Results 1 to 10 of 13
Thread: 07 Q7 4.2 TDI engine run away
    Apr 2017
    This morning after dropping the kids off at school I had the scare of my life. I pulled away from the intersection and accelerated like normal and I noticed it started to knock just a bit I didn't think anything of it when all of a sudden the Revs took off and continued to climb even with my foot off the throttle. I put it in neutral and shut it off as fast as I could but not before I saw the tach go past the 6k mark. It did shut down when I hit the button to turn it off and I got it off to the side of the road. I was surprised to not see the engines guts layed out all over the road to be honest. I checked the oil and fluid levels everything was fine. Turbos were both dry. I got back in it and tried to crank it which it did slowly at first than spun over like it normally does just wouldn't fire. It took me a good 5-10 minutes of cranking it on and off to get it to fire and I drove it home like nothing happened no noises no smoke no running rough. pulled the codes out of it when I got home and was a bit stumped. first code that popped up was an interesting one p0219- Maximum engine speed exceeded engine warranty VOID! freeze frame of 5334 rpm 4.6nm 68.4km/h time .10ms pressure 483.0 bar. Also had p2196 Signal too high (rich) lambda sensor B1 S1. freeze frame on that had me a bit confused also as it was 3612 rpm 586.7nm 67.3km/h duty cycle 100.2% mass air/rev 1110.4 mg/str. I don't think its the turbos to be honest I think its somehow overfueling but why? It just isn't making any sense. engine just turned 120k miles.
    Friday,09,February,2018,12:59:13:30922
    VCDS Version: 18.1.0.2 (x64)  HEX-V2 CB: 0.4411.4
    VIN: WAUZZZ4L07D104638   License Plate: OE07NPJ
    Mileage: 193310km-120117mi   Repair Order:
    Chassis Type: 4L (4L0)
    Scan: 01 02 03 05 06 07 08 09 0E 11 31 15 16 17 18 19 1E 34 36 37
              42 46 47 4F 52 55 56 61 62 67 69 6D 6F 72 76 77
    VIN: WAUZZZ4L07D104638   Mileage: 193310km-120117miles
    11-Engine II -- Status: Malfunction 0010
    31-Engine other -- Status: Malfunction 0010
       Part No SW: 4L0 910 409     HW: 4E1 907 409 B
       Component: 4.2L V8TDI  G001AGMŖ0020
       Revision: --H04---    Serial number:
       Coding: 0011779
       Shop #: WSC 31414 790 00001
       VCID: 6788B214F36A589FC9F-8032
    009299 - Diesel Particle Filter; Differential Pressure Sensor
                   P2453 - 003 - Implausible Signal
                        Fault Status: 01110011
                        Pressure: 57 mbar
                        Pressure: 0 mbar
                        Temperature: 243.6°C
                        Temperature: 226.2°C
                        (no units): 2.0
                        Pressure: 50 mbar
    008598 - Oxygen (Lambda) Sensor B1 S1
                   P2196 - 001 - Signal too High (Rich) - Intermittent
                        Fault Status: 00100001
                        Mileage: 193272 km
                        Date: 2018.02.08
                        Time: 20:45:07
                        RPM: 3612 /min
                        Torque: 586.7 Nm
                        Speed: 67.3 km/h
                        Duty Cycle: 100.2 %
                        Mass Air / Rev.: 1110.4 mg/str
                        (no units): 0.80
                        (no units): 0.0
    000537 - Maximum Engine Speed Exceeded: Engine Warranty VOID!
