Dear Friends,
I need you help with connecting the last wire in the circuit,
also I need your help with coding.
This is the parts:
Look what I found on AliExpress
https://www.aliexpress.com/item/32581706595/32581706595.html
this is the circuit.
https://imgur.com/a/FU2kV
Where is A200 point (Positive connection 5 (15a) (in instrument panel wiring harness)
It’s the same as fuse Sc32 wire ?? , how I can connect it ? can I just tap it to fuse from the front ??
when I did so , message appeared that the front assist is deactivated and it keep popping up in the middle cluster, so I remove it.
this is Auto scan after the canbus connection done (without connecting the fuse 32A c)
what is the address of the modules ???
is it appeared here, or I need to do fuse 32A first??
This is the parts:
Saturday,10,February,2018,21:12:02:35129
VCDS Version: 17.8.1.0 (x64) HEX-NET CB: 0.4409.4
VIN: WVWFM2AUXGW246170 License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 10 13 14 15 16 17 19 32 42 44 47 52 55 5F A9
VIN: WVWFM2AUXGW246170 Mileage: 25905km-16096miles
Address 01: Engine (J623-CJXE) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 K HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0001
Revision: --H13---
Coding: 091D00122464050B2000
ASAM Dataset: EV_ECM20TFS0205G0906259K 001002
ROD: EV_ECM20TFS0205G0906259F_VW37.rod
VCID: 3620C89689CE44F67B-8062
Readiness: 1110 0001
Part No SW: 0D9 300 020 K HW: 02E 927 770 AQ
Component: DQ250-6V MQB H53 4904
Revision: 06253104 Serial number: TFK01601191468
Shop #: WSC 04742 780 00200
ROD: EV_TCMDQ250021_VW37.rod
VCID: 1D72373A0C38F7AE9A-8048
P1734 00 [002] - -
Part No SW: 3Q0 907 379 AB HW: 3Q0 907 379 G
Component: ESC H42 0723
Revision: 00000000 Serial number: 60246000000551
Coding: 01FA6BA1542429720778060741C36980D62A94E0608296F7184250B9C208
VCID: 7AB81CA6FD566096DF-802E
Part No SW: 5G0 907 044 BD HW: 5G0 907 044 BD
Component: Climatronic H03 1001
Revision: 00001K08
Coding: 00020014200100001005000012101402
VCID: 6A982CE68DF6D0162F-803E
Air quality sensor:
Part No SW: 5Q0 937 084 AS HW: 5Q0 937 084 AN
Component: BCM MQBAB H H24 0175
Serial number: 01061602803455
Coding: 00101A46C20122F34B644000000C07281000000000000000000000000000
ROD: EV_BCMBOSCH_015_VW37.rod
VCID: 095A736AA8B07B0EC6-805C
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 160118 043 0551
Serial number: 160202045705
Component: RLHS 037 0059
Serial number: S2Y16M02D08H10M34S06
Coding: 90A8DD
Sun Roof:
Subsystem 3 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
Component: J245 PS73.403 H03 0004
Serial number: 0000FST000RK8J200000
Coding: 181801
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-283.clb
Part No SW: 5Q0 919 283 G HW: 5Q0 919 283
Component: PARKHILFE 4K H10 0056
Revision: -------- Serial number: 39291603300852
Coding: 0001150011
ASAM Dataset: EV_EPHVA14AU3700000 002024
VCID: 3D32D7BAACF897AEBA-8068
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 F HW: 5Q0 907 572 F
Component: ACC Bosch MQB H05 0400
Serial number: 02011604400195
Coding: 001C1300FE0739
ASAM Dataset: EV_ACCMRRBoschVW372 001016
VCID: 3A38DCA6BDD6A0969F-806E
Part No SW: 5Q0 907 376 A HW: 5Q0 907 376 A
Component: DAEMPFUNGS-SG H17 0120
Serial number: 29121541350443
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 373EC5928EC4BDFE60-8062
Part No SW: 5Q0 959 655 D HW: 5Q0 959 655 D
