Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 44
Thread: Several technical questions regarding VCDS on a 2018 Audi S6
  1. #31
    Jan 2018
    El Paso, TX USA
    Thanks a lot for your help Tommy. Hey, do you know how to tackle my MMI not recognizing the SIM card by any chance? Since no DTCs appeared when I cleared them, and MMI still can't read the SIM card, I could try to reset the appropriate channel via VCDS, but need somebody who knows how to do it. Would I have better luck on a different forum? This is the 'pre-sales' forum after all, therefore not really the appropriate place to discuss that IMO.
    I'd also like to know if VCDS can reset the SRI (service reminder) on a 981 (2015) Porsche Boxster. Saw a post somewhere where a Cayenne owner used VCDS to tackle more serious stuff, and was successful, hence my asking. I know the Porsche specific tool is 'Durametric', but maybe this thing works for scans and SRI resets. Thx.
  2. #32
    Quote Originally Posted by elp_jc View Post
    1. HOOK CABLE: cable on USB port first, then on car, then ignition on, then open software on computer? Like when doing it the first time?
    2. TO UNHOOK: Reverse of the above? No comments on the manual about that; at least I didn't see any. Hey, forgot to turn ignition off last time, unhooking cable before switching ignition off. Any issues with that?
    Nope. Plug / unplug order doesn't matter, nor does the state of the ignition.
    3. Do you need to test the connection every time? I didn't do it when messing with the module 5 (after the second full scan), and it went to it (didn't change anything though). But curious if we need to do that, and 'save' every time.
    No, you don't. You only need to do that when:
    • You first install, or later update the software
    • If you use a different cable.
    4. Does computer have to be connected to the internet while using the cable on the car? If yes, why?
    No, it does not. It only needs to be connected to the internet in order to update the firmware in the cable, or to register the cable (which you've already done).
  3. Likes Eric liked this post
  4. #33
    I think you've asked this before and I think I told you something to the effect of: I rather doubt it.
  5. #34
    Jan 2018
    El Paso, TX USA
    Indeed. So let me rephrase my question: Could I hurt anything if I try? If not, should I try both a scan and an SRI reset, or just the SRI reset? I'd relay my results here. If it's possible to hurt something, then we'll have to live with your doubt. He he. Thanks.
    And on the MMI SIM-card recognition issue, where should I post for better results? The 'Car Repair Support' forum? Thx.
  6. #35
    No, I don't think you can hurt anything, but I would definitely start with a scan, or even just an attempt to access 17-Instruments.
    This is a 2018 car, right with a warranty, right?
    Going back to page 1 of this thread for context, how exactly did you "disable the data module"? That was before you had VCDS, no?
  7. #36
    Jan 2018
    El Paso, TX USA
    Yep, 2018 car with warranty, but I don't take my cars to a dealer unless I absolutely have no choice. Now I still do, and it's called VCDS. He he. When having issues, I first disabled WiFi, and then the data module. Both are on the AudiConnect menu... when you can access it. Ha ha. Now I can't do anything, because MMI is not recognizing the SIM card. When I deactivated the module, it changed from 'turn data module off', to 'turn data module on', or something like that. After turning engine off and back on, that's when I couldn't access AudiConnect anymore.. but my other issues went away, like media sources not having sound, and not being able to connect my phone to BT.
    By the way, programmed both the lap timer and D+S gear indicator today, since those modules didn't have malfunctions. Worked fine, but thought the oil temp gauge wasn't working, since it only showed '---' until oil heated up to 145, which was exactly when the tach segments went from 5,500 rpm to the 6,400 redline. That's odd, but I'll take it over no gauge. Ha ha. Okay, so guess will mess with the module 5F myself, since nobody knows how to do it. Wish me luck. And will also report what happened to the Porsche. If VCDS wants me to use another VIN before I'm pretty sure it'd work, will abort. Results shortly.
