After more digging:
-measured if i have voltage at R96 antenna plug, found voltage there 11.8
-Swapped out antennas old vs new, code then chages to no signal/communication.
-with replacement antenna, i scroll to messuring blocks field "last reported sensor id" and i can see each individual wheel reporting with the correct pressure and all.
Code that stil lingers and causes MIL is still the R96 no basic setting/adaptation
Is the Audi dealer the only way out? Would they be able to login this tpms module and code it correctly? Or am i dreaming in colors?
