Results 1 to 6 of 6
Thread: 2006 EOS 2.0 FSI - No operation of trunk, roof or sunroof
    Feb 2018
    Hi All,
    Hoping someone can help me out.......
    I have a 2006 EOS 2.0 FSI which has recently developed a fault where the trunk, roof and sunroof all fail to operate, like there is no power to any of them. I did some checking yesterday and can confirm that there is a 12V supply to one of the connectors on the roof controller. However, I also discovered that the high level brake light has been letting in water and there were signs of corrosion on a couple of the electrical connectors - nothing too bad and they cleaned up quite easily with a small brush and some switch cleaner.
    I have purchased and registered a Ross-Tech HEX-V2 and downloaded the latest VCDS software. My log file is as follows........
    There are quite a few faults showing which I will investigate in time, but I'm particularly concerned with the convertible top control module (J256) which shows as 'no signal/communication'. Obviously without being able to communicate with it, I'm struggling to diagnose my roof issue.
    Can anyone help??
    Tuesday,13,February,2018,18:58:49:53052
    VCDS Version: 18.1.0.2 (x64)  HEX-V2 CB: 0.4411.4
    VIN: WVWZZZ1FZ6V008036   License Plate:
    Mileage: 180370km-112076mi   Repair Order:
    Chassis Type: 1F (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 26 37 42 44 46 52 56 62 72 76
    VIN: WVWZZZ1FZ6V008036   Mileage: 180370km-112076miles
    26-Auto Roof -- Status: Cannot be reached 1100
       Part No SW: 1Q0 907 115 C    HW: 1Q0 907 115
       Component: 2.0l R4/4V TFSI     0040
       Revision: --H14---    Serial number: VWX7Z0F23NM8OQ
       Coding: 041C000318070160
       Shop #: WSC 00413 210 52643
       VCID: 2C01FA465A07C4A7E4D-8078
    6 Faults Found:
    008825 - Leak in Air Intake System
                   P2279 - 002 -
                        Fault Status: 01100010
                        Mileage: 175873 km
                        Time: 23:44:17
                        RPM: 795 /min
                        Load: 16.1 %
                        Temperature: 67.0°C
                        Temperature: 24.0°C
                        Absolute Pres.: 990.0 mbar
                        Voltage: 13.843 V
    004506 - Fuel Pressure Sensor (G247)
                   P119A - 001 - Malfunction - Intermittent
                        Fault Status: 00100001
                        Mileage: 175940 km
                        Time: 05:40:37
                        RPM: 840 /min
                        Load: 16.1 %
                        Speed: 1.0 km/h
                        Temperature: 63.0°C
                        Temperature: 18.0°C
                        Absolute Pres.: 1010.0 mbar
                        Voltage: 14.351 V
    001287 - Idle Control System RPM
                   P0507 - 001 - Higher than Expected. - Intermittent
                        Mileage: 176219 km
                        Time: 22:50:38
                        RPM: 899 /min
                        Load: 14.9 %
                        Temperature: 67.0°C
                        Temperature: 16.0°C
                        Voltage: 14.351 V
    001089 - EVAP Emission Control Sys
                   P0441 - 002 - Incorrect Flow - Intermittent
                        Fault Status: 00110010
                        Mileage: 179606 km
                        Time: 10:08:02
                        RPM: 811 /min
                        Load: 14.5 %
                        Temperature: 73.0°C
                        Temperature: 31.0°C
                        Absolute Pres.: 1000.0 mbar
                        Voltage: 14.097 V
                        Temperature: -40.0°C
                        Absolute Pres.: 0.0 mbar
                        Voltage: 0.000 V
    004243 - Bank 1; Fuel Measuring System 2
                   P1093 - 008 - Malfunction - Intermittent
                        Mileage: 180371 km
                        Time: 04:14:30
                        RPM: 1552 /min
                        Load: 11.8 %
                        Speed: 22.0 km/h
                        Temperature: 68.0°C
                        Temperature: 15.0°C
                        Voltage: 14.478 V
    Readiness: 0000 0100
       Part No SW: 1K0 907 379 AA    HW: 1K0 907 379 AA
       Revision: 00H13001
       Coding: 0004834
       Shop #: WSC 00020 000 00000
       VCID: 71BF2B32BDA5E94F97B-8024
       Part No SW: 1Q0 907 044 A    HW: 1Q0 907 044 A
       Component: ClimatronicPQ35 093 0101
       Revision: 00093002    Serial number: 00000000000000
       VCID: 2B03F95A5F09C39FED7-807E
    00830 - Convertible Top Control Module (J256)
       Revision: 00H46000    Serial number: 00000005474167
       Coding: E58E8F0700041500470A00000F00000000095D035C0000
       VCID: 372BD52A9341777F99F-8062
       Subsystem 1 - Part No: 1K2 955 119 C  Labels: 1KX-955-119.CLB
       Component: Wischer VW350  013  0402
