Several technical questions regarding VCDS on a 2018 Audi S6
elp_jc
El Paso, TX USA
C?ID=323850
1. This is the most important one for me. Do ANY of the modules available on VCDS can cause a 'TD1' flag? For those who don't know, that's the flag that voids your warranty when Audi detects the ECU was tampered with. And it's a royal (and expensive) battle for ANY warranty claim with this flag. Don't want to inadvertently triggered it by using VCDS, since my car is new.
2. Read the VCDS user's manual and there was constant mentioning of both 'Gateway' and 'HEX' without explanation of any kind, or which cars have it. Do my S6 have either or both of those things? If yes, which one (or both), and what do I need to do differently when using VCDS?
3. I've read several threads on this, and I didn't see mentioned 2 things I want to disable: auto door-lock (should be a freaking user menu option), and MMI auto-retract. The latter will crap out sooner or later after incessant ins and outs. I always use it, so want it permanently out. If I want to retract it, that's what the dash button is for:D.
4. My MMI is not recognizing AudiConnect anymore, after I disabled the data module, trying to clear issues I was having. A forum member said I could fix that by going to module 5F and switching on SIM card recognition. Would like more detailed steps, but my question is VCDS manual only listed modules 5A and 5B. Why is not listed? Is it part of the 'hidden green menu'? Thx.
5. Talking about the 'hidden green menu', would activating it triggers the 'TD1' flag? What parameters can be changed there? Couldn't find any info on that. Although not related to VCDS, if anybody has a link I'd appreciate it. Only found info on older systems, but not for my car, hence the question.
6. Another big reason to buy this module is I want to lower the air suspension a little. Folks who have done it said it's supposedly not possible, but obviously it is. I want to hear from Ross-Tech's point of view why they don't support this function. What risks they're seeing, etc., to be able to make the decision if I should mess with it or not. Couldn't find out if altering the ride height also alters the shock settings or not. This is important since if it doesn't, car would bottom out easier if lowered, but shocks weren't adjusted accordingly. Maybe that's why.
That's all for now. Thanks in advance for your help.
JC
1) It is not entirely clear what triggers the TD1 flag. One would think this is primarily for ECUs that have had their programming modified with a "tune" to increase power, and that's something VCDS simply does not do. However, it's possible that they might trigger it on other changes as well, for example the kinds of changes that you can make with VCDS.
2) On modern cars, the "Gateway" is the module that routes data between the various buses (networks) in your car, including the dedicated diagnostic bus accessible on your car's OBD-II connector. "Hex" is a brand name for many of our interfaces.
3) I would expect it's possible to turn off Auto-Lock. I'm not sure about auto-retract of the MMI screen.
4) We'd need to see an Auto-Scan to even attempt to address this.
5) See #1 with respect to the TD1 flag. None of us have an A6 or S6 as new as yours, so it's hard for us to say exactly what you'll be able to change using the engineering menu.
6) I'm not sure anyone has figured out a procedure for altering the height on that generation of air-suspension control module.
elp_jc
El Paso, TX USA
C?ID=323850
Thanks Uwe. I'm not going to mess with the engine module other than just checking DTCs, so I shouldn't have any TD1 issues then. My MMI is not recognizing the SIM card; as simple as that. I expect the auto-scan to reveal that, but if not, is it as simple as the forum guy said? I'm ordering the cable now, so as soon as I get it will do an auto-scan. It wasn't clear from the instructions how to save the file (or change its name), but I'll ask for help if I need to. It'd be nice to rename it with easy titles, especially the first. I changed the SIM card with a new one I activated myself, and my MMI still said 'no SIM card inserted. Please insert one'. So can't even get in the menu now. And no, you cannot insert the SIM card wrong; it only 'clicks' when inserted properly (I tried all 4 possible ways). And it worked before on one that salesman put my wrong personal info, hence asking for a second one. Anyway, probably a bug, even after 7 years... exactly what I wanted to avoid with an old platform on its way out, but whatever. Hope it's an easy fix once I get the cable, and doesn't come back.
If you're curious about how to lower the suspension in both 7.0 and 7.5 S6s, I can get you a link on that subject from Audizine, if you want (or just go find it; it's an active thread). Many, many folks have done it already with VCDS, and even with OBD11. FYI.
elp_jc
El Paso, TX USA
C?ID=323850
Okay, getting my cable tomorrow. The first thing to do is getting a full scan. Will try to do that, but if I have trouble doing it, finding it, posting it here, or any of that, I come back here, correct? Will that file give me the suspension settings and the contents of the 5F module to verify the SIM card reader is turned off (and to turn it back on)? If not, then will write down the suspension settings, and just add 15mm to lower the car 15mm overall. Reportedly 17mm is the limit, so to play it safe, will do 15, like many other folks (reportedly the car won't go lower than 17mm, so it's protected from going lower than we should. A good thing). If I can't do either of those 2 things will report that on the main thread, correct?
