Change ESP 31 bytes to 41 bytes , what coding ??? 5Q0614517AF to 5Q0614517AQ
rojas
Spain
C?ID=261996
which encoding would be ESP coding 31 bytes converted into 41 bytes? i update to 5Q0614517AQ
Descripción del sistema: ESC
Número de software: 5Q0614517AF
Versión de software: 0398
Número de hardware: 5Q0614517AF
Versión de Hardware: H62
Número de serie: 62846000001359
Nombre ODX: EV_Brake1UDSContiMK100ESP
Versión ODX: 035019
Codificación extendida: 20EE62922423096E407F060141CA240446249002608224721441F08240A202
thx by the help ;)
rojas
Spain
C?ID=261996
of course uwe , but I want to advance any help or information about it, I can do it with my vcds this weekend ... of moment I can provide a scan with another device. thx
Removed.
This is forum is owned and operated by Ross-Tech, the makers of VCDS.
Scans from other products are not appropriate here.
rojas
Spain
C?ID=261996
Sunday,11,February,2018,23:40:11:22717
VCDS Version: 18.1.0.2 (x64)
VIN: VSSZZZ5FZGR23xxxx    License Plate:
Chassis Type: 5F-SE37 (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 3C 42 44 52 55 5F 65 A5
VIN: VSSZZZ5FZGRxxxxxxx   Mileage: 20378km-12662miles
3C-Lane Change -- Status: Cannot be reached 0100
Address 01: Engine (2D2D2-CXXB)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 056 CL    HW: 04L 907 445 B
   Component: R4 1.6l TDI   H06 2506
   Revision: 22004001
   Coding: 01114032434401090000
   Shop #: WSC 00049 770 00125
   ASAM Dataset: EV_ECM16TDI03004L906056CL 002006
   ROD: EV_ECM16TDI03004L906056_002_VW37.rod
   VCID: 79D71675F881EF8DF2-802C
Readiness: N/A
Address 03: ABS Brakes (J104)       Labels:| 5Q0-907-379-ESP-V1.clb
   Part No SW: 5Q0 614 517 AF    HW: 5Q0 614 517 AF
   Component: ESC           H62 0398
   Revision: 00000000    Serial number: 62846000001359
   Coding: 20EE62922423096E407F060141CA240446249002608224721441F08240A202
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 035019
   ROD: EV_Brake1UDSContiMK100ESP_035_SK37.rod
   VCID: 75CF1A45D4998BED96-8020
8216 - Databus
                    Reset counter: 103
                    Mileage: 20111 km
                    Date: 2018.02.04
                    Time: 20:22:41
8362 - Databus
                    Reset counter: 106
                    Mileage: 20111 km
                    Date: 2018.02.04
                    Time: 20:22:41
   Part No SW: 5F0 907 044 AD    HW: 5F0 907 044 AD
   Component: Climatronic   H05 1601
   Revision: 00001K09
   Coding: 00000104200110011105000000101020
   Shop #: WSC 00049 770 00101
   VCID: 68F14331932B66051D-803C
   Serial number: 01061627301511
   Coding: 08000B42424102FB0BA44000B10403081000000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 042977818F43A26591-8050
   Subsystem 1 - Part No SW: 5F1 955 119 A    HW: 5F1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 160923  041 0574
   Serial number:         161004180602
   Coding: 0BC5FD
   Component: RLHS  042 0105
   Serial number: S2Y16M09D29H16M29S42
   Coding: 00095D
   Subsystem 3 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY161872BDA
   Serial number: 00000000000036616961
   Part No SW: 5Q0 919 298 K    HW: 5Q0 919 298
   Component: PARKHILFE PLA 011 0054
   Revision: --------    Serial number: 61131303201263
   Coding: 0031167041
   ASAM Dataset: EV_EPHVA2CAU3700000 003021
   ROD: EV_EPHVA2CAU3700000_003.rod
   VCID: 47B3A08DFEF5497D34-8012
12664864 - Databus
                    Reset counter: 159
                    Mileage: 20257 km
                    Date: 2018.02.08
                    Time: 19:17:43
12666390 - Databus
                    Reset counter: 159
                    Mileage: 20257 km
                    Date: 2018.02.08
                    Time: 19:17:43
13639168 - Databus
                    Reset counter: 106
                    Mileage: 19785 km
