Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Help with some faults in a 2017 Golf GTI
    Clear the DTC's directly in modules 0x17 and 0x19 not just a broadcast..........
    Above Magic!
  2. #12
    Verified VCDS User jfim88's Avatar
    Feb 2018
    Spain
    I clear DTC’s after an Auto Scan in Clear all DTC button. It’s not the correct method?
  3. #13
    No...........................
    Above Magic!
  4. #14
    Feb 2018
    Spain
    Seems that after clearing errors in each module they are gone. Will re-check in a few hundreds of kilometers.
    Thanks you!
    VW Golf MK7.5 GTI 230 DSG 2017
  5. #15
    Feb 2018
    Spain
    I did an Auto Scan today...
    The fatigue recognition error still appearing. The right light seems to be a one-time fail?
    What can be the cause of the repeating fatigue fault?
    Wednesday,14,February,2018,15:44:51:27322
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86(Parallels)
    VCDS Version 18.1.0.2  HEX-V2 CB: 0.4411.4
    VIN: WVWZZZAUZHW321028   License Plate:
    Mileage: 20172km-12534mi   Repair Order:
    Chassis Type: AU-VW37 (3Q0)
    Scan: 01 02 03 08 09 10 13 15 16 17 19 29 39 42 44 4B 52 5F A9 D6
              D7
    VIN: WVWZZZAUZHW321028   Mileage: 20172km-12534miles
    39-Right Light -- Status: Malfunction 0010
    Address 01: Engine (J623-CHHA)       Labels:. 06K-907-425-V1.clb
       Revision: --H13---
       Coding: 091D00124464050B2000
       ROD: EV_ECM20TFS0205G0906259C.rod
       VCID: 2E04FFE58091EED7CA9-807B
       Part No SW: 0D9 300 042 S    HW: 02E 927 770 AS
       Component: DQ250-6F MQB  H54 5013
       Revision: 06454104    Serial number: TFK01702030666
       ROD: EV_TCMDQ250021.rod
       VCID: 290E0CF9B97F89EF1FB-807D
       Revision: 00000000    Serial number: 60437000000977
       Coding: 01FA6BA13422216D47770602C0CBA980D62C84E26003957738425078C209430000000012121212B835351919323200
       ROD: EV_Brake1UDSContiMK100IPB_036.rod
       VCID: 77AA1A813F4BEF1F59F-8023
       Part No SW: 5G0 907 044 CE    HW: 5G0 907 044 CE
       Revision: 00001K08
       Coding: 0002001420011001100500000010102A
       ROD: EV_ACClimaBHBVW37X_006_VW27.rod
       VCID: 6C8035ED760D5CC7A4D-8039
       Serial number: 02001704002591
       ROD: EV_BCMBOSCH_017.rod
       VCID: 7EA40FA51071DE571A9-802B
       Component: WWS    170114  043 0551
       Serial number:         170131122411
       Component: RLHS  042 0105
       Serial number: S6Y17M02D20H06M34S43
       Coding: 00A8DD
       Serial number: 000000000ZY17016357Z
       Serial number: 00000000000068487587
       Sun Roof:
       Component: J245 PS73.404  H03 0004
       Serial number: 0000FST001FK2KM00000
       Coding: 181901
       Part No SW: 5QA 919 294 A    HW: 5QA 919 294
       Component: PDC 8 KanalH07 0038
       Serial number: 000308418617049
       Coding: 0471151011
       ASAM Dataset: EV_EPHVA18AU3700000 009031
       ROD: EV_EPHVA18AU3700000_009_VW27.rod
       VCID: 4ACC93751C39A2F7F61-801F
       Part No SW: 5Q0 907 572 H    HW: 3QF 907 572
       Component: ACC BOSCH MQB H10 0620
       Coding: 3300678159FFC728949C810580400600000000000000000000
       ASAM Dataset: EV_ACCBOSCHVW416 002005
       ROD: EV_ACCBOSCHVW416.rod
       VCID: 3C20C5AD46ED0C4774D-8069
       Part No SW: 5Q0 959 655 AR    HW: 5Q0 959 655 AR
       Component: AirbagVW21    003 0317
       Serial number: 003TDR2M320F
       Coding: 98CCC000000000005C0000CF000800000065
       VCID: 1078411D3AE5D827F85-8045
       Belt Pretensioner left:
       Component: BeltPretRevFL  H37 0350
       Serial number: 34169667E14021751238
       Coding: 333135
       Belt Pretensioner right:
       Component: BeltPretRevFR  H37 0350
       Serial number: 34169668E15021740411
       Coding: 333135
       Subsystem 3 - Part No SW: -----------    HW: 480 001 502 17
       Serial number: 35700000000DF301B02H
       Subsystem 4 - Part No SW: -----------    HW: 480 001 802 17
       Serial number: 3580000000006898C12J
       Subsystem 5 - Part No SW: -----------    HW: 480 400 902 17
