2015 MK7 Golf Sportwagen Fog Lights
Chimuel
Boston, MA
C?ID=274674
I have installed my foglights but now need to code them. I used pins C3 (Leuchte17TFL R BLK SRB3TFL R BLK SRKC3) and C9 (Leuchte16BLK SLB25BLK SL KC9) on the BCM/CECM but am having a hard time coding it in. Pins B5 and B45 are not on my BCM, so I am using a different channel. Initially I was going to use the front side marker lights but would prefer not to lose that function.
My CECM part number is 5Q0 937 087 Q, is it even possible to have foglights with this or should I just buy a different CECM?
I am using HEX+CAN with VCDS 18.1
Chimuel
Boston, MA
C?ID=274674
Sorry, I meant to follow up but I got distracted by reading a manual.
Saturday,30,December,2017,15:13:22:46754
VCDS Version: 17.12.0.1 (x64)
Data version: 20171213 DS285.1
VIN: 3VWC17AU3FM516313   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 15 16 17 19 42 44 52 5F 75
VIN: 3VWC17AU3FM516313   Mileage: 41078km-25524miles
Address 01: Engine (J623-CXBB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5GM 906 264     HW: 06K 907 425 B
   Component: 1.8l R4 TFSI  H13 0001
   Revision: --H13---
   Coding: 091A00122424002F0000
   Shop #: WSC 00066 790 00218
   ASAM Dataset: EV_ECM18TFS0205GM906264 001001
   ROD: EV_ECM18TFS0208V0906264F.rod
   VCID: 0407FD108FADBD0AEBA-8050
   Part No SW: 09G 927 749 D    HW: 09G 927 749 D
   Component: AISIN AG6 G3  129 2866
   Coding: 010200000C000000000000000000000000000000
   ASAM Dataset: EV_TCMAQ250031 002009
   ROD: EV_TCMAQ250031_002_VW25.rod
   VCID: 3A7B43E8BDE93BFAC16-806E
28269 - Gear Selector
          P17C5 00 [104] - Implausible Signal
                    Reset counter: 39
                    Mileage: 38935 km
                    Date: 2017.12.14
                    Time: 16:39:23
                    Engine speed: 922.0 /min
                    Transmission input speed: 909 /min
                    Transmission output speed: 0 /min
                    Engine torque: -4 Nm
                    Transmission fluid temperature: 64 °C
                    Accelerator position: 0.0 %
                    Clutch_C1: Open
                    Clutch_C2: Open
                    Clutch_C3: Open
                    Clutch_C4: Open
                    Clutch_B1: Open
                    Clutch_B2: Open
                    Lock Up Clutch: Open
                    Electrical Oil Pump target revolution: 65534 /min
                    Electrical Oil Pump actual revolution: 65279 /min
                    Engine Speed signal Current: 65279 /min
                    Electrical Oil Pump failure status with Electrical Oil Pump without HV 1: Motor normal stop
                    Electrical Oil Pump target current: 65278 mA
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-ESP-V1.clb
   Part No SW: 3Q0 907 379 P    HW: 3Q0 907 379 C
   Component: ESC           H32 0385
   Revision: 00000000    Serial number: 50875000000483
   Coding: 04FA6AA124210972007A020181C6292056249000408194B400430050C002
   Shop #: WSC 01383 790 50316
   VCID: 479D2A1CFE1B56124E8-8012
16401 - Tire Pressure Warning
          C102D 00 [008] -  -
                    Reset counter: 139
                    Mileage: 32882 km
                    Date: 2017.09.15
                    Time: 17:37:32
   Part No SW: 5GM 907 426     HW: 5GM 907 426
   Component: AC Manuell    H02 1001
   Revision: 00001K01
   Coding: 02020004100100000000000000000000
   ROD: EV_ACManueBHBVW37X_003_VW37.rod
   VCID: 0501E01484978402FC4-8050
Address 09: Cent. Elect. (J519)       Labels:| 5Q0-937-08X-BV1.clb
   Part No SW: 5Q0 937 087 Q    HW: 5Q0 937 087 Q
   Component: BCM PQ37BOSCH 028 0145
   Revision: --------    Serial number: 86583003150003
   Coding: 000018424041804169E44000000403001000000000000000000000000000
   Shop #: WSC 00066 790 07031
   ROD: EV_BCMBOSCH_014.rod
   VCID: 49992C24E80FA06258C-801C
   Component: WWS    150403  043 0581
   Serial number:         150521102520
919560 - Light Switch
          B126A 29 [136] - Signal Implausible
          U95C050 F0 [008] - Safety Shut-Off due to Occupant Detection
