Hi guys,
This is my first post on this support forum. i hope someone will be able to provide some help.
I just replaced my Audi A1 by a very similar one but there is no Airbag deactivation switch fitted whereas I had it on the old one.
This is needed because my wife is pregnant and she would like to face the baby when driving.
As i do own the 2 vehicules until the first is sold, I looked closer and found the only physical differences seems to be the keyswitch on the glovebox, a little harness, and a dash panel warning switch with the Airbag-off light.
Lucky me the Airbag deactivation switch's harness and 3 wires plug was already there behind the glovebox, and the Dash light had the complete same wiring.
Therefore I swapped the parts from both cars and tried to make it work.
But I could not recode or change adaptation on any of the 2 cars !
Long coding helper showed no information on this module but as there was only 1 single bit of difference I took the risk to try changing coding.
(I did not use 0 values for Workshop code / importer as advised on other posts)
Is there something i missed ?
Thanks for your answer !
Here are the full scan of both cars :
error 22 coding rejected
condition not correct or requested sequence error.
UDS Adaptation Channel (8B): MAS00975-MAS00079-Airbag adaptations-Key switch
Stored value Airbag deactivation key switch not installed
Saturday,27,January,2018,13:08:10:61394
VCDS Version: 18.1.0.2 (x64)
VIN: WAUZZZ8XXCB231495 License Plate:
Chassis Type: 8X-AU21 (8U0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 5F 62 72
VIN: WAUZZZ8XXCB231495 Mileage: 93870km-58328miles
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 KP HW: 03L 906 023 KP
Component: R4 1.6l TDI H63 9978
Revision: --H63--- Serial number:
Coding: 00114036032401080000
Shop #: WSC 00046 790 00000
ASAM Dataset: EV_ECM16TDI02103L906023KP 003014
ROD: EV_ECM16TDI02103L906023KG.rod
VCID: 7EF3C823E118A7B5C7-802A
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 BB HW: 6R0 907 379 AH
Component: ESP8.2i front H07 0001
Revision: --------
Coding: 310448E9437000B38C2912EBC2D600520E00
Shop #: WSC 00046 000 00000
VCID: 7F0D3527EA12AEBDCC-802A
Address 08: Auto HVAC (J255) Labels:* None
Part No SW: 8X0 820 043 B HW: 8X0 820 043 B
Component: Klima 1 Zone H12 0070
Serial number: 00000000115030
Coding: 3403080050
ASAM Dataset: EV_AirCondiFrontAU210 006035
ROD: EV_AirCondiFrontAU210_006.rod
VCID: 336529179ADABADD78-8066
Address 09: Cent. Elect. (J519) Labels:. 8X0-907-063.clb
Part No SW: 8X0 907 063 G HW: 8X0 907 063 G
Component: BCM PQ35 M 110 0655
Revision: 00110 AE
Coding: 06000A2CE8051AC0201840E00100015443FB6C0A00EF4122DC0087830041
VCID: 408F76DBD36C1145F5-8014
Subsystem 1 - Part No SW: 8K0 955 559 HW: 8K0 955 559
Component: RLS H04 0003
Serial number: 20109760
Coding: 02562D
Address 10: Park/Steer Assist (J446) Labels:| 8X0-919-475.clb
Part No SW: 8X0 919 475 F HW: 8X0 919 475
Component: PARKHILFE 4K H03 0032
Revision: 11001001 Serial number: 37001206100786
Coding: 040001
ASAM Dataset: EV_EPHVA14AU21X0000 002004
ROD: EV_EPHVA14AU21X0000_002.rod
VCID: 49996BFFE856D00D22-801C
