Results 1 to 4 of 4
Thread: Touareg RNS 850 coding info needed
    Apr 2016
    I noticed on Club Touareg this tweak being shared, which dramatically changes the sound for a non Dynaudio RNS 850. Significant improvement in sound, but I really would like to know what this is changing.
    56 - Radio
    07 - Encoding (long coding)
    Change byte 4 from 01 and make it 00
    It sounds like the overall power output has significantly increased, not just louder, but far better bass, mid's and highs.
    2013 VW Touareg VR6 Lux
    2010 GTI
    01 = Standard Sound Profile for the internal amplifier
    00 = Sound Profile for external amplifier
  3. Likes Dana liked this post
    Oct 2016
    Stockholm Sweden
    Hm... is this really correct? I did this tweak myself. Not shure if it was made before this scan.
    But external amp, would that be Dynaudio or Fender? I find it hard to believe that the standard RNS/media unit could power the 8 speaker system in this big car without external amp.
    In my opinion this tweak adds a "loudness" function.
    Saturday,25,April,2015,14:33:11:51824
    VCDS Version: 14.10.2.0 (x64)
    Data version: 20150311
    VIN: WVGZZZ7PZED04xxxx   License Plate: CJX327
    Mileage: 8019km-4982mi   Repair Order:
    Chassis Type: 7P (7P6)
    Scan: 01 02 03 05 08 09 10 15 16 17 18 19 34 36 42 46 52 53 55 56
              5F 62 69 6C 6D 72
    VIN: WVGZZZ7PZED04xxxx   Mileage: 8019km-4982miles
    Address 01: Engine (J623-CRCA)       Labels: None
       Part No SW: 7P0 907 401 F    HW: 4G0 907 401
       Component: 3.0TDI EDC17  H41 0007
       Revision: 53H41---
       Coding: 292A401A233E01020000
       Shop #: WSC 31414 790 00001
       ASAM Dataset: EV_ECM30TDI0117P0907401F 001008
       ROD: EV_ECM30TDI0117P0907311C.rod
       VCID: 325325B365E511B1A8B-8067
    Address 02: Auto Trans (J217)       Labels: 0C8-927-750.clb
       Part No SW: 0C8 927 750 BQ    HW: 0C8 927 750 BQ
       Component: AL1000 AISIN  002 2530
       Coding: 003568
       Shop #: WSC 20131 002 1048576
       ASAM Dataset: EV_TCMAL991031 002115
       ROD: EV_TCMAL991031_VW52.rod
       VCID: 7CCFCB8BF72117C1327-8029
    Address 03: ABS Brakes (J104)       Labels: 7P0-907-379.clb
       Part No SW: 7P0 907 379 P    HW: 7P0 907 379 A
       Component: MK25A         H36 0446
       Revision: --------    Serial number: 404240010EC815
       Coding: 5B6B13C30B282558DAFAC89CD0D3A450F700
       ROD: EV_ESPMK25A00800.rod
       VCID: 4AA35D53ED757971F0B-801F
       Slave 1:
       Part No SW: 4H0 907 064 EH    HW: 4H0 907 064 EH
       Component: BCM2 2.0      H36 0521
       Coding: 01A60010000000000000
       VCID: 73DDE0B7D27F58B963D-8026
       Subsystem 1 - Part No SW: 7P6 959 754 AP    HW: 7P6 959 754 AP
       Component: FBSTOUAREGIDG  H08 0084
       Subsystem 2 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
    Address 08: Auto HVAC (J255)       Labels: 7P6-907-040.clb
       Part No SW: 7P6 907 040 BT    HW: 7P6 907 040 BT
       Component: Klima 2 Zonen H21 1306
       Coding: 3696000A10
       VCID: 0725A467BEE744192F5-8052
    Address 09: Cent. Elect. (J519)       Labels: 4H0-907-063.clb
       Part No SW: 4H0 907 063 CD    HW: 4H0 907 063 D
       Revision: 15012002    Serial number: 00000001736093
       Coding: 26001010D1345D010021000300005D0C431C670806010241000000020000
       VCID: 6CEFFBCB8F418741A27-8039
       Component: WWS    140409  033 0021
       Coding: 004DBD
       Subsystem 2 - Part No SW: 7P0 955 559 E    HW: 7P0 955 559 E  Labels: 8K0-955-559.CLB
       Component: RLFS  H10 0020
       Coding: 025223
       Subsystem 3 - Part No SW: 7P6 941 431 D    HW: 7P6 941 431 D
       Component: E1 - LDS  H04 0031
