Results 11 to 20 of 26
Thread: Octavia MKiii 2017 Starter system faulty workshop error
    Feb 2018
    Israel
    Also, in my last visit to the imprter's workshop, they replaced the battery as I complained i was getting "12v battery low" warning messages before starting the car.
    I noticed they didn't recode the battery's serial number . all the other details were correct (battery type, manufacturer, capacity). is this critical ?
  2. #12
    I think a change to the serial number is what tells the BEM that a new battery has been installed. Post your Battery History Data and let's see what it shows.
  4. #13
    Feb 2018
    Israel
    Pasting only the relevant part (i hope that's the right part..)
    Record 4/16: Battery change history
    2018-01-17-00:08*03*069*BA2*BA21H9VBDN*09989*00105*0000*0000*0000**
           0000000km*02*069*JCB*1111111111*09989*00795*0013*0001*0000**
           0000000km*01*069*JCB*1111111111*10000*00000*0000*0000*0000**
    17/1/18 is the date I've been in the garage . the serial number is wrong though, the one on the (new) battery is longer - BA2170930U0DN
  5. Likes Uwe liked this post
  6. #14
    Quote Originally Posted by tomer View Post
    Then it seems your BEM knows the battery has been changed. If it was mine, I wouldn't try "correct" the serial number at this point.
  7. #15
    Feb 2018
    Israel
    Thanks, i won't touch it.
    Any other thought about the "starter system" error message?
    I forgot to mention, that as part of the multimedia upgrade, I installed Connects2 Infodapter which allows me to control the car's settings through the Alpine screen and use the wrs button to change driving modes.
    I don't think it has anything to do with the error as it started to appear some time after the Infodapter installation.
  8. #16
    Feb 2018
    Israel
    Also, I'm trying to figure out this under airbags
     Supply Voltage
              B201C 00 [008] - Implausible Signal
              [Powersupply implausible signal]
    From what I understand, 4 fault priority is kind of high. Any thought what could this be?
  9. #17
     Supply Voltage
    If you clear it, does it come back?
  10. #18
    Feb 2018
    Israel
    yes, just found a scan from November, same error there. I've cleared all the errors several times since
  11. #19
    Feb 2018
    Israel
    Manged to solve the problem - it was the VW Infodapter causing this error http://www.connects2.co.uk/Product/ProductItem/CTUSK02
    once disconnected, warning message and beeping gone.
    Still getting the selector error under gearbox though
              P1734 00 [002] - -
  12. Likes Uwe, Jack@European_Parts liked this post
  13. #20
              P1734 00 [002] - -
    From the multiple posts about this intermittent error on briskoda.net it would appear that a faulty selector switch is a common problem on the Octavia III.
  14. Likes Jack@European_Parts, Uwe liked this post