  8. #37
    Jan 2018
    El Paso, TX USA
    Here's the new scan after using the car 10 miles:
    Saturday,03,February,2018,15:33:59:26044
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x86
    VCDS Version: 18.1.0.2  HEX-V2 CB: 0.4411.4
    VIN: WAUFFAFC0JN024395   License Plate:
    Mileage: 3372km-2095mi   Repair Order:
    Chassis Type: FC-AU57 (4G8)
    Scan: 01 02 03 05 08 09 13 15 16 17 19 1B 20 22 28 34 36 3B 3C 42
              44 46 52 53 55 5F 62 6C 72 85 8B 8E 8F 90 A9 BA
    VIN: WAUFFAFC0JN024395   Mileage: 3372km-2095miles
    BA-Motor Mounts -- Status: OK 0000
    Address 01: Engine (------CTGE)       Labels: None
       Part No SW: 4G0 906 014 D    HW: 4H0 906 014
       Component: 4.0l V8TFSI / H63 0002
       Revision: NCH63---
       Coding: 0A2500326546010E3000
       ASAM Dataset: EV_ECM40TFS0114G0906014D 001002
       ROD: EV_ECM40TFS0114G0906014D.rod
       VCID: 231312902B53A3DF557-8076
    Readiness: 0010 0001
       Part No SW: 4G0 927 166 F    HW: 0B5 927 156 K
       Component: 0B5 40TFSINAR H06 0007
       Revision: --H06---
       Coding: 000001
       ASAM Dataset: EV_TCMDL501021 001022
       ROD: EV_TCMDL501021.rod
       VCID: 3039EDDC6AA50847D85-8064
       Coding: 65BED449A67D2B921B00
       ROD: EV_ESP9BOSCHAU57X.rod
       VCID: 41DFB818D10F91CF27B-8014
       Part No SW: 4H0 907 064 HR    HW: 4H0 907 064 HR
       Component: BCM2 2.0      H61 0825
       Coding: 0DA86F4E000000000000
       VCID: 00597D1C9A0558C7685-8054
       Serial number: 3217000121943016
       Part No SW: 4G0 820 043 BL    HW: 4G0 820 043 BL
       Serial number: 13071700041624
       Coding: 680130784D0000
       VCID: 6A8D3FB48CF9B297D61-803E
    Address 09: Cent. Elect. (J519)       Labels: Redir Fail!
       Part No SW: 4H0 907 063 GM    HW: 4H0 907 063 AM
       Component: BCM1 2.0      H20 0368
       Revision: 2102003S    Serial number: 00001715237202
       Coding: 01050011043C9FF2F90048C7A0003800CF9CD208AE08022180000894F10017020060003D030000
       VCID: 79AF10F8F9DF090F2FB-802C
       Component: WWS57X 170522  H38 0080
       Serial number:         170622061250
       Coding: 0045F7
       Serial number: 20338411X81A955547A0
       Coding: 02006D
       Component: E1 - LDS  H07 0044
       Serial number: 06 07 2017  00000294
       Component: USHL4.2  H30 0030
       Serial number: 00000000095Z030F96D3
       Subsystem 5 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0300
       Serial number: WA128226000035191519
       Coding: 020300
       Subsystem 6 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
       Serial number: 054017B800PAG0MUFU03
       Part No SW: 4G0 907 561 B    HW: 4G0 907 561
       Component: ACC3          H21 0055
       Coding: 7E01010102
       ASAM Dataset: EV_AdaptCruisContrAU57X 002015
       ROD: EV_AdaptCruisContrAU57X_002.rod
       VCID: 290F00B8497F798F1FB-807C
    Address 15: Airbags (J234)       Labels:| 4H0-959-655.clb
       Part No SW: 4G0 959 655 B    HW: 4G0 959 655 B
       Component: Airbag10.43   H62 0092
       Revision: --------    Serial number: 003G00049PZ6
       Coding: 303331343135303334354A55304C34473053
       VCID: 3431E1CC9EBD3467BCD-8060
       Serial number: 6940000Y170001LPCC03
       Serial number: 3575HRB400659LTKB9S2
       Serial number: 3585HRB400A5BCHAH1G7
       Serial number: 3515JRB400M59NFOQHCD
       Serial number: 3525JRB400859NFOE94F
       Serial number: 3554VRB40045BE5CGGHI
       Serial number: 3564VRB40045BE5CGQ9L
       Part No SW: 4H0 953 568 G    HW: 4H0 953 568 G
       Component: Lenks.Modul   H05 0005
