Optical Illustration Jetta MK6
Luís Fernando
Brazil
C?ID=302213
I am trying to activate the "optical illustration" in a 2016 Jetta. I have questioned Ross Tech and they have instructed me to open a new topic in the forum.
Has anyone done this?
Dear Sir,
In the address 10 – Park / Steer Assist there used to be na option at byte 0, bit 4 – Optical Illustration Active. Currently bits 4 and 5 of this byte are blended together. And the optical illustration does not activate. I only see the camera image.
I have a 2016 jetta trendline.
Is it possible to activate the optical illustration yet?
Thanks.
Hello Luís,
The coding scheme you mention was for the older (PARKHILFE PLA) Mk5/6 platform #10 modules that used the CAN protocol. This module is the newest UDS protocol and the coding charts aren't the same.
It might not hurt to take a look at the Adaptation channels to see if anything similar is available but we need to steer Tweak and Retrofit question to our forum:
http://forums.ross-tech.com/
Someone there may be able to confirm or deny if that function is supported by the controller after taking a look at your Auto-Scan.
Best Regards,
Dana
Moved from Forum Support & Feedback to Tweaks.
Please post an Auto-Scan so people can see exactly how the car is equipped and configured.
Luís Fernando
Brazil
C?ID=302213
VCDS Version: 17.8.1.0 (x64)  HEX-V2 CB: 0.4401.4
VIN: 3VWRJ2166GM035665   License Plate: GJQ9978
Mileage: 4900km-3044mi   Repair Order:
Chassis Type: 16-VW32 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 56 62 72
VIN: 3VWRJ2166GM035665   Mileage: 4900km-3044miles
Address 01: Engine (J623-CZDA)       Labels: None
   Part No SW: 04E 906 027 JL    HW: 04E 907 309 BK
   Component: R4 1.4l TFS   H23 2493
   Revision: R9H23---
   Coding: 00190012230418080000
   Shop #: WSC 00066 000 00018
   ASAM Dataset: EV_ECM14TFS01104E906027JL 001003
   ROD: EV_ECM14TFS01104E906027JL.rod
   VCID: 77A8E2C4CF48838F6BB-8022
   Part No SW: 1K0 907 379 CC    HW: 1K0 907 379 CC
   Component: ESP MK60EC1   H46 0175
   Revision: 00H46001
   Coding: A43B40F8092500FF251102EA901E004020100010
   Shop #: WSC 00066 123 12345
   VCID: 75B4E8CCD5C4F19F797-8020
   Part No SW: 1K8 907 426 AB    HW: 1K8 907 426 AB
   Component: AC Manuell    H20 0808
   Revision: 00001002
   Coding: 0010000002
   Shop #: WSC 00066 790 00319
   VCID: 73B0D6D4DB30EFAF573-8026
   Part No SW: 5K0 937 087 AG    HW: 5K0 937 087 AG
   Component: BCM PQ35 H+   122 0183
   Revision: BF122001
   Coding: 0C000A00882DE3D0408000800000002403000008508088205C8000000040
   VCID: 7AAEFBF0FCDA9EE7145-802E
   Subsystem 1 - Part No: 5C0 951 171
   Component: Sensor, DWA 0  005 0502
   Part No SW: 1K8 919 472 B    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0479
   Revision: --------    Serial number: 39391601900611
   Coding: 0031150001
   ASAM Dataset: EV_EPHVA18VW364GP00 001006
   VCID: 36362FC088C2BA87B0D-8062
   Part No SW: 5C0 959 655 AF    HW: 5C0 959 655 AF
   Component: AirbagVW10    015 0614
   Serial number: 003S2M07Y7HY
   Coding: 00004334
   Shop #: WSC 00066 000 00293
   ASAM Dataset: EV_AirbaVW10SMEVW360 001032
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 76B6EFC0C842FA8770D-8022
   Serial number: 3572MSME3C265A56ZZZ%
   Serial number: 3582MSME3B265A56ZZZ%
   Serial number: 3516KSME1B41003CZZZL
   Serial number: 3526KSME6C1C303CZZZ$
   Part No SW: 5K0 953 521 FL    HW: 5K0 953 569 BD
