2006 EOS 2.0 FSI - No operation of trunk, roof or sunroof
stuart638
C?ID=322077
Hi All,
Hoping someone can help me out.......
I have a 2006 EOS 2.0 FSI which has recently developed a fault where the trunk, roof and sunroof all fail to operate, like there is no power to any of them. I did some checking yesterday and can confirm that there is a 12V supply to one of the connectors on the roof controller. However, I also discovered that the high level brake light has been letting in water and there were signs of corrosion on a couple of the electrical connectors - nothing too bad and they cleaned up quite easily with a small brush and some switch cleaner.
I have purchased and registered a Ross-Tech HEX-V2 and downloaded the latest VCDS software. My log file is as follows........
There are quite a few faults showing which I will investigate in time, but I'm particularly concerned with the convertible top control module (J256) which shows as 'no signal/communication'. Obviously without being able to communicate with it, I'm struggling to diagnose my roof issue.
Can anyone help??
Tuesday,13,February,2018,18:58:49:53052
VCDS Version: 18.1.0.2 (x64)  HEX-V2 CB: 0.4411.4
VIN: WVWZZZ1FZ6V008036   License Plate:
Mileage: 180370km-112076mi   Repair Order:
Chassis Type: 1F (1K0)
Scan: 01 03 08 09 15 16 17 19 25 26 37 42 44 46 52 56 62 72 76
VIN: WVWZZZ1FZ6V008036   Mileage: 180370km-112076miles
26-Auto Roof -- Status: Cannot be reached 1100
   Part No SW: 1Q0 907 115 C    HW: 1Q0 907 115
   Component: 2.0l R4/4V TFSI     0040
   Revision: --H14---    Serial number: VWX7Z0F23NM8OQ
   Coding: 041C000318070160
   Shop #: WSC 00413 210 52643
   VCID: 2C01FA465A07C4A7E4D-8078
008825 - Leak in Air Intake System
               P2279 - 002 -
                    Fault Status: 01100010
                    Mileage: 175873 km
                    Time: 23:44:17
                    RPM: 795 /min
                    Load: 16.1 %
                    Temperature: 67.0°C
                    Temperature: 24.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 13.843 V
004506 - Fuel Pressure Sensor (G247)
               P119A - 001 - Malfunction - Intermittent
                    Fault Status: 00100001
                    Mileage: 175940 km
                    Time: 05:40:37
                    RPM: 840 /min
                    Load: 16.1 %
                    Speed: 1.0 km/h
                    Temperature: 63.0°C
                    Temperature: 18.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 14.351 V
001287 - Idle Control System RPM
               P0507 - 001 - Higher than Expected. - Intermittent
                    Mileage: 176219 km
                    Time: 22:50:38
                    RPM: 899 /min
                    Load: 14.9 %
                    Temperature: 67.0°C
                    Temperature: 16.0°C
                    Voltage: 14.351 V
001089 - EVAP Emission Control Sys
               P0441 - 002 - Incorrect Flow - Intermittent
                    Fault Status: 00110010
                    Mileage: 179606 km
                    Time: 10:08:02
                    RPM: 811 /min
                    Load: 14.5 %
                    Temperature: 73.0°C
                    Temperature: 31.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 14.097 V
                    Load: 0.0 %
                    Temperature: -40.0°C
                    Absolute Pres.: 0.0 mbar
                    Voltage: 0.000 V
004243 - Bank 1; Fuel Measuring System 2
               P1093 - 008 - Malfunction - Intermittent
                    Mileage: 180371 km
                    Time: 04:14:30
                    RPM: 1552 /min
                    Load: 11.8 %
                    Speed: 22.0 km/h
                    Temperature: 68.0°C
                    Temperature: 15.0°C
                    Voltage: 14.478 V
Readiness: 0000 0100
   Part No SW: 1K0 907 379 AA    HW: 1K0 907 379 AA
   Revision: 00H13001
   Coding: 0004834
   Shop #: WSC 00020 000 00000
   VCID: 71BF2B32BDA5E94F97B-8024
   Part No SW: 1Q0 907 044 A    HW: 1Q0 907 044 A