                    Fault Frequency: 126
                    Reset counter: 116
                    Mileage: 12219 km
                    Date: 2016.10.04
                    Time: 11:39:33
   Serial number: 003GCR01LNV5
   Occupant Detection:
   Component: BF-Gewichtss.  H11 0021
   Serial number: IBH0000J150002PRED0N
   Coding: 303138
   Subsystem 2 - Part No SW: -----------    HW: 480 003 003 15
   Serial number: 35700000000DCCFCE31B
   Subsystem 3 - Part No SW: -----------    HW: 480 002 603 15
   Serial number: 35800000000C2951931F
   Subsystem 4 - Part No SW: -----------    HW: 480 403 103 15
   Serial number: 3510002C51941315D11O
   Subsystem 5 - Part No SW: -----------    HW: 480 403 103 15
   Serial number: 3520002A31A878548381
   Subsystem 6 - Part No SW: -----------    HW: 480 400 104 15
   Serial number: 3550002AB1A14CA2035+
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 400 104 15
   Serial number: 3560002AB1A14CA5F2CN
   Part No SW: 5Q0 953 521 P    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20150327500211
   Coding: 0410
   Shop #: WSC 66564 385 16448
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3F8D32FCA6CB1ED2F68-806A
617752 - Selector Lever Park Position Lock Switch
          B1162 29 [008] - Signal Implausible
                    Reset counter: 107
                    Mileage: 37828 km
                    Date: 2017.11.30
                    Time: 16:37:03
                    Ubat 30 Voltage: 14.10 V
                    Ignition State: On
                    Terminal 15: 13.30 V
                    A/D #1: 0.00 %
                    A/D #2: 0.00 %
                    A/D #3: 0.00 %
   Part No SW: 5G1 920 840     HW: 5G1 920 840
   Component: KOMBI         243 4270
   Coding: 0BB5110A2180CF0502086A001000000000000000
   VCID: 64C7DD906FED1D0A4BA-8030
   Part No SW: 5Q0 907 530 AB    HW: 5Q0 907 530 L
   Component: GW MQB Mid    211 2203
   Revision: --------    Serial number: 30041510000556
   Coding: 0101000820085900FF0000081C0F00000001050000000000000000000000
   Shop #: WSC 00066 790 07027
   ROD: EV_GatewConti_011_VW37.rod
   VCID: 71E9A4C4A01FB8A230C-8024
   Subsystem 2 - Part No SW: 5G0 959 442 P    HW: 5G0 959 442 P  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H16 0101
   Serial number: 27140002727850095154
   Coding: 31FFFF
   Part No SW: 5Q0 959 393 B    HW: 5Q0 959 393 B
   Serial number: 18051506050GBN
   Coding: 003003200000040000000000
   VCID: 3E734FF8A1C117DAFDE-806A
   Serial number: 00000000000001182805
   Coding: 011000
          B1487 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 89
                    Mileage: 39911 km
                    Date: 2017.12.18
                    Time: 07:33:45
   Component: EPS_MQB_ZFLS  126 1061
   Coding: 0102
   VCID: 43853E0CCA237A32920-8016
   Part No SW: 5Q0 959 392 B    HW: 5Q0 959 392 B
   Serial number: 1505150605098O
   Coding: 003003208C00040000000000
   VCID: 3D7148F4ACC70CC2E44-8068
   Serial number: 00000000000001160412
   Coding: 091000
   Part No SW: 5G0 035 844     HW: 5G0 035 844
   Component: MU-S-S-US     014 0655
   Serial number: V7B01504153511
   Coding: 02730200FF00000021220001001800001F0100040100010002
   Shop #: WSC 47844 001 1048576
   ROD: EV_MUStd4CPASE_VW37.rod
   Subsystem 1 - Part No SW: 5G0 919 605 H    HW: 5G0 919 605 H
   Component: ABT_Std_Plus  H60 0030
   Serial number: VWZ8Z9RS501QCL
          B11CF 53 [009] - Deactivated
                    Reset counter: 182
                    Mileage: 12200 km
                    Date: 2016.10.03
                    Time: 21:11:48
                    Voltage terminal 30: 11.9 V
   Component: OCULowMQBUS   007 0564
   Coding: 02730202C2821A017F1E06000000
   Shop #: WSC 00066 790 00323
   ROD: EV_OCULowMQB.rod
End-------------------------(Elapsed Time: 03:25)--------------------------
Chimuel
Boston, MA
C?ID=274674
I was able to get the bulbs to function but as soon as I drive away the fog lights will blink then stay off and then I get an error message on the dash and the "CAR" menu in the center display.
