Results 1 to 3 of 3
Thread: Introducing and a problem on my car.
    New User
    Dec 2017
    Hello ,
    this i my first post here , i come from the Netherlands and i drive a 2011 seat leon cupra r.
    in my spare time i fix cars and specially vag cars.
    recently i did a retrofit but it does not work correctly.
    i try to get the mirror down working on my leon, i fitted an new motor with memory and i have fitted the wiring from a golf 6.
    i had to code module 52 and module 09. but when i shift in reverse gear the mirror goes up.
    and it will not go back to its home position.
    does anyone know if this can be fixed ?
    Address 52: Door Elect, Pass. Labels: 3C0-959-70X-GEN4.clb
    Control Module Part Number: 1T0 959 702 AC HW: 3C0 959 792 A
    Component and/or Version: TUER-SG BT 002 0311
    Software Coding: 0015B0
    Work Shop Code: WSC 99999 123 12345
    ASAM Dataset: EV_DCU52BrosePasseSide A03004 (SE35)
    ROD: EV_DCU52BrosePasseSide.rod
    VCID: F9F3C533780D608D72-80AC
    66821 - Position Sensor for Mirror Adjustment
    B11FA 29 [008] - Signal Implausible
    Reset counter: 214
    Mileage: 179769 km
    Date: 2082.14.03
    Time: 17:24:09
    this is the scan from the module 52
    thanks
    Quote Originally Posted by Roelb79 View Post
    No, it is not.
    Please Get Verified so we can move this to the correct (Retrofits) section of the forum.
    New User
    Dec 2017
    No, it is not.
    You are correct i did post something here , i have send a reply to a member.
    About get verified , i have bought my vcds cable from the original buyer. That is the reason that i am not verified.
    Roel
