Results 1 to 8 of 8
Thread: RS3 DRLs
    Feb 2018
    RS3 DRLs
    I have a 2018 RS3 and am trying to alter the DRLs. The usual stuff - set them so they don't dim when the headlights are on, don't turn off when the turn signals on, set them in the Scandinavian settings so the tails are used as DRLs, too. There's plenty of info out there about how to do this on other models, and the channel names are usually more or less the same. However on my car, I can't find any channel names under central electronics that seem like they might control any of these. I've also played around with some of long coding suggested for other models and they don't appear to work the same. Does anyone have any idea how I might be able to get this done?
    Please post an Auto-Scan so people can see what this car is made of.
    A map of the adaptation channels in the BCM might be useful as well.
    Quote Originally Posted by The Wiry Irishman View Post
    Wiry: Hi and welcome to the forum! While you are getting the data ready for Uwe's suggestion, here's a bit of general information that might be a useful context in answering your question.
    As you are probably aware, your RS3 (very nice car!) was built on a MQB platform. One of the many changes that happened as part of the transfer of the "3" series Audi to this platform was the introduction of "leuchte-sets" to manage the operation of exterior lights. Leuchte-sets are a bunch of linked adaptation channels with the term "leuchte" in the Parent name. Each Leuchte-set has 19 x channels and each Leuchte-set is associated with a pin on the BCM (read, a lamp on the exterior of the car).
    So whereas in the past, you might have engaged/disabled a lamp via a long coding software switch, on many (all?) MQB models, this is now done by "programming" Leuchte-sets settings. Unfortunately, the naming convention for Leuchte-sets is not evocative of the lamp position on the car - so you won't find the term "Left, Front, DRL" (say) in the channel name. To find which Leuchte-set is associated with each lamp, a WD is needed to identify which pin number on the BCM that lamp is connected-to. The Leuchte-set has this pin number in its title.
    The reason why Uwe has asked for an auto scan is so that we can understand the equipment in your car . The reason for Uwe's request for an Admap is so we can see how the Leuchte-sets are programmed. With these two pieces of information the DNA of your car is exposed!!
    VW Golf MkVII (103TSI) my13
  4. Likes Uwe, iichel, mattylondon liked this post
    Verified VCDS User DJAlix's Avatar
    Apr 2015
    London, United Kingdom
    The facelift MY18 A3/S3/RS3 vehicles now have their Daytime Running Light behaviour "hardwired" with limited adaptation channel control
    VAG Car Coding
    Adaptation | Coding | Diagnostic | Retrofit - London, United Kingdom
    Authorised VW Group Services Provider and Independent Repairer
    @vagcarcoding
  6. Likes PetrolDave, DV52 liked this post
    Dec 2016
    DE
    The car might habe LCM modules which control the front lights. Leuchte-sets do not apply for them and it is currently unknown, if similar possibilities exist in those modules.
  8. Likes DV52 liked this post
  9. #6
    ^^^ TBAx/DJAlix - thanks for the advice. I guess the admap/autoscan reports will tell all!
  10. #7
    Feb 2018
    Thanks for the replies everyone!
    My autoscan is below. I didn't have time to run an adaptation channel map, but hopefully I can do that on Thursday.
    Monday,12,February,2018,18:55:28:12979
    VCDS Version: 18.1.0.2 (x64)  HEX-V2 CB: 0.4411.4
    VIN: WUABWGFF0J1902254   License Plate:
    Chassis Type: FF-AU37 (3Q0)
    Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 29 2B 39 3C 42 44 47
              4B 52 5F 6C BB BC CF D6 D7
    VIN: WUABWGFF0J1902254   Mileage: 6672km-4145miles
    Address 01: Engine (------DAZA)       Labels:. 07K-907-309-V1.clb
       Part No SW: 8V0 907 404 G    HW: 07K 907 309 E
       Component: 2.5l R5/4V TF H22 0002
       Revision: 53H22000
       Coding: 0A250032242600053620
       Shop #: WSC 06385 790 00016
       ASAM Dataset: EV_ECM25TFS0118V0907404G 001002
       ROD: EV_ECM25TFS0118V0907404G.rod
       VCID: 3D27C4EE1DF285DF433-8068
    28218 - Control Module for Exhaust Flap 2
              P14AC 00 [096] - Mechanical Malfunction
                        Mileage: 5038 km
                        Date: 2018.01.17
                        Time: 16:53:33
                        Engine speed: 2214.50 /min
                        Normed load value: 33.3 %
                        Vehicle speed: 118 km/h
                        Coolant temperature: 93 C