Address 15: Airbags (J234) Labels:| 8X0-959-655.clb
Part No SW: 8X0 959 655 B HW: 8X0 959 655 B
Component: Airbag10.41 H05 0009
Revision: -------- Serial number: 003KZ000WDP%
Coding: 30323236303230303137554A304C38583053
ASAM Dataset: EV_Airba1041BPAAU210 001018
ROD: EV_Airba1041BPAAU210.rod
Serial number: 3554VRB400U4UCT6LH1P
Serial number: 3575HRB404R16AM43H45
Serial number: 3585HRB406916AM09GG3
Rear Impact Crash Sensor:
Serial number: 3515ZRB40510P7AOC1MQ
Address 16: Steering wheel (J527) Labels:| 8X0-953-569.clb
Part No SW: 8X0 953 501 D HW: 5K0 953 569 H
Revision: FF010016 Serial number: 20120320101612
Coding: 1184204000
VCID: 3B750137B28A729DA0-806E
Subsystem 1 - Part No SW: 4G0 951 528 C HW: 4G0 951 528 C
Component: E221 - MFL H08 0009
Address 17: Instruments (J285) Labels:| 8X0-920-xxx-17.clb-SRI1
Part No SW: 8X0 920 930 D HW: 8X0 920 930 D
Component: KOMBI_MEDIUM H03 0180
Coding: 11CE00
ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04390
Address 19: CAN Gateway (J533) Labels: 8X0-907-468.clb
Part No SW: 8U0 907 468 A HW: 8U0 907 468 A
Component: GAT 4CAN 1L M H10 0044
Revision: 1P040023 Serial number: 2341P12302002D
Coding: FBCF005A000100010253
Subsystem 1 - Part No SW: 8K0 915 181 L HW: 8K0 915 181 L
Component: J367-BDM H08 0181
Serial number: 00000000004970414131
Subsystem 2 - Part No SW: 8K0 959 663 D HW: 8K0 959 663
Component: J532_DCDCStab H23 0021
Serial number: 261211000000000001D1
Component: IMMO H03 0180
Coding: 000002
ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04110
ROD: EV_Immo_UDS_VDD_AU10.rod
Address 42: Door Elect, Driver (J386) Labels:. 8X0-959-793.clb
Part No SW: 8X0 959 793 E HW: 8X0 959 793 E
Component: TSG FA H09 0410
Coding: 011802205C00000000
VCID: 4FAD45E71E32FE3D7C-801A
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11251
Shop #: WSC 00046
VCID: 2F6D2567EAF29E3D1C-807A
Address 52: Door Elect, Pass. (J387) Labels:. 8X0-959-792.clb
Part No SW: 8X0 959 792 E HW: 8X0 959 792 E
Component: TSG BF H09 0410
Coding: 011802201E00000000
VCID: 4E9358E31938F73577-801A
Part No SW: 8X0 035 193 E HW: 8X0 035 193 D
Component: RMC Cnct Nav H52 0775
Coding: 01000400000153070023020103010000000000
VCID: 3A7B0433B5B04B95BB-806E
Subsystem 1 - Part No SW: 8X0 919 603 HW: 8X0 919 603
Component: DU6 Basic H42 0084
Serial number: 9462CY0C2536592
Part No SW: 8X0 959 795 B HW: 8X0 959 795 B
Component: TSG HL H06 0409
Coding: 010002200000000000
Component: TSG HR H06 0409
End-------------------------(Elapsed Time: 02:33)--------------------------
Saturday,27,January,2018,12:54:33:61394
VIN: WAUZZZ8X9DB068758 License Plate:
Scan: 01 03 05 08 09 10 15 16 17 19 25 2B 42 44 46 52 55 5F 62 72
VIN: WAUZZZ8X9DB068758 Mileage: 41000km-25476miles
Part No SW: 03L 906 023 PS HW: 03L 906 023 KP
ASAM Dataset: EV_ECM16TDI02103L906023PS 003008
VCID: 0603A0C3B9C8FF758F-8052
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP90.clb
Part No SW: 6R0 907 379 BR HW: 6R0 907 379 BA
Component: ESP9.0i front H01 0003
Coding: 31DF488B432902C88C1B126EC25940561005
Shop #: WSC 00046 412 00000
ASAM Dataset: EV_Brake1ESP90iBOSCH 003031
ROD: EV_Brake1ESP90iBOSCH_003_VW21.rod
VCID: 0F2D85E7D6B2BE3D3C-805A
