Results 1 to 5 of 5
Thread: Cannot Perform SRI on Lamborghini Huracan
    Jul 2015
    Hex-Net controller being used with USB connection
    Copy of auto scan
    Saturday,10,February,2018,15:18:25:55582
    VCDS Version: 18.1.0.2 (x64)  HEX-NET CB: 0.4411.4
    VIN: ZHWUC1ZF7FLA01704   License Plate:
    Mileage: 26540km-16491mi   Repair Order:
    Chassis Type: ZF-LB72 (4S0)
    Scan: 01 02 03 05 08 09 11 31 14 15 16 17 19 1B 22 3B 42 44 46 52
              53 55 56 5F 65 6C C2 D0
    VIN: ZHWUC1ZF7FLA01704   Mileage: 26540km-16491miles
    C2-Auto Trans 2 -- Status: OK 0000
    D0-Frt Axle Lift -- Status: OK 0000
    Address 01: Engine (------CSJC)       Labels: None
       Part No SW: 4T0 907 552 A    HW: 4T0 907 552 A
       Component: 5.2l V10HDZ / H55 0004
       Revision: NHH55---
       Coding: 1E2500320506000D2000
       Shop #: WSC 47382 001 1048576
       ASAM Dataset: EV_ECM52FSI1114T0907552A 001005
       ROD: EV_ECM52FSI1114T0907552A.rod
       VCID: 3522C3D0949868ED56-8060
    Address 02: Auto Trans (J217)       Labels:. 0BH-927-711.clb
       Part No SW: 4T0 927 155 A    HW: 0BH 927 711 D
       Component: 0BZ_52FSI_NAR H09 0813
       Revision: 00H09V01
       ASAM Dataset: EV_TCMDL800041 001009
       ROD: EV_TCMDL800041.rod
       VCID: 3620C4DC899E63F55F-8062
       Part No SW: 4S0 907 379     HW: 4S0 907 379
       Component: ESP PREMIUM   H09 0087
       Coding: 218AC141845183824B00
       Shop #: WSC 02311 785 00200
       ASAM Dataset: EV_ESPPremiAU57X 004041
       ROD: EV_ESPPremiAU57X_AU72.rod
       VCID: 7AB810ECFD064795FB-802E
       Part No SW: 4H0 907 064 FD    HW: 4H0 907 064 ED
       Component: BCM2 2.0      H36 0560
       Coding: 09803006000000000000
       VCID: 70AC32C4A37A0DC545-8024
       Serial number: 3214000145060008
    00955 - Key 1
                        Reset counter: 239
                        Mileage: 25495 km
                        Date: 2017.08.05
                        Time: 04:58:15
       Part No SW: 4T0 820 043 A    HW: 4T0 820 043 A
       Component: KLIMA 1 ZONE  H03 0130
       Revision: A1013000    Serial number: 01061120140019
       Coding: 4A02208000
       VCID: 2A18E0AC45263715CB-807E
    Address 09: Cent. Elect. (J519)       Labels: Redir Fail!
       Part No SW: 4H0 907 063 DM    HW: 4H0 907 063 AM
       Revision: 21020001    Serial number: 00000954903101
       Coding: 00E90090402001303D01C8C300202800001C47C8020602C10000081C0440100000400034010000
       VCID: 76A004DCC11E23F59F-8022
       Subsystem 1 - Part No SW: 4T1 955 113     HW: 955 113
       Component: WWS72x 140803  041 0015
       Serial number:         ????????????
