Results 1 to 8 of 8
Thread: Rear Marker Disable
    Jan 2018
    Rear Marker Disable
    I am going to attempt to disable rear marker lights, but to do this I have to change settings:
    central convenience II
    byte 2
    bit 3 North American region disable
    Will this setting change anything else on the vehicle?
    A bit more context might be useful here.
    Jan 2018
    Well, I cannot post pics here.
    Context?
    Delete Rear Markers: How to?
    Can you explain it?
    Maybe that is how I should have started this post.
    Supposedly you can change here?
    byte 2
    Jan 2018
    El Paso, TX USA
    Seems different than Audis, but post the module number for extra safety. The rear ones on my new S6 (on the same central convenience module <46>, but channels 209 and 210), were already disabled, supposedly, but the single side LEDs are on, so maybe they're not considered 'rear reflectors'? Asked Euro owners but nobody replied. Would like to disable them, but since the channels were already set to 0 and 32 (the disabled state), maybe it's not possible. Who knows. The front ones were disabled successfully, however, but in another module (central electronics <09>). If the bit says in plain english what it's for, zero worries man; just do it. And you could actually test it before changing it, if you want. That's what I did with the front ones since there was no text. Good luck.
    Verified VCDS User DJAlix's Avatar
    Apr 2015
    London, United Kingdom
    A basic pre-requisite for this sort of information here is an auto-scan so people can see what vehicle you are enquiring about and the equipment which it has. At the moment you have said you want to disable rear marker lights, ok but on an Audi, VW, an A3 8V or an A6 C6? Two very different cars with very different methods.
    VAG Car Coding
    Adaptation | Coding | Diagnostic | Retrofit - London, United Kingdom
    Authorised VW Group Services Provider and Independent Repairer
    @vagcarcoding
  6. Likes Dana liked this post
    Quote Originally Posted by indy680 View Post
    Please see: How to Post Pictures.
    Context?
    Yeah, some details about the car you're trying to do this to might be helpful. Make, model, year, how it's equipped. Or better yet, an Auto-Scan.
    Jan 2018
    Try This. And thank you!
    2015 Prestige Sline 3.0 TFSI
    <blockquote class="imgur-embed-pub" lang="en" data-id="a/SuhPx"><a href="//imgur.com/SuhPx"></a></blockquote><script async src="//s.imgur.com/min/embed.js" charset="utf-8"></script>
  9. #8
    Jan 2018
    VIN: WA1DGAFE6FD008394   License Plate:
    Mileage: 60680km-37704mi   Repair Order:
    Chassis Type: FE-AU56 (4F0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 28 34 36 3C 42 46 47 4C 4F
              52 55 56 5F 62 69 6C 6D 6F 72
    VIN: WA1DGAFE6FD008394   Mileage: 60680km-37704miles
    Address 01: Engine (CTW)       Labels: None
       Part No SW: 4L0 910 551 Q    HW: 4L0 907 551 A
       Component: 3.0l V6 TFSI        0030
       Revision: --H08---    Serial number:
       Coding: 0121000A290F0928
       Shop #: WSC 31414 790 00001
       VCID: 3635DBE4644C6517B0D-8062
       Part No SW: 0C8 927 750 Q    HW: 0C8 927 750 Q
       Component: AL1000 AISIN  002 2443
       Coding: 001378
       Shop #: WSC 30586 001 1048576
       ROD: EV_TCMAL991031_002.rod
       VCID: 3A2DCFD45CD48177545-806E
       Revision: 00H02001
       Coding: 0103505
       VCID: 3431E1EC723077078E9-8060
       Part No SW: 4F0 910 852 B    HW: 4F0 905 852 H
       Component: FBSAUDIC6 ELV   H08 0210
       Revision: 00H08000    Serial number: 10603902162043
       Coding: 0000135