Before going, have 2 questions that couldn't find answers: 1. How do you know if the MMI resetted itself? Only found the 3 buttons to push, but when I tried that trying to get it to recognize the new SIM card, it didn't do anything I could notice except one of the times (like 1 out of 10) that the screen went completely blank. Was that it? I didn't notice in which menu I had it when that happened. Does it have to be in the main menu? And for how many seconds? Thx. 2. What's the 'engineering' menu? Is it the file posted where you can change the lap timer, D+S saying the gear, and all of that? If not, a link would be appreciated. Looking forward to do many changes tomorrow:). Thanks for all your help again Uwe.
I strongly urge you to post an Auto-Scan before you try to change anything at all. You need to be able to walk before you try to run. :)
elp_jc
El Paso, TX USA
C?ID=323850
That's sound advice:D. Should I post it here? Should be doing that later today.
By all means, post it here.
elp_jc
El Paso, TX USA
C?ID=323850
FULL SCAN 2018 AUDI S6
Here you go Uwe. Lots of 'Malfunction 0010' faults. Didn't do anything except the full scan, and exited. I'm probably going to hold off on the suspension lowering for now, so only want to do several little things like gear indicator in D/S, lap timer, etc., AND more importantly, correct the SIM card issue I have (let's see what you comment on that). Please let me know what you see and suggestions what to do next. Didn't clear anything, nor go to any modules. Just clicked 'auto scan' after the test was done. Thanks in advance for your help.
Hey, how the hell do I attach a file from my computer here? There's no such option under 'go advanced'; just to insert a photo or video from a url. Man, didn't anticipate getting stuck so soon. Ha ha. Oh well. Will wait for your instrucitons then. Or PM me your email to send you the file. All other forums have the ability to attach photos and files.
EDIT: Holy f**k. What the hell is wrong with my car? There're A TON of faults all over the place. The weird thing is nothing seems not to be working except the SIM card issue. The only fault I recognize is when I disconnected the 3rd brake light to tint the windows (had to move the car before reinstalling it). Damn. Hope there's nothing serious brewing. Waiting on instructions how to post the file. Tried every single icon and nothing points to browse on my computer. Oh well.
JC
elp_jc
El Paso, TX USA
C?ID=323850
Guess will have to wait until tomorrow. Oh well. Another thing: I was prompted several times that I have '14 uses' to register my cable. First of all, WHERE? And second of all, where is the serial number? Don't find it anywhere on the cable, and neither on the scan. Maybe it's on that barcode, but should have freaking numbers too (for resale). Thanks.
elp_jc
El Paso, TX USA
C?ID=323850
Okay, figured it out by analyzing other threads with files that said 'code'. Found the icon with that, and just copied the entire file and seems to be what others did. Here it goes:
Tuesday,30,January,2018,00:16:35:26044
VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x86
VCDS Version: 17.8.1.0  HEX-V2 CB: 0.4409.4
VIN: WAUFFAFC0JN024395   License Plate:
Mileage: 3357km-2085mi   Repair Order:
Chassis Type: FC-AU57 (4G8)
Scan: 01 02 03 05 08 09 13 15 16 17 19 1B 20 22 28 34 36 3B 3C 42
          44 46 52 53 55 5F 62 6C 72 85 8B 8E 8F 90 A9 BA
VIN: WAUFFAFC0JN024395   Mileage: 3357km-2085miles
8B-Adaptive Cruise 2 -- Status: Malfunction 0010
8F-Pretens. Frt Left -- Status: Malfunction 0010
90-Pretens. Frt Right -- Status: Malfunction 0010
BA-Motor Mounts -- Status: Malfunction 0010
Address 01: Engine (------CTGE)       Labels: None
   Part No SW: 4G0 906 014 D    HW: 4H0 906 014
   Component: 4.0l V8TFSI / H63 0002
   Revision: NCH63---
   Coding: 0A2500326546010E3000
   ASAM Dataset: EV_ECM40TFS0114G0906014D 001002
   ROD: EV_ECM40TFS0114G0906014D.rod
   VCID: 231312902B53A3DF673-8076
   Part No SW: 4G0 927 166 F    HW: 0B5 927 156 K
   Component: 0B5 40TFSINAR H06 0007
   Revision: --H06---
   Coding: 000001
   ASAM Dataset: EV_TCMDL501021 001022
   ROD: EV_TCMDL501021.rod
   VCID: 3039EDDC6AA50847EA1-8064
   Coding: 65BED449A67D2B921B00
   ROD: EV_ESP9BOSCHAU57X.rod
   VCID: 41DFB818D10F91CF15F-8014
   Part No SW: 4H0 907 064 HR    HW: 4H0 907 064 HR
   Component: BCM2 2.0      H61 0825
   Coding: 0DA86F4E000000000000
   VCID: 00597D1C9A0558C75A1-8054
   Serial number: 3217000121943016
   Part No SW: 4G0 820 043 BL    HW: 4G0 820 043 BL
   Serial number: 13071700041624
   Coding: 680130784D0000
   VCID: 6A8D3FB48CF9B297E45-803E
Address 09: Cent. Elect. (J519)       Labels: Redir Fail!
