Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: 2007 VW Passat 2.0T No Start
    Feb 2018
    Tuesday,13,February,2018,14:56:30:09859
    VCDS Version: 18.1.0.2 (x64)
    VIN: WVWJK73C47E246480   License Plate:
    Chassis Type: 3C (3C0)
    Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 52 53 56 62 65 72
    VIN: WVWJK73C47E246480   Mileage: 151280km-94001miles
    00-Steering Angle Sensor -- Status: INTERFACE NOT COMPATIBLE
    08-Auto HVAC -- Status: Cannot be reached 1100
    53-Parking Brake -- Status: Cannot be reached 1100
       Part No SW: 3C0 907 115 S    HW: 8P0 907 115 B
       Revision: 5BH16---    Serial number: VWZCZ000000000
       Coding: 0404010A19070160
       Shop #: WSC 25642 444 92495
       VCID: 3041E2B0A305D0C505-8064
    005715 - Please check DTC Memory of ABS Controller
                   P1653 - 004 -
                        Mileage: 151281 km
                        Date: 2018.02.11
                        Time: 18:36:51
                        Temperature: 18.0C
                        Temperature: 21.0C
                        Absolute Pres.: 1020.0 mbar
                        Voltage: 11.811 V
    049448 - No Communications with Parking Brake Control Module
                   U0128 - 008 -
                        Mileage: 151281 km
                        Date: 2018.02.11
                        Time: 18:36:52
                        Temperature: 18.0C
                        Temperature: 21.0C
                        Voltage: 11.684 V
    049508 - No Communications with HVAC Control Module (J301)
                   U0164 - 008 -
                        Mileage: 151281 km
                        Date: 2018.02.11
                        Time: 18:36:52
                        Temperature: 18.0C
                        Temperature: 21.0C
                        Voltage: 11.811 V
    Readiness: 0110 0101
       Part No SW: 09G 927 750 HJ    HW: 09G 927 750 FP
       Component: AQ 250 6F           1068
       Revision: 00H69000    Serial number:
       Coding: 0000072
       VCID: 0021727053258045B5-8054
    Address 03: ABS Brakes        Labels:. 3C0-614-095-C2.clb
       Part No SW: 3C0 614 109 A    HW: 3C0 614 109 A
       Component: ESP 440 C4     H018 0001
       Revision:  H018       Serial number: 0775412325
       Coding: 0013755
       Shop #: WSC 05311 000 00000
       VCID: 1C192600DF8D44A549-8048
                        Reset counter: 161
                        Mileage: 151281 km
                        Date: 2018.02.11
                        Time: 18:41:49
                        Reset counter: 161
                        Mileage: 151281 km
                        Date: 2018.02.11
                        Time: 18:41:49
    Address 08: Auto HVAC
       Part No SW: 3C0 937 049 AE    HW: 3C0 937 049 AE
       Component: Bordnetz-SG     H52 2002
       Revision: 00H52000    Serial number: 00000007061522
       Coding: 10840F0340041A00470000000F00000000285D435C0001
       VCID: 6CF936C04FAD742579-8038
       Subsystem 1 - Part No: 3C1 955 419 A  Labels: 1KX-955-119.CLB
       Component: Wischer 020407 003  0205
       Coding: 00046997
       Shop #: WSC 05311
                        Reset counter: 162
                        Mileage: 151281 km
                        Date: 2018.02.11
                        Time: 19:02:00
                        Voltage: 12.10 V
    01259 - Fuel Pump Relay (J17)
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 162
                        Mileage: 151281 km
                        Date: 2018.02.11
                        Time: 18:37:00
                        Voltage: 11.65 V
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 162
                        Mileage: 151281 km
                        Date: 2018.02.11
                        Time: 19:02:00
                        Voltage: 12.10 V
                        Reset counter: 162
                        Mileage: 151281 km
                        Date: 2018.02.11
                        Time: 18:37:00
                        Voltage: 11.65 V
       Part No SW: 3C0 909 605 N    HW: 3C0 909 605 N
