Results 1 to 10 of 11
Thread: Coding issues golf mk7 mbq chassis
    New User
    Aug 2017
    hi,
    i was looking to get some help with some coding issues i have with my golf mk 7 mbq chassis.
    can anyone help??.
    thank you
    stephen
    Stephen: What is the exact nature of the assistance that you are seeking and to help with the reader's understanding of the equipment in your mk7- can you post up a copy of an autoscan for your car?
    VW Golf MkVII (103TSI) my13
  3. Likes Uwe liked this post
    Aug 2016
    Switzerland
    How to post an autoscan, see below in my signature
    -= How to post an autoscan -=- How to post an autoscan =-= iichels Polo 6R =-= Don't follow me, I'm lost too =-
  5. Likes Uwe liked this post
  6. #4
    New User
    Aug 2017
    vw golf mk7 mbq 2013 1.6tdi error message coding?
    hi,
    thanks for the reply,i have a golf mk7 mbq originally just airbag issue due to water leak within cabin since fully out and due to being inexperienced with the software i think i may have either lost coding or created issues as the car has been used on regular basis i did not know whether components start shutting down as safety ,parking brake error , cruise control radar , start stop error along with the original airbag which from reading up will it be the case needing vw online link to reset.?
    thank you
    stephen
    Friday,09,February,2018,13:40:39:19792
    VCDS Version: 18.1.0.2
    VIN: WVWZZZAUZDW048601   License Plate: FR62NKX
    Mileage: 113291km-70395mi   Repair Order: 9/02/18
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 03 05 08 09 13 15 16 17 19 42 44 52 5F A5
    VIN: WVWZZZAUZDW048601   Mileage: 113291km-70395miles
    05-Acc/Start Auth. -- Status: Cannot be reached 0100
    15-Airbags -- Status: Cannot be reached 0100
    A5-Frt Sens. Drv. Assist -- Status: Cannot be reached 0100
       Part No SW: 04L 906 021 M    HW: 04L 907 309 B
       Component: R4 1,6L EDC   H22 4944
       Revision: 84H22---
       Coding: 01110012034505092000
       ASAM Dataset: EV_ECM16TDI01104L906021M 002007
       ROD: EV_ECM16TDI01104L906021P.rod
       VCID: 2F6D131476501C3D1C-807A
    5290 - Throttle Actuator Control Circuit
              P2100 00 [096] - Open Circuit
                        Mileage: 113222 km
                        Date: 2018.02.05
                        Time: 18:58:05
                        Coolant temperature: 85 C
                        Intake air temperature: 60 C
                        Voltage terminal 30: 12.580 V
                        Unlearning counter according OBD: 38
                        Mass airflow sensor 1 bank 1 airflow: raw value: 0.0 mg/stroke
                        Throttl.valve adapt. 1 bank 1: posit feedback - Spec.value: 0.00 %
                        Throttl.valve adapt. 1 bank 1: posit feedback - Act.value: 0.00 %
                        Throttl.valve adapt. 1 bank 1: posit feedback - Offset closed: -0.10 %
                        Throttle valve adapter 1 bank 1: monitoring - status-Bits 0-7: 0
                        Throttle valve adapter 1 bank 1: monitoring - status-Bits 0-7: 55
                        Throttle valve adapter 1 bank 1: monitoring - status-Bits 0-7: 2
                        Throttl.valve adapt. 1 bank 1: posit feedback - Uncnd vlt: 4457.2 mV
    4710 - No Communications with Airbag Control Module
              U0151 00 [047] - -
                        Mileage: 113166 km
                        Date: 2018.02.05
                        Time: 15:09:56
                        Coolant temperature: 38 C
                        Intake air temperature: 24 C
                        Voltage terminal 30: 11.940 V
                        Limitation: accelerator pedal: 110.9 Nm
                        Cruise Control System (CCS): status-Bits 0-7: 7
                        selected gear-Bits 0-7: 0
       Part No SW: 5Q0 907 379 AC    HW: 5Q0 907 379 D
       Component: ESC           H75 0437
       Coding: 01FA8AA120240A74037D060001C42580510450C06080A4F3F448F024C0
       ROD: EV_Brake1UDSContiMK100IPB_008.rod
       VCID: 7DF1F95CECBC3EADDE-8028
    8200 - Databus
                        Fault Frequency: 19
                        Reset counter: 127
                        Mileage: 113166 km
                        Date: 2018.02.05
                        Time: 15:09:57
    8204 - Databus
                        Fault Frequency: 18
                        Reset counter: 127
                        Mileage: 113166 km
                        Date: 2018.02.05
                        Time: 15:10:01
    8206 - Databus
                        Fault Frequency: 98
                        Reset counter: 127
                        Mileage: 113166 km
                        Date: 2018.02.05
                        Time: 15:10:04
    8299 - Databus
                        Reset counter: 123
                        Mileage: 113166 km
                        Date: 2018.02.05
                        Time: 15:09:57
    32869 - Databus
              U1123 00 [137] - Received Error Message
                        Reset counter: 123
                        Mileage: 113166 km
                        Date: 2018.02.05
                        Time: 15:10:00
    Address 05: Acc/Start Auth.