       VCID: 25170CA8C9EA1E8F097-8070
       Component: FBSAUDIC6 EZS   H04 0020
       Subsystem 3 - Part No: 4F0 910 220 G
       Component: FBSAUDIC6 IDG   H01 0053
       Part No SW: 4L0 910 043 D    HW: 4L0 820 043 AQ
       Revision: 00---031    Serial number: 00000000447079
       Coding: 000CC026
       VCID: 25170CA8C5EA1E8F097-8070
       Subsystem 1 - Part No SW: 8K0 959 772 F    HW: 8K0 959 772
       Component: SLR-B8  H06 0007
       Serial number:           0115208822
       Coding: 070000
       Subsystem 2 - Part No SW: 8K0 959 772 F    HW: 8K0 959 772
       Serial number:           0115208818
       Coding: 070000
       Part No SW: 4F0 910 279 AG    HW: 4F0 907 279 C
       Component: ILM Fahrer      H31 0400
       Coding: 0133123
       VCID: 6E8533845C9C1DD7B8D-803A
       Component: Wischer AU716   H18 0110
       Coding: 00064792
       Shop #: WSC 31414
       Coding: 00150059
       Shop #: WSC 31414
    Address 10: Park/Steer Assist (J446)       Labels:| 4L0-919-475-7X2.clb
       Part No SW: 4L0 919 475 A    HW: 4H0 919 475 C
       Component: PARKHILFE 8K  H07 0011
       Revision: 11001001    Serial number: 55961425401612
       Coding: 29011F
       ASAM Dataset: EV_EPHVA18AU7160000 001001
       ROD: EV_EPHVA18AU7160000.rod
       VCID: 3431E1EC7EB077078E9-8060
       Component: 73 AIRBAG AUDI8RH45 0230
       Revision: 09H45000    Serial number: 0038QD90ASU+
       Coding: 0014131
       VCID: 2B03FA90AF0E28FFDF3-807E
       Subsystem 1 - Part No: 4L0 959 339 C
       Component: BF-Gewichtsens. H05 0040
       Subsystem 2 - Serial number: 6332QSME79421A4EQ
       Subsystem 3 - Serial number: 6342QSME1F431D4CT
       Subsystem 4 - Serial number: 6352QSME43445458E
       Subsystem 5 - Serial number: 6362QSME3D44327ES
       Subsystem 6 - Serial number: 63734SME71424B54$
       Subsystem 7 - Serial number: 63834SME0D454E605
       Part No SW: 4F0 910 549 B    HW: 4F0 953 549 E
       Component: J0527               0830
       Revision: 00H09000    Serial number: 90026142050193
       Coding: 0012142
       VCID: 2809059CBEF803E7321-807C
       Component: E0221           H03 0040
       Part No SW: 4L0 920 985 S    HW: 4L0 920 985 S
       Component: KOMBIINSTR.   H35 0332
       Revision: 00000000    Serial number: X2R52NJ9F
       Coding: 8BD763040901CF05020205
       VCID: 44D1B12C2E90C7873E9-8010
       Part No SW: 4F0 907 468 S    HW: 4F0 907 468 G
       Component: GW-BEM 5CAN-M H06 0058
       Revision: MB800038    Serial number: 3800M1490204F4
       Coding: 00C303
       VCID: 3FDBBEC04776A45F63B-806A
       Component: J367-BDM  H07 0125
       Serial number: 41250510334121764484
       Part No SW: 4L0 910 158     HW: 4L0 919 158 AE
       Revision: 00---011    Serial number: 00000030351854
       Coding: 0000006
       VCID: 6889459C7E78C3E7F21-803C
    Address 34: Level Control        Labels: None
       Part No SW: 4L0 910 553 J    HW: 4L0 907 553 E
       Component: LUFTFDR.-CDC    H04 7860
       Revision: --H04001    Serial number: 15.1528-0143.2
       Coding: 0015520
       Shop #: WSC 29409 001 1048576
       VCID: 313FE8F88D22422FE5F-8064
       Part No SW: 4F0 959 760 D    HW: 4F0 959 760 D
       Component: MEM-FS        H08 0065
       Revision: AA000000    Serial number: 00000114006321
       Coding: 00581B00000011110000
       VCID: 323DE7F4842479379C5-8066
       Component: J0769_SWA_MasterH03 0050
       Revision: 00H03000    Serial number: 6PZ 009 014-10
       Coding: 0010001
       VCID: 2E05F3849C1C5DD7F8D-807A
       Component: J0770_SWA_Slave_H03 0050
       Subsystem 3 - Serial number: 5F28.08.1400H03000AMS14277
       Subsystem 4 - Serial number: S14277
