So, this is the first time using HEX-NET wirelessly with VCDS-Mobile. I run an auto-scan on my 2017 GTI and, as expected, there is no ASAM data for it stored on my HEX-NET yet.
After completing the auto-scan it prompts me to download ASAM data, which I did, and now it it seems to be in an update loop in which it continually says "updated rod data needed" when trying to update it via VCDS Interface Config.
Attached is the auto-scan after "Updating" my HEX-NET as well as the HEX-NET's info.
Any ideas? My guess is that the ASAM data isn't available yet, or I am doing it wrong.
EDIT: more or less the same issue as bramsey here: http://forums.ross-tech.com/showthread.php?12550-Autoscan-on-2017-GTI
VCDS Mobile 0.4411.0.4
VIN: 3VW4T7AU4H
Scan: 01 02 03 08 09 15 16 17 19 42 44 52 5F 75 A9
VIN: 3VW4T7AU4H
Address 01: Engine (CXCA J623) Labels: 5G-01.lbl
Part No SW: 5G0 906 259 L HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 091D00124424002F0000
Shop #: WSC 00066 790 00149
ASAM Dataset: EV_ECM20TFS0205G0906259L 001004
ROD: N/A
VCID: 3731B8DF3A950CC913296186F5-8062
No ASAM data for: "EV_ECM20TFS0205G0906259L"
No fault codes found.
Address 02: Auto Trans (J743) Labels: 0D-02.lbl
Part No SW: 0D9 300 042 S HW: 02E 927 770 AS
Component: DQ250-6F MQB H54 5007
Revision: 06454104
ROD: N/A
VCID: 29156EA7FC21AA39959DC7FE23-807C
No ASAM data for: "EV_TCMDQ250021"
Address 03: ABS Brakes (J104) Labels: 5Q-03.clb
Part No SW: 5Q0 614 517 AQ HW: 5Q0 614 517 AF
Component: ESC H62 0400
Revision: 00000000
Coding: 01FA6BA13424096F807A020780C92980D62C90014001943400435050C009430000000012121212B835351919323200
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_Brake1UDSContiMK100ESP 036010
ROD: N/A
VCID: 80439303AFDB0B7162038212B8-80D5
No ASAM data for: "EV_Brake1UDSContiMK100ESP"
016401 - ROD - Unknown faultcode
Address 08: Auto HVAC (J301) Labels: 5G0-907-426.clb
Part No SW: 5GM 907 426 E HW: 5GM 907 426 E
Component: AC Manuell H03 1801
Revision: 00001K04
Coding: 00020004200100000000000000000002
ROD: N/A
VCID: 4AD7F12B596781217CE7306AFE-801F
No ASAM data for: "EV_ACManueBHBVW37X"
Subsystem 1 -
Subsystem 2 -
Address 09: Cent. Elect. (J519) Labels: 5Q-09.clb
Part No SW: 5Q0 937 087 AN HW: 5Q0 937 087 AN
Component: BCM PQ37BOSCH 032 0223
Revision: --------
ROD: N/A
VCID: 8751881F8AF53C492349D146E5-80D2
No ASAM data for: "EV_BodyContrModul1UDSBosc"
Subsystem 1 - Part No SW: 5G1-955-119-A Labels: 5Qx-955-119-V1.clb
Component: MÝ
919560 - ROD - Unknown faultcode
006666 - ROD - Unknown faultcode
006922 - ROD - Unknown faultcode
017162 - ROD - Unknown faultcode
017674 - ROD - Unknown faultcode
017930 - ROD - Unknown faultcode
ROD: N/A
VCID: 47D1C81F4A757C4963C91146A5-8012
No ASAM data for: "EV_AirbaVW20SMEVW37X"
Subsystem 1 - Part No SW: 4M0-959-339-B
Component: 00Z
Subsystem 2 - Component: ---
Subsystem 3 - Component: ---
Subsystem 4 - Component: ---
Subsystem 5 - Component: ---
Subsystem 6 - Component: ---
Address 16: Steering wheel (J524) Labels: 5Q-16.lbl
Part No SW: 5Q0 953 521 P HW: 5Q0 953 569 A
Revision: FF034034
Coding: 0410
Shop #: WSC 66564 385 16448
ROD: N/A
VCID: 3FC1D0FF12A53489DB79B9E60D-806A
No ASAM data for: "EV_SMLSVALEOMQB"
Part No SW: 5G1 920 856 B HW: 5G1 920 856 B
Component: KOMBI 344 8311
Coding: 0BBD090AA180CF0502087A001000000000000000
ROD: N/A
VCID: 2D1D9AB7C8C9B61979C5F30E77-8078
No ASAM data for: "EV_DashBoardVDDMQBAB"
16777020 - ROD - Unknown faultcode
Part No SW: 3Q0 907 530 B HW: 3Q0 907 530 B
Component: GW MQB Mid 514 5286
Coding: 0101000870085900FB0000281C0F00000001050000000000000000000000
Shop #: WSC 00066 790 07030
ROD: N/A
VCID: 2E1F9DBBC5CFCD0140CFFC3A62-807B
No ASAM data for: "EV_GatewNF"
Subsystem 1 -
Subsystem 2 - Component: 1ÿÿ
Address 42: Door Elect, Driver (J386) Labels: 5Q-42.clb
Component: TSG FS 020 0041
Coding: 003E03200000020000000000
ROD: N/A
VCID: 43C9DC0F7E4D5069BFA1E53651-8016
No ASAM data for: "EV_DCUDriveSideEWMAXKLO"
Address 44: Steering Assist (J500) Labels: 3Q-44.lbl
Part No SW: 3QM 909 144 HW: 3QM 909 144
Component: EPS_MQB_ZFLS 506 5072
Coding: 8102
ROD: N/A
VCID: 0C5B37331393DF118E7B8682A4-8059
No ASAM data for: "EV_SteerAssisMQB"
Address 52: Door Elect, Pass. (J387) Labels: 5Q-52.clb
Component: TSG BFS 020 0041
ROD: N/A
VCID: 42C7D90B61575961B497D80A66-8017
No ASAM data for: "EV_DCUPasseSideEWMAXKLO"
Address 5F: Information Electr. (J794) Labels: 3Q-5f.clb
Part No SW: 3Q0 035 844 A HW: 3Q0 035 844 A
Component: MU-S-S-US 710 0751
Coding: 02730000FF00000051220001001808009F0203D40120010002
ROD: N/A
No ASAM data for: "EV_MUStd4CDELP"
Subsystem 1 - Part No SW: 3G0-919-605-H
Component: ABT_Std-2
Address 75: Telematics (J949) Labels: 5QE-035-285.clb
Component: OCULowMQBUS 007 0570
Coding: 02730002C2821A017F1E06000000
ROD: N/A
No ASAM data for: "EV_OCULowMQB"
Address A9: Struct. Borne Sound (J869) Labels: 5G-a9.lbl
Part No SW: 5G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0014
Shop #: WSC 00000 000
ROD: N/A
VCID: EB99D4AFB65DF829A7311D16C9-80BE
No ASAM data for: "EV_SoundActuaGen2AU64X"
CB: 0.4411
FW: 0.254
CFB: 0.10
BL: 0.28
DS: 00000050
