Touareg RNS 850 coding info needed
EAnglum
C?ID=276465
I noticed on Club Touareg this tweak being shared, which dramatically changes the sound for a non Dynaudio RNS 850. Significant improvement in sound, but I really would like to know what this is changing.
56 - Radio
07 - Encoding (long coding)
Change byte 4 from 01 and make it 00
It sounds like the overall power output has significantly increased, not just louder, but far better bass, mid's and highs.
01 = Standard Sound Profile for the internal amplifier
00 = Sound Profile for external amplifier
AndySwede
Stockholm Sweden
C?ID=172802
Hm... is this really correct? I did this tweak myself. Not shure if it was made before this scan.
But external amp, would that be Dynaudio or Fender? I find it hard to believe that the standard RNS/media unit could power the 8 speaker system in this big car without external amp.
In my opinion this tweak adds a "loudness" function.
Saturday,25,April,2015,14:33:11:51824
VCDS Version: 14.10.2.0 (x64)
Data version: 20150311
VIN: WVGZZZ7PZED04xxxx   License Plate: CJX327
Mileage: 8019km-4982mi   Repair Order:
Chassis Type: 7P (7P6)
Scan: 01 02 03 05 08 09 10 15 16 17 18 19 34 36 42 46 52 53 55 56
          5F 62 69 6C 6D 72
VIN: WVGZZZ7PZED04xxxx   Mileage: 8019km-4982miles
Address 01: Engine (J623-CRCA)       Labels: None
   Part No SW: 7P0 907 401 F    HW: 4G0 907 401
   Component: 3.0TDI EDC17  H41 0007
   Revision: 53H41---
   Coding: 292A401A233E01020000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_ECM30TDI0117P0907401F 001008
   ROD: EV_ECM30TDI0117P0907311C.rod
   VCID: 325325B365E511B1A8B-8067
Address 02: Auto Trans (J217)       Labels: 0C8-927-750.clb
   Part No SW: 0C8 927 750 BQ    HW: 0C8 927 750 BQ
   Component: AL1000 AISIN  002 2530
   Coding: 003568
   Shop #: WSC 20131 002 1048576
   ASAM Dataset: EV_TCMAL991031 002115
   ROD: EV_TCMAL991031_VW52.rod
   VCID: 7CCFCB8BF72117C1327-8029
Address 03: ABS Brakes (J104)       Labels: 7P0-907-379.clb
   Part No SW: 7P0 907 379 P    HW: 7P0 907 379 A
   Component: MK25A         H36 0446
   Revision: --------    Serial number: 404240010EC815
   Coding: 5B6B13C30B282558DAFAC89CD0D3A450F700
   ASAM Dataset: EV_MK25AXT 008001
   ROD: EV_ESPMK25A00800.rod
   VCID: 4AA35D53ED757971F0B-801F
   Slave 1:
   Part No SW: 4H0 907 064 EH    HW: 4H0 907 064 EH
   Component: BCM2 2.0      H36 0521
   Coding: 01A60010000000000000
   VCID: 73DDE0B7D27F58B963D-8026
   Subsystem 1 - Part No SW: 7P6 959 754 AP    HW: 7P6 959 754 AP
   Component: FBSTOUAREGIDG  H08 0084
Address 08: Auto HVAC (J255)       Labels: 7P6-907-040.clb
   Part No SW: 7P6 907 040 BT    HW: 7P6 907 040 BT
   Component: Klima 2 Zonen H21 1306
   Coding: 3696000A10
   VCID: 0725A467BEE744192F5-8052
Address 09: Cent. Elect. (J519)       Labels: 4H0-907-063.clb
   Part No SW: 4H0 907 063 CD    HW: 4H0 907 063 D
   Revision: 15012002    Serial number: 00000001736093
   Coding: 26001010D1345D010021000300005D0C431C670806010241000000020000
   VCID: 6CEFFBCB8F418741A27-8039
   Component: WWS    140409  033 0021
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7P0 955 559 E    HW: 7P0 955 559 E  Labels: 8K0-955-559.CLB
   Component: RLFS  H10 0020
   Coding: 025223
   Subsystem 3 - Part No SW: 7P6 941 431 D    HW: 7P6 941 431 D
   Component: E1 - LDS  H04 0031
Address 10: Park/Steer Assist (J446)       Labels: 7P6-919-475.clb
