Results 1 to 5 of 5
Thread: 7-Speed S-Tronic Direct-Shift Gearbox (DSG/0B5) calibration
    Apr 2015
    Norway
    Hi there... I am trying to follow this procedure (http://wiki.ross-tech.com/wiki/index...rbox_(DSG/0B5)), but it fails in step one "Erase counter for start and stop processes" with "error, request out of range"
    Any suggestions?
    Apr 2015
    Norway
    Monday,29,January,2018,20:01:55:19306
    VCDS Version: 18.1.0.2
    VIN: WAUZZZ8R1AA051164   License Plate: UF43336
    Mileage: 114380km-71072mi   Repair Order:
    Chassis Type: 8R-AU48 (8T0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 20 42 46 52 53 55 56 5F 62
              69 72
    VIN: WAUZZZ8R1AA051164   Mileage: 114380km-71072miles
    Address 01: Engine (J623-CAHA)       Labels:| 03L-906-022-CAG.clb
       Part No SW: 03L 906 019 AS    HW: 03L 906 022 B
       Component: R4 2.0l TDI   H03 9977
       Revision: 11H03---
       Coding: 01210023240F2920
       Shop #: WSC 34629 001 1048576
       ASAM Dataset: EV_ECM20TDI03L906019AS A01011
       ROD: EV_ECM20TDI03L906019AR.rod
       VCID: 7CFD0BF9F7A00DA5E9-8028
       Part No SW: 8R0 927 156 K    HW: 0B5 927 156 E
       Component: 0B5 20 TDIRdW H03 0006
       Revision: --H03---    Serial number: 0000001111
       Coding: 000001
       Shop #: WSC 06335 000 00000
       ASAM Dataset: EV_TCMDL501 A02044
       ROD: EV_TCMDL501.rod
       VCID: 438FB005CADEB25DE8-8016
    Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V1.clb
       Part No SW: 8R0 907 379 L    HW: 8R0 907 379 L
       Component: ESP8 quattro  H07 0010
       Coding: 0D9540
       VCID: 4993A22DE0F2680D22-801C
       Part No SW: 8K0 907 064 DP    HW: 8K0 907 064 DP
       Component: BCM2 1.1      H02 0326
       Coding: 010500
       VCID: 01037A0D9842604DBA-8054
       Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
       Serial number: 0509000060794009
       Serial number: 0209000079325008
       Part No SW: 8T1 820 043 AQ    HW: 8T1 820 043 AQ
       Component: KLIMA 3 ZONEN H08 0171
       Revision: C1000000    Serial number: 01261020091711
       Coding: 34110000
       VCID: 00057F0993486945B5-8054
       Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
       Component: BCM1 1.0      H28 0380
       Revision: 10028001    Serial number: 00000000375651
       Coding: 2600D0914074AF010001000300001D0D0F1C670800010141000000
       VCID: 3C7DCBF9BF20CDA5A9-8068
       Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS416 091019  H10 0041
       Serial number: 90243014091015085703
       Coding: 01DD13
       Component: RLS  H04 0003
       Serial number: 10649037
       Coding: 024D25
       Subsystem 3 - Part No SW: 8K0 941 531 AL    HW: 8K0 941 531 AL
       Component: E1 - LDS  H08 0090
       Serial number: 00000000001910091823
       Part No SW: 8K0 919 475 J    HW: 8K0 919 475 A
       Component: PARKHILFE 8K  H06 0050
       Revision: 11001001    Serial number: 39840930121371
       Coding: 110108
       VCID: 4085BF09D3C8A945F5-8014
    Address 15: Airbags (J234)       Labels:| 8R0-959-655.clb
       Part No SW: 8R0 959 655 C    HW: 8R0 959 655 C
       Component: AirbagVW-AU10 H39 0560
       Serial number: 003FQD05PYZR
       Coding: 30423331313030303030554A304C38523053
       ROD: EV_AirbaAU10SMEAU416.rod
       VCID: 448DB319CFD0B565D1-8010
       Serial number: 6334MSME4A454278H
       Serial number: 6344MSME4C66247CR
       Serial number: 6352QSME7A401728G
       Serial number: 6362QSME61410E06A
       Serial number: 63732SME77404F081
       Serial number: 63832SME5F404630.