    Address 10: Park/Steer Assist (J446)       Labels: 7P6-919-475.clb
       Part No SW: 7P6 919 475 C    HW: 7N0 919 475
       Component: PARKHILFE 8K  H05 0026
       Revision: --------    Serial number: 28261411902693
       Coding: 518501
       ASAM Dataset: EV_VW526ParkiAssis2 001012
       ROD: EV_VW526ParkiAssis2.rod
       VCID: 43BD7077CA5FA83933D-8016
       Part No SW: 7P0 959 655 D    HW: 7P0 959 655 D
       Component: VW10Airbag04Z H06 0026
       Revision: --------    Serial number: 003L5005B58F
       Coding: 00000000000000000000000000000000345A
       ROD: EV_AirbaVW10BPAVW526.rod
       VCID: 42B37573D545A13138B-8017
       Serial number: 3575LRB405T2E3MI4PF5
       Serial number: 3585LRB405V2E3MI0P6
       Serial number: 3515RRB400450T8IT9CP
       Serial number: 3525RRB400450T8INHGW
       Serial number: 3555NRB400C52JN0K9FG
       Serial number: 3565NRB400C52JN0K9PR
    Address 16: Steering wheel (J527)       Labels: 4H0-953-568.clb
       Part No SW: 4H0 953 568 H    HW: 7P6 953 507 M
       Revision: --------    Serial number: 01335NDR0015T
       Coding: 000C35
       VCID: 3847179B8B99FBE196F-806D
       Subsystem 1 - Part No SW: 7P6 959 542 A    HW: 7P6 959 542 A
       Component: E221__MFL-TAS  H04 0028
    Address 17: Instruments (J285)       Labels: 7P6-920-xxx-17.clb
       Part No SW: 7P6 920 882 M    HW: 7P6 920 882 M
       Component: Kombi         H13 0419
       Revision: 13240270    Serial number: 658240414592048
       Coding: 133733003A00000800000C
       ASAM Dataset: EV_KombiUDSRBVW526 001020
       ROD: EV_KombiUDSRBVW526.rod
       VCID: 47A56467FE678419EF5-8012
    Address 18: Aux. Heat (J364)       Labels: 8R0-265-105.clb
       Part No SW: 7P0 963 272 E    HW: 7P0 963 272 E
       Component: Standheizung  H23 0247
       Revision: 56005006    Serial number: 20140227223754
       Coding: 594200
       VCID: 3941129FB093E2E9691-806C
       Part No SW: 7P6 907 530 J    HW: 7P6 907 530 F
       Component: GW-CAN-L-MOST H13 6032
       Revision: --------    Serial number: 00000001371293
       Coding: 000D07AD00
       ROD: EV_GatewUDS_VW52.rod
       VCID: 3FB57C87A6B7CCD9575-806A
       Subsystem 1 - Part No SW: 7P0 915 181 B    HW: 7P0 915 181
       Component: Batt_Sensor  H07 0190
       Serial number: 41106J00355701126743
       Voltage stabilizer:
    12290 - Quiescent Current
              U1406 00 [008] - Too High
                        Reset counter: 10
                        Mileage: 7625 km
                        Date: 2015.04.22
                        Time: 11:48:00
    16384 - Function Restriction due to Driver Fatigue Recognition
              B130E 00 [008] -  -
                        Reset counter: 11
                        Mileage: 7680 km
                        Date: 2015.04.24
                        Time: 12:05:33
    Address 34: Level Control (J197)       Labels: 7P0-907-553.clb
       Part No SW: 7P0 907 553 AA    HW: 7P0 907 553 AA
       Component: PASM          H04 1800
       Revision: 00000000    Serial number: 00000141070311
       Coding: 14210000
       ASAM Dataset: EV_PASMConti 001004
       ROD: EV_PASMConti.rod
       VCID: 76DBD9A3C90D4D91443-8023
       Component: MEM-FS        H08 0156
       Revision: AA000000    Serial number: 00000099028505
       Coding: 0058130000004001000001010101202020202121202020
       VCID: 345F23AB97F11F81BA7-8061
       Part No SW: 4H0 959 793 AC    HW: 4H0 959 793 P
       Component: TSG FA        H02 0306
       Revision: --------    Serial number: 0000100949393
       Coding: 011D0620DE00451005080002
       VCID: 7AC3CD93F51529F120B-802F
    Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