       Coding: 00063445
       Shop #: WSC 00020
       Subsystem 2 - Part No: 1K0 955 559 T  Labels: 1K0-955-559-AF.CLB
       Component: RegenLichtSens 011  1110
       Coding: 00208933
       Shop #: WSC 00020
                        Reset counter: 103
                        Mileage: 179894 km
                        Voltage: 12.40 V
    Address 15: Airbags        Labels: 1Q0-959-655.lbl
       Part No SW: 1Q0 959 655 A    HW: 1Q0 959 655 A
       Component: 3C Airbag VW8C      0180
       Revision: 92009018    Serial number: 003B30007E0
       Coding: 0013123
       VCID: 3A2DCC1EA0536A17661-806E
       Subsystem 1 - Serial number: 6332SRB402E34F2D8
       Subsystem 2 - Serial number: 6342SRB4031B9223U
       Subsystem 3 - Serial number: 637  RB4        8
       Subsystem 4 - Serial number: 638  RB4        9
       Part No SW: 1K0 953 549 AF    HW: 1K0 953 549 AF
       Component: Lenksäulenmodul 634 0070
       Coding: 0000041
       VCID: 76B5182ED4CBCE77429-8022
       Part No: 1Q0 920 972 B
       Component: KOMBIINSTRUMENT VDD 4314
       Coding: 0021403
       Shop #: WSC 80093 222 69422
       VCID: 313FEB327D25A94FD7B-8064
       Part No SW: 1K0 907 530 G    HW: 1K0 907 951
       Component: J533__Gateway   H10 0140
       Revision:   H10       Serial number: 30001063248727
       Coding: 3D3F274807005001
                        Fault Frequency: 16
                        Reset counter: 103
                        Mileage: 179894 km
                        Time: 11:39:51
       Component: IMMO            VDD 4314
    Address 26: Auto Roof
    Address 37: Navigation        Labels: 1K0-919-887-MFD2.lbl
       Part No: 1K0 919 887 F
       Component:      Navigation     0028
       Coding: 0000101
       VCID: 3C21CA06AA67542774D-8068
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX2.lbl
       Part No: 1Q0 959 701 C
       Component: Tuer-SG         024 2728
       Coding: 0000695
       VCID: 3431E22682379C67BCD-8060
    00131 - Outside Door Handle Illumination/mirror Light Driver Side
       Part No: 1K2 909 144 K
       Component:    KSG PQ35 G2  020 0202
       Coding: 81908A000186285B0804840570085EC690BC00
       VCID: 035371FA9719EBDF757-8056
       Subsystem 1 - Part No: 1K0 951 605 B
       Component: LIN BACKUP HORN H07 7001
       Component: Neigungssensor  005 0003
       Subsystem 3 - Part No: 1Q0 951 177 A
       Component: Innenraumueberw.158 0502
    00956 - Key 2
                        Fault Status: 00110101
                        Reset counter: 142
                        Mileage: 177262 km
                        Time: 00:41:26
                        Fault Frequency: 9
                        Reset counter: 102
                        Reset counter: 142
    01134 - Alarm Horn (H12)
                000 -  -  - Intermittent
                        Reset counter: 142
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX2.lbl
       Part No: 1Q0 959 702 C
       Coding: 0000694
       VCID: 3537DF22894D856F8B3-8060
    Address 56: Radio        Labels: 1K0-035-095.lbl
       Part No: 1K0 035 095 E
       Component:        Radio        0028
       Coding: 0040402
       Shop #: WSC 00413 210 63940
       VCID: 270B056A43E1E7FF09F-8072
       Part No: 1Q0 959 703
       Component: Tuer-SG         021 2705
       Coding: 0000128
       VCID: 73B3213AC7B9DB5F657-8026
       Part No: 1Q0 959 704
       Component: Tuer-SG         020 2705
       Coding: 0000128
       VCID: 74B12226C2B7DC677CD-8020
    Address 76: Park Assist        Labels: 1K0-919-283.lbl
       Part No: 1Q0 919 283
       Component: 30 Einparkhilfe     0702
       VCID: 72BD243EB8A3D2576E1-8026
    End----------(Elapsed Time: 01:26, VBatt start/end: 12.1V/12.1V)-----------
    Address 01: DTCs cleared
    Address 08: DTCs cleared
    Address 46: DTCs cleared
    Activating transport mode...Done.
    You're going to have to figure out why the roof module is off-line. The car's gateway can't see it:
    And VCDS can't access it either:
    So the next thing to do is check power, ground, and CAN bus connections to the module with a multimeter per wiring diagrams.
    Fuses first..........
    Clean and investigate visually or isolate the water ingress.........be sure no puddle in spare tire area causing a rain effect in modules of trunk area.
    When corrosion is present, this usually means this has been going on for some time now depending on how heavy and what reacted.
    Better have a look at WD in ERWIN to see what tracks are shared like Uwe aforementioned.
    You might find these threads helpful......
    WD HELP!
    http://forums.ross-tech.com/showthre...(final-version)
    CAN BUS HELP !
    http://forums.ross-tech.com/showthre...derstanding-of-!
    JPPSG !
    European Parts Emporium/Performance / Immobilizer Solutions LLC
  4. Likes stuart638, Boki Ar liked this post
    Feb 2018
    Hi Uwe,
    I've done a bit more investigating on this.....