    Address 08: Auto HVAC (J301)       Labels:. 5G0-907-426.clb
       Part No SW: 5G0 907 426 J    HW: 5G0 907 426 J
       Component: AC Manuell    H01 0503
       Revision: 00001K06
       Coding: 00120104202100001000000000000000
       ASAM Dataset: EV_ACManueBHBVW37X 002017
       ROD: EV_ACManueBHBVW37X_002_VW37.rod
       VCID: 326B1A60656231D573-8066
    459009 - Databus
                        Reset counter: 123
                        Mileage: 113166 km
                        Date: 2018.02.05
                        Time: 15:09:56
       Part No SW: 5Q0 937 084 N    HW: 5Q0 937 084 N
       Component: BCM MQBAB M   H14 0106
       Serial number: 00011233400545
       Coding: 03000842C24102730FA44080B10403281000000000000000000000000000
       ROD: EV_BCMBOSCH_010.rod
       VCID: 43854FA4CAD8885DE8-8016
       Component: WWS    121016  042 0551
       Serial number:         121109200451
       Coding: 0E4DD5
       Subsystem 2 - Part No SW: 5Q0 955 559     HW: 5Q0 955 559   Labels: 5Q0-955-547.CLB
       Component: RLS  024 0042
       Serial number: Y12M11D16H09M43S31S1
       Coding: 00A8DD
       Component: Sensor, DWA  005 0313
       Serial number: 000000000ZY12285030P
       Serial number: 00000000000055367025
    204546 - Remote key 2
                        Reset counter: 123
                        Mileage: 113166 km
    558101 - Databus
                        Reset counter: 123
                        Mileage: 113166 km
                        Date: 2018.02.05
                        Time: 15:09:56
    Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-567.clb
       Part No SW: 5Q0 907 567 G    HW: 5Q0 907 567 G
       Component: ACC3          H08 0390
       Serial number: 02121275030093
       Coding: 00000300FE030B
       ASAM Dataset: EV_ACCBoschMQB 001021
       ROD: EV_ACCBoschMQB_VW37.rod
       VCID: 3F8D4354A630ECBD8C-806A
    0283 - Databus
              U1121 00 [047] - Missing Message
                        Reset counter: 123
                        Mileage: 113166 km
                        Date: 2018.02.05
                        Time: 15:09:58
                        Control Module temperature: 10 C
                        Voltage terminal 15: 11.9 V
                        Vehicle speed: 0.00 m/s
                        Acceleration: 0.00 m/s
    1043 - Automatic Distance Control
              U8EA150 F0 [047] - Disconnected
                        Reset counter: 123
                        Mileage: 113166 km
                        Date: 2018.02.05
                        Time: 15:09:56
                        Control Module temperature: 11 C
    Address 15: Airbags
       Part No SW: 5Q0 953 507 AG    HW: 5Q0 953 549 A
       Revision: --------    Serial number: 28111200010982
       Coding: 0D00
       ROD: EV_SMLSKLOMQB_011_AU37.rod
       VCID: 7BF5F744F2A8309DE0-802E
       Part No SW: 5G0 920 960 A    HW: 5G0 920 960 A
       Component: KOMBI         236 0555
       Coding: 27A402002780260001882A01040000
       VCID: 275DFB345EA0447DD4-8072
    16776962 - Databus
                        Reset counter: 123
                        Mileage: 113166 km
                        Date: 2018.02.05
                        Time: 15:09:56
       Part No SW: 5Q0 907 530 F    HW: 5Q0 907 530 F
       Component: GW MQB High   122 1109
       Revision: --------    Serial number: 0000178549
       Coding: 030100040B087300EF00005C080F00010001000000000000000000000000
       ASAM Dataset: EV_GatewLear 006010
       ROD: EV_GatewLear_006_VW37.rod
       VCID: 34671C789F763FE561-8060
    H13 0035
       Serial number: 02120004780110020291
       Coding: 2C0000
