Results 1 to 3 of 3
Thread: T6 Start Stop T5.1 bulb warning
    Jun 2017
    Hi guys,
    Been trying to find a definite answer to this but ive got a couple of T5.1 - fitted HIDs and LED lights and cant find any way of removing the bulb warning! been through and unticked cold diagnosis for everything in cent elec
    Am i missing something?
    Also is there a way to disable start stop automatically on start up on a T6? Its so annoying!
    Many thanks!
    I suggest posting an Auto-Scan so people can see exactly how this vehicle is equipped.
    Jun 2017
    Thursday,16,March,2017,20:34:16:28586
    VCDS Version: 17.1.3.0 (x64)
    Data version: 20170220 DS267.3
    VIN: WV1ZZZ7HZGH072655   License Plate: T6CXM
    Mileage: 71710km-44558mi   Repair Order:
    Chassis Type: 7H (7E0)
    Scan: 01 03 04 08 09 10 15 17 19 25 55 56 61 0B
    VIN: WV1ZZZ7HZGH072655   Mileage: 71710km-44558miles
    Address 01: Engine (J623-CAAC)       Labels: 03L-906-022-CAA.clb
       Part No SW: 03L 906 019 GQ    HW: 03L 907 309 L
       Component: R4 2,0L EDC   H38 8440
       Revision: 22H38---    Serial number: 00000000000000
       Coding: 01194012232401080000
       Shop #: WSC 02737 790 50316
       ASAM Dataset: EV_ECM20TDI01103L906019GQ 003006
       ROD: EV_ECM20TDI01103L906019FH_003.rod
       VCID: 00080C599B6CA941E9-8054
    4807 - EGR System
              P0401 00 [096] - Insufficient Flow
       Part No SW: 7E0 907 379 P    HW: 7E0 907 379 M
       Component: ESC           H05 0132
       Revision: 00000000    Serial number: 43095000002190
       Coding: 517E4098256984808A7B027BA48721E6390000
       Shop #: WSC 02739 790 50316
       ROD: EV_Brake1ESCCONTIVN75XGP2_011_VN35.rod
       VCID: 3F8ACFA5A61216B9D0-806A
    Address 04: Steering Angle (G085)       Labels: 6R0-959-654.clb
       Component: LENKW.SENSOR  H07 0070
       Serial number: 30101513470767
       Coding: 01
       ROD: EV_LWSKLOVW25X.rod
       VCID: 7EF472A1E198DFB19B-802A
    Address 08: Auto HVAC (J301)       Labels: 7E5-907-047.clb
       Part No SW: 7E0 907 047 T    HW: 7E0 907 047 T
       Component: Climatic-T5   H22 0607
       Revision: 00001002
       Coding: 0000000003
       ROD: EV_ClimaticT5.rod
       VCID: 3B72BBB5B20A0A99FC-806E
    Address 09: Cent. Elect. (J519)       Labels: 7E0-937-BCM-V1.clb
       Part No SW: 7E0 937 090 A    HW: 7E0 937 090
       Component: BCM PQ25 Max4 H80 0736
       Revision: B9080001    Serial number: 0779 316151209
       Coding: B8A4303A0A6134B193284F306CE88E7402B0720F60CD7960320400220820
       Shop #: WSC 14613 002 104857
       VCID: 295E71FD409688099E-807C
       Subsystem 1 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
       Component: RLS 231115 03  37  0059
       Coding: 0228EE
       Subsystem 2 - Part No SW: 7E0 959 801 L    HW: 7E0 959 801 L  Labels: 7E0-959-80X-V2.CLB
       Component: J386__TSG_FT  003 8654
       Serial number: KU0KU004111553088830
       Coding: 1400B1
       Subsystem 3 - Part No SW: 7E0 959 802 L    HW: 7E0 959 802 L  Labels: 7E0-959-80X-V2.CLB
       Component: J387__TSG_BT  003 8654
       Serial number: KU0KU005111553094707
       Coding: 0400A1
       Subsystem 4 - Part No: 7E1 951 172
       Subsystem 5 - Part No: 1K0 951 605 C
       Subsystem 6 - Part No: 7E1 951 172
       Subsystem 7 - Part No SW: 2H0 959 442     HW: 2H0 959 442
       Component: E221__MFL-DC1  H02 0103
       Serial number: 29150002232630025454
       Coding: A4FFFF
    03303 - Response Closing Status of Rear Left Door
                        Reset counter: 146
                        Mileage: 58731 km
                        Date: 2016.12.12
                        Time: 03:17:36
    Address 10: Park/Steer Assist (J446)       Labels: 7E0-919-475.clb
       Part No SW: 7E0 919 475 M    HW: 1Q0 919 475
       Component: PARKHILFE 4K  H03 0205
       Revision: --------    Serial number: 32961528604953
       Coding: 10800A
       ASAM Dataset: EV_VW75XParkAssis4K 001008
       ROD: EV_VW75XParkAssis4K.rod
       VCID: 3C70B8A9B7040DA1F5-8068
       Part No SW: 7E0 959 655 D    HW: 7E0 959 655 D
       Component: VW10Airbag00J 008 0016
       Revision: --------    Serial number: 003PH001V0PG
       Coding: 00000000000000000000000000000000304A
       Shop #: WSC 02734 790 50316
       ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
       ROD: EV_AirbaVW10BPAVN750.rod
       VCID: 377AA7858E222EF918-8062
       Part No SW: 7E0 920 970 L    HW: 7E0 920 970 L
       Component: KOMBI         H05 1008
       Coding: 4709230100
       ROD: EV_Kombi_UDS_VDD_RM09_VN35.rod
       VCID: 336293959A5AC2D924-8066
       Part No SW: 7E0 909 901     HW: 7E0 937 090
       Component: GW-K-CAN TP20 H80 0736
       Revision: B9080001
       Coding: 042305
       VCID: 68D834F99B1C710141-803C
       Component: IMMO          H05 1008
       VCID: 6ADC4EF18D10431157-803E
    Address 55: Headlight Range (J431)       Labels: 6R0-907-357.clb
       Part No SW: 6R0 907 357 C    HW: 6R0 907 357 B
       Component: AFS-ECU       005 0050
       Coding: 0FCE020001000000
       Shop #: WSC 02757 790 50316
       ASAM Dataset: EV_HeadlRegulVWLWRCC 002006
       ROD: EV_HeadlRegulVWLWRCC.rod
       VCID: 3A7CBEB1BD303391E7-806E
    Address 56: Radio
    Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
       Part No SW: 7E0 907 534     HW: 7E0 937 090
       Component: Batt.regelung H80 0736
       Coding: 330B1A73
       Shop #: WSC 02739 790 00000
       Subsystem 1 - Part No SW: 7E0 915 181 G    HW: 7E0 915 181 G
       Component: J367-BDM  H08 0223
       Serial number: 62302024211261974538
    End-------------------------(Elapsed Time: 03:09)--------------------------
    This is an autoscan of the T6... need to be able to disable start stop and bulb warning
    guessing its the same process for bulb warning on a t5.1
  4. Likes Uwe liked this post