Here is the adaptations and what I have changed:
C9 - Lasstyp set to 23 allgemeine Scheinwerfer
C9 - Lampendefektbitposition set to 38
C9 - Fehlerort mittleres Byte DTC-DFCC set to 22
C9 - Lichtfunktion A - Set to Nebellicht links
C9 - Lichtfunktion B - Set to Abbiegelicht links
C9 - Lichtfunktion C through H - Set to Not Active
C9 - Dimmwert AB - Set to 100
C9 - Dimming Direction AB - Set to maximize
C9 - Dimmwert CD, EF, GH - Set to 0
C9 - Lichtansteuerung HD AB - Set to Always
C3 - Lasstyp set to 23 allgemeine Scheinwerfer
C3 - Lampendefektbitposition set to 42
C3 - Fehlerort mittleres Byte DTC-DFCC set to 23
C3 - Lichtfunktion A - Set to Nebellicht rechts
C3 - Lichtfunktion B - Set to Abbiegelicht rechts
C3 - Lichtfunktion C through H - Set to Not Active
C3 - Dimmwert AB - Set to 100
C3 - Dimmwert CD, EF, GH - Set to 0
C3 - Lichtansteuerung HD AB - Set to Always
Here is the snippet from a scan after the fault codes show up:
8711 - Bulb for Left Fog Lamp
          B121F 11 [009] - Short to Ground
                    Reset counter: 157
                    Mileage: 43858 km
                    Date: 2018.02.11
                    Time: 20:56:59
8967 - Bulb for Right Fog Lamp
          B1220 11 [008] - Short to Ground
                    Reset counter: 197
                    Mileage: 43858 km
                    Date: 2018.02.11
                    Time: 20:56:59
DV52
C?ID=194404
^^^ I'm guessing, but (Leuchte17TFL R BLK SRB3TFL R BLK SRKC3) and C9 (Leuchte16BLK SLB25BLK SL KC9) are factory set to operate ONLY for LED tail-light fittings (they are the inner turn-signal Leuchte-sets). These 2 x Leuchte-sets are not intended for incandescent lamps. Have you installed LED front fogs or incandescent? If the latter - I wonder if the threashold settings for lamp monitoring can accomodate the higher currents?
If your retro-fitted fogs are LED, try changing Lasstyp to 6 - LED Lichtmodul.
Chimuel
Boston, MA
C?ID=274674
Good idea... I only have incandescent bulbs in there for the moment but I guess I'll be upgrading to LEDs sooner than planned! It does seem like a circuit protection scheme is superseding my settings (which I expect since like you said this particular circuit is for LED lights).
The LED bulbs I ordered have a "black box" attached to a wire that goes to the LED on one end and the other end goes to the regular plug, do I need to change the Lasstyp to 6- LED if I install that type of bulb?
Don, I am very thankful for your thorough documentation... it helped me understand the lighting settings much better!
DV52
C?ID=194404
^^^ "black box"? hmm..... normally LEDs have a simple series resistor as ballast for electrical current flow. Yours sounds like they might have a constant current ciruit (very fancy).
Here's the factory wattage numbers for an OEM LED tail light fitting.
As you can see, "Section 2" has a LED cluster with a load of 5.5 Watts for the inner turn signal. So, I suspect that the lamp monitoring ciruit in the BCM for pins #3 & #9 on the C socket is tailored for this electrical load.
I suggest that you make sure that your LED fog lamps have a watt value around this number. And yes - change the Lastyp channel to the LED setting
Chimuel
Boston, MA
C?ID=274674
Don, the LED bulbs I ordered are these:
The other circuit I was going to use boxed in red (another user in the golfmk7 forums, Basemodel, used it) was for the NAR front side marker lamps, would you happen to have the watt rating that circuit can handle? I don't want to lose that functionality and I may just go back and switch C3 and C9 to pins B10 and B21.
I am also trying to avoid adding relays but I think if all the above fails I will install a relay triggered by pins C3 and C9 (assuming they are 12V) for each of the front fogs.
EDIT: I may be straying off the main topic here but would you also be able to tell me what pin the light in the blue box is linked to? It is a rear side marker light but since I have converted to the RoW outer taillights I no longer have them and would like to use that pin/channel set for LED rear fogs.