       Coding: 0000F7
       Serial number: 23449666
       Coding: 02005D
       Subsystem 3 - Part No SW: 4T1 941 531 D    HW: 4T1 941 531 D
       Component: LCU  H02 0012
       Serial number: BC288A57000000000001
    01543 - Parking Aid Warning Chime (H15)
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 137
                        Mileage: 25063 km
                        Date: 2017.06.12
                        Time: 08:09:44
    Address 11: Engine II (-----)       Labels: None
       Revision: NHH55---
       ASAM Dataset: EV_ECM52FSI2114T0907552A 001005
       ROD: EV_ECM52FSI2114T0907552A.rod
    Address 14: Susp. Elect. (J250)       Labels: None
       Part No SW: 4S0 907 376 A    HW: 4S0 907 376 A
       Component: DAEMPFUNGS-SG H03 0043
       Serial number:       051114020
       ASAM Dataset: EV_AudiMagneRide 002004
       ROD: EV_AudiMagneRide.rod
       VCID: 383CCAE4838A95854D-806C
    Address 15: Airbags (J234)       Labels:| 4H0-959-655.clb
       Part No SW: 4G0 959 655 B    HW: 4G0 959 655 B
       Component: Airbag10.43   H62 0086
       Revision: --------    Serial number: 003G0001LP5S
       Coding: 303333343033303030364A55304C34543053
       ROD: EV_AirbaAU10BPAAU64X_AU72.rod
       VCID: 3424FED49FE271E561-8060
       Serial number: 6940000Y1400017VPS0L
       Serial number: 3575HRB40532MV3CEHK-
       Serial number: 3585HRB40532MV3CEH4L
       Serial number: 3515JRB404P32020CG8I
       Serial number: 3525JRB405932020C9F4
       Serial number: 3554VRB405J3201SH193
       Serial number: 3564VRB405L3201SL1NO
       Part No SW: 4T0 953 513     HW: 4T0 953 513
       Component: Lenks.Modul   H02 0080
       Revision: C0068719    Serial number: 90815NKI0004S
       VCID: 72A838CCAD763FD5B3-8026
       Subsystem 1 - Part No SW: 18G 959 542 B    HW: 18G 959 542 B
       Component: E221__MFL-TAS  H05 0012
       Serial number: 0003498 TAT 20140918
    Address 17: Instruments (J285)       Labels:. 4T0-920-xxx-17.clb
       Part No SW: 4T0 920 900 B    HW: 4T0 920 900 B
       Component: KOMBIINSTR.   013 0159
       Revision: AA001001    Serial number: 40400107013MOC
       Coding: 01F80094B3B1C3F0020000
       VCID: 2E10ECBC79CE5B3517-807A
    03158 - Control Module for Information Electronics 1 (J794)
                        Reset counter: 250
                        Mileage: 25063 km
                        Date: 2017.06.12
                        Time: 08:12:03
       Part No SW: 4S0 907 468     HW: 4S0 907 468
       Revision: --------    Serial number: 00000001635556
       Coding: 0009071600
       VCID: 79BA0FE0F8004C8DF2-802C
       Subsystem 1 - Part No SW: 8K0 915 181 M    HW: 8K0 915 181 M
       Component: J367-BDM  H08 0190
       Serial number: 51297K21463371983582
       Voltage stabilizer:
       Subsystem 2 - Part No SW: 8K0 959 663 C    HW: 8K0 959 663 C
       Serial number: 14323003317011200410
       Part No SW: 8K0 907 144 M    HW: 8K0 907 144 M
       Component: DYNAMIKLENK.  H06 0730
       Coding: 050000
       VCID: 393ACFE0B0808C8DB2-806C
    Address 22: AWD (J492)       Labels: 4T0-907-160.clb
       Part No SW: 4T0 907 160     HW: 4T0 907 160
       Component: 4 Wheel Drive H02 0006
       Revision: 00001002    Serial number: BBKR545
       ASAM Dataset: EV_AllWheelContrBORGLB724 004010
       ROD: EV_AllWheelContrBORGLB724_004.rod
       VCID: 6FAE31B8B644123D5C-803A
       Component: SARA 6D red   H04 0056
       Revision: --------    Serial number: EJ1BPA7E018YM.