       Revision: --------    Serial number: 90372QGE00058
       Coding: 0000FC
       VCID: 372BD6C08F4BDF7F99F-8062
       Subsystem 1 - Part No SW: 8U0 951 528 H    HW: 8U0 951 528 H
       Serial number: 01 07 2017  D0000573
       Part No SW: 4G0 920 982 S    HW: 4G0 920 982 S
       Component: TBenUsaAccNv  H17 0225
       Revision: 18001312    Serial number: 658120717592019
       Coding: 03CD0905BF51CF05020200
       ASAM Dataset: EV_RBD4K 004060
       ROD: EV_RBD4K_AU57.rod
       VCID: 3C21C9ECB6EDFC2774D-8068
       Part No SW: 4G8 907 468 K    HW: 4G8 907 468
       Component: J533--Gateway H15 0110
       Revision: --------    Serial number: 00000002665750
       Coding: C0ED074814
       ASAM Dataset: EV_GatewPkoUDS 002011
       ROD: EV_GatewPkoUDS_002_VW51.rod
       VCID: 40D9BD1CDA0598C7285-8014
       Subsystem 1 - Part No SW: 8S0 915 181 B    HW: 8S0 915 181 B
       Serial number: 9275964504
       Voltage stabilizer:
       Serial number: 170429000000000007F9
       Part No SW: 8K0 907 144 N    HW: 8K0 907 144 N
       Component: DYNAMIKLENK.  H06 0740
       Coding: 0E0100
       VCID: 3A2DCFF4BC59C217661-806E
       Part No SW: 4H0 857 511     HW: 4H0 857 511
       Component: FLA           H04 0021
       Revision: AA001002
       VCID: 678B46809F6B8FFFC9F-8032
    Address 22: AWD (J492)       Labels: 4H0-907-163.clb
       Part No SW: 4H0 907 163 B    HW: 4H0 907 163 A
       Component: 4 Wheel Drive H19 0200
       Serial number: 002806170001025
       ASAM Dataset: EV_AllWheelDiffeQSPFR 003026
       VCID: 280905BC52754087005-807C
       Part No SW: 4G0 919 158 Q    HW: 4G0 919 158 Q
       Component: KLIMA FOND    H08 0113
       Serial number: 20071700040181
       Coding: 20
       VCID: 3D27C4E8ADF7F52F433-8068
       Part No SW: 4G0 907 553 G    HW: 4G0 907 553 F
       Component: LUFE-DAEMPFER H19 0783
       Coding: 008006
       ASAM Dataset: EV_AirSuspe 003025
       ROD: EV_AirSuspe_VW51.rod
       VCID: 2F3BEEA0779B17BFC1F-807A
       Revision: AA000000    Serial number: 00000264708827
       VCID: 77AB16C0CFCB1F7F59F-8022
       Component: SARA 6D red   H04 0056
       Revision: --------    Serial number: EJ1BPA7E02X9HX
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 372BD6C08FCBDF7F99F-8062
       Part No SW: 4G0 907 566 M    HW: 4H0 907 566 F
       Component: SWA Master    H08 0070
       Serial number: 0447460632
       Coding: 040211
       VCID: 392FD0F8B9DFC90F6FB-806C
       Lane Change Assistant 2:
       Subsystem 1 - Part No SW: 4G0 907 568 M    HW: 4H0 907 568 F
       Component: SWA Slave  H08 0070
       Serial number: 0447830783
       Coding: 040211
       Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
       Component: TSG FA        H04 0511
       Coding: 011F17015E00628002000013
       VCID: 45D7AC08C5A7BDEF1B3-8010
       Component: RCevo         H54 0202
       Revision: 00000002    Serial number: 0000882256
       Coding: 011001010001
       ASAM Dataset: EV_RCEPS 106007
       ROD: EV_RCEPS_106.rod
       VCID: 3A2DCFF4BCD9C217661-806E
       Revision: 00002001    Serial number: 0444726645
       Coding: 0106063A00FA408580B0088402070E470000000000000000000000000000
       Component: GTO BF  H01 0081
       Serial number: 00000000000000407338
       Subsystem 2 - Part No: 1K0 951 605 F
       Component: LIN BACKUP HO  H01 0008
       Subsystem 3 - Part No SW: 4G8 959 591 A    HW: 8V3 959 591 A
       Component: J245 PS40.402  H03 0004
       Serial number: 0000FST001OVAA400000
       Coding: 101F02
       Subsystem 4 - Part No SW: 4G0 947 135 G    HW: 4G0 947 135
       Serial number: 0000000AP00030640034
