Results 1 to 8 of 8
Thread: Emblem Reverse Camera View on RNS510
    Feb 2018
    Australia
    I have recently installed a Emblem Reversing Camera on my 2013 Beetle which is fitted with an RNS510 and it's working OK but Can I change the default screen from the Plan view illustration from the Optical Park System to the Camera as the default ? It would to have the Camera view each time I select reverse rather than having to select it each time. At the moment each time Reverse is selected I have to manually select the reverse camera and also when I select the camera view there are a few different views show, on the right of the screen shows a X to close the screen, a mute selection for the optical park warning sounds, Contrast settings adjustments and the fourth selection is to change back from Camera to the plan view optical sensor. Also generally on the left of the camera screen normally it show a plan view of the car but this doesn’t so can any of these selections be tweaked with VCDS ?
    Aug 2016
    Switzerland
    You want to have a look at the PDC unit, login, go to adaptation and play a bit with the display parameter for reverse. You can choose PDC, camera or automatic. Not sure which one you need.
    -= How to post an autoscan -=- How to post an autoscan =-= iichels Polo 6R =-= Don't follow me, I'm lost too =-
    Feb 2018
    Australia
    I am very new to all this so can you tell me how to login to the PDC ? is it thru the VCDS or on the RNS510 headhunt ? I haven't seen any way of getting in on the Headunit but maybe there is a way to boot into it, Thanks for your help
    Aug 2016
    Switzerland
    use the VCDS
    Feb 2018
    Australia
    Thank you so much, that is so cool, you obviously know your way around VCDS
  6. #6
    Aug 2016
    Switzerland
  7. #7
    Feb 2018
    Australia
    I like your Polo and I am thinking of getting one for my son this year
    Once again thanks for your help
  8. #8
    Aug 2016
    Switzerland
    No problem, always happy to help!
    The polo is a great car, but I'd recommend to go for a 6C, if you're considering one, rather than the 6R like I have. It's the facelifted version.
    They are built a bit better than the 6R, mainly engine wise, and the new MQB platform will allow you to tweak your heart out. Plus, the new infotainment system is great.
  9. Likes PetrolDave, Uwe liked this post
