Monday,12,February,2018,18:55:28:12979
VCDS Version: 18.1.0.2 (x64) HEX-V2 CB: 0.4411.4
VIN: WUABWGFF0J1902254 License Plate:
Chassis Type: FF-AU37 (3Q0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 29 2B 39 3C 42 44 47
4B 52 5F 6C BB BC CF D6 D7
VIN: WUABWGFF0J1902254 Mileage: 6672km-4145miles
Address 01: Engine (------DAZA) Labels:. 07K-907-309-V1.clb
Part No SW: 8V0 907 404 G HW: 07K 907 309 E
Component: 2.5l R5/4V TF H22 0002
Revision: 53H22000
Coding: 0A250032242600053620
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM25TFS0118V0907404G 001002
ROD: EV_ECM25TFS0118V0907404G.rod
VCID: 3D27C4EE1DF285DF433-8068
28218 - Control Module for Exhaust Flap 2
P14AC 00 [096] - Mechanical Malfunction
Mileage: 5038 km
Date: 2018.01.17
Time: 16:53:33
Engine speed: 2214.50 /min
Normed load value: 33.3 %
Vehicle speed: 118 km/h
Coolant temperature: 93 °C
Intake air temperature: 4 °C
Voltage terminal 30: 14.620 V
Unlearning counter according OBD: 19
Engine status: COENG_RUNNING
19813 - Control Module for Exhaust Flap
P14AB 00 [096] - Mechanical Malfunction
Mileage: 5043 km
Date: 2018.01.17
Time: 16:57:11
Engine speed: 1615.00 /min
Normed load value: 13.7 %
Vehicle speed: 32 km/h
Coolant temperature: 90 °C
Intake air temperature: 6 °C
Voltage terminal 30: 14.540 V
17022 - Fuel/Air Mixture Cylinder 2
P219D 00 [101] - Unbalanced
Mileage: 6350 km
Date: 2018.02.09
Time: 09:10:35
Engine speed: 2137.00 /min
Normed load value: 38.4 %
Vehicle speed: 114 km/h
Coolant temperature: 92 °C
Intake air temperature: -3 °C
Voltage terminal 30: 14.560 V
Part No SW: 0DL 300 012 H HW: 0GC 927 711 G
Component: GSG DQ500 H06 2112
Revision: 00H06V07
VCID: 2E05F3A2C0946E47CA9-807A
Part No SW: 8V0 614 517 C HW: 8V0 614 517 C
Component: ESC H25 0621
Revision: 00000000 Serial number: 62307000000227
Coding: 2EAA6B7DD4990BAB89930B6981956974D62BD091D0819636024150D4828812
ASAM Dataset: EV_Brake1UDSContiMK100IPB 070001
ROD: EV_Brake1UDSContiMK100IPB_070.rod
VCID: 392FD0FE09DAB9FF6FB-806C
Part No SW: 5Q0 959 435 C HW: 5Q0 959 435
Component: VWKESSYMQB 021 0803
Revision: 00021000 Serial number: 0452480752
Coding: 030C0C
ASAM Dataset: EV_KessyHellaMQBAB 002020
VCID: 3C21C9EA06E88CD774D-8068
Part No SW: 8V0 820 043 Q HW: 8V0 820 043 Q
Component: AC Automat H03 0130
Revision: 20002000 Serial number: 00000001333653
Coding: 03000015010000000000000000001400
ASAM Dataset: EV_AirCondiFrontVaAU37X 008022
VCID: 40D9BD1A6A00E837285-8014
Subsystem 1 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H02 0007
Serial number: 0D6095C800PAG0MUFU03
Part No SW: 5Q0 937 085 BN HW: 5Q0 937 085 BF
Component: BCM MQBAB MNA H36 0253
Serial number: 01001724200042
ROD: EV_BCMBOSCH_018.rod
VCID: 06556B0208A40607529-8052
Subsystem 1 - Part No SW: 8V1 955 119 C HW: 8V1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 170725 043 0585
Serial number: 170818090553
Coding: 0A47F7
Component: G397_RLFS H06 0004
Serial number: 62968853
Coding: 00006C
Subsystem 3 - Part No SW: 8V0 941 531 AR HW: 8V0 941 531 AR
Component: E1 - LDS MQB H06 0032
Serial number: 24 04 2017 00000811
Serial number: 00000000000039179985
Sun Roof:
Component: J245 PS73.404 H03 0004
Serial number: 0000FST001QUEYX00000
Coding: 101F00
Part No SW: 5QA 919 294 B HW: 5QA 919 294
Serial number: 000308418617243
Coding: 0470155011
ROD: EV_EPHVA18AU3700000_009_AU37.rod
VCID: 4BC39A3653463B6FCD7-801E
Address 14: Susp. Elect. (J250) Labels: 8V0-907-376.clb
Part No SW: 8V0 907 376 G HW: 8V0 907 376 F
Component: DAEMPFUNGS-SG H11 0082
Serial number: 010817072
ASAM Dataset: EV_AudiMagneRide 002008
ROD: EV_AudiMagneRide.rod
VCID: 45D7AC0E7522CD1F1B3-8010
Serial number: 003GCR09ED3B
Coding: 9DCCFCC0008000005000001AC24800000065
VCID: 47CBA6064F2EDF0FE9F-8012
Belt Pretensioner left:
Serial number: 34230167A30081751573
Coding: 333135
Belt Pretensioner right:
Serial number: 34230168A29081740240
Coding: 333135
Occupant Detection:
Serial number: 694000000000001MT8XQ
Coding: 303337
Subsystem 4 - Part No SW: ----------- HW: 480 002 808 17
Serial number: 3570000000075698472K
Subsystem 5 - Part No SW: ----------- HW: 480 002 808 17
Serial number: 3580000000005698472E
Subsystem 6 - Part No SW: ----------- HW: 480 402 808 17
