Results 1 to 10 of 10
Thread: ABS coding problem, T4 TDI swap
    Nov 2015
    Pennsylvania
    I am swapping a European 5cyl TDI (engine code AJT) into a U.S. Eurovan. It was originally a VR6 AXK with an auto trans. The cluster, immobilzer, and key pill were swapped to match the ecu. It's running great on diesel now, and control units are mostly happy except for ABS. I need the correct login and coding for the ABS system with EPC. I can get PR numbers for either vin if needed. Any help would be greatly appreciated.
    vin for the VR6 van: WV2KB47002H067736
    vin for the TDI van: WV1ZZZ70Z3H101278
    Monday,12,February,2018,11:51:54:45387
    VCDS Version: 18.1.0.2 (x64)  HEX-NET CB: 0.4411.4
    VIN: WV1ZZZ70Z3H101278   License Plate:
    Mileage: 312980km-194476mi   Repair Order:
    Chassis Type: 70 (7D - VW Transporter/Multivan (1996 > 2004))
    Scan: 01 02 03 08 15 17 18 19 22 25 35 37 56
    VIN: WV1ZZZ70Z3H101278   Mileage: 312980km-194476miles
       Part No: 074 906 018 AK
       Component: 2,5l R5 EDC 0000SG  3905
       Coding: 00002
       Shop #: WSC 02757
       VCID: 5F8E493ADF8CD7BDEC-4B7A
       WV1ZZZ70Z3H101278     VWZ1Z0B2287967
    17849 - EGR Valve (N18)
                P1441 - 35-10 - Open Circuit or Short to Ground - Intermittent
    19561 - Valve for Intake Manifold Flap (N239)
                P3105 - 35-10 - Open or Short to Ground - Intermittent
    Readiness: N/A
    Address 03: ABS Brakes        Labels: 7D0-907-379.lbl
       Part No: 7D0 907 379 E
       Component: ESP 5.3 T4 FRONT    V37
       Coding: 06732
       Shop #: WSC 12345
       VCID: 3326F58A038423DD78-5160
    18256 - Please check DTC Memory of Engine Controller
                P1848 - 35-00 -
                36-00 - Open Circuit
    01203 - Electrical Connection between ABS and Instrument Cluster
                35-00 -  -
       Part No: 7D0 907 040
       Component: CLIMATRONIC         0004
       Coding: 00032
       Shop #: WSC 02743
       VCID: 5F8E493ADF8CD7BDEC-25B6
    Address 15: Airbags        Labels: 1J0-909-60x-VW3.lbl
       Part No: 1J0 909 603 BM
       Component: AIRBAG VW3 -        V04
       Coding: 16973
       Shop #: WSC 02743
       VCID: 75A20B924D707DED96-4B7A
    Address 17: Instruments        Labels: 7D0-920-xxx-17.lbl
       Part No: 7D0 920 903 B
       Component: T4-KOMBIINSTR. VDO V26
       Coding: 01252
       Shop #: WSC 02743
       VCID: 240406D6B66AB465F1-5160
       Part No: 6N0 909 901
       Coding: 00002
       Shop #: WSC 02743
       VCID: 70AC3A86321258C545-5160
    Address 25: Immobilizer        Labels: 6X0-953-257.lbl
       Part No: 6X0 953 257
       Component: IMMO                0008
       Coding: 00001
       VCID: 7DB213B2754025ADDE-4B3C
    Address 35: Centr. Locks        Labels: 7D0-959-800.lbl
       Part No: 7D0 959 800 C
       Component:    Funksteuergerát  0001
       Coding: 00001
       Shop #: WSC 02743
       VCID: 2D12E3F2E5A0752D2E-4B3C
    Address 56: Radio        Labels: 1J0-035-18x-56.lbl
       Part No: 1J0 035 180 B
       Component:  Radio DE2         0005
       Coding: 09400
       Shop #: WSC 02743
       VCID: 1E70343E98069EB5A7-51F2
    End----(Elapsed Time: 02:27, VBatt start/end: 14.4V/14.4V. VIgn 0.0V)------
    Aug 2016
    Switzerland
    can you retrieve the coding from the donor cars ABS?
    -= How to post an autoscan -=- How to post an autoscan =-= iichels Polo 6R =-= Don't follow me, I'm lost too =-
    Nov 2015
    Pennsylvania
    Thanks for the quick response. I'm doing the swap for a customer and he got the parts. I understand he bought this stuff from a salvage yard in UK. It's a good idea so I will pursue it, but I'm not expecting much.
    I have a fuzzy recollection that the old Bentley CD or paper manual for the Eurovan had a fairly comprehensive login/coding table for the ABS modules used in these vans -- far more comprehensive than it needed to be for the NAR market. Unfortunately, I can't find either one anymore.
    I've gone looking (via Google) for both the ECU and the ABS part numbers. Both seem rather rare and I can't find a single scan with that ECU part number that also shows the ABS.
    Nov 2015
    Pennsylvania
    I checked it out through erwin and there is a bit more than what is needed for NAR market. There is only two engine codes listed: AXK and ACV. I tried the closest ones for ACV. (you can see in the autoscan) It accepts but still throws the "incorrect coding". I have Parts Link 24 which shows that EPC could have been an option under the TDI vin. Do you think the paper manual has more than erwin?
    Well, I did say my memory of this is somewhat fuzzy, but VW has been known to strip stuff out of the manuals over time that isn't "necessary" in their view.
  7. #7
    Nov 2015
    Pennsylvania
    I realized that if I unplug the ecu the "incorrect coding" fault disappears in the ABS. Is it safe to assume that the ecu has everything to do with the ABS unit accepting the coding? The charts list coding by the pr code options, but the ABS system couldn't know if you got the pr codes correct. I'm thinking about making a list of all the coding option that I found so far, and posting it for other's reference. Unless someone knows of a place such a list has already been created.
  8. #8
    Yes, there's some kind of hand-shake between the ABS and the ECU.
  9. #9
    Aug 2016
    Switzerland
    I could imagine, for example, a different build-up of brake booster vacuum between a petrol and diesel engine could already confuse an ABS.
  10. Likes Uwe liked this post
  11. #10
    Dallas (McKinney) ,TX ,USA
    The problem is that NAR Euro van came with only Petrol engine and Auto transmission, and ABS software was never meant to be for TDI.
    So I doubt even if you have right coding you will be able to re code ABS module.
    I know someone who put Manual transmission in VR6 Euro van and never was able to re-code ABS for manual transmission.
    Immobilizer/ECU
    Mk6 cluster in Mk5 -CLIK
    email : marinmm2001@yahoo.com
  12. Likes Uwe liked this post
