Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Blind spot monitoring retrofit - GTI Clubsport
    Jan 2018
    Kuwait
    Yes. shouldn't be too bad for them to do. Maybe an hours work.
    Oh and I almost forgot to say the most important thing. Nice retrofit, congratulations for finishing it, good job
    Thanks downtime, without your help and the guys supports , this couldn’t be done.
    Also I will post and auto scan and admap in order for any one planning to do the retrofit, it would be helpful and make things easier.
  2. Likes Uwe, downtime liked this post
  3. #12
    Jan 2018
    Kuwait
    Tuesday,13,February,2018,17:52:35:35129
    VCDS Version: 17.8.1.0 (x64)  HEX-NET CB: 0.4409.4
    VIN: WVWFM2AUXGW246170   License Plate:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 02 03 08 09 10 13 14 15 16 17 19 32 3C 42 44 47 52 55 5F
              A9
    VIN: WVWFM2AUXGW246170   Mileage: 26028km-16173miles
    Address 01: Engine (J623-CJXE)       Labels:. 06K-907-425-V1.clb
       Part No SW: 5G0 906 259 K    HW: 06K 907 425 B
       Component: 2.0l R4 TFSI  H13 0001
       Revision: --H13---
       Coding: 091D00122464050B2000
       ASAM Dataset: EV_ECM20TFS0205G0906259K 001002
       ROD: EV_ECM20TFS0205G0906259F_VW37.rod
       VCID: 3620C89689CE44F67B-8062
    Readiness: 1110 0001
       Part No SW: 0D9 300 020 K    HW: 02E 927 770 AQ
       Component: DQ250-6V MQB  H53 4904
       Revision: 06253104    Serial number: TFK01601191468
       Shop #: WSC 04742 780 00200
       ROD: EV_TCMDQ250021_VW37.rod
       VCID: 1D72373A0C38F7AE9A-8048
              P1734 00 [002] - -
       Revision: 00000000    Serial number: 60246000000551
       Coding: 01FA6BA1542429720778060741C36980D62A94E0608296F7184250B9C288
       VCID: 7AB81CA6FD566096DF-802E
       Part No SW: 5G0 907 044 BD    HW: 5G0 907 044 BD
       Revision: 00001K08
       Coding: 00020014200100001005000012101402
       VCID: 6A982CE68DF6D0162F-803E
       Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
       Serial number: 01061602803455
       Coding: 00101A46C20122F34B644000000C07281000000000000000000000000000
       ROD: EV_BCMBOSCH_015_VW37.rod
       VCID: 095A736AA8B07B0EC6-805C
       Component: WWS    160118  043 0551
       Serial number:         160202045705
       Component: RLHS  037 0059
       Serial number: S2Y16M02D08H10M34S06
       Coding: 90A8DD
       Sun Roof:
       Subsystem 3 - Part No SW: 8V3 959 591 A    HW: 8V3 959 591 A
       Component: J245 PS73.403  H03 0004
       Serial number: 0000FST000RK8J200000
       Coding: 181801
       Part No SW: 5Q0 919 283 G    HW: 5Q0 919 283
       Component: PARKHILFE 4K  H10 0056
       Revision: --------    Serial number: 39291603300852
       Coding: 0001150011
       ASAM Dataset: EV_EPHVA14AU3700000 002024
       VCID: 3D32D7BAACF897AEBA-8068
       Part No SW: 5Q0 907 572 F    HW: 5Q0 907 572 F
       Component: ACC Bosch MQB H05 0400
       Serial number: 02011604400195
       Coding: 001C1300FE0739
       ASAM Dataset: EV_ACCMRRBoschVW372 001016
       VCID: 3A38DCA6BDD6A0969F-806E
       Part No SW: 5Q0 907 376 A    HW: 5Q0 907 376 A
       Component: DAEMPFUNGS-SG H17 0120
       Serial number: 29121541350443
       ROD: EV_DRCONTITEMIC_VW37.rod
       VCID: 373EC5928EC4BDFE60-8062
       Serial number: 003F6R1CV8AR
       VCID: 41CAAB4AD000F34EDE-8014
       Subsystem 1 - Part No SW: -----------    HW: 480 000 902 16
       Serial number: 35767000000E9650291V
       Subsystem 2 - Part No SW: -----------    HW: 480 000 902 16
       Serial number: 3586700000038644881S
       Subsystem 3 - Part No SW: -----------    HW: 480 400 202 16
       Serial number: 3516502B71EDD3E4637W
       Subsystem 4 - Part No SW: -----------    HW: 480 400 202 16
       Serial number: 3526502B71EDD3E591A
       Subsystem 5 - Part No SW: -----------    HW: 480 400 502 16
       Serial number: 3556502AD1EDD3E150D/
       Part No SW: 5Q0 953 521 P    HW: 5Q0 953 569 A
       Revision: FF033033    Serial number: 20160204500421
       Coding: 0410
       ROD: EV_SMLSVALEOMQB_VW37.rod
       VCID: 3FCEADB2A6F485BEA8-806A
       Part No SW: 5G0 920 756     HW: 5G0 920 756
       Component: KOMBI         302 6420
