Results 1 to 10 of 15
Thread: 2007 VW Passat 2.0T No Start
    Feb 2018
    Hello all I am new to this but am very grateful for any help.
    Tuesday,13,February,2018,11:54:58:09859
    VCDS Version: 18.1.0.2 (x64)
    VIN: WVWJK73C47E246480   License Plate:
    Mileage: 151280km-94001mi   Repair Order:
    Chassis Type: 3C (3C0)
    Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 52 53 56 62 65 72
    VIN: WVWJK73C47E246480   Mileage: 151280km-94001miles
    00-Steering Angle Sensor -- Status: INTERFACE NOT COMPATIBLE
    02-Auto Trans -- Status: Malfunction 1010
    08-Auto HVAC -- Status: Cannot be reached 1100
    15-Airbags -- Status: Malfunction 1010
    25-Immobilizer -- Status: Malfunction 1010
    46-Central Conv. -- Status: Malfunction 1010
    52-Door Elect, Pass. -- Status: Malfunction 1010
    53-Parking Brake -- Status: Cannot be reached 1100
    65-Tire Pressure -- Status: Malfunction 1010
    72-Door, Rear Right -- Status: Malfunction 1010
       Part No SW: 3C0 907 115 S    HW: 8P0 907 115 B
       Revision: 5BH16---    Serial number: VWZCZ000000000
       Coding: 0404010A19070160
       Shop #: WSC 25642 444 92495
       VCID: 3041E2B0A305D0C505-8064
    6 Faults Found:
    005715 - Please check DTC Memory of ABS Controller
                   P1653 - 004 -
                        Fault Frequency: 25
                        Mileage: 151281 km
                        Date: 2018.02.10
                        Time: 10:57:15
                        Temperature: 18.0C
                        Temperature: 19.0C
                        Absolute Pres.: 1010.0 mbar
                        Voltage: 12.192 V
    049448 - No Communications with Parking Brake Control Module
                   U0128 - 008 -
                        Mileage: 151281 km
                        Date: 2018.02.10
                        Time: 10:57:16
                        Temperature: 19.0C
                        Temperature: 19.0C
                        Voltage: 12.192 V
    049508 - No Communications with HVAC Control Module (J301)
                   U0164 - 008 -
                        Mileage: 151281 km
                        Date: 2018.02.10
                        Time: 10:57:16
                        Temperature: 19.0C
                        Temperature: 20.0C
                        Voltage: 12.192 V
    012425 - Signal Line for Fuel Pump Electronics
                   P3089 - 002 - Electrical Malfunction
                        Fault Status: 01100010
                        Mileage: 151281 km
                        Date: 2018.02.10
                        Time: 10:57:42
                        RPM: 258 /min
                        Load: 67.0 %
                        Temperature: 19.0C
                        Temperature: 20.0C
                        Voltage: 11.176 V
    000256 - Mass Air Flow Sensor (G70)
                   P0100 - 004 - Supply Voltage
                        Mileage: 151281 km
                        Temperature: 9.0C
                        Temperature: 11.0C
                        Absolute Pres.: 1020.0 mbar
                        Voltage: 12.319 V
    008852 - Fuel Pressure Regulator Valve (N276)
                   P2294 - 004 - Open Circuit - Intermittent
                        Mileage: 151281 km
                        RPM: 236 /min
                        Load: 67.4 %
                        Temperature: 9.0C
                        Temperature: 11.0C
                        Voltage: 11.938 V
    Readiness: 0110 0101
       Part No SW: 09G 927 750 HJ    HW: 09G 927 750 FP
       Component: AQ 250 6F           1068
       Revision: 00H69000    Serial number:
       Coding: 0000072
       VCID: 0021727053258045B5-8054
                        Fault Frequency: 27
                        Reset counter: 0
                        Mileage: 42756 km
                        Date: 2009.03.25
                        Time: 13:35:04
                013 - Check DTC Memory
                        Fault Frequency: 27
                        Reset counter: 0
                        Mileage: 42756 km
                        Date: 2009.03.25
                        Time: 13:35:04
    Address 03: ABS Brakes        Labels:. 3C0-614-095-C2.clb