Address 05: Acc/Start Auth. (J518) Labels:| 5K0-959-434.clb
Part No SW: 5K0 959 434 B HW: 5K0 959 434
Component: VWKESSYPQ35GP 086 1101
Revision: 00086000 Serial number: 0194858823
Coding: 010E0E
VCID: 34672A0B9FD4BDE561-8060
Part No SW: 8X0 820 043 C HW: 8X0 820 043 C
Component: Klima 1 Zone H13 0090
Serial number: 00000000166711
Coding: 3403080050
ASAM Dataset: EV_AirCondiFrontAU210 006036
Revision: 00110 AE
Coding: 46000A2CA8051AC0201840E00100094C43FF720A20EF51B2E4008787E0C1
Subsystem 1 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 20770928
Coding: 02005D
Part No SW: 8X0 919 475 K HW: 4H0 919 475 C
Component: PARKHILFE 8K H07 0040
Revision: 11001001 Serial number: 55931232015077
Coding: 080201
Shop #: WSC 00046 790 12345
ASAM Dataset: EV_EPHVA18AU21X0000 002005
ROD: EV_EPHVA18AU21X0000_002.rod
VCID: 4E9358E31138F73577-801A
Revision: -------- Serial number: 003KZ003L5MN
Coding: 30323236303230303139554A304C38583053
Serial number: 3554VRB40104UNQ4A8H+
Serial number: 3575HRB40104UNBC8PO2
Serial number: 3585HRB40104UNBC8HR+
Serial number: 3515ZRB405N18E5G6GMZ
Part No SW: 8X0 953 501 H HW: 5K0 953 569 L
Revision: FF010017 Serial number: 20121205201076
Coding: 1104204000
VCID: 3F8D7527A6926EBD8C-806A
Part No SW: 8X0 920 930 J HW: 8X0 920 930 J
Component: KOMBI_MEDIUM H03 0252
Coding: 11CE00
ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04396
VCID: 418973DFD066184DFA-8014
Part No SW: 8U0 907 468 G HW: 8U0 907 468 G
Component: GAT 4CAN 1L M H13 0059
Revision: 1P100034 Serial number: 3441P12B280008
Coding: FBCF105A000100010253
VCID: 468360C3F1483F75CF-8012
Serial number: 00000000002040685946
Serial number: 1209280000000000024B
Component: IMMO H03 0252
Coding: 000007
ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04113
Address 2B: Steer. Col. Lock (J764) Labels:| 5K0-905-861.clb
Part No SW: 5K0 905 861 B HW: 5K0 905 861 B
Component: ELV-PQ35 H20 0240
Revision: 00000000 Serial number: 12000004569003
Coding: 4100000000000000
ROD: EV_ELVMarquMPVW36X.rod
VCID: 2F6D256776F29E3D1C-807A
Part No SW: 8X0 959 793 H HW: 8X0 959 793 H
Component: TSG FA H10 0415
Coding: 011812205C00000000
Shop #: WSC 00046 123 12345
VCID: 52AB4C930D0093D553-8006
Part No: 6R0 423 156 C
Component: LenkhilfeTRW V278
Coding: 11251
Shop #: WSC 00046
VCID: 306F261BF7CC81C505-8064
Part No SW: 8X0 959 792 H HW: 8X0 959 792 H
Component: TSG BF H10 0415
Coding: 011812201E00000000
VCID: 51A9439F0806E8CD6A-8004
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 8X0 907 357 C HW: 8X0 907 357 B
Serial number: 121121-0004-082
Coding: 1133941010022501
ROD: EV_HeadlRegulBasic.rod
VCID: 428B7CD3D5600355E3-8016
Part No SW: 8X0 035 193 F HW: 8X0 035 193 D
Component: RMC Cnct Nav H53 0801
VCID: 3B750137BA8A729DA0-806E
Subsystem 1 - Part No: 8X0 919 884 E
Component: P18-50-12.06 0001
Subsystem 2 - Part No SW: 8X0 919 603 A HW: 8X0 919 603 A
Component: DU6 Basic H43 0084
Serial number: 9462KZ0C2613733
Part No SW: 8X0 959 795 D HW: 8X0 959 795 D
Component: TSG HL H07 0415
Coding: 010012200000000000
VCID: 50AF469B030CE1C565-8004
Component: TSG HR H07 0415
End-------------------------(Elapsed Time: 03:00)--------------------------