       Coding: 47AD01083F98000801886A091400000000000000
       VCID: 699A53EA88F0DB0E26-803C
    16776980 - Databus
                        Reset counter: 47
                        Mileage: 26028 km
                        Date: 2018.02.13
                        Time: 17:47:45
       Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
       Component: GW MQB High   212 2246
       Revision: --------    Serial number: 30011610802973
       Coding: 030100043F085900FB00027B9C0F00010001050000000000000000000000
       ROD: EV_GatewConti_013_VW37.rod
       VCID: 79BA03AAF8506B8ED6-802C
       Serial number: 29160000048900016026
       Coding: 2DFFFF
       Serial number: 6060799103
    Address 32: Differential Locks (J492)       Labels:* 0CQ-907-554.clb
       Part No SW: 0CQ 907 554 E    HW: 0CQ 907 554 E
       Component: Quersperre    H52 8042
       Serial number: HA1-00023.11.15
       Coding: 0001
       ASAM Dataset: EV_LockElectHA1VW37X 001007
       ROD: EV_LockElectHA1VW37X.rod
       VCID: 47DEB552FE24CD7E10-8012
       Component: HRE_Master    H11 0071
       Serial number: 0391756389
       Coding: 01031103
       ROD: EV_HREntryHella_VW32.rod
       VCID: 3C34DABEB7E29EA68D-8068
       Lane Change Assistant 2:
       Serial number: 070116EA606676
       Coding: 003F0320D000040100001000
       VCID: 43C6A142CA1CE15ECC-8016
       Part No SW: 3Q0 909 144 J    HW: 3Q0 909 144 H
       Component: EPS_MQB_ZFLS  505 5063
       Coding: 8103
       ROD: EV_SteerAssisMQB.rod
       VCID: 393AC3AAB8D0AB8E96-806C
    Address 47: Sound System (J525)       Labels:| 5Q0-035-456.clb
       Part No SW: 5Q0 035 456     HW: 5Q0 035 456
       Component: MIB2_lite_amp H20 0130
       Revision: 00000001    Serial number: VWZ8Z1FBA01GG51
       Coding: 12000000008AAA8A000000000000
       ASAM Dataset: EV_AMPMst11CGen2ALPI 001003
       ROD: EV_AMPMst11CGen2ALPI_VW37.rod
       VCID: 6D9227FABC18C72E4A-8038
       Serial number: 080116EA801099
       Coding: 003F0120DC00040100801000
       VCID: 42C8A446D506E856C7-8016
       Coding: 029203000B010200
       VCID: 40CCAE4EDB0AFA46D1-8014
       Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
       Coding: 2E0000
       Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
       Coding: 2E0000
       Part No SW: 3G0 035 045 B    HW: 3G0 035 045
       Component: MU-H-N-RW     H50 0343
       Serial number: A688A0GB002325
       Coding: 0273000C0000000051110002001828001F0203F401200100DF
       Component: ABT_High  H62 0031
       Serial number: VWZ8Z9RU304VU1
       Subsystem 2 - Part No SW: V03 959 801 ED    HW: -----------
       Component: ROW 2017/2018  --- 0065
       Component: Gracenote2  --- 4008
       Part No SW: 5G0 907 159 E    HW: 4H0 907 159 A
       Component: SAS-GEN 2     H07 0002
       Serial number: 151216201255
       ROD: EV_SoundActuaGen2AU64X_VW26.rod
       VCID: 302CFE8E6BAA6AC621-8064
    End----------(Elapsed Time: 01:47, VBatt start/end: 12.3V/12.3V)-----------
    this the autoscan after the blind spot (lane change assist) retrofit.
  4. Likes Uwe, downtime liked this post
  5. #13
    Jan 2018
    Kuwait
    ;SW:5Q0-907-686-B HW:5Q0-907-686-B --- Lane Change
    ;Component:HRE_Master H11 0071 Coding:01031103
    ;EV_HREntryHella 1028 EV_HREntryHella_VW32.rod
    ;Tuesday 13 February 2018 17:56:28:35129
    ;VCDS Version: Release 17.8.1 (x64) Data version: 20171130 DS276.6
    ;VCID: 3C34DABEB7E29EA68D-8068
    IDE02332-Deactivate production mode Deactivating 3
    IDE05397-Calibration mode not activated 1
    IDE80001-Analysis 1 not activated 1
    IDE80004-Analysis 4 not activated 1
    Elapsed Time: 00:01
    ;Tuesday 13 February 2018 17:56:51:35129
    Elapsed Time: 00:01
    This is the admap for the 3c module
  6. Likes downtime liked this post
  7. #14
    Apr 2015
    Ponferrada of Spain
    Hi @Qassem
    You look my retrofit Blind Spot with Rear Traffic.
    http://forums.ross-tech.com/showthre...ll=1#post71716
    Regards
  8. Likes Qassem liked this post
  9. #15
    Dec 2015
    Such a shame its in spanish...
    16 Skoda Superb Combi 1.4 TSI ACT DSG Ambition + - Magnetic Brown
    16 VW Golf 1.0 TSI BlueMotion Style - Pure White
