Results 1 to 7 of 7
Thread: Bulb out error audi a5 2011
    Nov 2016
    I have got some led bulbs for my fog lights on my A5 Audi...........they give bulb out/error ........is there any way of disabling with vcds ?
    Nov 2016
    Wednesday,05,April,2017,10:44:36:07086
    VCDS Version: 17.1.3.0
    Data version: 20170203 DS267.2
    VIN: WAUZZZ8F4BN016585   License Plate: IAZ A5
    Mileage: 106550km-66207mi   Repair Order:
    Chassis Type: 8F (8T0)
    Scan: 01 03 05 08 09 10 15 16 17 19 26 42 46 52 53 55 56 5F 62 72
    VIN: WAUZZZ8F4BN016585   Mileage: 106550km-66207miles
    Address 01: Engine (J623-CAHA)       Labels: 03L-906-019-CAG.clb
       Part No SW: 03L 906 022 NP    HW: 03L 906 019 AL
       Component: R4 2.0l TDI   H34 9978
       Revision: 25H34---
       Coding: 22194012232503080000
       Shop #: WSC 53439 002 1048576
       ASAM Dataset: EV_ECM20TDI03L906022NP A02012
       ROD: EV_ECM20TDI03L906022NP.rod
       VCID: 0005934E9B18AD41E9-8054
    4901 - Engine Mount Solenoid Valves (N144/N145)
              P1588 00 [039] - Open Circuit
                        Mileage: 106557 km
                        Date: 2017.04.05
                        Time: 10:38:15
                        Coolant temperature: 11 C
                        Intake air temperature: 11 C
                        Voltage terminal 30: 12.160 V
                        EM Dmp st Ps 0-Bit 0: 00000000
    4640 - Engine Oil Temp. Sensor (G8)
              P0197 00 [039] - Signal too Low
                        Mileage: 106557 km
                        Date: 2017.04.05
                        Time: 10:38:17
                        Intake air temperature: 10 C
                        Fl Sys dvol Fl Cons All Tot: 0.00 l/h
                        Engine oil temperature: 22.3 C
                        Oil warning threshold: 31.500 mm
                        Control Module temperature: 13.6 C
                        Oil fill level: 120.000 mm
                        Ambient temperature: 6.5 C
                        Fuel temperature: 11.4 C
    Address 03: ABS Brakes (J104)       Labels: 8K0-907-379-V1.clb
       Part No SW: 8K0 907 379 BF    HW: 8K0 907 379 BF
       Component: ESP8 front    H04 0030
       Coding: 160504
       Shop #: WSC 02391 823 56573
       VCID: 7EF9EDB6E9ECDBB19B-802A
       Part No SW: 8K0 907 064 CP    HW: 8K0 907 064 CP
       Component: BCM2 2.0      H05 0435
       Coding: 033300
       Shop #: WSC 02399 823 56573
       VCID: 0005934E9318AD41E9-8054
       Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
       Component: FBSAUDIB8 IDG  H60 0072
       Serial number: 0811000023921017
       Serial number: 2311000031755008
       Part No SW: 8T2 820 043 AG    HW: 8T2 820 043 AG
       Component: KLIMA 3 ZONEN H08 0180
       Revision: D1000000    Serial number: 01120320111037
       Coding: 34370000
       VCID: 77F7F892C6D6EAF9D8-8022
    00898 - Control Circuit A/C compressor
                        Fault Frequency: 16
                        Reset counter: 207
                        Mileage: 104859 km
                        Date: 2017.02.04
                        Time: 13:09:15
                        Current: 0.600 A
                        Current: 0.000 A
                        Voltage: 13.60 V
       Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
       Component: BCM1 1.0      H30 0392
       Revision: 10030001    Serial number: 00000000978631
       Coding: 260050914034AF000009000300005D5D411D038806010141000000
       VCID: 3C7D27BEBF7009A1F5-8068
       Subsystem 1 - Part No SW: 8F2 955 119     HW: 8K2 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 230211  H06 0021
       Serial number: SWF11020235106
       Coding: 00FD11
       Component: RLS  H04 0003
       Serial number: 11313691
       Coding: 02562A
       Component: E1 - LDS  H03 0031
       Serial number: 00000000001902110631
    01232 - A/C Compressor Regulator Valve (N280)
                        Fault Frequency: 15
                        Reset counter: 197
                        Mileage: 104261 km
                        Date: 2017.01.22
                        Time: 13:45:00
    Address 10: Park/Steer Assist (J446)       Labels: 8K0-919-475.clb
       Part No SW: 8K0 919 475 T    HW: 8P0 919 475 M
       Component: PARKHILFE 4K  H01 0080
       Revision: 11001001    Serial number: 36891106348599
       Coding: 100001
       VCID: 4A917166E5A4A71177-801E
    Address 15: Airbags (J234)       Labels: 8F0-959-655.clb
       Part No SW: 8F0 959 655 C    HW: 8F0 959 655 C
       Component: AirbagVW-AU10 H11 0430
       Serial number: 003JND702EUP
       Coding: 30413635353130303030554A305238463053
       Shop #: WSC 02135 785 00200
       ASAM Dataset: EV_AirbaAU10SMEAU485 001004
       ROD: EV_AirbaAU10SMEAU485.rod
       VCID: 38753BAE8348258111-806C
       Serial number: 6334MSME5C740F0CS
       Serial number: 6344MSME5C633314B
       Serial number: 6352QSME081D3568L
       Serial number: 6362QSME06000A543
       Serial number: 63732SME1F074C421
       Serial number: 63832SME1F07357E9
       Component: Lenks.Modul   H17 0014
       Revision: --------    Serial number: 90372KC60000T
       Coding: 000016
       VCID: 3D7B2ABAA46A00A9C2-8068
       Component: E221 - MFL  H02 0010
    Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
       Part No SW: 8T0 920 983 B    HW: 8T0 920 983 B
       Component: KOMBIINSTR.   H41 0258
       Revision: 00000000    Serial number: EHY20M63C
       Coding: 2F05180002002600010000
       Part No SW: 8T0 907 468 AD    HW: 8T0 907 468 K
       Component: GW-BEM 4CAN-M H09 0117
       Revision: EC000056    Serial number: 5600E112170385
       Coding: 00CF07
       VCID: 030F9C42820EB659F4-8056
       Component: J367-BDM  H07 0140
       Serial number: 00000000005650678839
       Serial number: 11062000554011200181
                000 -  -  - Intermittent
                        Fault Frequency: 28
                        Reset counter: 234
                        Mileage: 104364 km
                        Date: 2017.01.25
                        Time: 07:54:00
                        Bin. Bits:    00000
                        Voltage: 12.60 V
                        Count: 17
    02256 - Quiescent Current
                        Fault Frequency: 28
                        Reset counter: 234
                        Mileage: 104364 km
                        Date: 2017.01.25
                        Time: 07:54:00
    Address 26: Auto Roof (J256)       Labels: 8F0-959-255.clb
       Part No SW: 8F0 959 255     HW: 8F0 959 255
       Component: VSG-AUDI-B8   H11 0190
       ASAM Dataset: EV_ElectRoofContr 001008
       ROD: EV_ElectRoofContr.rod
       VCID: 71E3C68AA0B2B4C916-8024
       Part No SW: 8T0 959 793 M    HW: 8T0 959 793 D
       Component: TSG FA        H08 1501
       Coding: 011042724009330C03
       VCID: 53AF6C0232EEE6D904-8006
       Revision: 00002001    Serial number: 0145159121
       Coding: 011F06A200B904608220033680000000
       Subsystem 1 - Part No: 8P7 951 177
       Component: DWA-Sensor  H03 0050
                        Fault Status: 00101100
                        Reset counter: 229
                        Mileage: 106343 km
                        Date: 2017.03.26
                        Time: 17:57:20
       Part No SW: 8T0 959 792 M    HW: 8T0 959 792 D
       Component: TSG BF        H08 1501
       Coding: 011042324009330C03
       VCID: 52A169060DF4EFD10F-8006
    02124 - Exterior Door Handle Switch
                        Fault Frequency: 33
                        Reset counter: 213
                        Mileage: 104320 km
                        Date: 2017.01.24
                        Time: 19:30:46
       Revision: 00000003    Serial number: 10000000747447
       VCID: 346D0F9E9720C1E13D-8060
       Part No: 8K5 907 357 B
       Shop #: WSC 02145 785 00200
       VCID: 39733EAA70423C89EE-806C
       Part No SW: 4G0 035 056     HW: 4G0 035 056
       Component: Radio U STD   H52 0051
       Revision: AB001007    Serial number: 469C90B7689590
       Coding: 010003020100000101
       VCID: 5EB98D36492C3BB1BB-800A
       Part No SW: 8T2 035 666 H    HW: 8T2 035 666 E
       Component: H-BN-EU       H51 0146
       Revision: --------    Serial number: 475C00B7565078
       Coding: 010101030006C1ED01000F1E000000010101
       VCID: 4085534ED3986D41A9-8014
       Subsystem 1 - Part No: 8R0 060 884 N
       Component: EUR 2011  1205
       Component: DU7 High  H41 0104
       Serial number: A130LD0BS084508
       Subsystem 3 - Part No SW: 8T0 919 609 F    HW: 8T0 919 609 F
       Component: E0380 Bedient  H08 0100
       Serial number: 00000000771420
       Component: CD-Database  2712
                        Reset counter: 197
                        Mileage: 106557 km
                        Date: 2017.04.05
                        Time: 10:29:46
                        Voltage: 11.70 V
       Part No SW: 8T0 959 795 L    HW: 8T0 959 795 C
       Component: TSG HL        H07 1501
       Coding: 010002324009370C03
       VCID: 54AD6F1E37E0E1E11D-8000
    03531 - Belt Assistant
                        Fault Status: 00100011
                        Fault Frequency: 11
                        Reset counter: 236
                        Mileage: 104242 km
                        Date: 2017.01.21
                        Time: 22:25:55
    Address 72: Door, Rear Right (J389)       Labels: 8K0-959-794.clb
       Component: TSG HR        H07 1501
                        Fault Frequency: 81
                        Reset counter: 237
                        Mileage: 104278 km
                        Date: 2017.01.23
                        Time: 19:07:38
    End-------------------------(Elapsed Time: 0
    Verified VCDS User rlarsen's Avatar
    May 2015
    Copenhagen, Denmark
    Front or Rear fog light ??
    Rene Larsen
    Audi A4 Avant 3.0 TDI quattro tiptronic MY2009 - sold
    VCDS 18.2.0
    (HEX-V2)
    Nov 2016
    Quote Originally Posted by rlarsen View Post
    sorry ....front
    Nov 2016
    anyone any ideas?
    Aug 2016
    Switzerland
    Reset counter: 229
    Mileage: 106343 km
    Date: 2017.03.26
    Time: 17:57:20
    Check this one (bulb and wiring)
    Fixing it is better than masking the error.
  7. Likes Uwe liked this post
    May 2015
    Copenhagen, Denmark
    Normally you need to use resistors on the front lights - on the rear it can be coded.
    And yes, delete all the errors - then see which one you get again - and take action there after.
    Rene Larsen
    VCDS 18.2.0
    (HEX-V2)
  9. Likes Uwe liked this post
