Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: 2006 TDI Jetta Steering angle problem after dead battery
  1. #21
    Quote Originally Posted by rabbitpower View Post
    They all read ok when I’m moving. Logically speaking in the output boxes. That red one is screwed up on the graph. The measuring block reads 0. The graph reads moving.
    Is the scaling for all four the same? It would be good if you posted a proper screen shot rather than a photo of the screen.
    Which color goes with which wheel? I want to make sure I’m looking at the correct sensor.
    Do the colors follow the order from left to right same as the measuring block values for g46,47, etc?
    Yes, the data boxes in VC-Scope are in the same order as the four fields in the measuring block, so red should be front, left.
  2. #22
    Feb 2018
    I wasnít aware scaling could be changed per sensor value. I havenít changed anything from the default it was set at from Ross tech. I guess I thought all 4 sensors shared the same global scaling factor?
    Iíll try to get a screen shot of it next time.
    By front left, you mean passenger front correct?
    Sorry for the confusion I just want to make sure if Iím out sitting in the snow in working on the correct wheel lol.
    First order is to check scaling
    Second order is to check the bearing/sensor/wire for damage.
    Thanks!!
  3. #23
    I wasn’t aware scaling could be changed per sensor value. I haven’t changed anything from the default it was set at from Ross tech. I guess I thought all 4 sensors shared the same global scaling factor?
    If you haven't changed it, I would think so to0, but like I said, your picture doesn't show the Y-axis values, so I can't be sure.
    No, left/right is defined form the perspective of the car's direction of travel. So that would be the driver's side in a US-model car.
  4. #24
    Feb 2018
    The values are all 250kmh if I remember correctly. One for each color.
    As soon as I start scope the red line just takes off, while Iím sitting still.
  5. #25
    Feb 2018
    I checked the scaling and it is the same for all 4 wheels. What should I try next?
  6. #26
    Log it and post actual log data?
  7. #27
    Feb 2018
    **********************LATEST AUTOSCAN:******************
    Friday,16,February,2018,19:07:57:45755
    VCDS Version: 18.2.0.3  HEX-NET CB: 0.4411.4
    VIN: 3VWST71KX6M783890   License Plate:
    Mileage: 303230km-188418mi   Repair Order:
    Chassis Type: 1K (1K0)
    Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 47 52 56 62 72 7D
    VIN: 3VWST71KX6M783890   Mileage: 303230km-188418miles
    0F-Digital Radio -- Status: Cannot be reached 1100
    Address 01: Engine        Labels: 038-906-016-BEW.lbl
       Part No SW: 03G 906 016 AC    HW: 028 101 223 9
       Component: R4 1,9L EDC G000DG  7551
       Revision: --H02---    Serial number: VWZ7Z0F3428799
       Coding: 0050078
       VCID: 64844C78A7E904649C-8030
       Part No SW: 02E 300 043     HW: 02E 927 770 AE
       Component: GSG DSG         070 1126
       Revision: 04507000    Serial number: 00000601121333
       VCID: 51EA95ACC85B81CCC7-8004
       Part No SW: 1K0 907 379 AA    HW: 1K0 907 379 AA
       Revision: 00H13001
       Coding: 0021122
       VCID: 71AA352C681BA1CCE7-8024
    01487 - System Function Test
                000 -  -  - Intermittent
       Part No: 1K0 820 047 EC
       Component: Climatic PQ35   090 0505
       VCID: 699A5D4C40CB590CAF-803C
    Address 09: Cent. Elect.        Labels:. 3C0-937-049-23-M.lbl
       Part No SW: 3C0 937 049 D    HW: 3C0 937 049 D
       Component: Bordnetz-SG     H37 1002
       Revision: 00H37000    Serial number: 00000000275564
       Coding: 14018E234004150000140000001400000008730B5C
       Shop #: WSC 02415 444 57278
       VCID: 2A18E240854D921466-807E
       Subsystem 1 - Part No: 1K1 955 119 C  Labels: 1KX-955-119.CLB
       Component: Wischer VW350  013  0402
       Coding: 00063445
       Shop #: WSC 02415
    02381 - Windshield Wiper Motor; Overload
                        Fault Status: 00100011
                        Fault Frequency: 171