       Subsystem 5 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
       Serial number: 6600<58:
       Coding: 011F17015E00628002000002
       VCID: 46D5AB04F8A1B6F7129-8012
       Part No SW: 4H0 907 801 M    HW: 4H0 907 801 M
       Component: EPB-4         H01 0018
       Revision: --------    Serial number: 00000002250703
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 323DE7D464A93A57AE1-8066
       Coding: 04FA0A1122600400
       Coding: E01E00
       Coding: E01E00
       Part No SW: 4G1 035 025 G    HW: 4G1 035 025 C
       Component: MU-H-LNS-US   054 0980
       Serial number: A741G0HS005590
       Coding: 017551020000000013220002041A00102F0007E5F17001047E
       ROD: EV_MUHig6C3Gen2HBAS_AU49.rod
       VCID: 221D17943449AAD75E1-8076
       Subsystem 1 - Part No SW: V03 959 801 PS    HW: -----------
       Component: NAR 2018  --- 0063
       Subsystem 2 - Part No SW: 4G1 919 605 B    HW: 4G1 919 605 B
       Serial number: AUZ8Z9HY808BNX
       Multimedia Operating Unit:
       Serial number: 90349QGA000ZC
       Component: Gracenote2---  --- 3012
       VCID: 49CFA038E9BF598FFFB-801C
    Address 6C: Back-up Cam. (J772)       Labels:* None
       Part No SW: 4S0 980 556     HW: 4M0 980 556
       Component: RVC Compact   H08 0140
       Coding: 027500010A002003000040
       ASAM Dataset: EV_CamSysRVRVCPANAAU57X 001001
       ROD: EV_CamSysRVRVCPANAAU57X.rod
       VCID: 78A915FCC2551007505-802C
    Address 85: On Board Cam. (J852)       Labels:* None
       Part No SW: 4H0 907 217 F    HW: 4H0 907 217 A
       Component: DPC-SG        H28 0081
       Coding: EA060000
       ROD: EV_OnBoardCamerDPC.rod
       VCID: 2C01F9AC468D6CA7E4D-8078
       Part No SW: 4G0 907 541 B    HW: 4G0 907 541
       Coding: 7E01010102
       ASAM Dataset: EV_AdaptCruisContr2AU57X 002013
       ROD: EV_AdaptCruisContr2AU57X_002.rod
       VCID: 270B06805F6B4FFF09F-8072
       Part No SW: 4H0 907 107 H    HW: 4H0 907 107
       Component: BV-SG         H34 0090
       Serial number: 005002451805177
       Coding: 04C1BA1B0111
       ASAM Dataset: EV_BC7 001001
       ROD: EV_BC7.rod
    Address 8F: Pretens. Frt Left (J854)       Labels:. 4H0-980-94x-RGS.clb
       Component: RGS-VL        H16 0080
       Coding: 0066E608031F0376070308014240C0010000
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: 313FE8D861AF014FD7B-8064
    Address 90: Pretens. Frt Right (J855)       Labels:. 4H0-980-94x-RGS.clb
       Component: RGS-VR        H16 0080
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
       Part No SW: 4G0 907 159 B    HW: 4H0 907 159 A
       Component: SAS-GEN 2     H06 0010
       Serial number: 170514200712
    Address BA: Motor Mounts (J931)       Labels: 4H0-907-145.clb
       Part No SW: 4H0 907 145 B    HW: 4H0 907 145
       Component: AEM - LEAR    H10 0008
       Revision: 00001001    Serial number: 97813008680901
       ASAM Dataset: EV_AEMLearAU64X 002016
       ROD: EV_AEMLearAU64X.rod
    End----------(Elapsed Time: 02:57, VBatt start/end: 12.2V/12.2V)-----------
    Looks like no faults, even though MMI still doesn't let me into AudiConnect. Will mess with module 5F in a little bit. But all is well then??? Only 10 miles, but if I had a canbus issue, or some other crap, that'd be enough, correct? Only messed with module 17 (instruments), making changes nobody has posted (like changing pressure from kPa to PSI), but since my car doesn't have TPMS sensors, maybe it's irrelevant, but changed it anyway. He he. Have other questions/concerns that I saw, but you're probably not going to know since they're Audi S6 7.5 