Hi Guys,
This vehicle has a water ingress issue (what a surprise) and has been standing for some time.
On my first scan the only comms was with the engine so I decided the CANbus was inop and popped the CAN gateway out. No surprise that the connector was water damaged. Cleaned the cable connector and put the gateway in the U/S tank. I've now got the CAN working and managed to start the car. The problem is that it will only start very occasionally, storing a 01176 004 key, no signal/communication code when it won't say running.
The customer only has one key. I've opened up the cluster and refreshed the solder on the back and inter-board connectors. The reader coil measures 22.8 Ohms, continuity from reader coil to cluster is good. If I disconnect the coil or use a key from another vehicle I get the same code, no change at all. I've look around the Megamos chip on the small board in the cluster (with a microscope) no signs of any dry joints. I don't know if its for "security" reasons but I can't find a datasheet or application note for this chip, so I'm unable to very the components around it.
I strongly suspect I'm looking at an issue with the cluster rather than anything else.
The reader coil is part of the barrel if it had been a seperate one I would have replaced it to rule it out. I do have another vehicle here that could probably lend it's barrel if I have to.
Any ideas folks?
Any ideas folks?
Wednesday,31,January,2018,14:59:34:20505
VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x86
VCDS Version: 18.1.0.2
Dealer/Shop Name: Response Diagnostics 01732 863344
VIN: WVWZZZ1FZ7V001709 License Plate: RO06YTE
Mileage: 76130km-47304mi Repair Order:
Chassis Type: 1F (1K0)
Scan: 01 03 08 09 15 16 17 19 25 26 42 44 46 52 56 62 72 76 7D
VIN: WVWZZZ1FZ7V001709 Mileage: 76130km-47304miles
00-Steering Angle Sensor -- Status: INTERFACE NOT COMPATIBLE
15-Airbags -- Status: Malfunction 1010
26-Auto Roof -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 1010
Address 01: Engine Labels: 03G-906-021-BMM.clb
Part No SW: 03G 906 021 FS HW: 03G 906 021 AB
Component: R4 2,0L EDC 000SG 9397
Revision: --H02--- Serial number: VWX7Z0F43NU9F2
Coding: 0000072
Shop #: WSC 00399 210 50755
VCID: 75E5DD851C912FED96-8020
005488 - Engine Start Blocked by Immobilizer
P1570 - 000 - - MIL ON
Fault Status: 11110000
Mileage: 75996 km
Time: 10:43:14
RPM: 1008 /min
Load: 0.0 %
Voltage: 12.01 V
Bin. Bits: 00000100
Bin. Bits: 00000000
(no units): 33.0
Revision: 00H11001
Coding: 0006882
Shop #: WSC 00020 000 00000
VCID: 73E1E39D12E531DDB8-8026
Part No: 1Q0 820 047
Component: Climatic PQ35 100 0101
VCID: 67D987CD563DCD7D14-8032
013 - Check DTC Memory
00532 - Supply Voltage B+
01271 - Positioning Motor for Temperature Flap (V68)
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 Q HW: 3C0 937 049 Q
Component: Bordnetz-SG H46 1501
Revision: 00H46000 Serial number: 00000005704035
Coding: 05880F0700041500470A00000F00000000095D035C0000
VCID: 3779178D461D9DFD44-8062
Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 170506 020 0501
Coding: 00038805
Shop #: WSC 00020
10 Faults Found:
Fault Status: 00101110
Reset counter: 166
Voltage: 9.25 V
00906 - Horn (H1)
Fault Status: 00101001
Reset counter: 172
Mileage: 76136 km
Voltage: 13.05 V