   Component: ClimatronicPQ35 093 0101
   Revision: 00093002    Serial number: 00000000000000
   VCID: 2B03F95A5F09C39FED7-807E
00830 - Convertible Top Control Module (J256)
   Part No SW: 3C0 937 049 Q    HW: 3C0 937 049 Q
   Revision: 00H46000    Serial number: 00000005474167
   Coding: E58E8F0700041500470A00000F00000000095D035C0000
   VCID: 372BD52A9341777F99F-8062
   Subsystem 1 - Part No: 1K2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  013  0402
   Coding: 00063445
   Shop #: WSC 00020
   Subsystem 2 - Part No: 1K0 955 559 T  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 011  1110
   Coding: 00208933
   Shop #: WSC 00020
                    Reset counter: 103
                    Mileage: 179894 km
                    Voltage: 12.40 V
Address 15: Airbags        Labels: 1Q0-959-655.lbl
   Part No SW: 1Q0 959 655 A    HW: 1Q0 959 655 A
   Component: 3C Airbag VW8C      0180
   Revision: 92009018    Serial number: 003B30007E0
   Coding: 0013123
   VCID: 3A2DCC1EA0536A17661-806E
   Subsystem 1 - Serial number: 6332SRB402E34F2D8
   Subsystem 2 - Serial number: 6342SRB4031B9223U
   Subsystem 3 - Serial number: 637  RB4        8
   Subsystem 4 - Serial number: 638  RB4        9
   Part No SW: 1K0 953 549 AF    HW: 1K0 953 549 AF
   Component: Lenksäulenmodul 634 0070
   Coding: 0000041
   VCID: 76B5182ED4CBCE77429-8022
   Part No: 1Q0 920 972 B
   Component: KOMBIINSTRUMENT VDD 4314
   Coding: 0021403
   Shop #: WSC 80093 222 69422
   VCID: 313FEB327D25A94FD7B-8064
   Part No SW: 1K0 907 530 G    HW: 1K0 907 951
   Component: J533__Gateway   H10 0140
   Revision:   H10       Serial number: 30001063248727
   Coding: 3D3F274807005001
                    Fault Frequency: 16
                    Reset counter: 103
                    Mileage: 179894 km
                    Time: 11:39:51
   Component: IMMO            VDD 4314
Address 26: Auto Roof
Address 37: Navigation        Labels: 1K0-919-887-MFD2.lbl
   Part No: 1K0 919 887 F
   Component:      Navigation     0028
   Coding: 0000101
   VCID: 3C21CA06AA67542774D-8068
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX2.lbl
   Part No: 1Q0 959 701 C
   Component: Tuer-SG         024 2728
   Coding: 0000695
   VCID: 3431E22682379C67BCD-8060
00131 - Outside Door Handle Illumination/mirror Light Driver Side
   Part No: 1K2 909 144 K
   Component: EPS_ZFLS Kl.5   D06 1701
   Component:    KSG PQ35 G2  020 0202
   Coding: 81908A000186285B0804840570085EC690BC00
   VCID: 035371FA9719EBDF757-8056
   Subsystem 1 - Part No: 1K0 951 605 B
   Component: LIN BACKUP HORN H07 7001
   Subsystem 2 - Part No: 1K0 907 719 C
   Component: Neigungssensor  005 0003
   Subsystem 3 - Part No: 1Q0 951 177 A
   Component: Innenraumueberw.158 0502
00956 - Key 2
                    Fault Status: 00110101
                    Reset counter: 142
                    Mileage: 177262 km
                    Time: 00:41:26
                    Fault Frequency: 9
                    Reset counter: 102
                    Reset counter: 142
01134 - Alarm Horn (H12)
            000 -  -  - Intermittent
                    Reset counter: 142
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX2.lbl
   Part No: 1Q0 959 702 C
   Coding: 0000694
   VCID: 3537DF22894D856F8B3-8060
Address 56: Radio        Labels: 1K0-035-095.lbl
   Part No: 1K0 035 095 E
   Component:        Radio        0028
   Coding: 0040402
   Shop #: WSC 00413 210 63940
   VCID: 270B056A43E1E7FF09F-8072
   Part No: 1Q0 959 703
   Component: Tuer-SG         021 2705
   Coding: 0000128
   VCID: 73B3213AC7B9DB5F657-8026
   Part No: 1Q0 959 704
   Component: Tuer-SG         020 2705
   Coding: 0000128
   VCID: 74B12226C2B7DC677CD-8020
Address 76: Park Assist        Labels: 1K0-919-283.lbl
   Part No: 1Q0 919 283
   Component: 30 Einparkhilfe     0702
   VCID: 72BD243EB8A3D2576E1-8026
End----------(Elapsed Time: 01:26, VBatt start/end: 12.1V/12.1V)-----------
Address 01: DTCs cleared
Address 08: DTCs cleared
Address 46: DTCs cleared
Activating transport mode...Done.