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 373EC9D88E949AFD44-8062
       Part No SW: 4T0 959 793 H    HW: 4T0 959 793 H
       Component: TSG FA        H07 0801
       Revision: --------    Serial number: 0000116743510
       Coding: 010C4B025000620100080102
       VCID: 4AD8802CE56617152B-801E
       Part No SW: 4S0 909 144 D    HW: 4S0 909 144 B
       Component: EPS           H12 0901
       Revision: 00000000    Serial number:      L00061902
       Coding: 09
       ASAM Dataset: EV_EPSZFAU72X 001001
       ROD: EV_EPSZFAU72X_001.rod
       Revision: 00002001    Serial number: 0350994060
       Coding: 011E029A18F20081A0B0C800008503470000000000000000000000000000
       Subsystem 1 - Part No: 8J0 951 177
       Component: DWA-Sensor  H03 0030
       Part No SW: 4T0 959 792 H    HW: 4T0 959 792 H
       Component: TSG BF        H07 0801
       Revision: --------    Serial number: 0000126793503
       Coding: 010C4B825000620100080100
       VCID: 49DABF20E0601C0D22-801C
       Part No SW: 4S0 907 801     HW: 8K0 907 801
       Component: EPB-4         H02 0001
       Revision: --------    Serial number: 00000000000250
       ROD: EV_ParkiBrake_AU72.rod
       VCID: 70AC32C4AB7A0DC545-8024
    Address 55: Headlight Range (J431)       Labels:| 4H4-907-357-V1.clb
       Part No SW: 4T0 907 357 A    HW: 4H4 907 357 A
       Component: ....AFS13.... H01 0003
       Serial number: 141119-0004-045
       Coding: 72846F6118020200
       ASAM Dataset: EV_AFSLEDHELLALB72X 006131
       ROD: EV_AFSLEDHELLALB72X.rod
       Subsystem 1 - Part No SW: 7PP 941 329 S    HW: 7PP 941 329 S
    H01 7020
       Coding: 1D0000
       Subsystem 2 - Part No SW: 7PP 941 329 S    HW: 7PP 941 329 S
    H01 7020
       Coding: 1D0000
       Component: Radio U SIRIU H66 0133
       Revision: AB001007    Serial number: 156K60E8115975
       Coding: 020007020100000001
       VCID: 24040E942702E165F1-8070
       Part No SW: 4T0 035 664     HW: 4T0 035 664
       Component: H-BN-NA       H40 0795
       Revision: --------    Serial number: 325K 0E7500717
       Coding: 010200000001A16F0100820600000001FD0000020000000000
       Subsystem 1 - Part No: 4T0 919 859 D
       Component: NAR 2014  0801
       Subsystem 3 - Part No SW: 4T0 919 609 A    HW: 4T0 919 609 A
       Component: E380 BDT LB2  H01 0011
       Serial number: 00000000002217
       Component: CD-Database  5571
    Address 65: Tire Pressure (-----)       Labels: 3Y0-907-273.clb
       Part No SW: 4H0 907 273 B    HW: 4H0 907 273 B
       Component: RDKBERU25     H10 0820
       Serial number: 10000000011490
       ROD: EV_RDKBERU25_AU57.rod
       VCID: 2A18E0AC4D263715CB-807E
    Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-907-441.clb
       Part No SW: 4T0 907 441     HW: 5Q0 907 441 A
       Component: LB72x RVC Mid H07 0030
       Coding: 080004010A01000300
       ASAM Dataset: EV_CamSysRearPANAAU914 002002
       ROD: EV_CamSysRearPANAAU914.rod
       VCID: 71AA37C0A07004CD4A-8024
    Address C2: Auto Trans 2 (J217)       Labels: None
       Part No SW: 4T0 927 109     HW: 4T0 927 109
       Component: DL800 ZSG     H28 0006
       Revision: --H28---    Serial number: 0000000098
       Coding: 000001
       ASAM Dataset: EV_TCMDL800421 001019
       ROD: EV_TCMDL800421_001001.rod
       VCID: 74A43ED4DF6231E5A1-8020
    Address D0: Frt Axle Lift
    End-----(Elapsed Time: 02:07, VBatt start/end: 12.3V/0.0V. VIgn 0.0V)------
    Check your PMs.
    Jul 2015
    Thank you.
    Jul 2015
    Once more question I tired to change the setting in the Instrument cluster to display tire pressure in PSI. The long coding saved but still the cluster displays the tire pressure in Bar.
    Well, we'll just run right out and try to duplicate that in our Huracan.
    Oh wait. We don't have Huracan (or any other Lambo) to test anything on...
  6. Likes golfi_vend, NZDubNurd liked this post
