Well...
I own two (2) cars VAG cars, a 2010 Audi A3 (8P) (My car) and a 2013 VW Jetta SEL (Wifey's car). I decided to grab a HEX-V2 so I could activate the reversing/backup camera that I just installed on the Jetta - Rather than paying a VW dealership an hour of labor to make it happen.
Anyway. Prior to purchase, I looked at some videos on The YouTubes and read thru some of the HEX-V2 manual. Activating the camera seemed pretty straightforward. So. I managed to get that done, I also activated the Instrument/Gauge 'celebration' on the Jetta. EZ-Peezy.
Then I connected the set-up to my Audi. Managed to enable (disable?) the Fog Lights w/High Beams On. So. That's pretty cool.
Beyond all that, I'm not sure what else I should do. Learning (anything beyond very basic) features on this tool seems akin to learning another language...and I have enough trouble keeping English in my thinker.
I'm pretty sure I have successfully saved a logfile - and seem to have some faults (on the Audi). Going to try to post it below.
Not quite sure where to go from here...
- I'd like to get the 'bulb out' warning(s) off the dash - which have been there since I installed LED bulbs.
- I'd like to get the Air Bag warning light to disappear - it's been on since I took the passenger seat out to vacuum below it (yes, all wires were reconnected properly & verified as solid. twice, actually).
- I don't think the radio faults are going away - as I've replaced the factory radio with an Android unit.
- The 'misfire' doesn't seem to have occurred much - the coils were all replaced about 1500-miles ago.
Thoughts?
Any feedback is much appreciated.
Brad R
Thoughts?
Brad R
Friday,09,February,2018,11:38:22:42977
VCDS Version: 18.1.0.2 (x64) HEX-V2 CB: 0.4411.4
VIN: WAUMFAFM8AA145568 License Plate: -ING
Mileage: 182160km-113188mi Repair Order:
Chassis Type: FM-AU35 (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 22 25 42 44 46 47 52 55 56 62
65 72 77
VIN: WAUMFAFM8AA145568 Mileage: 182160km-113188miles
Address 01: Engine (CCT) Labels:. 06J-906-026-CCT.clb
Part No SW: 8P0 907 115 AM HW: 8P0 907 115 Q
Component: 2.0l R4/4V TFSI 0020
Revision: AAH16--- Serial number: AUX7Z0J2FN20IQ
Coding: 0103010A1C0F0160
Shop #: WSC 06314 000 00000
VCID: 7DA7046271FB10FF033-8028
P0300 - 000 - - Intermittent
Mileage: 181916 km
Date: 2018.02.03
Time: 22:25:17
RPM: 1094 /min
Load: 58.0 %
Temperature: 3.0°C
Temperature: 3.0°C
Absolute Pres.: 980.0 mbar
Voltage: 14.097 V
000770 - Cylinder 2
P0302 - 000 - Misfire Detected - Intermittent
Mileage: 181916 km
Date: 2018.02.03
Time: 22:26:06
RPM: 847 /min
Load: 24.7 %
Temperature: 15.0°C
Temperature: 3.0°C
Voltage: 14.224 V
Part No SW: 02E 300 012 K HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2111
Revision: 51112 Serial number: 00001002270002
VCID: 186935F67E99D5D7B05-804C
Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 1150600F492600FF881006EA92210041390000
VCID: 7AAD0F7E6CD527C7261-802E
Part No SW: 8P0 820 043 BN HW: 8P0 820 043 BN
Component: KlimavollautomatH09 0150
Revision: 000887 Serial number: 8P0820043BN
VCID: 79AF107265D32CDF2FB-802C
Fault Status: 00101001
Reset counter: 5
Mileage: 180516 km
Date: 2018.01.12
Time: 08:09:15
Temperature: -9.5°C
Voltage: 14.50 V
RPM: 1450 /min
Load: 9.0 %
Address 09: Cent. Elect. (J519) Labels:. 8P0-907-063.clb
Part No SW: 8P0 907 063 D HW: 8P0 907 063 D
Component: BCM PQ35 M 105 0575
Revision: 00105 AK
Coding: 2E000A0FB01336E4287041E000100D4D411E62AA104DD929E40008840040
VCID: 3537DC42054B08BF8B3-8060