                        Intake air temperature: 4 C
                        Voltage terminal 30: 14.620 V
                        Unlearning counter according OBD: 19
                        Engine status: COENG_RUNNING
                        Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
    19813 - Control Module for Exhaust Flap
              P14AB 00 [096] - Mechanical Malfunction
                        Mileage: 5043 km
                        Date: 2018.01.17
                        Time: 16:57:11
                        Engine speed: 1615.00 /min
                        Normed load value: 13.7 %
                        Vehicle speed: 32 km/h
                        Coolant temperature: 90 C
                        Intake air temperature: 6 C
                        Voltage terminal 30: 14.540 V
    17022 - Fuel/Air Mixture Cylinder 2
              P219D 00 [101] - Unbalanced
                        Mileage: 6350 km
                        Date: 2018.02.09
                        Time: 09:10:35
                        Engine speed: 2137.00 /min
                        Normed load value: 38.4 %
                        Vehicle speed: 114 km/h
                        Coolant temperature: 92 C
                        Intake air temperature: -3 C
                        Voltage terminal 30: 14.560 V
       Part No SW: 0DL 300 012 H    HW: 0GC 927 711 G
       Component: GSG DQ500     H06 2112
       Revision: 00H06V07
       VCID: 2E05F3A2C0946E47CA9-807A
       Part No SW: 8V0 614 517 C    HW: 8V0 614 517 C
       Component: ESC           H25 0621
       Revision: 00000000    Serial number: 62307000000227
       Coding: 2EAA6B7DD4990BAB89930B6981956974D62BD091D0819636024150D4828812
       ASAM Dataset: EV_Brake1UDSContiMK100IPB 070001
       ROD: EV_Brake1UDSContiMK100IPB_070.rod
       VCID: 392FD0FE09DAB9FF6FB-806C
       Part No SW: 5Q0 959 435 C    HW: 5Q0 959 435
       Component: VWKESSYMQB    021 0803
       Revision: 00021000    Serial number: 0452480752
       Coding: 030C0C
       ASAM Dataset: EV_KessyHellaMQBAB 002020
       VCID: 3C21C9EA06E88CD774D-8068
       Part No SW: 8V0 820 043 Q    HW: 8V0 820 043 Q
       Component: AC Automat    H03 0130
       Revision: 20002000    Serial number: 00000001333653
       Coding: 03000015010000000000000000001400
       ASAM Dataset: EV_AirCondiFrontVaAU37X 008022
       VCID: 40D9BD1A6A00E837285-8014
       Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
       Component: AQ_Hum_Sensor  H02 0007
       Serial number: 0D6095C800PAG0MUFU03
       Part No SW: 5Q0 937 085 BN    HW: 5Q0 937 085 BF
       Component: BCM MQBAB MNA H36 0253
       Serial number: 01001724200042
       ROD: EV_BCMBOSCH_018.rod
       VCID: 06556B0208A40607529-8052
       Component: WWS371 170725  043 0585
       Serial number:         170818090553
       Coding: 0A47F7
       Serial number: 62968853
       Coding: 00006C
       Light switch:
       Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
       Component: E1 - LDS MQB  H06 0032
       Serial number: 24 04 2017  00000811
       Serial number: 00000000000039179985
       Sun Roof:
       Component: J245 PS73.404  H03 0004
       Serial number: 0000FST001QUEYX00000
       Coding: 101F00
       Serial number: 000308418617243
       Coding: 0470155011
       ROD: EV_EPHVA18AU3700000_009_AU37.rod
       VCID: 4BC39A3653463B6FCD7-801E
       Part No SW: 8V0 907 376 G    HW: 8V0 907 376 F
       Component: DAEMPFUNGS-SG H11 0082
       Serial number:       010817072
       ASAM Dataset: EV_AudiMagneRide 002008
       ROD: EV_AudiMagneRide.rod
       VCID: 45D7AC0E7522CD1F1B3-8010
       Serial number: 003GCR09ED3B
       Coding: 9DCCFCC0008000005000001AC24800000065
       VCID: 47CBA6064F2EDF0FE9F-8012
       Belt Pretensioner left:
       Component: BeltPretRevFL  H37 0350
       Serial number: 34230167A30081751573
       Coding: 333135
       Belt Pretensioner right:
       Component: BeltPretRevFR  H37 0350
       Serial number: 34230168A29081740240
       Coding: 333135
       Occupant Detection:
       Subsystem 3 - Part No SW: 5C6 959 339 B    HW: 5C6 959 339 B
       Serial number: 694000000000001MT8XQ
       Coding: 303337
       Subsystem 4 - Part No SW: -----------    HW: 480 002 808 17
       Serial number: 3570000000075698472K
       Subsystem 5 - Part No SW: -----------    HW: 480 002 808 17
       Serial number: 3580000000005698472E
       Subsystem 6 - Part No SW: -----------    HW: 480 402 808 17
       Serial number: 3510001B72625E3546F4
       Subsystem 7 - Part No SW: -----------    HW: 480 402 808 17
       Serial number: 3520001B52625E32F11Z
       Subsystem 8 - Part No SW: -----------    HW: 480 402 607 17