   Part No SW: 7P6 919 475 C    HW: 7N0 919 475
   Component: PARKHILFE 8K  H05 0026
   Revision: --------    Serial number: 28261411902693
   Coding: 518501
   ASAM Dataset: EV_VW526ParkiAssis2 001012
   ROD: EV_VW526ParkiAssis2.rod
   VCID: 43BD7077CA5FA83933D-8016
   Part No SW: 7P0 959 655 D    HW: 7P0 959 655 D
   Component: VW10Airbag04Z H06 0026
   Revision: --------    Serial number: 003L5005B58F
   Coding: 00000000000000000000000000000000345A
   ROD: EV_AirbaVW10BPAVW526.rod
   VCID: 42B37573D545A13138B-8017
   Serial number: 3575LRB405T2E3MI4PF5
   Serial number: 3585LRB405V2E3MI0P6
   Serial number: 3515RRB400450T8IT9CP
   Serial number: 3525RRB400450T8INHGW
   Serial number: 3555NRB400C52JN0K9FG
   Serial number: 3565NRB400C52JN0K9PR
Address 16: Steering wheel (J527)       Labels: 4H0-953-568.clb
   Part No SW: 4H0 953 568 H    HW: 7P6 953 507 M
   Revision: --------    Serial number: 01335NDR0015T
   Coding: 000C35
   VCID: 3847179B8B99FBE196F-806D
   Subsystem 1 - Part No SW: 7P6 959 542 A    HW: 7P6 959 542 A
   Component: E221__MFL-TAS  H04 0028
Address 17: Instruments (J285)       Labels: 7P6-920-xxx-17.clb
   Part No SW: 7P6 920 882 M    HW: 7P6 920 882 M
   Component: Kombi         H13 0419
   Revision: 13240270    Serial number: 658240414592048
   Coding: 133733003A00000800000C
   ASAM Dataset: EV_KombiUDSRBVW526 001020
   ROD: EV_KombiUDSRBVW526.rod
   VCID: 47A56467FE678419EF5-8012
Address 18: Aux. Heat (J364)       Labels: 8R0-265-105.clb
   Part No SW: 7P0 963 272 E    HW: 7P0 963 272 E
   Component: Standheizung  H23 0247
   Revision: 56005006    Serial number: 20140227223754
   Coding: 594200
   VCID: 3941129FB093E2E9691-806C
   Part No SW: 7P6 907 530 J    HW: 7P6 907 530 F
   Component: GW-CAN-L-MOST H13 6032
   Revision: --------    Serial number: 00000001371293
   Coding: 000D07AD00
   ASAM Dataset: EV_GatewVW526UDS 001007
   ROD: EV_GatewUDS_VW52.rod
   VCID: 3FB57C87A6B7CCD9575-806A
   Subsystem 1 - Part No SW: 7P0 915 181 B    HW: 7P0 915 181
   Component: Batt_Sensor  H07 0190
   Serial number: 41106J00355701126743
   Voltage stabilizer:
12290 - Quiescent Current
          U1406 00 [008] - Too High
                    Reset counter: 10
                    Mileage: 7625 km
                    Date: 2015.04.22
                    Time: 11:48:00
16384 - Function Restriction due to Driver Fatigue Recognition
          B130E 00 [008] -  -
                    Reset counter: 11
                    Mileage: 7680 km
                    Date: 2015.04.24
                    Time: 12:05:33
Address 34: Level Control (J197)       Labels: 7P0-907-553.clb
   Part No SW: 7P0 907 553 AA    HW: 7P0 907 553 AA
   Component: PASM          H04 1800
   Revision: 00000000    Serial number: 00000141070311
   Coding: 14210000
   ASAM Dataset: EV_PASMConti 001004
   ROD: EV_PASMConti.rod
   VCID: 76DBD9A3C90D4D91443-8023
   Component: MEM-FS        H08 0156
   Revision: AA000000    Serial number: 00000099028505
   Coding: 0058130000004001000001010101202020202121202020
   VCID: 345F23AB97F11F81BA7-8061
   Part No SW: 4H0 959 793 AC    HW: 4H0 959 793 P
   Component: TSG FA        H02 0306
   Revision: --------    Serial number: 0000100949393
   Coding: 011D0620DE00451005080002
   VCID: 7AC3CD93F51529F120B-802F
Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