                   P0219 - 000 - -) - Intermittent
                        Mileage: 193305 km
                        Date: 2018.02.09
                        Time: 08:37:20
                        RPM: 5334 /min
                        Torque: 4.6 Nm
                        Speed: 68.4 km/h
                        Time: 0.10 ms
                        Voltage: 14.06 V
                        Pressure: 483.0 bar
                        RPM: 2730 /min
    000801 - Engine Speed Sensor (G28)
                   P0321 - 001 - Implausible Signal - Intermittent
                        Mileage: 193305 km
                        Date: 2018.02.09
                        Time: 08:37:20
                        RPM: 5334 /min
                        Torque: 4.6 Nm
                        Speed: 68.4 km/h
                        (no units): 4.0
                        Voltage: 14.06 V
                        (no units): 478.8
                        (no units): 434.0
    Readiness: 1 1 0 0 0
       Part No SW: 09D 927 750 FE    HW: 09D 927 750 FE
       Component: AL 750 6A           1050
       Revision: 00H64000    Serial number:
       Coding: 0000504
       VCID: 76B6EF50A4C0B117429-8022
       Part No SW: 4L0 910 517 K    HW: 4L0 614 517 K
       Revision: 00H30001
       Coding: 0103569
       Shop #: WSC 22234 221 23456
       VCID: 323E13400828ED37AE1-8066
       Component: FBSAUDIC6 ELV   H31 0220
       Revision: 31050601    Serial number: 10601100732280
       Coding: 0000151
       VCID: 6390A604075234BF157-8036
       Subsystem 1 - Part No: 4F0 910 131 G
       Component: FBSAUDIC6 KSG   H27 0080
    00191 - Passenger's Door Handle Touch Sensor (G416)
                007 - Short to Ground
                        Fault Status: 01110111
                        Reset counter: 13
                        Mileage: 193316 km
                        Date: 2018.02.09
                        Time: 09:41:27
    00192 - Rear Left Door Handle Touch Sensor (G417)
                        Reset counter: 13
                        Mileage: 193316 km
                        Date: 2018.02.09
                        Time: 09:41:27
                        Reset counter: 13
                        Mileage: 193316 km
                        Date: 2018.02.09
                        Time: 09:41:27
                        Reset counter: 53
                        Mileage: 193316 km
                        Date: 2018.02.09
                        Time: 12:47:45
       Part No SW: 4F0 910 760     HW: 4L0 959 760
       Component: Sitzmemory BFS  H01 0100
       Revision: 00000000    Serial number: 00000000896401
       Coding: 0078944
       VCID: 619CAC0C1D4E26AF07B-8034
    Address 07: Control Head        Labels: 4L0-910-7xx-07-H.clb
       Part No SW: 4L0 910 732 S    HW: 4E0 035 729
       Component: Interfacebox    H43 5150
       Revision: 00000000    Serial number: 386DX077540827
       Coding: 0002002
       VCID: 392C246CD55E1E6F6FB-806C
       Subsystem 2 - Serial number: 00000001337903
       Subsystem 3 - Serial number: 0123.06.090000000100010489’
       Subsystem 4 - Serial number: 010489’
    02257 - Remote Control Receiver
                014 - Defective
                        Fault Status: 01101110
                        Reset counter: 13
                        Mileage: 193316 km
                        Date: 2018.02.09
                        Time: 09:22:59
       Part No SW: 4L0 910 043     HW: 4L0 820 043 E
       Revision: 00---012    Serial number: 00000000111993
       Coding: 0001048
                014 - Defective
                        Reset counter: 13
                        Mileage: 193316 km
                        Date: 2018.02.09
                        Time: 09:23:18
                        Temperature: 13.0°C
                000 -  -  - Intermittent
                        Reset counter: 53
                        Mileage: 193316 km
                        Date: 2018.02.09
                        Time: 12:47:48
                        Voltage: 12.10 V
       Part No SW: 4F0 910 279 J    HW: 4F0 907 279 A
       Coding: 0113121
       VCID: 303A19480624DF27D85-8064
       Subsystem 1 - Part No: 4L2 910 113   Labels: 1KX-955-119.CLB
       Component: Wischer AU716   H09 0080
       Coding: 00064792
       Shop #: WSC 31414
       Coding: 00150059
       Shop #: WSC 31414
       Part No SW: 4L0 910 110 B    HW: 4L0 035 110
       Component: MP3-Changer     H43 0390
       Revision: 00043000    Serial number: AUZ5ZBG1059061
       VCID: 1E66D7F06CB059577A9-804A
    Address 11: Engine II        Labels: Redir Fail!