       Serial number: 6374118601
    131605 - No Communications with Airbag Control Module
              U0151 00 [009] - -
                        Reset counter: 123
                        Mileage: 113166 km
                        Date: 2018.02.05
                        Time: 15:09:57
                        Terminal 15: On
    131634 - No Communications with Control Module for Access/Start Authorization
              U100A 00 [009] - -
                        Reset counter: 123
                        Mileage: 113166 km
                        Date: 2018.02.05
                        Time: 15:09:57
                        Terminal 15: On
    131663 - No Communications with Front Sensor Package for Driver Assist. Systems
              U10E0 00 [009] - -
                        Reset counter: 123
                        Mileage: 113166 km
                        Date: 2018.02.05
                        Time: 15:09:57
                        Terminal 15: On
       Part No SW: 5Q0 959 393 A    HW: 5Q0 959 393
       Component: TSG FS        012 0006
       Serial number: 23111200011497
       Coding: 003002208001048000001000
       VCID: 3D71395CAC3CFEAD9E-8068
       Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000000396759
       Coding: 0D0000
    458752 - Databus
                        Reset counter: 123
                        Mileage: 113166 km
                        Date: 2018.02.05
                        Time: 15:09:56
    458857 - Databus
                        Reset counter: 123
                        Mileage: 113166 km
                        Date: 2018.02.05
                        Time: 15:09:56
       Coding: 81
       ROD: EV_SteerAssisMQB_008.rod
       Part No SW: 5Q0 959 392 A    HW: 5Q0 959 392
       Component: TSG BFS       H12 0006
       Serial number: 20101200010698
       Coding: 003000208001048000801000
       VCID: 3C773458B726F7A5A9-8068
       Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000000405617
       Coding: 050000
    458752 - Databus
                        Reset counter: 123
                        Mileage: 113166 km
                        Date: 2018.02.05
                        Time: 15:09:56
    458857 - Databus
                        Reset counter: 123
                        Mileage: 113166 km
                        Date: 2018.02.05
                        Time: 15:09:56
       Part No SW: 5G0 035 820     HW: 5G0 035 820
       Component: MU-S-D-ER     038 0130
       Serial number: V5C02711120538
       Coding: 02730000FF0000002111120100A800001F0100060100010001
       ASAM Dataset: EV_MUStd4CPASE 002036
       ROD: EV_MUStd4CPASE_VW37.rod
       VCID: 5EB39ED0417AC5B5E7-800A
       Subsystem 1 - Part No SW: 5G0 919 605     HW: 5G0 919 605
       Component: ABT_Std_Radio  H44 0020
       Serial number: VWZ8Z9M2400SJY
    6697 - Databus
                        Fault Frequency: 14
                        Reset counter: 127
                        Mileage: 113166 km
                        Date: 2018.02.05
                        Time: 15:09:56
                        Voltage terminal 30: 11.8 V
    7199 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 123
                        Mileage: 113166 km
                        Date: 2018.02.05
                        Time: 15:09:59
                        BAP-BAP_Function_ID: 02
    Address A5: Frt Sens. Drv. Assist
    End-------------------------(Elapsed Time: 05:55)--------------------------
    Control modules that "Cannot be reached" either by the Gateway or VCDS cannot be "reset" either. You need to fix whatever power and/or wiring problems this car has.