                    Date: 2018.01.27
                    Time: 14:46:22
13688835 - Databus
                    Reset counter: 143
                    Mileage: 19786 km
                    Date: 2018.01.27
                    Time: 15:35:00
   Part No SW: 5Q0 907 572 F    HW: 5Q0 907 572 F
   Component: ACC Bosch MQB H05 0400
   Serial number: 26081604382596
   Coding: 00200400FE0739
   ASAM Dataset: EV_ACCMRRBoschVW372 001016
   VCID: 3A55C979BD072495BB-806E
   Part No SW: 3Q0 959 655 AS    HW: 3Q0 959 655 AS
   Component: Airbag VW20   013 0200
   Revision: --------    Serial number: 003SQPL5YPTO
   Coding: 98CCC000000000005C0000CC000800000065
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 0F0348ADD605D13D3C-805A
   Subsystem 1 - Part No SW: -----------    HW: 454 000 110 16
   Serial number: 3576U000000BE6AC8E1+
   Subsystem 2 - Part No SW: -----------    HW: 454 003 009 16
   Serial number: 3586U000000186614E17
   Subsystem 3 - Part No SW: -----------    HW: 454 802 309 16
   Serial number: 3516RC4A8E90C000000P
   Subsystem 4 - Part No SW: -----------    HW: 454 802 309 16
   Serial number: 3526R5CAFE90C000000Y
   Subsystem 5 - Part No SW: -----------    HW: 454 802 109 16
   Serial number: 3556V58ABB70C000000S
   Part No SW: 5Q0 953 507 HA    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 10101608491038
   Coding: 6C00
   ROD: EV_SMLSKLOMQB_VW37.rod
   VCID: 7CD90F61F7B3DAA5E9-8028
   Part No SW: 5F0 920 751 D    HW: 5F0 920 751 D
   Component: KOMBI         306 8311
   Coding: 07AD02806C9C000800887A0F1000000000000000
   VCID: 2773000D5EB5A97DD4-8072
16777008 - Function Restricted due to Interrupted Communications
          U1110 00 [009] - -
                    Reset counter: 106
                    Mileage: 20111 km
                    Date: 2018.02.04
                    Time: 20:22:43
16776982 - Databus
                    Reset counter: 106
                    Mileage: 20111 km
                    Date: 2018.02.04
                    Time: 20:22:40
   Revision: --------    Serial number: 01101610520549
   Coding: 030100F40F087300EA000250000F00010001050000000000000000000000
   ROD: EV_GatewConti_013_VW48.rod
   Subsystem 2 - Part No SW: 5F0 959 537 B    HW: 5F0 959 537 B
   Serial number: 000000000B0862140916
   Coding: 002000
   Serial number: 75410803001609283863
131594 - Parallel Parking Assistance Control Module
          U104E 00 [008] - No communication
                    Reset counter: 159
                    Mileage: 20257 km
                    Date: 2018.02.08
                    Time: 19:17:45
                    Supply voltage: Terminal 30: 14.3 V
                    Terminal 15: On
131662 - Lane change assistant control module
          U1045 00 [009] - No communication
                    Fault Frequency: 56
                    Reset counter: 119
                    Mileage: 19785 km
                    Date: 2018.01.27
                    Time: 14:45:34
                    Supply voltage: Terminal 30: 11.7 V
                    Terminal 15: On
Address 3C: Lane Change
   Serial number: 0000221146639
   Coding: 00100220DC00040000001000
   Serial number: 00000000000011663857
   Coding: 310000
   Component: EPS_MQB_ZFLS  129 1072
   Coding: 1303
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 45AFAA85C4F95B6DC6-8010
   Serial number: 0000218933482
   Coding: 00100220DE00040000001000
   VCID: 46ADAD89F9FF5075CF-8012
   Serial number: 00000000000011781848
   Coding: 290000
   Coding: 048A000009000000
Address 5F: Information Electr. (J794)       Labels:* 5F0-035-MIB-STD2.clb
   Part No SW: 5QA 035 846 A    HW: 5QA 035 846 A
   Component: MU-S-N-ER     H30 0359
   Serial number: SEZAZ2S0170124
   Coding: 04730001D70A000011110001000808002F0200D40120010086
   ASAM Dataset: EV_MUStd6C1TSAT 001015
   ROD: EV_MUStd6C1TSAT_SE27.rod