       Component: 4.2L V8TDI  G001AGSŖ0020
       Coding: 0011779
       Shop #: WSC 10285 210 01865
    008600 - Oxygen (Lambda) Sensor B2 S1
                   P2198 - 001 - Signal too High (Rich) - Intermittent
                        Mileage: 193272 km
                        Date: 2018.02.08
                        Time: 20:45:07
                        RPM: 3780 /min
                        Torque: 591.4 Nm
                        Speed: 66.1 km/h
                        Duty Cycle: 100.2 %
                        Mass Air / Rev.: 1069.3 mg/str
                        (no units): 0.60
                        (no units): 0.0
       Part No SW: 4L0 910 655 B    HW: 4L0 959 655
       Component: 31 AIRBAG AUDI8RH39 0120
       Revision: 06H39000    Serial number: 0037GD09D2G-
       Coding: 0013105
       VCID: 2C020D382A0CBBC7E4D-8078
       Subsystem 1 - Serial number: 6332QSME29533D3BO
       Subsystem 2 - Serial number: 6342QSME2C094D75S
       Subsystem 3 - Serial number: 6352QSME286B205BM
       Subsystem 4 - Serial number: 6362QSME293234359
       Subsystem 5 - Serial number: 63734SME25223F27$
       Subsystem 6 - Serial number: 63834SME252B2761
       Revision: 00H08000    Serial number: 90026071160011
       Coding: 0112142
       VCID: 6696BF10F4604197F29-8032
    Address 17: Instruments        Labels: 4L0-910-xxx-17.lbl
       Part No SW: 4F0 910 930 C    HW: 4L0 920 980 G
       Component: KOMBIINSTR. M73 H18 0240
       Revision: 00400000    Serial number: 5HJ304357
       Coding: 2657448
       Shop #: WSC 00581 210 64475
       VCID: 2310E60447D274BF557-8076
    Address 18: Aux. Heat        Labels: None
       Part No SW: 4L0 910 105     HW: 4L0 815 071 D
       Component: Heizgeraet      H08 0080
       Revision: 0000000C    Serial number: 00000009014264
       VCID: 609AA90816442FA7085-8034
       Part No SW: 4L0 910 468     HW: 4L0 907 468
       Component: J533__Gateway   H06 0040
       Revision: 00H06000    Serial number: 0900B07425806D
       Coding: F7DBBFFF707202
       VCID: 6C82CD38EA8C7BC7A4D-8038
    Address 1E: Media Player 2 (R199)       Labels:. 4E0-035-785.lbl
       Part No SW: 4E0 035 785 E    HW: 4E0 035 785 B
       Component: SG ext.Player H09 0840
       Revision: 00000000
       VCID: 2A0E0B202CF8A5F7161-807E
    Address 34: Level Control        Labels: None
       Part No SW: 4L0 910 553 C    HW: 4L0 907 553
       Component: LUFTFDR.-CDC    H03 7660
       Revision: --H03001    Serial number: 15.1528-0096.2
       Coding: 0015520
       VCID: 2A0E0B2020F8A5F7161-807E
                        Reset counter: 53
                        Mileage: 193316 km
                        Date: 2018.02.09
                        Time: 12:37:08
                        Error Code: 13
       Component: Sitzmemory FS   H01 0100
       Coding: 0074858
       Part No SW: 4E0 910 888 P    HW: 4E0 919 887 M
       Component: MNS ECE         H49 1060
       Revision: 00000000    Serial number: 399D1077573648
       Shop #: WSC 00196 210 90007
       VCID: 3B203E64DF622C7F7D7-806E
                        Reset counter: 53
                        Mileage: 193316 km
                        Date: 2018.02.09
                        Time: 12:47:46
                        Hex Value: 0x5A7D
                        Hex Value: 0x9872
                        Hex Value: 0x004D
    Address 42: Door Elect, Driver        Labels: 4L0-910-793-42.lbl
       Part No SW: 4L0 910 793 B    HW: 4L0 959 793 B
       Component: TSG FA          H12 0150
       Revision: 00-00000
       Coding: 0019163
       VCID: 2F381A341B1AC0DFC1F-807A
       Part No SW: 4L0 910 289 F    HW: 4L0 907 289 C
       Component: Komfortgeraet   H07 0040
       Revision: 0040 ---    Serial number: 01041657000000
       Coding: 7348475
       VCID: 33301644F732E43FA57-8066
    01699 - Motor for Central Locking; Hatch/Trunk (V53)
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 6
                        Mileage: 178192 km
                        Date: 2017.08.09
                        Time: 11:52:00
    Address 47: Sound System        Labels: 4L0-910-223-BO.lbl
       Part No SW: 4L0 910 223 G    HW: 4L0 035 223 D
       Component: DSP-High AU716  H03 0150
       Revision: PROD_01     Serial number: 00000000022118
       Coding: 0000023
