Results 1 to 5 of 5
Thread: Set xenon on vw golf 2009
    Pirate
    Feb 2018
    Hello forum members.
    i have build xenon on my vw golf 2009 and installed it witch afs system.
    For this i have to set my xenon as shown below:
    Basic Setting
    Software Part Numbers 5M0-907-357 through 5M0-907-357-D ONLY
    Headlight Adjustment
    [Select]
    [55 - Xenon Range]
    [Basic Settings - 04]
    Group 001
    [Go!]
    Activate the Basic Setting.
    [ON/OFF/Next]
    The meas. block field now shows "Wait" and should switch to "Adjust Headlights" then (this may take up to 10 seconds).
    Adjust the headlights using their manual adjusting screws as referenced against a suitable aiming target.
    [ON/OFF/Next]
    The adjustment should now be learned.
    [Done, Go Back]
    Don't forget to check/clear fault codes afterwards.
    [Close Controller, Go Back - 06]
    the meas block field does not show in vagcom.
    i down know what i am doeing wrong.
    everything is ok and there are no error messages comming up.
    who can help me?
    Pirate
    Feb 2018
    i did the scan, and this are the results.
    Removed.   Data from a clone/pirate copy of VCDS is not welcome here
    i hope you can find a sollution?
    Pirate
    Feb 2018
    i have also got these two errors
    but i down have a alarm in my car and is still gives a alarm horn error.
    And also gives a error for my rear spoiler with does not move so it moesnt give a error
    Legitimate VCDS systems are available directly from us:
    http://www.ross-tech.com/distributors.php#nl