01800 - Light Switch (E1)
008 - Implausible Signal
Fault Status: 01101000
Reset counter: 132
Mileage: 76137 km
Voltage: 14.15 V
Fault Status: 01101001
Reset counter: 132
Mileage: 76137 km
Voltage: 13.45 V
Reset counter: 167
Mileage: 75853 km
Voltage: 8.60 V
Reset counter: 166
Voltage: 9.75 V
Reset counter: 172
Mileage: 75830 km
Voltage: 8.05 V
00154 - Windshield Wiper Motor; Passenger Side (V217)
Fault Frequency: 106
Reset counter: 172
Mileage: 75830 km
Voltage: 9.30 V
02383 - Windshield Wiper Motor Function Restricted due to Under-Voltage
Reset counter: 172
Mileage: 75830 km
Voltage: 9.30 V
00927 - Terminal 30 (Right)
Fault Status: 00101011
Reset counter: 172
Mileage: 76136 km
Voltage: 13.15 V
Address 15: Airbags Labels: 1Q0-959-655.lbl
Part No SW: 1Q0 959 655 A HW: 1Q0 959 655 A
Component: 3C Airbag VW8C 0180
Revision: 92009018 Serial number: 003B3000B20U
Coding: 0013123
VCID: 3A7F0EB9750F8095BB-806E
Subsystem 1 - Serial number: 6332SRB4034CCF359
Subsystem 2 - Serial number: 6342SRB403484F2E6
Subsystem 3 - Serial number: 637 RB4 8
Subsystem 4 - Serial number: 638 RB4 9
Mileage: 76137 km
Time: 13:37:22
Part No SW: 1K0 953 549 AP HW: 1K0 953 549 AP
Component: Lenksäulenmodul 035 0070
Coding: 0000011
VCID: 000BBC5153531A45B5-8054
Part No SW: 1Q0 920 963 A HW: 1Q0 920 963 A
Revision: V0003000 Serial number: VWX7Z0F43NU9F2
Coding: 0017403
Shop #: WSC 00126 067 57207
VCID: 306B2C91A3734AC505-8064
Fault Frequency: 52
Reset counter: 172
Reset counter: 166
Mileage: 75847 km
Time: 18:14:55
Reset counter: 167
Mileage: 75853 km
Time: 01:06:41
Address 19: CAN Gateway Labels:. 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Revision: H12 Serial number: 31001065248381
Coding: 3D3F2F4007005001
VCID: 2C5338E18F5B2E2539-8078
9 Faults Found:
Fault Status: 01101100
Fault Frequency: 16
Reset counter: 206
Mileage: 62244 km
Time: 07:46:34
Fault Frequency: 30
Reset counter: 121
Mileage: 66068 km
Time: 07:32:35
01312 - Powertrain Data Bus
Reset counter: 165
Mileage: 75837 km
Time: 12:44:11
Reset counter: 165
Mileage: 75837 km
Time: 12:55:05
Reset counter: 165
Mileage: 75837 km
Time: 12:56:58
01316 - ABS Control Module
Reset counter: 165
Mileage: 75837 km
Time: 12:56:58
Reset counter: 165
Mileage: 75837 km
Time: 12:56:58
Reset counter: 165
Mileage: 75837 km
Time: 12:56:58
Reset counter: 165
Mileage: 75837 km
Time: 12:56:58
Component: IMMO VDD 1610
01176 - Key
Reset counter: 132
Mileage: 76136 km
Time: 13:18:16
Address 26: Auto Roof Labels: 1Q0-959-255.clb
Part No SW: 1Q0 959 255 A HW: 1Q0 959 255 A
Component: Verdecksteuergeraet 0512
Revision: 0028000J Serial number: 061100003
Coding: 0655362
VCID: 36671A89411764F55F-8062
Reset counter: 162
Mileage: 74794 km
Time: 21:07:40
Voltage: 11.70 V
Voltage: 11.70 V
Voltage: 4.90 V
Error Code: 0
03061 - Left Roof Pillar Opening Sensor (G566)
Reset counter: 132
Mileage: 75823 km
Time: 18:57:41
Voltage: 14.30 V
Voltage: 14.30 V
Voltage: 4.90 V
Error Code: 0
03053 - Left Roof Pillar Lock Sensor (G558)
Fault Frequency: 46
Reset counter: 166
Mileage: 75837 km
Time: 13:29:57
Voltage: 12.10 V
Voltage: 12.10 V
Voltage: 4.90 V
Error Code: 0
Fault Frequency: 13
Reset counter: 166
Voltage: 9.30 V
Voltage: 9.40 V
Voltage: 4.90 V
Error Code: 0
Reset counter: 172
Mileage: 75853 km
Time: 15:36:27
Voltage: 6.90 V