       Part No SW: 3C0 614 109 A    HW: 3C0 614 109 A
       Component: ESP 440 C4     H018 0001
       Revision:  H018       Serial number: 0775412325
       Coding: 0013755
       Shop #: WSC 05311 000 00000
       VCID: 1C192600DF8D44A549-8048
                        Fault Frequency: 170
                        Reset counter: 161
                        Mileage: 151281 km
                        Date: 2018.01.30
                        Time: 18:45:08
    00532 - Supply Voltage B+
                        Reset counter: 161
                        Mileage: 151281 km
                        Date: 2018.01.30
                        Time: 19:39:59
                        Fault Status: 01101101
                        Fault Frequency: 12
                        Reset counter: 161
                        Mileage: 151281 km
                        Date: 2018.02.10
                        Time: 18:34:04
                        Fault Frequency: 12
                        Reset counter: 161
                        Mileage: 151281 km
                        Date: 2018.02.10
                        Time: 18:34:04
    Address 08: Auto HVAC
       Part No SW: 3C0 937 049 AE    HW: 3C0 937 049 AE
       Component: Bordnetz-SG     H52 2002
       Revision: 00H52000    Serial number: 00000007061522
       Coding: 10840F0340041A00470000000F00000000285D435C0001
       VCID: 6CF936C04FAD742579-8038
       Subsystem 1 - Part No: 3C1 955 419 A  Labels: 1KX-955-119.CLB
       Component: Wischer 020407 003  0205
       Coding: 00046997
       Shop #: WSC 05311
    10 Faults Found:
                        Reset counter: 162
                        Mileage: 150459 km
                        Date: 2017.12.16
                        Time: 17:52:00
                        Voltage: 11.80 V
    00906 - Horn (H1)
                        Fault Status: 00101001
                        Reset counter: 202
                        Mileage: 151281 km
                        Date: 2018.01.30
                        Time: 17:15:00
                        Voltage: 12.25 V
    01516 - Terminal 30; Left
                        Fault Status: 00101011
                        Reset counter: 202
                        Mileage: 151281 km
                        Date: 2018.01.30
                        Time: 17:57:00
                        Voltage: 12.30 V
                        Fault Frequency: 15
                        Reset counter: 202
                        Mileage: 151280 km
                        Date: 2018.01.27
                        Time: 23:52:00
                        Voltage: 12.25 V
                        Reset counter: 202
                        Mileage: 151280 km
                        Date: 2018.01.28
                        Time: 01:38:00
                        Voltage: 12.15 V
                        Reset counter: 202
                        Mileage: 149648 km
                        Date: 2017.11.29
                        Time: 10:30:00
                        Voltage: 13.75 V
                        Fault Frequency: 106
                        Reset counter: 162
                        Mileage: 151280 km
                        Date: 2018.01.28
                        Time: 00:47:00
                        Voltage: 11.95 V
                        Reset counter: 202
                        Mileage: 151280 km
                        Date: 2018.01.28
                        Time: 01:15:00
                        Voltage: 11.80 V
    02383 - Windshield Wiper Motor Function Restricted due to Under-Voltage
                        Reset counter: 202
                        Mileage: 151281 km
                        Date: 2018.01.30
                        Time: 19:41:00
                        Voltage: 9.70 V
                        Reset counter: 202
                        Mileage: 151280 km
                        Date: 2018.01.28
                        Time: 01:15:00
                        Voltage: 11.80 V
       Part No SW: 3C0 909 605 N    HW: 3C0 909 605 N
       Component: 17 AIRBAG VW8R  032 2522
       Revision: 13032000    Serial number: 003B2P7ZGJ7$
       Coding: 0012599
       VCID: 3147E7B4A80FD9CD0A-8064
       Subsystem 1 - Part No: 3C0 959 339 B
       Component: BF-Gewichtsens. 007 0003