       Serial number: 3550002BB24F3851C203
       Front Sensor Passenger:
       Subsystem 9 - Part No SW: -----------    HW: 480 402 607 17
       Serial number: 3560002BB24F3852302$
       Part No SW: 8V0 953 521 KK    HW: 5Q0 953 549 E
       Revision: --------    Serial number: 03091704221376
       Coding: 2018
       VCID: 0D47542E6DD2755F133-8058
    Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI2
       Part No SW: 8V0 920 890 A    HW: 8V0 920 890 A
       Component: FBenUSA       H16 0066
       Coding: 086D18533B88CF050204EC041800001000000000
       ASAM Dataset: EV_DashBoardFPKAU37X 001027
       ROD: EV_DashBoardFPKAU37X.rod
       VCID: 3B23CAF603E68BEF7D7-806E
       Part No SW: 3Q0 907 530 G    HW: 3Q0 907 530 C
       Component: GW MQB High   518 5304
       Serial number: 22081710800621
       Coding: 03010004340860005B00802EB80B00000001010000000000000000000000
       ROD: EV_GatewNF_VW48.rod
       VCID: 3333E2D62BB643AFA57-8066
       Subsystem 2 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
       Component: J453 MFL  H04 0002
       Serial number: 20170824103355 21360
       Subsystem 3 - Part No SW: 8S0 915 181 C    HW: 8S0 915 181 C
       Serial number: 0746025104
       Part No SW: 0CQ 907 554 K    HW: 0CQ 525 130
       Component: Haldex4Motion H52 7762
       Serial number: HA1-00021.06.17
       Coding: 0601
       VCID: 4DC7942EAD52355FD33-8018
    Address 29: Left Light (J1018)       Labels: 8S0-907-397.clb
       Part No SW: 8S0 907 397 D    HW: 8S0 907 397 D
       Component: LCM_MQB       H06 0017
       ASAM Dataset: EV_LCMLeftCONTIAU426 001009
       ROD: EV_LCMLeftCONTIAU426_VW41.rod
       VCID: 42DDB712640CFA273E1-8016
       Revision: 00000000    Serial number: 17000240102007
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB.rod
       VCID: 3431E1CA2EB84497BCD-8060
    Address 39: Right Light (J1023)       Labels: 8S0-907-397.clb
       ASAM Dataset: EV_LCMRightCONTIAU426 001009
    Address 3C: Lane Change (J769)       Labels:| 3Q0-907-566.clb
       Part No SW: 3Q0 907 566 F    HW: 3Q0 907 566
       Component: MRR1Rear      H21 0610
       Revision: --------
       Coding: 040002
       Serial number: 240817EHN18355
       Coding: 005F1B205C00048000000002
       VCID: 43D3B2167B16F32F357-8016
       Coding: 8106
       ROD: EV_SteerAssisMQB_013.rod
       VCID: 3A2DCFF20CDCB2E7661-806E
       Part No SW: 81A 035 466 B    HW: 81A 035 466
       Component: MIB2_amp_P_A3 H10 0440
       Revision: 00000001    Serial number: AUZ8ZAH5F00PMJG
       Coding: 0173030000AAAA2AAA0000010000
       ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
       ROD: EV_AMPMst16C9Gen2ALPI.rod
       VCID: 2411118A9E58D4172CD-8070
       Serial number: 11081710801466
       Coding: 000000050100143206112300040000000000000000000000000000000000
       VCID: 72BD27D2142C0AA76E1-8026
       Serial number: 180817EHI30481
       Coding: 005F13205E00048000000002
    Address 5F: Information Electr. (J794)       Labels:* Redir Fail!
       Part No SW: 8V1 035 880 B    HW: 8V1 035 880
       Component: MU-P-LNS-US   054 1110
       Serial number: A702I0H2503067
       Coding: 017361020000000011220002041A00102F0028E5017001047E
       Subsystem 1 - Part No SW: V03 959 801 PS    HW: -----------
       Component: NAR 2018  --- 0063
       Component: DU High  H49 0014
       Serial number: AUZ8Z9H1Y04WR5
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 8V0 919 614 BK    HW: 8V0 919 614 BK
       Component: ControlUnit_H  H85 0855
       Serial number: ALJAL113071700050786
       Component: Gracenote2  --- 3012
       Coding: 0273010102002001400040
       ROD: EV_CamSysRVRVCPANAMQBAB.rod
       Serial number: 210817EHK0964C
       Coding: 000E13204000048000000002
       Serial number: 210817EHK09347
    Address CF: Lane Chge Asst 2 (J770)       Labels:. 3Q0-907-566.clb
       Part No SW: 3Q0 907 590 F    HW: 3Q0 907 590
       Revision: --------
       Coding: 040002
       VCID: 3829D5FA32D0A0F7905-806C
       Part No SW: 7PP 941 572 AC    HW: 7PP 941 572 A
       Component: LED1L         H09 0008
       VCID: 176B36465F0E8F8FB9F-8042
       Component: LED1R         H09 0008
    End----------(Elapsed Time: 01:52, VBatt start/end: 12.1V/12.1V)-----------
  11. #8
    Jun 2017
    Model year 2018 have the Multifunc control unit (4B) where light commands like DLR or Turn signals are received from the BCM via CAN Bus (!!). This informtion is forwarded also via CAN Bus to the light control modules in each headlight.
    No more "Leuchte" manipulation in BCM possible regarding such light functions.
  12. Likes DJAlix liked this post
