Results 1 to 10 of 10
Thread: No ROD file found...
    Nov 2016
    Did an autoscan of my Audi S4 today, no faults and AFAIK everything working OK but at the end of the scan I get a popup;
    "No ROD file found"
    with the description;
    " Unable to find a .ROD file for: EV_SoundAc 002005 (AU48)
    Please make sure you are using the latest version (including BETA).
    If you are using the latest version, please send an Autoscan from this car to Ross-Tech."
    At the end of the autoscan is an extra paragraph to previous scans;
    "No ASAM data for: "EV_SoundAc" (AU48)
    No fault code found."
    VCDS is Ver 18.1.0 which I believe is the latest version?
    Is this a VCDS fault or something on my car?
    2014 Audi S4 Avant, 'black edition'.
    No autoscan?
    If this is this car it sounds like you had a comms issue reading the ASAM ID of that controller, which should be EV_SoundActuaGen2AU64X.
  3. Likes Uwe, Dukedesmo liked this post
    Nov 2016
    No autoscan?
    Yes that's the car, here's the autoscan;
    Tuesday,13,February,2018,12:38:07:24986
    VCDS Version: 18.1.0.2
    VIN: WAUZZZ8K7EA150192   License Plate:
    Chassis Type: 8K-AU48 (8R0)
    Scan: 01 02 03 05 08 09 15 16 17 19 30 36 42 44 46 47 52 53 56 5F
              62 6D 72 A9
    VIN: WAUZZZ8K7EA150192   Mileage: 38310km-23804miles
    Address 01: Engine (J623-CGWC)       Labels:. 06E-907-551-CGW.clb
       Part No SW: 8K5 907 551 D    HW: 4H0 907 551
       Component: 3.0l V6 TFSIX07 0004
       Revision: --X07---
       Coding: 12250034052701020800
       Shop #: WSC 06208 000 00000
       ASAM Dataset: EV_ECM30TFS0218K5907551D 001004
       ROD: EV_ECM30TFS0218K5907551D.rod
       VCID: 377CA0AB8E2C1EFD44-8062
       Part No SW: 8K5 927 156 B    HW: 0B5 927 156 K
       Component: 0B5 30TFSIRdW H03 0003
       Revision: --H03---
       Shop #: WSC 04742 780 00200
       ROD: EV_TCMDL501021.rod
       VCID: 387EA397833211854D-806C
       Part No SW: 8K0 907 379 CP    HW: 8K0 907 379 CP
       Coding: 291DCC01
       Shop #: WSC 06335 000 00000
       VCID: 09181653A058D80DE2-805C
       Part No SW: 8K0 907 064 JG    HW: 8K0 907 064 JG
       Component: BCM2 2.0      H14 0650
       Coding: 01B24040000000000000
       VCID: 7EF2758FE996EFB5C7-802A
       Subsystem 1 - Part No SW: 8K0 959 754 BH    HW: 8K0 959 754 BH
       Serial number: 0514000046830011
       Serial number: 0214000068278002
       Part No SW: 8K2 820 043 AQ    HW: 8K2 820 043 AQ
       Revision: D1000000    Serial number: 01100420140302
       Coding: 6624028000
       VCID: 78FE6397CBB2D1858D-802C
       Revision: 08016001    Serial number: 00000789946701
       Coding: 260000118034AFC00081404300001D0D0F1D470A27090201000008004400030100000024000000
       Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 010414  H06 0080
       Serial number: SWF14044015610
       Coding: 00FD11
       Serial number: 22487512
       Coding: 02005D
       Component: E1 - LDS  H03 0031
       Serial number: 00000000000104144832
       Serial number: FA780227000000000001
       Component: AirbagVW-AU10 H48 0610
       Serial number: 003KFDC0WUTP
       Coding: 30534435363030303030554A3052384B3053
       Shop #: WSC 60782 001 1048576
       VCID: 489ED357F3D261053D-801C
       Serial number: 6334MSME443A333AD
       Serial number: 6344MSME443C6E75T
       Serial number: 6352QSME1E400648E
       Serial number: 6362QSME1A401B6EP
       Serial number: 63732SME40404A66X
       Serial number: 63832SME4F400F689
       Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
       Component: Lenks.Modul   H03 0003
       Revision: C0062331    Serial number: 90862NDE001IC
       Coding: 000037
       VCID: 489ED357FBD261053D-801C
       Part No SW: 8K0 920 982 T    HW: 8K0 920 982 T
       Component: KOMBIINSTR.   H35 0564
       Revision: 00100000    Serial number: ZAE62M34F
       Coding: 33BF110003012600010000
       VCID: 4580DA63CCC07C6DC6-8010
       Part No SW: 8R0 907 468 N    HW: 8R0 907 468 C
       Component: GW-BEM 4CAN-M H11 0060
       Revision: 1Y080030    Serial number: 3041Y143310158
       Coding: 80CF07FF00
       VCID: 4A9AE95FE5DE93152B-801E
       Serial number: 9802233103
       Serial number: 14099003849011200410
       Part No SW: 8K0 907 440 B    HW: 8K0 907 440
       Component: STS           H04 0020
       Revision: S0H04000    Serial number: 00000000084090
       VCID: 2D5082C37470A42D2E-8078
       Component: MEM-FS        H06 0077
       Revision: AA000000    Serial number: 00000097259421
       Coding: 01781300000000000000
       VCID: 3B74BC9BBA043A9DA0-806E
       Component: TSG FA        H02 0510
       Revision:             Serial number: 0000098884238
       Coding: 011C02205E21410001
       VCID: 4FACF84B1EBCB63D7C-801A
       Part No SW: 8K0 909 144 G    HW: 8K0 909 144 B
       Component: RCEPS         H40 0508
       Revision: 00001000    Serial number: 0003457337
       Coding: 100000000001
       Shop #: WSC 06334 000 00000