   VCID: 42A5B199D5D76C55E3-8016
   Subsystem 1 - Part No SW: 5F0 919 606     HW: 5F0 919 606
   Component: ABTm-2_8-CR  H41 1042
   Serial number: SEZ8Z9T6C01H72
   Subsystem 2 - Part No SW: 6P0 919 866 AB    HW: -----------
   Component: ECE1 2018  --- 0915
7194 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 106
                    Mileage: 19785 km
                    Date: 2018.01.27
                    Time: 14:46:17
                    Voltage terminal 30: 11.7 V
                    BAP-BAP_Function_ID: 02
   Part No SW: 5Q0 907 273 B    HW: 5Q0 907 273
   Component: RDKBERU30     H04 0009
   Serial number: 30000000001272
   ROD: EV_RDKBERU30_005.rod
   VCID: 3449E7419F63D2E561-8060
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 5Q0-980-653.clb
   Part No SW: 5Q0 980 653 G    HW: 5Q0 980 653
   Component: MQB_MFK       H07 0060
   Serial number: 10000606797
   Coding: 0101010001020306000500010100000100
   ROD: EV_MFKBoschAU370.rod
   VCID: 3C59CF61B7331AA5A9-8068
1123593 - Databus
                    Reset counter: 158
                    Mileage: 20165 km
                    Date: 2018.02.06
                    Time: 18:08:12
                    Control Module temperature: 16 °C
                    Outside air temperature: 15.0 °C
                    Vehicle speed: 0.00 km/h
                    Voltage terminal 15: 11.9 V
                    Terminal 15 on: 4.6 s
1123600 - predictive route data
          B1630 02 [008] - Signal Failure
                    Reset counter: 144
                    Mileage: 19810 km
                    Date: 2018.01.27
                    Time: 21:58:38
                    Control Module temperature: 37 °C
                    Outside air temperature: 6.0 °C
                    Vehicle speed: 17.92 km/h
                    Voltage terminal 15: 14.1 V
                    Terminal 15 on: 932.3 s
1123601 - predictive route data
                    Reset counter: 151
                    Mileage: 19978 km
                    Date: 2018.02.01
                    Time: 08:03:01
                    Control Module temperature: 27 °C
                    Outside air temperature: 6.5 °C
                    Vehicle speed: 22.72 km/h
                    Voltage terminal 15: 14.5 V
                    Terminal 15 on: 251.2 s
1114112 - Databus
                    Reset counter: 119
                    Mileage: 19785 km
                    Date: 2018.01.27
                    Time: 14:46:31
                    Control Module temperature: 34 °C
                    Outside air temperature: 10.0 °C
                    Voltage terminal 15: 11.7 V
                    Terminal 15 on: 310.4 s
End-------------------------(Elapsed Time: 03:37)--------------------------
this is the scan . i need know coding in ABS 31 to 41 bytes
rojas
Spain
C?ID=261996
i thank all ideas :)
downtime
C?ID=280813
So you haven't swapped the abs block yet?
I know this is not very easy task. The last bytes most likely contain again some devious scrambled byte values from the existing code first 29 bytes :)
It might be easiest to make it the hard way. Google for some autoscans and compare them byte by byte especially the last bytes and try to understand what they contain. They most likely don't contain any options. Of course not 100% sure of that either.
EDIT :
Actually, might be easier than expected. I compared only two AQ abs block codings and both have EXACTLY the same last bytes even though they are from different cars.
So guessing from that, your new coding is :
20EE62922423096E407F060141CA240446249002608224721441F08240A2020000000012121212B835351919323200
rojas
Spain
C?ID=261996
EDIT :
yes . i see this
i compared a leon and a golf ... the last bytes is same coding both cars , but i think better ask this and look different ideas .