       Revision: --------    Serial number: 90315IJT00048
       Coding: 000017
       VCID: 3D7BC6FDA43AC4AD9E-8068
    Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
       Part No SW: 8R0 920 930 D    HW: 8R0 920 930 D
       Component: KOMBIINSTR.   H10 0255
       Revision: 00000000    Serial number: CJL43CYA9
       Coding: 0F06220002000008010000
       VCID: 356BDEDD9C0A1CED56-8060
       Part No SW: 8T0 907 468 AA    HW: 8T0 907 468 L
       Component: GW-BEM 5CAN-M H10 0105
       Revision: FB900055    Serial number: 5500F09A148179
       Coding: 00C303
       Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
       Component: J367-BDM  H07 0107
       Serial number: 00000000004140727448
       Part No SW: 8K0 857 511 E    HW: 8K0 857 511 A
       Revision: AA001002
       Coding: 02012064747464545425363E
       VCID: 336FE0C5927E02DD78-8066
       Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
       Component: TSG FA        H11 0306
       Revision:             Serial number: 0000009550792
       Coding: 011D02205000440004
       VCID: 458BAE1DCCEA8C6DC6-8010
       Revision: 00002001    Serial number: 0122999648
       Coding: 01000620203904800520053280000000
                        Fault Status: 00101001
                        Fault Frequency: 67
                        Reset counter: 194
                        Mileage: 112946 km
                        Date: 2018.01.01
                        Time: 12:20:30
                        Fault Status: 00101100
                        Reset counter: 189
                        Mileage: 113498 km
                        Date: 2018.01.11
                        Time: 16:33:45
       Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
       Component: TSG BF        H11 0306
       Revision:             Serial number: 0000009556307
       VCID: 448DB319C7D0B565D1-8010
       Revision: 00000003    Serial number: 00000000483123
       VCID: 346DE3D9977005E561-8060
       Part No: 8K0 907 357 B
       Component: Dynamische LWR  H01 0030
       Coding: 0000006
       Shop #: WSC 06334 000 00000
       VCID: 346DE3D9577005E561-8060
       Part No SW: 4F0 035 056 B    HW: 4F0 035 056
       Component: Radio U STD   H45 0020
       Revision: AB001007    Serial number: 342J6097699753
       Coding: 010003020100000001
       VCID: 1F471C750EF6B6BDAC-804A
       Part No SW: 8T1 035 652 D    HW: 8T1 035 652 D
       Component: B-BN-EU       H52 0048
       Revision: --------    Serial number: 323J%097528297
       Coding: 01010006010581ED01002B0E000000010000
       Shop #: WSC 00150 218 176870
       VCID: 3669D9D1810C17F55F-8062
       Subsystem 1 - Part No SW: 4L0 919 604     HW: 4L0 919 604
       Component: DU6 Basic  H43 0306
       Serial number: 9355JN091042423
       Subsystem 2 - Part No SW: 8T0 919 609     HW: 8T0 919 609
       Component: E0380 Bedient  H08 0100
       Serial number: 00000000392803
       Part No SW: 8K0 959 795 C    HW: 8K0 959 795 C
       Component: TSG HL        H10 0306
       Revision:             Serial number: 0000102195026
       Coding: 010C02204000240004
       VCID: 4281B501DDC4BB55E3-8016
    Address 69: Trailer (J345)       Labels:. 8K0-907-383.clb
       Part No SW: 8K0 907 383 C    HW: 8K0 907 383 C
       Component: Anhaenger     H08 0080
       Revision: 1G002002    Serial number: 00000123114950
       Coding: 0109080000000000
       Component: TSG HR        H10 0306
       Revision:             Serial number: 0000102195036
    End-------------------------(Elapsed Time: 03:53)--------------------------
  4. Likes Uwe liked this post
    Apr 2015
    Norway
    What does "Erase counter for start and stop processes" do actually?
    Apr 2015
    Norway
    Any help would be much appreciated...
