1 - Part No SW: 8T0 959 754 A HW: 8T0 959 754 A
Component: FBSAUDIB8 IDG H37 0060
Serial number: 0508000078110021
Component: ELVAUDIB8 H36 0041
Serial number: 0208000097208013
00956 - Key 2
Fault Status: 00100101
Reset counter: 234
Mileage: 160264 km
Date: 2018.02.06
Time: 12:47:17
Part No SW: 8T1 820 043 AC HW: 8T1 820 043 AC
Component: KLIMA 3 ZONEN H06 0150
Revision: C1000000 Serial number: 01181120081391
Coding: 64002000
VCID: 72BED3A154A732772BD-8026
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
Component: BCM1 1.0 H22 0253
Revision: 05022001 Serial number: 00000000268546
Coding: 26001091063CAF010000080300003D0D0F1C520800010161000000
VCID: 303A19A99A2B40679D9-8064
Component: WWS 221108 H06 0070
Serial number: SWF08110225025
Coding: 00FD11
Component: RLS H04 0003
Serial number: 10325243
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 AA HW: 8K0 941 531 AA
Component: E1 - LDS H07 0080
Serial number: 00000000001211081711
Subsystem 4 - Part No SW: 8K0 907 410 B HW: 8K0 907 410 B
Component: HOMELINK H01 0010
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 F HW: 8K0 959 655 F
Serial number: 0039KD14KT6J
Shop #: WSC 02135 785 00200
VCID: 40DA49692A0BD0E76D9-8014
Subsystem 1 - Part No SW: 8K0 959 339 B HW: 8K0 959 339 B
Component: BF-Gewichtss. H01 0030
Serial number: 5810000R08000032UT
Serial number: 6334MSME4271641CA
Serial number: 6344MSME43632E1CJ
Serial number: 6352QSME59120A16B
Serial number: 6362QSME38132B18F
Serial number: 63732SME07052404L
Serial number: 63832SME19132E32Z
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Component: Lenks.Modul H13 0013
Revision: -------- Serial number: 90304HKG000F2
Coding: 000016
VCID: 3D24309D5D79BD0F06F-8068
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 950 A HW: 8K0 920 950 A
Component: KOMBIINSTR. H17 0224
Revision: 00000000 Serial number: 9DR395RA8
Coding: 8B1609000300D705020000
VCID: 2D0400DD8D192D8FB6F-8078
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 M HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0095
Revision: GB300043 Serial number: 4300G08B088A0B
Coding: 000303
VCID: 4BC06E4513CD03BF88B-801E
Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H04 0150
Serial number: 180542E9051108
Address 2E: Media Player 3 (R199) Labels: 8T0-035-785.clb
Part No SW: 8T0 035 785 HW: 8T0 035 785
Revision: 00000000
Coding: 020302
VCID: 78AAE18932DB5827159-802C
Address 36: Seat Mem. Drvr (J136) Labels: 8T0-959-760.clb
Part No SW: 8K0 959 760 HW: 8K0 959 760
Component: MEM-FS H05 0043
Revision: AA000000 Serial number: 00001001184505
Coding: 00581300000000000000
VCID: 77A8E2B53FC5575F1C3-8022
Fault Frequency: 25
Mileage: 139113 km
Date: 2016.12.16
Time: 16:25:01
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 D HW: 8K0 959 793 D
Component: TSG FA H11 0250
Revision: Serial number: 0000008120104
Coding: 011C03204E00410001
VCID: 41DC4C6D2181D9EF627-8014
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0116178449
Coding: 0106023A007A440400B001
Subsystem 1 - Part No SW: 8K0 959 719 HW: 8K0 959 719
Component: GTO BF H06 0040
Serial number: 00000000000000093983
Subsystem 3 - Part No SW: 8K0 959 591 HW: 8K0 959 591
Component: J245 PS034 H06 0037
02616 - Fuel Tank Cap; Unlock
Fault Status: 00101001
Reset counter: 247
Mileage: 159916 km
Date: 2018.01.20
Time: 14:33:15
Address 47: Sound System (J525) Labels: 8T0-035-223-ASC.clb
Part No SW: 8T0 035 223 AB HW: 8T0 035 223
Component: DSP STD H07 0220
Revision: S2100000
Coding: 0203010102
VCID: 6E86C7D1409F1697CF5-803A
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 D HW: 8K0 959 792 D
Component: TSG BF H11 0250
Revision: Serial number: 0000008151308
VCID: 40DA49692A8BD0E76D9-8014
008 - Implausible Signal
Fault Status: 01101000
Reset counter: 209
Mileage: 134330 km
Date: 2016.10.14
Time: 12:56:23
Part No SW: 8K0 907 801 F HW: 8K0 907 801 F
Component: EPB Audi B8 H06 0070
Revision: 00000003 Serial number: 00000000272188
VCID: 323E13A194277277EBD-8066
Part No: 8K5 907 357
Coding: 0000004
VCID: 77A8E2B533C5575F1C3-8022
Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 195 L HW: 8T1 035 195 L
Component: Symph3 Sirius H02 0231
Revision: 00000005 Serial number: AUZ5Z4H1067231
Coding: 040200020101850043D9070800
Subsystem 1 - Part No SW: 8T0 919 603 A HW: 8T0 919 603 A
Component: Display
Reset counter: 209
Mileage: 134330 km
Date: 2016.10.14
Time: 12:48:43
Address 62: Door, Rear Left (J388) Labels: 4F0-959-795.clb
Part No SW: 4F0 959 795 N HW: 8K0 959 795 C
Component: TSG HL H10 0251
Revision: Serial number: 0000100497509
Coding: 010C03204000210001
VCID: 44D245793E93CCC7491-8010
Address 65: Tire Pressure (J502) Labels: 8K0-907-273.clb
Part No SW: 8K0 907 273 A HW: 8K0 907 273 A
Component: J502-RDK H03 0250
Revision: 00001001 Serial number: 13140782135965
Coding: 0CD154
Fault Status: 11100100
Reset counter: 209
Mileage: 134330 km
Date: 2016.10.14
Time: 16:50:33
Bin. Bits: 00000000 01000001
Voltage: 12.40 V
Text: 20,5°C;n.erkannt;3390320244;--h;---°C
Address 72: Door, Rear Right (J389) Labels: 4F0-959-795.clb
Component: TSG HR H10 0251
Revision: Serial number: 0000100497506
Reset counter: 209
Mileage: 134330 km
Date: 2016.10.14
Time: 12:51:56
Part No SW: 8T0 862 336 C HW: 8T0 862 336 C
Component: FSE_256x BT H33 0550
Revision: 00000000 Serial number: 00000005011784
Coding: 0010370
Shop #: WSC 02335 785 00200
VCID: 3B203E854F6DB33F38B-806E
End----------(Elapsed Time: 01:49, VBatt start/end: 11.9V/11.9V)-----------