You're going to have to figure out why the roof module is off-line. The car's gateway can't see it:
And VCDS can't access it either:
So the next thing to do is check power, ground, and CAN bus connections to the module with a multimeter per wiring diagrams.
Fuses first..........
Clean and investigate visually or isolate the water ingress.........be sure no puddle in spare tire area causing a rain effect in modules of trunk area.
When corrosion is present, this usually means this has been going on for some time now depending on how heavy and what reacted.
Better have a look at WD in ERWIN to see what tracks are shared like Uwe aforementioned.
http://wiki.ross-tech.com/wiki/index.php/Official_Factory_Repair_Information
You might find these threads helpful......
WD HELP!
http://forums.ross-tech.com/showthr...ead-wiring-diagrams-the-videos-(final-version)
CAN BUS HELP !
http://forums.ross-tech.com/showthr...a-you-should-have-a-baseline-understanding-of-!
JPPSG !
http://forums.ross-tech.com/showthr...essional-Problem-Solver-Guide-quot-JPPSG-quot
stuart638
C?ID=322077
Hi Uwe,
I've done a bit more investigating on this.....
Can confirm that there is 12.4V at J256 - Convertible roof actuation control unit. This was present on plug B, pins 1 & 3. Also have good earths on pins 4 & 6. This was done according to the following pin info:
G558 -    Sender for left roof member locked
G559 -    Sender for right roof member locked
G560 -    Left sender for rear window frame locked
G561 -    Right sender for rear window frame locked
G562 -    Sender for rear window frame open
G563 -    Left sender for rear shelf locked
G565 -    Sender for roof stowed
G564 -    Right sender for rear shelf locked
G566 -    Sender for left roof member flap open
G567 -    Sender for right roof member flap open
G672 -    Sender 2 for roof stowed
G555 -    Hydraulic pump temperature sender
N272 -    Power operated convertible roof valve 1
N341 -    Power operated convertible roof valve 2
N342 -    Power operated convertible roof valve 3
Convertible roof actuation hydraulic pump
F364 -    Luggage cover contact switch
V329 -    Power latching motor (Trunk Lock)
Roof Controller:
10-pin connector -T10e--A-
1 -  Convertible roof actuation hydraulic pump -V118- positive
2 -  Power operated convertible roof valve 1 -N272- earth
3 -  Power operated convertible roof valve 2 -N341- earth
4 -  Power operated convertible roof valve 3 -N342- earth
5 -  Hydraulic pump temperature sender -G555-
6 -  Convertible roof actuation hydraulic pump -V118-
7 -  Power operated convertible roof valve 1 -N272-
8 -  Power operated convertible roof valve 2 -N341-
9 -  Power operated convertible roof valve 3 -N342-
10 -  Hydraulic pump temperature sender -G555-
6-pin connector -T6ar--B-
1 -  Sliding sunroof thermal fuse -S83-
2 -  Vacant
3 -  Fuse 7 on fuse holder A -SA7-
4 -  662 earth point, in rear left side panel
5 -  Vacant
6 -  662 earth point, in rear left side pa
16-pin connector -T16l--C-
1 -  Left sender for rear window frame locked -G560-
2 -  Right sender for rear window frame locked -G561-
3 -  Sender for left roof member flap open -G566- Roof
4 -  Sender for roof stowed -G565-
5 -  Right sender for rear shelf locked -G564-
6 -  Left sender for rear shelf locked -G563-
7 -  Sender for rear window frame open -G562-
8 -  Sliding sunroof adjustment control unit -J245- (sliding sunroof motor -V1-), terminal 30
9 -  Vacant