    Can confirm that there is 12.4V at J256 - Convertible roof actuation control unit. This was present on plug B, pins 1 & 3. Also have good earths on pins 4 & 6. This was done according to the following pin info:
    G558 -    Sender for left roof member locked
    G559 -    Sender for right roof member locked
    G560 -    Left sender for rear window frame locked
    G561 -    Right sender for rear window frame locked
    G562 -    Sender for rear window frame open
    G563 -    Left sender for rear shelf locked
    G565 -    Sender for roof stowed
    G564 -    Right sender for rear shelf locked
    G566 -    Sender for left roof member flap open
    G567 -    Sender for right roof member flap open
    G672 -    Sender 2 for roof stowed
    G555 -    Hydraulic pump temperature sender
    N272 -    Power operated convertible roof valve 1
    N341 -    Power operated convertible roof valve 2
    N342 -    Power operated convertible roof valve 3
    Convertible roof actuation hydraulic pump
    F364 -    Luggage cover contact switch
    V329 -    Power latching motor (Trunk Lock)
    Roof Controller:
    10-pin connector -T10e--A-
    1 -  Convertible roof actuation hydraulic pump -V118- positive
    2 -  Power operated convertible roof valve 1 -N272- earth
    3 -  Power operated convertible roof valve 2 -N341- earth
    4 -  Power operated convertible roof valve 3 -N342- earth
    5 -  Hydraulic pump temperature sender -G555-
    6 -  Convertible roof actuation hydraulic pump -V118-
    7 -  Power operated convertible roof valve 1 -N272-
    8 -  Power operated convertible roof valve 2 -N341-
    9 -  Power operated convertible roof valve 3 -N342-
    10 -  Hydraulic pump temperature sender -G555-
    6-pin connector -T6ar--B-
    1 -  Sliding sunroof thermal fuse -S83-
    2 -  Vacant
    3 -  Fuse 7 on fuse holder A -SA7-
    4 -  662 earth point, in rear left side panel
    5 -  Vacant
    6 -  662 earth point, in rear left side pa
    16-pin connector -T16l--C-
    1 -  Left sender for rear window frame locked -G560-
    2 -  Right sender for rear window frame locked -G561-
    3 -  Sender for left roof member flap open -G566- Roof
    4 -  Sender for roof stowed -G565-
    5 -  Right sender for rear shelf locked -G564-
    6 -  Left sender for rear shelf locked -G563-
    7 -  Sender for rear window frame open -G562-
    8 -  Sliding sunroof adjustment control unit -J245- (sliding sunroof motor -V1-), terminal 30
    9 -  Vacant
    10 -  Sender for left roof member locked -G558-
    11 -  Sender for right roof member locked -G559-
    12 -  Sliding sunroof adjustment control unit -J245-
    13 -  Sender for right roof member flap open -G567-
    14 -  Sender supply, connection 5, in convertible top wiring harness - M36-
    15 -  Sender supply, connection 7, in convertible top wiring harness - M38-
    16 -  Sliding sunroof adjustment control unit -J245- (sliding sunroof motor -V1-), terminal 31
    16-pin connector -T16j--D-
    1 -  Convenience CAN bus high
    2 -  Convenience CAN bus low
    3 -  Vacant
    4 -  Luggage cover contact switch -F364-
    5 -  Sender supply, connection 1, in convertible top wiring harness - M32-
    6 -  Power latching control unit -J657-
    7 -  Front sender for position of right roof member -G557-
    8 -  Front sender for position of left roof member -G556-
    9 -  Convertible roof actuation button -E137- (open convertible roof)
    10 -  Convertible roof actuation button -E137- (close convertible roof)
    11 -  Sunroof button -E325- (open sliding sunroof)
    12 -  Sunroof button -E325- (close sliding sunroof)
    13 -  Central switch for window regulators in driver door -E189- (open window)
    14 -  Central switch for window regulators in driver door -E189- (close window)
    15 -  Power latching control unit -J657-
    16 -  Power latching control unit -J657-
    What I did find was that on 16-pin connector D, pin 2 (Convenience CAN bus low) There were some light traces of oxidisation present. I have cleaned this up and it looks fine now. From what I have been able to work out, the CAN bus circuits should be around 4V. I did a quick check on both pin 1 (Convenience CAN bus high) & pin 2 (Convenience CAN bus low) and the showed 0V & 12V respectively. On operating the remote boot open button on the fob these reading changed to 0.7V & 4.5V respectively.
    I am very very far from an expert on CAN bus, but this doesn't seem right from what I can tell. I'm going to put the VCDS back on it over the weekend and will post the log again.
    Based on the above, can you think of any thing obvious I should look at?
    Did you take module apart to inspect the progression of water ingress to the board from where you observed it on or at connector?
    If this is above your scope change the module.
    Feb 2018
    Hello Jack,
    I did take the heat sink off the back and couldn’t see anything out of the ordinary but I didn’t take the PCB off to check the back of it. Will do that on Sunday and report back.
    Thanks for your help so far.
    BTW, paid for an hour on Erwin and saved a load of wiring diagrams, so I’ll also try and work through them too.
  8. Likes Uwe, Jack@European_Parts liked this post