Subsystem 1 - Part No SW: 8P1 955 119 F HW: 8P1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00DD13
Fault Status: 00101100
Reset counter: 28
Mileage: 148051 km
Date: 2015.09.22
Time: 11:22:32
Voltage: 14.45 V
Term 50 Off
Fault Status: 00101110
Reset counter: 31
Mileage: 167267 km
Date: 2016.06.18
Time: 09:47:42
Voltage: 13.60 V
Term 50 Off
Part No SW: 8E0 035 593 P HW: 8E0 035 593 P
Component: SDAR SIRIUS H07 0160
Revision: 00000000 Serial number: AUZ4Z7K0571506
Coding: 0000100
VCID: 3635DB4E144D03A7829-8062
Fault Frequency: 9
Reset counter: 216
Mileage: 180954 km
Date: 2018.01.16
Time: 08:13:34
01304 - Radio
Fault Frequency: 234
Reset counter: 31
Mileage: 182165 km
Date: 2018.02.09
Time: 07:41:00
Address 15: Airbags (J234) Labels:| 8P0-959-655-10.clb
Part No SW: 8P0 959 655 Q HW: 8P0 959 655 Q
Component: Airbag AU1042 H06 0160
Revision: -------- Serial number: 003FC00153B7
Coding: 303142393041303030374A55304C38503053
VCID: 50F98DD69A694D97B85-FFFE
Subsystem 1 - Part No SW: 8P0 910 339 C HW: 8P0 959 339 C
Component: BF-Gewichtss. H02 0030
Serial number: 5810000R0000004CR7
Subsystem 2 - Serial number: 3572DRB40000AE3921D
Subsystem 3 - Serial number: 3582DRB40000AE3449D1
Subsystem 4 - Serial number: 35128RB4000056B7D99Z
Subsystem 5 - Serial number: 35228RB4000056C1F09O
Subsystem 6 - Serial number: 35547RB40000573B6B5S
Subsystem 7 - Serial number: 35647RB40000573C4ADZ
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
Component: J0527 H37 0070
Coding: 0014142
VCID: 46D5AB8E64AD9327129-8012
Component: E0221 H02 0100
Part No SW: 8P0 920 982 N HW: 8P0 920 982 N
Component: KOMBIINSTR. VDO H03 0990
Revision: D0H03005 Serial number: 2242J005002261
Coding: 0017288
Shop #: WSC 62954 001 1048576
VCID: 44D1B1865291A1370CD-8010
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H16 0233
Revision: H16 Serial number: 4520K1030100D0
Coding: ED837F07100702002102
VCID: 698F403215739C5FDFB-803C
01304 - Radio
Reset counter: 30
Mileage: 167438 km
Part No SW: 0BR 907 554 A HW: 0BR 907 554 A
Component: Haldex 4Motion 3016
Coding: 0000005
VCID: 43D3B29A579FA60F357-8016
Revision: D0H03005 Serial number: AUX7Z0J2FN20IQ
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 N HW: 8P0 959 801 N
Component: Tuer-SG H04 0100
Coding: 0001213
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 232 3501
Revision: 00H22000
VCID: 392FD0722553ECDF6FB-806C
Part No SW: 8P4 035 382 E HW: 8P4 035 382 E
Component: AB2 SUBWOOFERBOXH07 0180
Revision: 00006 Serial number: 92158067916442
Part No SW: 8P0 959 802 N HW: 8P0 959 802 N
Coding: 0001213
VCID: 47CBA68A63A78A2FE9F-8012
Part No: 8P3 907 357
Coding: 0000013
VCID: 7AAD0F7E60D527C7261-802E
Address 56: Radio
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 F HW: 8P4 959 801 F
Component: Tuer-SG H04 0050
Coding: 0001176
Shop #: WSC 06314 000 1012544
VCID: 42DDB79E4885AF073E1-8016
Address 65: Tire Pressure Labels: 8J0-907-273.lbl
Part No SW: 8J0 907 273 A HW: 8J0 907 273 A
Component: J502-RDK H03 0370
Revision: --H03-H0 Serial number: 13373700443496
Coding: 0860021
Shop #: WSC 06435 000 00000
VCID: 2F3BEE2AEB17326FC1F-807A
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 F HW: 8P4 959 802 F
Coding: 0001176
Part No SW: 8P0 862 335 AB HW: 8P0 862 335 T
Component: FSE_256x BT H38 0600
Revision: 00000000 Serial number: 00000005032491
Coding: 0001277
VCID: 76B51B4E54CD43A7429-8022
02503 - Output Wire to Radio
Reset counter: 119
Mileage: 167438 km
Date: 2016.06.21
Time: 18:42:34
End----(Elapsed Time: 01:36, VBatt start/end: 11.8V/11.9V. VIgn 11.9V)-----