   Component: LENKS.MODUL   018 0230
   Revision: FF010042    Serial number: 20150219101362
   Coding: 408A140000
   Shop #: WSC 05447 001 104857
   ROD: EV_SMLSNGVOLWSR8C.rod
   VCID: 7BA0FEF4F360A7EF0F3-802E
          B1149 13 [009] - Open Circuit
                    Reset counter: 71
                    Mileage: 4902 km
                    Date: 2018.01.25
                    Time: 23:26:10
365080 - Controls in Steering Wheel
                    Reset counter: 71
                    Mileage: 4902 km
                    Date: 2018.01.25
                    Time: 23:26:10
   Part No SW: 5C6 920 865     HW: 5C6 920 865
   Component: KOMBI         H04 1008
   Coding: 270B280000
   VCID: 6C82CDA8860E3057969-8038
   Part No SW: 7N0 907 530 BD    HW: 7N0 907 530 AK
   Component: J533  Gateway H57 1673
   Revision:   H57       Serial number: 27021603010280
   Coding: 351002
   VCID: 73B0D6D4DBB0EFAF573-8026
   Component: IMMO          H04 1008
   VCID: 6A8ECBB08CFA2E67E45-803E
   Part No SW: 561 959 701 B    HW: 3C0 959 793 H
   Component: TUER-SG FT    002 0631
   Revision: 13100010    Serial number: 0010312905
   Coding: 0411B5
   Shop #: WSC 00066 790 00161
   ASAM Dataset: EV_TSGFPQ35BRFVW46X A04004
   VCID: 1D64D06C0D3409DF517-8048
   Slave Driver:
   Subsystem 1 - Part No SW: 6R0 959 811 T    HW: 6R0 959 811 T
   Component: J388__TSG_HL  022 1467
   Serial number: 14102745160225110710
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 68     3501
   Revision: 00H22000
   VCID: 392C24FCB55C55FF5DF-806C
   Part No SW: 561 959 702 B    HW: 3C0 959 792 H
   Component: TUER-SG BT    002 0631
   Revision: 15100010    Serial number: 0010315124
   Coding: 0411B4
   ASAM Dataset: EV_TSGBPQ35BRFVW46X A04004
   VCID: 1E66D760003212C748D-804A
   Slave Passenger:
   Subsystem 1 - Part No SW: 6R0 959 812 T    HW: 6R0 959 812 T
   Component: J389__TSG_HR  022 1467
   Serial number: 14102744160302155101
Address 56: Radio (J503)       Labels: None
   Part No SW: 6RF 035 187     HW: 6RF 035 187
   Component: Radio         013 0116
   Revision: --------    Serial number: VWZGZ1S0490256
   Coding: 00000450020011
   VCID: 06569F00B822EA0760D-8052
kamold
Australia
C?ID=241363
Your coding is correct for ''Optical parking system illustration'.
This is at byte 02, bit 0, which you have enabled.
You also have 'Display and operating protocol (BAP)' set to v.4.0
This is in Byte 02, bit 2.
I'm not sure which BAP version your radio supports, but you could try changing it to v3.3 by disabling byte 02 bit 2 and enabling byte 02 bit 3.
So your new coding for Address 10 Park/Steer Assist will be 00311A0001
If this doesn't work then you would need to find out if it is actually possible to get an OPS overlay on your RVC image with that particular radio...
Luís Fernando
Brazil
C?ID=302213
It did not work...
kamold
Australia
C?ID=241363
Do you know if this is possible with this radio? Have you seen the OPS overlay with RVC image working with this model?
I am not sure if it is supported...
Luís Fernando
Brazil
C?ID=302213
No, I don´t know. But I expect VW to progress. If it could be done in the past...
kamold
Australia
C?ID=241363
This is a budget system.
The Composition Media and Discover Media systems can do the OPS/RVC overlay.
downtime
C?ID=280813
RCD330G is also able to do RVC and OPS overlay at the same time. So coding or adaptation issue.