       Subsystem 2 - Serial number: 0000000003LESJ
       Subsystem 3 - Serial number: 0001.01.000000700000000000†63
       Subsystem 4 - Serial number: 000000†6332MSME19425E29H†63
       Subsystem 5 - Serial number: 25E29H†6342MSME13170139/†63
       Subsystem 6 - Serial number: 70139/†6351HTS6LNFST6K6S†63
       Subsystem 7 - Serial number: ST6K6S†6361HTS6LNF4L576Q†63
       Subsystem 8 - Serial number: 4L576Q†63727TS6LNFCA8C7O†63
       Subsystem 9 - Serial number: CA8C7O†63827TS6LNFCA5H6Q
       Subsystem 10 - Serial number: CA5H6Q
    03032 - Supply Voltage for Seat Occupied Recognition Control Module
       Part No SW: 3C0 953 549 N    HW: 3C0 953 549 N
       Revision: 00006000    Serial number: 3C5953507AK
       Coding: 0002013
       Shop #: WSC 25642 444 04951
       VCID: 3753D9AC466B07FD44-8062
       Part No SW: 3C0 920 971 A    HW: 3C0 920 971 A
       Component: KOMBIINSTRUMENT VD1 1614
       Revision: V0007000    Serial number: 00000000000000
       Coding: 0007205
       VCID: 236B1DFCE2F37B5D88-8076
                        Fault Frequency: 30
                        Reset counter: 162
                        Mileage: 151281 km
                        Date: 2018.01.30
                        Time: 18:44:39
                        Reset counter: 202
                        Mileage: 151281 km
                        Date: 2018.01.30
                        Time: 19:39:12
                        Reset counter: 202
                        Mileage: 151281 km
                        Date: 2018.01.30
                        Time: 19:40:08
    Address 19: CAN Gateway        Labels:. 3C0-907-530-V1.clb
       Revision: 00007000    Serial number: 0700C0750404F2
       Coding: 3FFD0E04D21002
       VCID: 216717F4F8EF694D9A-8074
    9 Faults Found:
                        Reset counter: 144
                        Mileage: 150581 km
                        Date: 2017.12.20
                        Time: 17:35:28
                        Reset counter: 202
                        Mileage: 151280 km
                        Date: 2018.01.27
                        Time: 23:26:02
                        Reset counter: 202
                        Mileage: 151280 km
                        Date: 2018.01.27
                        Time: 23:52:34
                        Reset counter: 162
                        Mileage: 151280 km
                        Date: 2018.01.28
                        Time: 00:47:40
                        Reset counter: 202
                        Mileage: 151280 km
                        Date: 2018.01.28
                        Time: 01:38:06
                        Reset counter: 202
                        Mileage: 151280 km
                        Date: 2018.01.28
                        Time: 01:38:10
                        Reset counter: 202
                        Mileage: 151280 km
                        Date: 2018.01.28
                        Time: 01:38:10
                        Reset counter: 202
                        Mileage: 151280 km
                        Date: 2018.01.28
                        Time: 01:38:10
                        Reset counter: 162
                        Mileage: 151280 km
                        Date: 2018.01.28
                        Time: 23:35:27
       Part No SW: 3C0 919 965     HW: 3C0 919 965
       Component: Kompass         005 0003
       Revision: 00005000    Serial number: 1166279TRF6R06
       VCID: 6DFF3BC474B77D2D6E-8038
                        Fault Frequency: 26
                        Reset counter: 202
                        Mileage: 151280 km
                        Date: 2018.01.28
                        Time: 01:15:46
       Part No SW: 3C0 959 433 AK    HW: 3C0 959 433 AK
       Component:    IMMO         051 0383
       Revision: 00051000    Serial number: VWZCZ000000000
       Shop #: WSC 25642 444 12164
       VCID: 73CB2DBC1293ABDDB8-8026
    02823 - Requirements for Locking the Steering Column Lock not met
                000 -  -  - Intermittent
                        Reset counter: 202
                        Mileage: 151281 km
                        Date: 2018.01.29
                        Time: 00:00:25