    New User
    Aug 2017
    hi,
    thank you for the reply , power problems as in no power to the modules ,wiring problems as in loose bad connections?.
    i have read that some of the plug in connections do flag up problems and have read of people soldering the wiring together removing the connections giving issues , i know water and dampness does not help these?.
    the car has had a few furry friends thinking they could use the car for shelter assuming mice they climb up the gutter run from the bulkhead and run along the bulkhead which i have now blocked they have chewed the wiring to the wipers on my caddy work van roadside repaired and on the golf chewed the alarm siren cable , as i have read they do like the soy in the new vw wiring never touched vauxhall pvc , i have reduced the size of the drain holes in the bulkhead to stop and checked wiring through out but have not found any more of this anywhere else.
    i was looking at a scan i first did and the abs module does have a space on the coding and some of figures are slightly different so i will take the 2 laptops into the car today to restore back to original scanned when everything was working hopefully going through all the modules i will find more to be restored.
    i will let you know what happens.
    thank you
    stephen
    New User
    Aug 2017
    hi,
    i now see what you mean power problem, main problems seamed to start when i looked into the battery adaptions the battery was not listed as correct was jcb make efb type , which was not so i changed to the correct agm varta battery installed as on car when bought ,as i thought i re coded the battery but as looks on the scans voltage readings of 11.9 volts would not be sufficient to run modules so as why i am getting problems , i will look to get a new battery and re code hopefully this will clear most of the issues once this has the power from a fresh battery.
    one more ,should i be scanning with the engine running would it cause a problem when not running causing power issues?.
    thank you
    stephen
  10. #8
    Quote Originally Posted by tigerbelle View Post
    thank you
    If the car has a battery that's in good condition and fully charged, it should be OK to leave the ignition on (and engine not running) for a few minutes at at time, such as when doing an Auto-Scan. I would still turn off all unnecessary loads that can be turned off though, such as any exterior lights, the HVAC blower, seat heaters, etc.
    For more extensive scanning sessions such as making module maps, you should either connect a battery charger with enough capacity to keep the battey above 13V or keep the engine running. IMO, the former is generally preferable to the latter for a number of reasons.
    Personally, I do not think that this car's electrical woes are just due to a weak battery.
  11. #9
    New User
    Aug 2017
    hi uwe
    right I have been over and cleaned connections to air bag controller can bus controller ecu but wanted to ask if this was down to the airbag controller being faulty , would these faults on the airbag module be clear if I replaced the airbag controller with a working one of the same id ref, or would it not be clear or clear until it was coded and if required component protection removed dealership?.
    trying to ascertain if by doing this it would show as the issue being with airbag controller?
    thanks again
    stephen
  12. #10
    New User
    Aug 2017
    looks like i am finding power issues and aggressive scanning at mostly fault
    hi uwe
    I have been through most connections cleaning and have taken srs airbag out and apart finding what looks like bad soldered legs of chip possibly where moisture had entered and 2 fuses had ruptured which were replaced ,so I have booked the vehicle into a workshop to remove component protection when a replacement used good unit is to be fitted , the issues I have been having look like they have been associated with the voltage as I had the car battery being charged conditioning battery and error messages are down to 3 from 7 only 1 important still need to look into abs brakes and cruise control module ,I have rescanned and unchecked aggressive mode which only comes up with 6 modules requiring attention looking like as they are connected to the srs controller issue.
    so most problems flagged up on original scan were due to aggressive mode checked and most units have returned back as looks like either battery voltage was the issue or the fact the vehicles lack of regular not getting sufficient charge .
    so I just have the airbag issues to resolve and hopefully I am all good .
    thank you
    stephen
  13. Likes Uwe liked this post