       Component: 17 AIRBAG VW8R  032 2522
       Revision: 13032000    Serial number: 003B2P7ZGJ7$
       Coding: 0012599
       VCID: 3147E7B4A80FD9CD0A-8064
       Subsystem 1 - Part No: 3C0 959 339 B
       Component: BF-Gewichtsens. 007 0003
       Subsystem 2 - Serial number: 0000000003LESJ
       Subsystem 3 - Serial number: 0001.01.000000700000000000†63
       Subsystem 4 - Serial number: 000000†6332MSME19425E29H†63
       Subsystem 5 - Serial number: 25E29H†6342MSME13170139/†63
       Subsystem 6 - Serial number: 70139/†6351HTS6LNFST6K6S†63
       Subsystem 7 - Serial number: ST6K6S†6361HTS6LNF4L576Q†63
       Subsystem 8 - Serial number: 4L576Q†63727TS6LNFCA8C7O†63
       Subsystem 9 - Serial number: CA8C7O†63827TS6LNFCA5H6Q
       Subsystem 10 - Serial number: CA5H6Q
       Part No SW: 3C0 953 549 N    HW: 3C0 953 549 N
       Revision: 00006000    Serial number: 3C5953507AK
       Coding: 0002013
       Shop #: WSC 25642 444 04951
       VCID: 3753D9AC466B07FD44-8062
       Part No SW: 3C0 920 971 A    HW: 3C0 920 971 A
       Component: KOMBIINSTRUMENT VD1 1614
       Revision: V0007000    Serial number: 00000000000000
       Coding: 0007205
       VCID: 236B1DFCE2F37B5D88-8076
                        Fault Frequency: 9
                        Reset counter: 162
                        Mileage: 151281 km
                        Date: 2018.02.11
                        Time: 17:57:19
    Address 19: CAN Gateway        Labels:. 3C0-907-530-V1.clb
       Revision: 00007000    Serial number: 0700C0750404F2
       Coding: 3FFD0E04D21002
       VCID: 216717F4F8EF694D9A-8074
                        Reset counter: 162
                        Mileage: 151281 km
                        Date: 2018.02.11
                        Time: 18:20:46
                        Reset counter: 162
                        Mileage: 151281 km
                        Date: 2018.02.11
                        Time: 18:20:46
       Part No SW: 3C0 919 965     HW: 3C0 919 965
       Component: Kompass         005 0003
       Revision: 00005000    Serial number: 1166279TRF6R06
       VCID: 6DFF3BC474B77D2D6E-8038
       Part No SW: 3C0 959 433 AK    HW: 3C0 959 433 AK
       Component:    IMMO         051 0383
       Revision: 00051000    Serial number: VWZCZ000000000
       Shop #: WSC 25642 444 12164
       VCID: 73CB2DBC1293ABDDB8-8026
       Component: J386  TUER-SG FT    1131
       Revision: 32008001    Serial number: 00000063678424
       Coding: 0001205
       VCID: 3B5BC59C7A43239DA0-806E
    Address 44: Steering Assist
  2. #12
    Jul 2015
    Canada
    I'm still seeing numerous electrical faults and several modules that "Cannot be reached".
    Have you checked all fuses? How about the relays? Particularly the fuel pump relay.. You're going to need a wiring diagram and a multimeter...
  5. #14
    Feb 2018
    latest update- the car runs again and I can't thank you guys enough. that is the short version, if you care to read the long version its that we had a headlight go out and upon trying to change the bulb I noticed that the plastic coating on the wires inside the headlight housing were melted. I proceeded to remove the wiring harness making repairs to work long enough for the new set I ordered came in. When I finished the repair I forget which light wouldn't work right so I played with some of the fuses.(some of the fuses\and locations aren't right in the manual found another setup online) got the car working and had 2 lights on the dash and upon trying to troubleshoot those lights went back to playing with the fuses and the car wouldn't start. played around some more and got it to start but wouldn't go into gear then it wouldn't start then would start and would go into gear but the back brakes were locked then back to no start at which point I found this site and it was the guidance I needed to hang in there and figure it out THANKS AGAIN SO MUCH SO WORTH EVERY PENNY SPENT ON VAG COM
  6. Likes Uwe liked this post
  7. #15
    Induced FOD wins again!
    European Parts Emporium/Performance / Immobilizer Solutions LLC