specific, so will have to ask at the Audi forum. For instance, saw 'cruise control system installed' not checked, and was wondering if I click it, if I could have both, like on my other cars. On this one, it's only adaptive or nothing. Also saw byte 2, bit 3-5 checked as 'Audi A6/S6 limousine', which makes no sense, but the other choices are avant, allroad, so maybe it's the correct one. Do you know what that particular bit range is for? Thx. Oh, also byte 10, bit 0 'brake pad warning active' was unchecked, which would be fine with me, but why? My main concers was with the codes. Hopefully you'll give my car a clean bill of health. Ha ha. Thanks Uwe.
  9. #38
    limousine = sedan
  10. Likes Uwe liked this post
  11. #39
    Jan 2018
    El Paso, TX USA
    limousine = sedan
    Oh, thanks. Guess it's so freaking big it's a limo in Europe, right? Ha ha. Thanks man. Another bit, the one for the fuel tank (probably for size) didn't have an S6 or even an A6, but an A7/S7 (selected), also with Avant and Allroad options, but since I confirmed via google all 4 variants have the same 19.8-gal size tank, no worries there either.
    Hey guys, one more question. Most of the time I don't like adaptive cruise control (ACC), and much prefer regular CC. Well, my stupid car seems like it doesn't do that, at least now. On my other cars, I just press the distance button for a second after turning cruise on, and it toggles between ACC and CC. Tried everything on this car and nothing. But found this option on instruments (byte 1, bit 5): 'cruise control system installed', which wasn't checked on my car. Do you guys think if I click on it I'd be able to have both, or it'd have to be either one or the other? Don't remember seeing 'adaptive cruise control installed', but I'm sure it's there somewhere. Just curious if you think I should try clicking on both, but would need to know how to toggle them. As an alternative, it'd be good to toggle between them on the driver assistance menu, instead of having to code one or the other only in the garage. Thank you in advance for your help on this.
  12. #40
    Dec 2016
    NL
    In instruments, you're only changing the settings of (wait for it...) the instrument cluster. You could tell the instrument cluster that a conventional cruise control system is installed. In which case the instrument cluster will immediately throw cruise control errors since nothing is replying to its messages on the bus all while receiving messages its not expecting. If you want to disable ACC and enable CCS, you'd have to start at the radar sensor control module. Then tell the ABS that theres no ACC anymore but just CCS, then the engine control module, probably some other units and finally the instrument cluster.
    All things aside, VCDS is a tool. A pretty handy one at that, but tools have to be mastered. No manual could possibly contain everything you can, can't, can but not in combination with this and that, can't unless circumstance X is met, etcetera.
    Your best bet is to start off by reading in to HOW the system works. What is a databus? What is the function of the Gateway? For function X, which control modules are involved and what are their roles? That is info that allows you to come to a conclusion.
    Now I'm not saying you'd better take a year or two in seclusion with an old Golf and have at it. But there is an enormous amount of info regarding VCDS use aside from what the manual says (although the manual could also use an overhaul) available online, both written and on video.
    Current:
  13. Likes PetrolDave liked this post