       Component: TSG FA        H12 0362
       Revision:             Serial number: 0000118410359
       Coding: 011F57205E40440004
       VCID: 48C9A51C12B8E3E7D21-801C
       Part No SW: 4L0 910 289 K    HW: 4L0 907 289 K
       Component: Komfortgeraet   H12 0130
       Revision: 0130 ---    Serial number: 82007937900000
       Coding: 3570077
       VCID: 3829D5DC6E589367A21-806C
       Part No SW: 4L0 035 223 J    HW: 4L0 035 223 G
       Component: BOSE G3 Q7    H04 0160
       Revision: CH004001    Serial number: 00000000060077
       Coding: 030000
       VCID: 290F0098A9F23AEF2DF-807C
       Part No SW: 4F0 910 274 B    HW: 4F0 907 274
       Component: J793  RKA+      H04 0110
       Revision: 00000519    Serial number: 00005191069910
       Coding: 0694221
       VCID: 231312B0C7DEE0BF673-8076
       Component: ILM Beifahrer   H16 0100
       Revision:             Serial number: 00000000196405
       Coding: 0012001
       VCID: 5EE56344AC3C8D5708D-800A
       Component: TSG BF        H12 0362
       Revision:             Serial number: 0000118095476
       VCID: 47CBA6201FA6EC9FDBB-8012
       Part No SW: 4L0 910 357 B    HW: 4L0 907 357 B
       Component: AFS 1           H01 0010
       Coding: 0000032
       Component: AFS-Modul links H07 0004
       Component: AFS-Modul rechtsH07 0004
       Component: Radio U SIRIU H60 0133
       Revision: AB001007    Serial number: 156I.0E8063162
       Coding: 020007010000000000
       VCID: 241111ACCED0E7871E9-8070
       Part No SW: 4L2 035 746 F    HW: 4L2 035 746 D
       Component: H-BNT-NA      H41 0812
       Revision: --------    Serial number: 224IU0E7551041
       Coding: 180200060104F1FF51002F456F632003140000000100000000
       VCID: 313FE8F88122422FE5F-8064
       Subsystem 1 - Part No: 8R0 060 884 CA
       Component: NAR 2014  1002
       Component: DU7 High  H42 0104
       Serial number: A130IY0E3128854
       Subsystem 3 - Part No SW: 4L0 919 614 C    HW: 4L0 919 614 C
       Component: E0380 Bedient  H01 0060
       Serial number: 00000002205827
       Component: CD-Database  5950
       Part No SW: 4F0 959 795 P    HW: 4F0 959 795 P
       Component: TSG HL        H11 0362
       Revision:             Serial number: 0000117954997
       Coding: 010E57204040230004
       VCID: 46D5AB2418ACF59720D-8012
    Address 69: Trailer (J345)       Labels:. 4E0-907-383.clb
       Part No SW: 4E0 907 383 J    HW: 4E0 907 383 J
       Revision: 2A001001    Serial number: 00008200812238
       Coding: 0200000000000000
       Part No SW: 4L0 907 428     HW: 7P6 907 441 D
       Component: TopView       H05 0293
       Revision: 11001001    Serial number: 82330JF0171124
       Coding: 020C000001000100010102000000
       ASAM Dataset: EV_CamSysteCorneViewAUDI 004005
       ROD: EV_CamSysteCorneViewAUDI.rod
       VCID: 6E853384501C1DD7B8D-803A
       Part No SW: 4L0 910 945     HW: 4L0 827 851 F
       Component: ValeoHeckdeckel H58 0500
       Revision: --H58001    Serial number: E5030000B
       Shop #: WSC 98765 666 38354
       VCID: 6C81398C6A80EFC7969-8038
    3
       Subsystem 3 - Serial number: RD12.09.14--H58001002G0094
       Subsystem 4 - Serial number: 2G0094
       Component: ILM HINTEN 2    H08 0080
       Revision: AAH08080    Serial number: 0118255819----
       Coding: 0003595
       VCID: 26150BA4B4EC159700D-8072
       Component: J_245_EE16_SKB10H15 0220
       Component: J_394_EE16_SKB10H15 0220
       Component: J_392_EE16_SKB10H15 0220
       Component: TSG HR        H11 0362
       Revision:             Serial number: 0000117954996
    End----(Elapsed Time: 02:15, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