10 -  Sender for left roof member locked -G558-
11 -  Sender for right roof member locked -G559-
12 -  Sliding sunroof adjustment control unit -J245-
13 -  Sender for right roof member flap open -G567-
14 -  Sender supply, connection 5, in convertible top wiring harness - M36-
15 -  Sender supply, connection 7, in convertible top wiring harness - M38-
16 -  Sliding sunroof adjustment control unit -J245- (sliding sunroof motor -V1-), terminal 31
16-pin connector -T16j--D-
1 -  Convenience CAN bus high
2 -  Convenience CAN bus low
3 -  Vacant
4 -  Luggage cover contact switch -F364-
5 -  Sender supply, connection 1, in convertible top wiring harness - M32-
6 -  Power latching control unit -J657-
7 -  Front sender for position of right roof member -G557-
8 -  Front sender for position of left roof member -G556-
9 -  Convertible roof actuation button -E137- (open convertible roof)
10 -  Convertible roof actuation button -E137- (close convertible roof)
11 -  Sunroof button -E325- (open sliding sunroof)
12 -  Sunroof button -E325- (close sliding sunroof)
13 -  Central switch for window regulators in driver door -E189- (open window)
14 -  Central switch for window regulators in driver door -E189- (close window)
15 -  Power latching control unit -J657-
16 -  Power latching control unit -J657-
What I did find was that on 16-pin connector D, pin 2 (Convenience CAN bus low) There were some light traces of oxidisation present. I have cleaned this up and it looks fine now. From what I have been able to work out, the CAN bus circuits should be around 4V. I did a quick check on both pin 1 (Convenience CAN bus high) & pin 2 (Convenience CAN bus low) and the showed 0V & 12V respectively. On operating the remote boot open button on the fob these reading changed to 0.7V & 4.5V respectively.
I am very very far from an expert on CAN bus, but this doesn't seem right from what I can tell. I'm going to put the VCDS back on it over the weekend and will post the log again.
Based on the above, can you think of any thing obvious I should look at?
Did you take module apart to inspect the progression of water ingress to the board from where you observed it on or at connector?
If this is above your scope change the module.
stuart638
C?ID=322077
Hello Jack,
I did take the heat sink off the back and couldn’t see anything out of the ordinary but I didn’t take the PCB off to check the back of it. Will do that on Sunday and report back.
Thanks for your help so far.
BTW, paid for an hour on Erwin and saved a load of wiring diagrams, so I’ll also try and work through them too.
stuart638
C?ID=322077
Hi, it’s been a while since I posted last, been busy with work commitments, but I thought I’d let you know I have resolved my issue with no comms to the roof controller that was stopping operation of roof, boot, sunroof and the all windows function.
I had water ingress in through the high level brake light and there was water in the bottom of the boot. Replaced the light and stopped the water ingress and let everything dry out thoroughly.
Although my roof controller looked ok, other than a tiny bit of corrosion on one of the pins, I decided to order a replacement. This arrived yesterday and was disappointed to find that it had some green corrosion in exactly the same place as mine. However I decided I had nothing to lose so tried it anyway and hey presto! Everything now works again!!
Most importantly I have a happy wife!!!
RIGHT!