Voltage: 6.90 V
Voltage: 4.90 V
Error Code: 0
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX2.lbl
Part No: 1Q0 959 701 B
Component: Tuer-SG 024 2730
Coding: 0000693
VCID: 3361239D526571DD78-8066
01811 - Supply Voltage for Door Controller; Drivers Side (J386)
Part No: 1K2 909 144 L
Component: EPS_ZFLS Kl.070 H07 1806
VCID: 35651D855C116FED56-8060
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0202
Coding: 99908A000186285B0804840570085EC690BCA0
Shop #: WSC 00399 210 80966
VCID: 0301B35D4245015DA8-8056
Subsystem 1 - Component: Sounder No Answer
Subsystem 2 - Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Subsystem 3 - Part No: 1Q0 951 177 A
Component: Innenraumueberw.158 0502
8 Faults Found:
00830 - Convertible Top Control Module (J256)
Reset counter: 166
01134 - Alarm Horn (H12)
Fault Frequency: 194
Reset counter: 132
Fault Status: 00100101
Reset counter: 40
Fault Frequency: 10
Reset counter: 166
Fault Status: 00110010
Reset counter: 167
Fault Frequency: 177
Reset counter: 167
Mileage: 75853 km
Time: 00:43:10
00955 - Key 1
Fault Status: 00110101
Reset counter: 172
Mileage: 76136 km
Time: 13:18:30
Fault Status: 01101101
Reset counter: 132
Mileage: 76137 km
Time: 00:00:01
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX2.lbl
Part No: 1Q0 959 702 B
Coding: 0000692
VCID: 34632081576B76E561-8060
01812 - Supply Voltage for Door Controller; Pass. Side (J387)
Part No SW: 1K0 035 186 R HW: 1K0 035 186 R
Component: Radio FO3 021 0012
Revision: 00021000 Serial number: VWZ7Z2F0020502
Coding: 0020200
Shop #: WSC 00401 210 15949
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1Q0 959 703
Component: Tuer-SG 021 2705
Coding: 0000128
01813 - Supply Voltage for Door Controller; Rear Left (J388)
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1Q0 959 704
Coding: 0000128
VCID: 74E3E08117EB36E5A1-8020
01814 - Supply Voltage for Door Controller; Rear Right (J389)
Address 76: Park Assist Labels: 1K0-919-283.lbl
Part No: 1Q0 919 283
Component: 30 Einparkhilfe 0702
VCID: 72EFE6996DFF38D5B3-8026
01548 - Sensor for Parking Aid; Rear Right (G206)
014 - Defective
01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D5535E5B441272D2E-8078
End-------------------------(Elapsed Time: 02:14)--------------------------
Address 25: DTCs cleared
Coding: 0000072
P1570 - 000 - - Intermittent
Fault Status: 00110000
Mileage: 75996 km
Time: 10:43:14
RPM: 1008 /min
Load: 0.0 %
Voltage: 12.01 V
Bin. Bits: 00000100
Bin. Bits: 00000000
(no units): 33.0
Revision: 00H11001
Coding: 0006882
Coding: 00038805
Shop #: WSC 00020
Reset counter: 132
Mileage: 76137 km
Voltage: 14.10 V
Reset counter: 132
Mileage: 76137 km
Voltage: 13.50 V
Reset counter: 172
Voltage: 13.55 V
Coding: 0013123
Coding: 0000011
Coding: 0017403
Fault Status: 01101011
Reset counter: 132
Mileage: 76137 km
Time: 00:00:02
01176 - Key
Reset counter: 132
Mileage: 76137 km
Time: 00:01:19
Coding: 0655362
Reset counter: 132
Mileage: 76137 km
Time: 00:06:18
Voltage: 12.60 V
Voltage: 12.70 V
Voltage: 4.90 V
Error Code: 0
Coding: 0000693
Reset counter: 132
Mileage: 76137 km
Time: 00:00:01
Reset counter: 132
Mileage: 76137 km
Time: 00:14:32
Coding: 0000692
Coding: 0020200
Coding: 0000128
Coding: 0000128
End-------------------------(Elapsed Time: 02:06)--------------------------