       VCID: 280AF1283EF497E7005-807C
       Part No SW: 4F0 910 280     HW: 4F0 907 280 E
       Revision:             Serial number: 00000000019220
       Coding: 0011101
       VCID: 5EE697F02C3019573A9-800A
    Address 52: Door Elect, Pass.        Labels: 4L0-910-793-52.lbl
       Part No SW: 4L0 910 793 B    HW: 4L0 959 792 B
       Component: TSG BF          H12 0150
       Revision: 00-00000
       Coding: 0019163
                        Reset counter: 13
                        Mileage: 193316 km
                        Date: 2018.02.09
                        Time: 09:25:32
       Coding: 0000022
       VCID: 290CF42C25FEAEEF1FB-807C
       Part No SW: 4E0 910 541 Q    HW: 4E0 035 541 S
       Revision: 00000000    Serial number: 388DY077619207
       VCID: 2E0607301C10C9D7CA9-807A
       Part No SW: 4L0 910 181     HW: 4L0 915 181
       Component: J0644 BEM       H12 0530
       Revision: --------    Serial number: 00000000021809
       VCID: 6492A518025C3387ECD-8030
       Component: von VA0  30010993D0
       Coding: 344630393135313035442056413033303031303939334430
       Shop #: WSC 00359 210 91468
                        Mileage: 193316 km
                        Date: 2018.02.09
                        Time: 09:39:19
    Address 62: Door, Rear Left        Labels: 4L0-910-795.lbl
       Part No SW: 4L0 910 795 B    HW: 4L0 959 795 B
       Coding: 0018442
       VCID: 313C1C4C0D2ED62FD7B-8064
                        Reset counter: 13
                        Mileage: 193316 km
                        Date: 2018.02.09
                        Time: 09:26:26
       Part No SW: 4E0 910 754 S    HW: 4E0 035 753 A
       Component: SDS 3502 UK     H45 0630
       Revision: 00000000    Serial number: 00000703300521
       Shop #: WSC 12336 024 394758
       VCID: 36362F50E440F117829-8062
    Address 69: Trailer        Labels: None
       Part No SW: 4L0 910 383     HW: 4L0 907 383
       Component: ANHAENGERELEKTR 003 0020
       Coding: 0000101
       VCID: 688AB128FE7457E7C05-803C
       Part No SW: 4L0 910 945     HW: 4L0 827 851 B
       Component: ValeoHeckdeckel H21 0280
       Revision: --H21001    Serial number: E5030000B
       Shop #: WSC 98765 666 38354
       Subsystem 3 - Serial number: RD28.04.07--H21001001B0232’
       Subsystem 4 - Serial number: 1B0232’
       Part No SW: 4L0 910 290     HW: 4L0 907 290
       Revision: AAH05061    Serial number: 002667307-----
       VCID: 6594B81C09664A8FFB3-8030
    02960 - Lamp in Bumper; Rear Left
                        Reset counter: 13
                        Mileage: 193316 km
                        Date: 2018.02.09
                        Time: 09:26:39
                        Bin. Bits:  000 001
    Address 72: Door, Rear Right        Labels: 4L0-910-795.lbl
       Part No SW: 4L0 910 795 B    HW: 4L0 959 794 B
       Coding: 0018442
                        Reset counter: 13
                        Mileage: 193316 km
                        Date: 2018.02.09
                        Time: 09:26:55
       Part No SW: 4F0 910 283 G    HW: 4F0 919 283 G
       Component: Parkhilfe 8-Kan H12 0060
       Revision: 00H12000    Serial number: 06330711309778
       Coding: 0211146
       Part No SW: 4E0 910 336 M    HW: 4E0 862 335
       Component: Handyvorb2      H18 1130
       Revision: 00000000    Serial number: 00000005127875
       Coding: 0010900
       Shop #: WSC 00359 210 62483
    End----------(Elapsed Time: 02:28, VBatt start/end: 13.7V/13.5V)-----------
  2. Likes Uwe, Jack@European_Parts liked this post
  3. #2
    Apr 2017
    Got to spend a bit of time with it today and do a bit of poking around. There isn't a lot of information out there on these engines as they just aren't that common (I don't know why they aren't they are a ball to drive) Turns out the oil level was over full by a lot. I dumped it as it was due to be serviced anyway and took over 15L out of it (holds 9-9.5 to begin with). Turns out that differential pressure sensor is causing it to try to regen all the time and these don't have a separate injector for the DPF's they use the engine injectors on the exhaust stroke. So now I am stuck with the decision to either delete the DPF's (don't need them they weren't required for that year) or pull the transmission and replace the £30 sensor.