                        Reset counter: 13
                        Mileage: 303221 km
                        Voltage: 14.20 V
    Address 0F: Digital Radio
       Part No SW: 1K0 909 605 P    HW: 1K0 909 605 P
       Component: 39 AIRBAG VW8R  032 7900
       Revision: 03032000    Serial number: 0038FD04TWK
       Coding: 0013113
       VCID: 393ACD0C70EB298C1F-806C
       Subsystem 1 - Part No: 1K0 959 339 E
       Component: BF-Gewichtsens. 006 0005
       Subsystem 2 - Serial number: 6332MSME0E461277C
       Subsystem 3 - Serial number: 6342MSME0F0334524
       Subsystem 4 - Serial number: 6351HSME0924213F3
       Subsystem 5 - Serial number: 6361HSME09284A5AG
       Subsystem 6 - Serial number: 63727SME08794A053
       Subsystem 7 - Serial number: 63827SME0B161071V
       Part No SW: 1K0 953 549 AH    HW: 1K0 953 549 AH
       Component: J0527           034 0070
       Coding: 0010021
       VCID: 78BC08080B61F08420-802C
       Part No: 1K0 920 953 D
       Component: KOMBIINSTRUMENT 3HL 4312
       Coding: 0023203
       Shop #: WSC 03083 444 83886
       VCID: 2C14E4588FB98C2494-8078
       Part No SW: 1K0 907 530 F    HW: 1K0 907 951
       Component: Gateway         H10 0120
       Revision:   H10       Serial number: 28001061020206
       Coding: 3F3F0B62071002
       Shop #: WSC 00066 123 12345
                        Fault Frequency: 42
                        Reset counter: 229
                        Mileage: 303205 km
                        Time: 02:42:53
    02649 - Digital Radio Tuner
                        Fault Frequency: 42
                        Reset counter: 229
                        Mileage: 303205 km
                        Time: 02:42:53
       Component: IMMO            3HL 4312
       Part No: 1K0 959 701 K
       Component: Tuer-SG         024 2377
       Coding: 0001269
       VCID: 3620C63041F5C6F4F2-8062
       Part No: 1K1 909 144 K
       VCID: 3326FF245287D3DCD5-8066
    02546 - Steering Limit Stop
                        Mileage: 3200 km
                        Temperature: 11.0įC
                        Voltage: 14.00 V
                        Voltage: 13.80 V
    Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
       Part No: 1K0 959 433 AF
       Coding: 137803281B09058F880F048051A0
       Shop #: WSC 02415 444 66564
       VCID: 74A43C38170994E40C-8020
    Address 47: Sound System
       Part No: 1K0 959 702 K
       Coding: 0001269
       VCID: 373ECB3446FF3FFCE9-8062
       Part No SW: 1K0 035 180 C    HW: 1K0 035 180 C
       Component: Radio DE2       011 0014
       Revision: 00011000    Serial number: VWZ4Z7E2036123
       Coding: 0040400
       Shop #: WSC 02415 444 84652
       VCID: 200C0068F371584438-8074
    02218 - Satellite Radio (R146)
       Part No: 1K0 959 703 D
       Component: Tuer-SG         021 2434
       Coding: 0000144
       VCID: 312AF52CA89BE1CCA7-8064
       Part No: 1K0 959 704 D
       Coding: 0000144
       VCID: 3228FA20AD9DDAD4DE-8066
       Revision: 00800000    Serial number:
       VCID: 2D12E95CB4A3852C83-8078
                014 - Defective
    End----------(Elapsed Time: 01:11, VBatt start/end: 14.3V/14.4V)-----------
    *********************ABS MEASURING BLOCK STATUS****************
    *********************ACTUAL GRAPH OF MEASURING BLOCK 1***********
    It never changes. If I turn off the drivers side front [red] the line goes away. As soon as I click on "graph" the horizontal line takes off. The other 3 sensors graph correctly. Changing the scale will shift the red line but will not change its behavior. The live dynamic output of the sensor corresponding to the red line appears to keep up with the other 3 when driving, but the graph and the actual output do not in any way match as far as I can see? Am I doing something wrong?
  8. #28
    Again, please do an actual log while driving slowly in a straight line (starting from 0 km/h) and post the raw log data.
    Using VC-Scope, the scaling you have seems a bit inappropriate for the purpose at hand. Try -5 as the min and 50 as the max for all four items, or maybe even -2 and 20. We're looking for small differences at low speeds.