    02828 - Enabling Steering Column Lock from Diagnostic Interface
                        Reset counter: 202
                        Mileage: 151280 km
                        Date: 2018.01.28
                        Time: 02:17:25
    02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
                        Reset counter: 202
                        Mileage: 151281 km
                        Date: 2018.01.30
                        Time: 19:40:54
       Component: J386  TUER-SG FT    1131
       Revision: 32008001    Serial number: 00000063678424
       Coding: 0001205
       VCID: 3B5BC59C7A43239DA0-806E
                        Fault Status: 00100101
                        Reset counter: 202
                        Reset counter: 202
                        Mileage: 151280 km
                        Date: 2018.01.28
                        Time: 01:38:11
       Part No: 1K1 909 144 L
       Component: EPS_ZFLS Kl.135 H07 1806
       VCID: 3449EEA0571DECE561-8060
       Component:    KSG PQ46 RDK 051 0221
       Coding: 13910F8001862E521004141FF08A0F0E085800
                        Fault Frequency: 9
                        Reset counter: 162
                        Mileage: 151280 km
                        Date: 2018.01.28
                        Time: 00:47:41
                        Reset counter: 202
                        Mileage: 151281 km
                        Date: 2018.01.30
                        Time: 19:39:17
                        Reset counter: 202
                        Mileage: 151280 km
                        Date: 2018.01.28
                        Time: 01:38:07
                        Reset counter: 202
                        Mileage: 151280 km
                        Date: 2018.01.28
                        Time: 01:38:07
       Part No SW: 1K0 959 702 P    HW: 1K0 959 792 L
       Component: J387  TUER-SG BT    1131
       Revision: 32008001    Serial number: 00000597178502
       Coding: 0001204
       VCID: 3C59C6807F4D24A5A9-8068
                        Reset counter: 202
                        Mileage: 151280 km
                        Date: 2018.01.27
                        Time: 23:53:11
                        Fault Status: 01111000
                        Fault Frequency: 18
                        Reset counter: 162
                        Mileage: 151280 km
                        Date: 2018.01.28
                        Time: 22:02:30
    00106 - Signal Central Locking SAVE/LOCK Passenger Side
                        Reset counter: 162
                        Mileage: 135588 km
                        Date: 2016.08.10
                        Time: 20:38:12
    Address 53: Parking Brake
    Address 56: Radio        Labels: 1K0-035-161.lbl
       Part No SW: 1K0 035 161 B    HW: 1K0 035 161 B
       Component: Radio DE2       014 0017
       Revision: 00014000    Serial number: VWZ4Z7G6236642
       Coding: 0040401
       Shop #: WSC 05314 000 00000
       VCID: 1E1D2C08C99156B5A7-804A
       Part No SW: 1K0 959 703 Q    HW: 1K0 959 795 J
       Component: J388   TUER-SG HL   1118
       Revision: 12006001    Serial number: 00000001660661
       Coding: 0001168
       VCID: 3E5DCC88695136B587-806A
    01813 - Supply Voltage for Door Controller; Rear Left (J388)
                        Reset counter: 202
                        Mileage: 147941 km
                        Date: 2017.10.25
                        Time: 19:39:34
       Coding: 0100101
    00625 - Vehicle Speed Signal
                        Fault Frequency: 21
                        Reset counter: 202
                        Mileage: 151280 km
                        Date: 2018.01.28
                        Time: 22:39:32
       Part No SW: 1K0 959 704 Q    HW: 1K0 959 794 J
       Component: J389   TUER-SG HR   1118
       Revision: 12006001    Serial number: 00000001528899
       Coding: 0001168
       VCID: 3FA3B18C6E5B3FBD8C-806A
    01814 - Supply Voltage for Door Controller; Rear Right (J389)
                        Reset counter: 202
                        Mileage: 147941 km
                        Date: 2017.10.25
                        Time: 19:39:34
    End-------------------------(Elapsed Time: 02:33)--------------------------
    Have you carefully checked all fuses?