    Was the oil contaminated with diesel fuel to a degree raising that sump level and run away or was it actually overfilled?
    Could be leaky or stuck injector......
    Add a good lubricity additive to fuel.
    Above Magic!
  5. Likes Uwe liked this post
  6. #4
    Apr 2017
    contaminated with diesel. It failed the drip test on a plain sheet of paper with flying colors and when it came out it looked like water and definitely smelled like diesel once it was in the drain pan. injectors all look good on VCDS. I'm going to run it in a bit and see what it does now that its got fresh oil in it and at its proper level. I didn't fill it to the full line this time around I left it in the middle so I can keep an eye on the level and see what it does. I ordered 2 new differential pressure sensors too (might as well do both while I have the trans pulled down). Going to try to lower the tail of the transmission and see if I can sneak my arms up in there to change the sensors out.
  7. Likes Uwe liked this post
  8. #5
    I would observe VCDS blocks to see if any type of balance indication is possible and if not remove injector lines and units for complete inspection.
    You could also measure exhaust manifold banks for a colder port with temp gun or watch with infrared camera like I do.
    You don't want to risk filling the sump with such fuel contamination because this will be the kiss of death for turbo's and engine life.
    Do yourself a favor and save that V8 before it becomes FUBAR !
    Above Magic!
  9. #6
    Apr 2017
    The injector balance was one of the first things I checked and all are pretty much dead nuts equal % wise in the measuring blocks. It’s tough to figure out what is what in the measuring blocks on VCDS too as there just isn’t that much information out there for that engine and it doesn’t tell you what it what for most of the blocks. Most dpf stuff is in the 60-70 range for every other vag diesel this one is I think 102-106. It’s saying the dpf is full (it isn’t I’ve checked it) I don’t know how long that sensor has been like that trying to get it to regen when it doesn’t need to. I haven’t owned it for all that long either which makes it even harder to figure out what is going on as I don’t know what is truly normal for it.
    UPDATE
    no need to further diagnose I took it out for a drive around the block and it seized up. I guess the damage was already done. Now to search for a replacement lump.
  10. #7
    Nov 2017
    Serbia
    That sounds familiar. Recently I had 2007 A6 3.0 tdi with same problem. The customer said that car just catapulted on its own on the highway. It turned out that it was constantly trying to do regen. In the end oil was so diluted from diesel that it passed by seals on the turbo and ........ I drained around 16l of fluid from the sump. But in this case engine survived.
  11. Likes Jack@European_Parts, Uwe, vodonnell liked this post
  12. #8
    Apr 2017
    I'm going to try to pull the DPF's off it tomorrow I went out and started it today and it was quiet as a mouse but wasn't running right. I may just have a blocked up DPF on one of the banks. I'm crossing my fingers and hoping. I did find a company local that will pull the motor refurb it and reinstall with 2 new turbos for £5k all said and done if it is indeed the engine. I was looking today and I don't think I can get the sump off without pulling the motor to check the crank and rod bearings.
  13. #9
    Quote Originally Posted by 05a6c6 View Post
    If it is the DPFs then be sure to replace them if you'll need an MOT test after May 2018, from 1st May 2018 DPFs not being present will be an MOT fail under the new test guidelines.
  14. Likes Uwe, Jack@European_Parts liked this post
  15. #10
    he he he he ..........where pondering FOD is a bad idea......... /\
    Still thinking that emission's are to restrictive after seeing the actual numbers of real output people?
    Above Magic!