       ASAM Dataset: EV_RCEPSAU48X 008015
       ROD: EV_RCEPSAU48X_008.rod
       VCID: 3560AAA39420ECED56-8060
       Revision: 00002001    Serial number: 0332027708
       Coding: 013B0622A0B938948330023680000047
       Subsystem 3 - Part No SW: 8K0 959 591 C    HW: 8K0 959 591
       Component: J245 PS151  H08 0043
       Subsystem 4 - Part No SW: 8K0 959 591 C    HW: 8K0 959 591
       Component: J394 PS240  H08 0043
       Revision: 00005001    Serial number: 94813028507104
       Component: TSG BF        H02 0510
       Revision:             Serial number: 0000098720192
       VCID: 4E92E54F19B6BF3577-801A
       Component: EPB-4         H01 0005
       Revision: --------    Serial number: 20000000431915
       ROD: EV_ParkiBrake_AU48.rod
       VCID: 3A7AB99FBD3E0395BB-806E
       Part No SW: 4G0 035 061 N    HW: 4G0 035 061
       Component: Radio U DAB   H60 0139
       Revision: AB001007    Serial number: 109D20E7915856
       Coding: 010103010000000001
       VCID: 285E73D75B928105DD-807C
       Part No SW: 8R2 035 666 E    HW: 8R2 035 666 C
       Component: H-BN-EU       H47 0793
       Revision: --------    Serial number: 206DZ0E7560780
       Coding: 110101010206A1ED41808F5E00000403E40100020000000000
       Subsystem 1 - Part No: 8R0 060 884 BK
       Component: EUR 2014  1703
       Component: DU7 High  H42 0104
       Serial number: A130DI0E3000809
       Subsystem 3 - Part No SW: 8T0 919 611 K    HW: 8T0 919 611 B
       Serial number: 00000001824649
       Component: CD-Database  5571
       Component: TSG HL        H01 0510
       Revision:             Serial number: 0000098922402
       Coding: 010C02204021210001
       VCID: 4682DD6FF1C67775CF-8012
       Part No SW: 8K9 827 851 C    HW: 8K9 827 851 C
       Component: J605  Master  H53 0330
       Revision: --------    Serial number: 8K9827851C
       VCID: 3E72B58FA9162FB587-806A
       Subsystem 1 - Part No SW: 8K9 827 852 C    HW: 8K9 827 852 C
       Component: J756  Slave  H53 0330
       Serial number: 8K9827852C
       Component: TSG HR        H01 0510
       Revision:             Serial number: 0000098919842
       Component: SAS-GEN 2     H06 0005
       Serial number: 140301200807
       ASAM Dataset: EV_SoundAc 002005
       ROD: N/A
       VCID: 72EA51BFA5CEBBD5B3-8026
    End-------------------------(Elapsed Time: 05:33)--------------------------
    Nov 2016
    Here's the error popup;
    If it matters, I think this is the first autoscan on this car since the recent update of VCDS software?
    Does it happen all the time? PC specs?
  7. Likes Uwe liked this post
    Nov 2016
    I've only done the one autoscan with this software and this PC combination on this car. But it didn't show any errors before with this PC and the older software.
    The PC is an old, small Samsung notebook; Intel Atom CPU N570 @1.66GHz with 2mb RAM on Win7. I do have a couple of more modern laptops with Win10 which I also use (the scan you linked to was done with a newer Win10 PC) but not tried with the new software yet.
    I generally use the Samsung though because it's a 10" screen so convenient size to be easily portable, has a huge battery life and is of low enough value that if I drop it, it doesn't matter too much. I have noticed that it takes longer to do an autoscan than a newer PC though.
  9. Likes Eric liked this post
  10. #7
    Well I did say a long time ago that if you insist on using an Atom under UDS with the ever-growing dataset that VAG is forcing down everyone's throat, a HEX-v2 or HEX-NET would be the way forward...
  11. #8
    Nov 2016
    OK, I'll do a scan with a better PC and get back to you.
  12. Likes Eric liked this post
  13. #9
    Nov 2016
    I've done some more scans, using 4 different PCs including the above mentioned Atom and all are OK this time. There was quite a difference in time taken though which I suppose is down to processor speed?
    From 5:38 slowest (mighty Atom) to 4:07 fastest (Pentium i7), all scans show the 'missing' ROD file.
    Tuesday,13,February,2018,17:52:05:24986
    VCDS Version: 18.1.0.2 (x64)
              62 6D 72 A9
       Revision: --X07---
       Revision: --H03---
       Coding: 291DCC01
       Coding: 6624028000
       Coding: 00FD11
       Coding: 02005D
       Coding: 000037
       Coding: 80CF07FF00
    End-------------------------(Elapsed Time: 04:07)--------------------------
    Happy to know it's not a car problem.
  14. Likes Uwe liked this post
  15. #10
    Quote Originally Posted by Dukedesmo View Post
    Yup. Processor speed can be a limiting factor in how fast VCDS can load the data required for each module.
    Sounds like you encountered a one-time, sporadic communications glitch on the first scan. Part of that module's data identifier either didn't get sent by the car or got dropped somewhere before it got to VCDS, so with an incomplete identifier, VCDS was unable to find the corresponding data.
  16. Likes Dukedesmo liked this post