    I would clear all fault codes (the slow way):
    [Auto-Scan]
    [Gateway Installation List]
    After it pulls it up (just a second or three), un-check "Use CAN Command" and then:
    [Clear all DTCs]
    After it's done, cycle the ignition off, wait 60 seconds, turn it on again, and do another full scan to see what faults come back.
    Feb 2018
    Im on it, I will let you know thanks
    As Uwe aforementioned on all &........
    Battery voltage is poor...........correct it first because 0x25 immobilizer is unhappy!
    Sort open circuit on N276 first using WD.
    Verify wire and FP control module using WD as well.
    Verify 0x08 not running interference for COM errors.
    http://forums.ross-tech.com/showthre...ut-0x01-08-000
    JPPSG
    RTFB at ERWIN + print to PDF to save money.
    Feb 2018
    Its saying Professional Grade interface required for this function
    Feb 2018
    That is when trying to clear dtcs
    Feb 2018
    As you mentioned Jack about the Battery voltage I had it checked at Autozone one day and they said it was fine, then a couple of days later I brought it back for a second opinion and they said it was bad and I had enough warranty to just get another one so the battery is new now. Uwe I have to ask, why would I get that response when trying to clear the DTC’s doing it the way you described and is their a work around I mean maybe with the new battery and clearing the dtc’s a lot of this could correct itself maybe?
  9. #8
    Quote Originally Posted by CrazyCajun View Post
    It’s saying “Professional Grade interface required for this function”
    Sorry, I didn't check what you had -- looks like a Micro-CAN...
    I'm afraid you'll have to do it the old-fashioned way. Go to each module individually and clear fault codes.
  10. #9
    Feb 2018
    thanks so much I will try anything at this point. I will report back with the results.
  11. #10
    Feb 2018
    I tried to manually clear the codes get out of it wait a few minutes and tried again
    Tuesday,13,February,2018,14:56:30:09859
                   P1653 - 004 -
                        Mileage: 151281 km
                        Date: 2018.02.11
                        Time: 18:36:51
                        Temperature: 18.0C
                        Temperature: 21.0C
                        Voltage: 11.811 V
                   U0128 - 008 -
                        Mileage: 151281 km
                        Date: 2018.02.11
                        Time: 18:36:52
                        Temperature: 18.0C
                        Temperature: 21.0C
                        Voltage: 11.684 V
                   U0164 - 008 -
                        Mileage: 151281 km
                        Date: 2018.02.11
                        Time: 18:36:52
                        Temperature: 18.0C
                        Temperature: 21.0C
                        Voltage: 11.811 V
       Coding: 0000072
       Coding: 0013755
                        Reset counter: 161
                        Mileage: 151281 km
                        Date: 2018.02.11
                        Time: 18:41:49
                        Reset counter: 161
                        Mileage: 151281 km
                        Date: 2018.02.11
                        Time: 18:41:49
       Coding: 00046997
       Shop #: WSC 05311
                        Reset counter: 162
                        Mileage: 151281 km
                        Date: 2018.02.11
                        Time: 19:02:00
                        Voltage: 12.10 V
    01259 - Fuel Pump Relay (J17)
                        Fault Status: 01101001
                        Reset counter: 162
                        Mileage: 151281 km
                        Date: 2018.02.11
                        Time: 18:37:00
                        Voltage: 11.65 V
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 162
                        Mileage: 151281 km
                        Date: 2018.02.11
                        Time: 19:02:00
                        Voltage: 12.10 V
                        Reset counter: 162
                        Mileage: 151281 km
                        Date: 2018.02.11
                        Time: 18:37:00
                        Voltage: 11.65 V
       Coding: 0012599
       Coding: 0002013
       Coding: 0007205
                        Fault Frequency: 9
                        Reset counter: 162
                        Mileage: 151281 km
                        Date: 2018.02.11
                        Time: 17:57:19
                        Reset counter: 162
                        Mileage: 151281 km
                        Date: 2018.02.11
                        Time: 18:20:46
                        Reset counter: 162
                        Mileage: 151281 km
                        Date: 2018.02.11
                        Time: 18:20:46
       Coding: 0001205