       Serial number: 3510001B7247FF92A27F
       Subsystem 6 - Part No SW: -----------    HW: 480 400 902 17
       Serial number: 3520001BF248E894C38N
       Subsystem 7 - Part No SW: -----------    HW: 480 401 102 17
       Serial number: 3550001BF247FF96545Q
       Part No SW: 5Q0 953 507 GH    HW: 5Q0 953 549 E
       Revision: --------    Serial number: 13021708490772
       Coding: 0410
       ROD: EV_SMLSKLOMQB_VW37.rod
       VCID: 025C7B556489BAB77E1-8057
       Part No SW: 5G1 920 791     HW: 5G1 920 791
       Component: KOMBI         408 2180
       Coding: 07AD11082F80000801886B011400000000000000
       ASAM Dataset: EV_DashBoardVDDMQBAB 009052
       VCID: 698E4CF979FF49EFDFB-803D
       Component: GW MQB High   418 4286
       Revision: --------    Serial number: 0005944752
       Coding: 030100047F085900FB00027E1C0F00010001050000000000000000000000
       ROD: EV_GatewNF_VW27.rod
       VCID: 2F3AE2E1879BE7DFC1F-807B
       Serial number: 29170000191010047054
       Coding: 2DFFFF
       Serial number: 2705523004
    9175296 - Function Restriction due to Driver Fatigue Recognition
              B130E 00 [008] -  -
              [Funktionseinschränkung Pausenempfehlung - Ausfall CAN-MSG Prio2]
                        Reset counter: 214
                        Mileage: 20054 km
                        Date: 2018.02.09
                        Time: 18:55:28
                        Supply voltage: Terminal 30: 14.6 V
                        Terminal 15: On
       Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
       Component: LCM_MLBevoH08 0014
       VCID: 47CAAA410F2B5F9FE9F-8013
    0033 - Supply voltage
              [Supply voltage - lower limit exceeded]
                        Reset counter: 213
                        Mileage: 20139 km
                        Date: 2018.02.13
                        Time: 18:28:03
       Serial number: 250117EAP23083
       Coding: 003F0220D000048000001000
       VCID: 43D2BE513B1373BF357-8017
       Serial number: 00000000000013385730
       Coding: 110000
       Coding: 8107
       ROD: EV_SteerAssisMQB_013.rod
       VCID: 3A2CC3B54CD93277661-806F
       Component: FCM MQB Low   001 0285
       Serial number: 06021710801447
       Coding: 000000050100164A01100F01020000000000000000000000000000000000
       VCID: 72BC2B9554298A376E1-8027
       Serial number: 280117EAS02146
       Coding: 003F0020DE00048000801000
       VCID: 42DCBB5524097AB73E1-8017
       Serial number: 00000000000013346273
       Coding: 090000
       Part No SW: 3Q0 035 864 B    HW: 3Q0 035 864 B
       Component: MU-S-N-ER     840 0751
       Coding: 02731001FF0000005111000100080A001F0503F401200000CF
       ROD: EV_MUStd4CDELP_VW27.rod
       VCID: 3038E19D9AA5F827D85-8065
       Component: ABT_Std-2_Nav  H41 8077
       Serial number: VWZ6ZET0481789
       Subsystem 2 - Part No SW: 3G0 919 866 BC    HW: -----------
       Component: ECE1 2017/18  --- 0820
       Serial number: 161118201537
       VCID: 6B8236F173035BFFAD7-803F
       Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
       Component: LED1L         H06 0002
       ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
       ROD: EV_LEDMinMaxL_KEBODAVW481.rod
       VCID: 392EDCB949DF396F6FB-806D
       Component: LED1R         H06 0002
       ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
       ROD: EV_LEDMinMaxR_KEBODAVW481.rod
    End----(Elapsed Time: 01:43, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
  6. #16
    Faulty loose wiring or a problem with the light.
    Above Magic!
  7. #17
    Feb 2018
    Spain
    Will check the lights and wiring.
    And the fatigue detector fault? It is appearing after clearing it.
  8. #18
    Clean it & inspect or change it if nothing can be found wrong with wiring.
    Above Magic!
  9. Likes jfim88 liked this post
  10. #19
    Feb 2018
    Spain
    Just tested all light and all are running fine.
    And the “Function limited due to driver fatigue recognition” fault? It always come again after clearing.