DV52
C?ID=194404
Chimuel: I must warn (again) that my hypothesis is just that. Your retrofit is "innovative" - I've not heard of anyone doing this before, so I'm just guessing (the BCM has 3 x pin sizes which infer electrical current capacity - I suspect that C3 & C9 are the smallest size pins)
So a few comments on your last post above. My knowledge of NAR models isn't good but I believe that B10/B21 pins are intended for the orange "parking lights" below the orange reflector on US cars with Halogen lights. I have quite a few "yanky" cars in my database and the Leuchte-sets for these pins are invariably set-up for LED lamps. But I was able to find a NAR admap that had the lasstyp channel set to 8 - allgemeine Glühlampe 12W (2016 Sport Wagon S) for B10/B21. The normal incandescent fog light on a mk7 is a H11 fitting with a 55 Watt lamp. But if you are retrofitting a LED lamp into the fog light base, there does appear to be more headroom in these pins
As to your suggestion for a relay sub-circuit - you could have the opposite problem (i.e. open-circuit error, instead of short-circuit error). The operating current for the coil in a 12V electo-mechanical relay is typically of the order of 100 milli-amps. The lamp monitoring circuits on C3/C9 may see this small current as an open ciruit - so you might need to add a resistor in parallel with the relay coil to fool the monitoring ciruit. A bit of basic theory: the expected load on C3/C9=5.5 Watts=V^2/R. Assuming a nominal rail voltage of 13V, R=14 ohms. Be aware that the long term heat dissipation of this resistor will be 5.5 Watts, so to keep everything cool, perhaps choose a 20W resistor. The added resistor might not be needed (try without first), but the calculation might be useful if this is not the case.
Chimuel
Boston, MA
C?ID=274674
Don! Thanks for the write up. Amazon pulled through with same-day delivery and now I have fully functional front fog lights! The lights worked when I had Lasstyp set to 10 and Dimmwert was set to 100. I have gone ahead and changed those two settings to Lasstyp 6 and Dimmwert 127 to tidy up the programming.
C3 and C9 pins are exactly the same size as the B5, B45, B10, and B21 pins so I thought there would be higher headroom for amperage --my wiring harness is OEM with the proper pins.
I am very glad I did not need to add relays, that was my last resort! --My engineering background would have come in handy but I'm a little rusty after having worked in IT for a few years now.
Only issue I am running into now is that when I have the light controls pulled to the first detent, after I start driving the fog lights turn off and only turn on to the side I am turning to when I turn the steering wheel. I imagine I set the cornering lights on, should I change the "B" in the AB pair to "not active"?
Thanks for the insight and responses, much appreciated!
DV52
C?ID=194404
^^^ well done!!!
Yes - Abbiegelicht links/rechts is the leuchte command for "cornering lights". Set them to not active to disable (the cornering lights will only work if the car's speed is below a threshold value)
Chimuel
Boston, MA
C?ID=274674
^^^ well done!!!
So I talked to the boss (my wife) and she said she liked the cornering lights. I was wondering if I could reach a nice medium and have it so that the foglights are dim (say, about 50% intensity) and go to 100% when they are used for cornering or when I override it by pulling the light switch to activate the rear fogs. Is that possible? What should I program?
DV52
C?ID=194404
^^ A man after my own heart - I always consult my current lifetime partner (wife) before making changes to my mk7 !!;)
The following values should result in the lamps @ 50% when operating as front fog-lights only and @ 100% when used as cornering lights, or when turned-on in conjunction with rear fogs:
PS: I make no judgement as to whether this arrangement is road-legal up there in the land of the free (I have never understood your DoT rules)- you will need to satisfy yourself in this regard
iichel
Netherlands, eastern part
C?ID=284912
I just ask my wife afterwards whether she likes what I've done. That counts, right?
PS, Don, your image doesn't work.
DV52
C?ID=194404
^^ Michel: Ask the wife AFTER you have made the changes?
You are clearly the type of man that likes to live life on the edge!!:D
iichel
C?ID=284912
she's always yelling at me that we need to 'keep things exciting'. mission accomplished!
Chimuel
Boston, MA
C?ID=274674
Don,
I tried the settings you showed but I couldn't get it to take. I may have to test it when the vehicle is in motion.
Chimuel
Boston, MA
C?ID=274674
Don,
Any reason I should not separate these two?
C3/9 - Lichtfunktion A - Set to Nebellicht links
C3/9 - Lichtfunktion B - Set to Abbiegelicht links
I was thinking of setting Abbiegelicht links to Lichtfunktion C and setting Lichtfunktion B\D to not active. I have an issue where if I activate the front fogs, they do not turn on at all unless I turn on the rear fogs as well.