Component: AirbagVW20 015 0388
Serial number: 003F6R1CV8AR
VCID: 41CAAB4AD000F34EDE-8014
Subsystem 1 - Part No SW: ----------- HW: 480 000 902 16
Serial number: 35767000000E9650291V
Subsystem 2 - Part No SW: ----------- HW: 480 000 902 16
Serial number: 3586700000038644881S
Subsystem 3 - Part No SW: ----------- HW: 480 400 202 16
Serial number: 3516502B71EDD3E4637W
Subsystem 4 - Part No SW: ----------- HW: 480 400 202 16
Serial number: 3526502B71EDD3E591A
Subsystem 5 - Part No SW: ----------- HW: 480 400 502 16
Serial number: 3556502AD1EDD3E150D/
Part No SW: 5Q0 953 521 P HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0195
Revision: FF033033 Serial number: 20160204500421
Coding: 0410
ROD: EV_SMLSVALEOMQB_VW37.rod
VCID: 3FCEADB2A6F485BEA8-806A
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb
Part No SW: 5G0 920 756 HW: 5G0 920 756
Component: KOMBI 302 6420
Coding: 47AD01083F80000801886A011400000000000000
VCID: 699A53EA88F0DB0E26-803C
Part No SW: 5Q0 907 530 AJ HW: 5Q0 907 530 M
Component: GW MQB High 212 2246
Revision: -------- Serial number: 30011610802973
Coding: 030100043F085900FB00027B9C0F00010001050000000000000000000000
ROD: EV_GatewConti_013_VW37.rod
VCID: 79BA03AAF8506B8ED6-802C
Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0040
Serial number: 29160000048900016026
Coding: 2DFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Component: J367-BDMHella H04 8050
Serial number: 6060799103
Address 32: Differential Locks (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 E HW: 0CQ 907 554 E
Component: Quersperre H52 8042
Serial number: HA1-00023.11.15
Coding: 0001
ASAM Dataset: EV_LockElectHA1VW37X 001007
ROD: EV_LockElectHA1VW37X.rod
VCID: 47DEB552FE24CD7E10-8012
Component: TSG FS 020 0041
Serial number: 070116EA606676
Coding: 003E0320D000040100001000
VCID: 43C6A142CA1CE15ECC-8016
Part No SW: 3Q0 909 144 J HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5063
Coding: 8103
ROD: EV_SteerAssisMQB.rod
VCID: 393AC3AAB8D0AB8E96-806C
Address 47: Sound System (J525) Labels:| 5Q0-035-456.clb
Part No SW: 5Q0 035 456 HW: 5Q0 035 456
Component: MIB2_lite_amp H20 0130
Revision: 00000001 Serial number: VWZ8Z1FBA01GG51
Coding: 12000000008AAA8A000000000000
ASAM Dataset: EV_AMPMst11CGen2ALPI 001003
ROD: EV_AMPMst11CGen2ALPI_VW37.rod
VCID: 6D9227FABC18C72E4A-8038
Component: TSG BFS 020 0041
Serial number: 080116EA801099
Coding: 003E0120D000040100801000
VCID: 42C8A446D506E856C7-8016
Component: AFS-ECU H07 0090
Coding: 029203000B010200
VCID: 40CCAE4EDB0AFA46D1-8014
Subsystem 1 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0002
Coding: 2E0000
Subsystem 2 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0002
Coding: 2E0000
Part No SW: 3G0 035 045 B HW: 3G0 035 045
Component: MU-H-N-RW H50 0343
Serial number: A688A0GB002325
Coding: 0273000C0000000051110002001828001F0203F401200100DF
Subsystem 1 - Part No SW: 5G0 919 606 HW: 5G0 919 606
Component: ABT_High H62 0031
Serial number: VWZ8Z9RU304VU1
Subsystem 2 - Part No SW: V03 959 801 ED HW: -----------
Component: ROW 2017/2018 --- 0065
Component: Gracenote2 --- 4008
Part No SW: 5G0 907 159 E HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0002
Serial number: 151216201255
VCID: 302CFE8E6BAA6AC621-8064
End----------(Elapsed Time: 01:42, VBatt start/end: 12.5V/12.4V)-----------