       Revision: 00002001    Serial number: 0333604048
       Coding: 019A162028B9109483200624210000000000000000000000000000000000
       Subsystem 1 - Part No: 7P6 951 171
       Component: DWA-Sensor  002 0204
       Subsystem 3 - Part No SW: 7P0 959 591 B    HW: 7P0 959 591 B
       Component: J245 PS30.055  H01 0008
       Coding: 191100
       Subsystem 4 - Part No SW: 7P0 959 591 C    HW: 7P0 959 591 C
       Component: J394 PS30.055  H01 0008
       Coding: 191100
       Part No SW: 4H0 959 792 S    HW: 4H0 959 792 M
       Component: TSG BF        H02 0306
       Revision: --------    Serial number: 0000100556854
       Coding: 011D0620DE00451005080000
       VCID: 48A7675BFB798B61E6F-801D
    Address 53: Parking Brake (J540-)       Labels: 7P0-907-801.clb
       Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
       Component: EPB           H51 1201
       Revision: 00000000    Serial number: C1441700404
       Coding: 01040100
       ROD: EV_ParkbA7.rod
       VCID: 365B19A3898D0D91843-8063
       Slave 3:
       Coding: 01AA00000F000200
       Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329
       Component: LeiMo links  H01 0003
       Coding: 130000
       Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329
       Component: LeiMo rechts  H01 0003
       Coding: 130000
       Part No SW: 4G0 035 061 N    HW: 4G0 035 061
       Component: Radio U DAB   H60 0139
       Revision: AB001007    Serial number: 109D30E7919592
       Coding: 010105020100000003
       VCID: 2867C7DB5B396B6106F-807D
    Address 5F: Information Electr. (J794)       Labels: 4E0-035-6xx-5F.clb
       Part No SW: 7P6 035 670 F    HW: 7P6 035 670 A
       Component: H-BNT-EU      H40 0816
       Revision: --------    Serial number: 444D-0E7505346
       Coding: 010100050040C3EF41002B0E00000003F00401030000000000
       Subsystem 1 - Part No: 7P6 060 884
       Component: EUR 2014  2004
       Subsystem 2 - Part No SW: 7P6 919 603     HW: 7P6 919 603
       Component: DU8 SV Touch  H26 0045
       Subsystem 3 - Part No SW: 7P6 919 603     HW: 7P6 919 603
       Component: CD-Database  5571
       Part No SW: 4H0 959 795 P    HW: 4H0 959 795 J
       Component: TSG HL        H03 0306
       Revision: --------    Serial number: 0000101095149
       Coding: 011804200000251005080000
    Address 69: Trailer (J345)       Labels: None
       Part No SW: 7P0 907 383 J    HW: 7P0 907 383 C
       Component: Anhaenger     H11 0130
       Revision: 5H001001    Serial number: 00008200264169
       Coding: 0106040000000000
       VCID: 3FB57C87AEB7CCD9575-806A
    Address 6C: Back-up Cam. (J928)       Labels: 7P6-907-441-V1.clb
       Part No SW: 7P6 907 441 E    HW: 7P6 907 441 D
       Component: TopView       H05 0100
       Revision: 11001001    Serial number: 82330JF0147099
       Coding: 0100000001010000010102000000
       ASAM Dataset: EV_CamerSysteTopViewVW 001014
       ROD: EV_CamerSysteTopViewVW.rod
       VCID: 3B4D0897B2AFD0F97BD-806E
    Address 6D: Trunk Elect. (----)       Labels: 7N0-959-107.clb
       Part No SW: 7P6 959 107 C    HW: 7P6 959 107
       Component: HDSG-Modul    H10 0043
       Revision: 22010001    Serial number: 093401616
       Coding: 0533314003
       ROD: EV_HeckkTouar.rod
       Component: TSG HR        H03 0306
       Revision: --------    Serial number: 0000101089427
    End-------------------------(Elapsed Time: 03:44)--------------------------
    Quote Originally Posted by AndySwede View Post
    That's the only documentation I could find for this byte. Whether it's "correct" or not, well...
    I would imagine they use different, more efficient speaker without an external amp?