Serial number: 3510001B72625E3546F4
Subsystem 7 - Part No SW: ----------- HW: 480 402 808 17
Serial number: 3520001B52625E32F11Z
Subsystem 8 - Part No SW: ----------- HW: 480 402 607 17
Serial number: 3550002BB24F3851C203
Front Sensor Passenger:
Subsystem 9 - Part No SW: ----------- HW: 480 402 607 17
Serial number: 3560002BB24F3852302$
Part No SW: 8V0 953 521 KK HW: 5Q0 953 549 E
Revision: -------- Serial number: 03091704221376
Coding: 2018
VCID: 0D47542E6DD2755F133-8058
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI2
Part No SW: 8V0 920 890 A HW: 8V0 920 890 A
Component: FBenUSA H16 0066
Coding: 086D18533B88CF050204EC041800001000000000
ASAM Dataset: EV_DashBoardFPKAU37X 001027
ROD: EV_DashBoardFPKAU37X.rod
VCID: 3B23CAF603E68BEF7D7-806E
Part No SW: 3Q0 907 530 G HW: 3Q0 907 530 C
Component: GW MQB High 518 5304
Serial number: 22081710800621
Coding: 03010004340860005B00802EB80B00000001010000000000000000000000
ROD: EV_GatewNF_VW48.rod
VCID: 3333E2D62BB643AFA57-8066
Subsystem 2 - Part No SW: 8W0 951 523 F HW: 8W0 951 523 F
Component: J453 MFL H04 0002
Serial number: 20170824103355 21360
Subsystem 3 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 0746025104
Part No SW: 0CQ 907 554 K HW: 0CQ 525 130
Component: Haldex4Motion H52 7762
Serial number: HA1-00021.06.17
Coding: 0601
VCID: 4DC7942EAD52355FD33-8018
Address 29: Left Light (J1018) Labels: 8S0-907-397.clb
Part No SW: 8S0 907 397 D HW: 8S0 907 397 D
Component: LCM_MQB H06 0017
VCID: 42DDB712640CFA273E1-8016
Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 17000240102007
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 3431E1CA2EB84497BCD-8060
Address 39: Right Light (J1023) Labels: 8S0-907-397.clb
Address 3C: Lane Change (J769) Labels:| 3Q0-907-566.clb
Part No SW: 3Q0 907 566 F HW: 3Q0 907 566
Component: MRR1Rear H21 0610
Revision: --------
Coding: 040002
Component: TSG FS 020 0041
Serial number: 240817EHN18355
Coding: 005F1B205C00048000000002
VCID: 43D3B2167B16F32F357-8016
Part No SW: 3Q0 909 144 K HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 506 5072
Coding: 8106
ROD: EV_SteerAssisMQB_013.rod
VCID: 3A2DCFF20CDCB2E7661-806E
Address 47: Sound System (J525) Labels:| 81A-035-466.clb
Part No SW: 81A 035 466 B HW: 81A 035 466
Component: MIB2_amp_P_A3 H10 0440
Revision: 00000001 Serial number: AUZ8ZAH5F00PMJG
Coding: 0173030000AAAA2AAA0000010000
ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
ROD: EV_AMPMst16C9Gen2ALPI.rod
VCID: 2411118A9E58D4172CD-8070
Address 4B: Multifunc. Module (J745) Labels:* None
Part No SW: 3Q0 907 338 HW: 3Q0 907 338
Component: FCM MQB Low 002 0286
Serial number: 11081710801466
Coding: 000000050100143206112300040000000000000000000000000000000000
ROD: EV_MultiModulContiVW48X.rod
VCID: 72BD27D2142C0AA76E1-8026
Component: TSG BFS 020 0041
Serial number: 180817EHI30481
Coding: 005F13205E00048000000002
Address 5F: Information Electr. (J794) Labels:* Redir Fail!
Part No SW: 8V1 035 880 B HW: 8V1 035 880
Component: MU-P-LNS-US 054 1110
Serial number: A702I0H2503067
Coding: 017361020000000011220002041A00102F0028E5017001047E
Subsystem 1 - Part No SW: V03 959 801 PS HW: -----------
Component: NAR 2018 --- 0063
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9H1Y04WR5
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8V0 919 614 BK HW: 8V0 919 614 BK
Component: ControlUnit_H H85 0855
Serial number: ALJAL113071700050786
Component: Gracenote2 --- 3012
Component: RVC Compact H12 0231
Coding: 0273010102002001400040
ROD: EV_CamSysRVRVCPANAMQBAB.rod
Part No SW: 5Q0 959 595 E HW: 5Q0 959 595 B
Component: TSG HFS 020 0041
Serial number: 210817EHK0964C
Coding: 000E13204000048000000002
Component: TSG HBFS 020 0041
Serial number: 210817EHK09347
Address CF: Lane Chge Asst 2 (J770) Labels:. 3Q0-907-566.clb
Part No SW: 3Q0 907 590 F HW: 3Q0 907 590
Revision: --------
Coding: 040002
ASAM Dataset: EV_RearRadarS2BoschVW48X 001007
VCID: 3829D5FA32D0A0F7905-806C
Part No SW: 7PP 941 572 AC HW: 7PP 941 572 A
Component: LED1L H09 0008
VCID: 176B36465F0E8F8FB9F-8042
Component: LED1R H09 0008
End----------(Elapsed Time: 01:52, VBatt start/end: 12.1V/12.1V)-----------