   Revision: 00002001    Serial number: 0333604048
   Coding: 019A162028B9109483200624210000000000000000000000000000000000
   Subsystem 1 - Part No: 7P6 951 171
   Component: DWA-Sensor  002 0204
   Subsystem 3 - Part No SW: 7P0 959 591 B    HW: 7P0 959 591 B
   Component: J245 PS30.055  H01 0008
   Coding: 191100
   Subsystem 4 - Part No SW: 7P0 959 591 C    HW: 7P0 959 591 C
   Component: J394 PS30.055  H01 0008
   Coding: 191100
   Part No SW: 4H0 959 792 S    HW: 4H0 959 792 M
   Component: TSG BF        H02 0306
   Revision: --------    Serial number: 0000100556854
   Coding: 011D0620DE00451005080000
   VCID: 48A7675BFB798B61E6F-801D
Address 53: Parking Brake (J540-)       Labels: 7P0-907-801.clb
   Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
   Component: EPB           H51 1201
   Revision: 00000000    Serial number: C1441700404
   Coding: 01040100
   ROD: EV_ParkbA7.rod
   VCID: 365B19A3898D0D91843-8063
   Slave 3:
   Part No SW: 7P6 907 357     HW: 7L6 907 357 C
   Component: AFS-ECU       H04 0110
   Coding: 01AA00000F000200
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329
   Component: LeiMo links  H01 0003
   Coding: 130000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329
   Component: LeiMo rechts  H01 0003
   Coding: 130000
   Part No SW: 4G0 035 061 N    HW: 4G0 035 061
   Component: Radio U DAB   H60 0139
   Revision: AB001007    Serial number: 109D30E7919592
   Coding: 010105020100000003
   VCID: 2867C7DB5B396B6106F-807D
   Part No SW: 7P6 035 670 F    HW: 7P6 035 670 A
   Component: H-BNT-EU      H40 0816
   Revision: --------    Serial number: 444D-0E7505346
   Coding: 010100050040C3EF41002B0E00000003F00401030000000000
   Subsystem 1 - Part No: 7P6 060 884
   Component: EUR 2014  2004
   Subsystem 2 - Part No SW: 7P6 919 603     HW: 7P6 919 603
   Component: DU8 SV Touch  H26 0045
   Subsystem 3 - Part No SW: 7P6 919 603     HW: 7P6 919 603
   Component: CD-Database  5571
   Part No SW: 4H0 959 795 P    HW: 4H0 959 795 J
   Component: TSG HL        H03 0306
   Revision: --------    Serial number: 0000101095149
   Coding: 011804200000251005080000
Address 69: Trailer (J345)       Labels: None
   Part No SW: 7P0 907 383 J    HW: 7P0 907 383 C
   Component: Anhaenger     H11 0130
   Revision: 5H001001    Serial number: 00008200264169
   Coding: 0106040000000000
   VCID: 3FB57C87AEB7CCD9575-806A
Address 6C: Back-up Cam. (J928)       Labels: 7P6-907-441-V1.clb
   Part No SW: 7P6 907 441 E    HW: 7P6 907 441 D
   Component: TopView       H05 0100
   Revision: 11001001    Serial number: 82330JF0147099
   Coding: 0100000001010000010102000000
   ASAM Dataset: EV_CamerSysteTopViewVW 001014
   ROD: EV_CamerSysteTopViewVW.rod
   VCID: 3B4D0897B2AFD0F97BD-806E
Address 6D: Trunk Elect. (----)       Labels: 7N0-959-107.clb
   Part No SW: 7P6 959 107 C    HW: 7P6 959 107
   Component: HDSG-Modul    H10 0043
   Revision: 22010001    Serial number: 093401616
   Coding: 0533314003
   ASAM Dataset: EV_HeckkTouar 202142
   ROD: EV_HeckkTouar.rod
   Component: TSG HR        H03 0306
   Revision: --------    Serial number: 0000101089427
End-------------------------(Elapsed Time: 03:44)--------------------------
That's the only documentation I could find for this byte. Whether it's "correct" or not, well...
I would imagine they use different, more efficient speaker without an external amp?