   Part No SW: 4H0 907 063 GM    HW: 4H0 907 063 AM
   Component: BCM1 2.0      H20 0368
   Revision: 2102003S    Serial number: 00001715237202
   Coding: 01050011043C9FF2F90048C7A0003800CF9CD208AE08022180000894F10017020060003D030000
   VCID: 79AF10F8F9DF090F1DF-802C
   Component: WWS57X 170522  H38 0080
   Serial number:         170622061250
   Coding: 0045F7
   Serial number: 20338411X81A955547A0
   Coding: 02006D
   Component: E1 - LDS  H07 0044
   Serial number: 06 07 2017  00000294
   Component: USHL4.2  H30 0030
   Serial number: 00000000095Z030F96D3
   Subsystem 5 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA128226000035191519
   Coding: 020300
   Subsystem 6 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Serial number: 054017B800PAG0MUFU03
03455 - Function Restriction due to Faults in Other Modules
            000 -  -  - Intermittent
                    Reset counter: 63
                    Mileage: 348 km
                    Date: 2018.01.12
                    Time: 21:43:59
   Part No SW: 4G0 907 561 B    HW: 4G0 907 561
   Component: ACC3          H21 0055
   Coding: 7E01010102
   ASAM Dataset: EV_AdaptCruisContrAU57X 002015
   ROD: EV_AdaptCruisContrAU57X_002.rod
   VCID: 290F00B8497F798F2DF-807C
34816 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 63
                    Mileage: 348 km
                    Date: 2018.01.12
                    Time: 21:45:54
                    Voltage terminal 15: 12.514 V
                    Velocity_vehicle_reference: -0.01 m/s
35072 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 63
                    Mileage: 348 km
                    Date: 2018.01.12
                    Time: 21:45:54
35328 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 63
                    Mileage: 348 km
                    Date: 2018.01.12
                    Time: 21:45:54
35584 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 63
                    Mileage: 348 km
                    Date: 2018.01.12
                    Time: 21:45:54
93440 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 63
                    Mileage: 348 km
                    Date: 2018.01.12
                    Time: 21:45:54
                    Voltage terminal 15: 12.517 V
Address 15: Airbags (J234)       Labels:| 4H0-959-655.clb
   Part No SW: 4G0 959 655 B    HW: 4G0 959 655 B
   Component: Airbag10.43   H62 0092
   Revision: --------    Serial number: 003G00049PZ6
   Coding: 303331343135303334354A55304C34473053
   VCID: 3431E1CC9EBD34678E9-8060
   Serial number: 6940000Y170001LPCC03
   Serial number: 3575HRB400659LTKB9S2
   Serial number: 3585HRB400A5BCHAH1G7
   Serial number: 3515JRB400M59NFOQHCD
   Serial number: 3525JRB400859NFOE94F
   Serial number: 3554VRB40045BE5CGGHI
   Serial number: 3564VRB40045BE5CGQ9L
   Part No SW: 4H0 953 568 G    HW: 4H0 953 568 G
   Component: Lenks.Modul   H05 0005
   Revision: --------    Serial number: 90372QGE00058
   Coding: 0000FC
   VCID: 372BD6C08F4BDF7FABB-8062
   Subsystem 1 - Part No SW: 8U0 951 528 H    HW: 8U0 951 528 H
   Serial number: 01 07 2017  D0000573
Address 17: Instruments (J285)       Labels:| 4H0-920-xxx-17.clb
   Part No SW: 4G0 920 982 S    HW: 4G0 920 982 S
   Component: TBenUsaAccNv  H17 0225
   Revision: 18001312    Serial number: 658120717592019
   Coding: 0BC70905BF51D705020200
   ASAM Dataset: EV_RBD4K 004060
   ROD: EV_RBD4K.rod
   VCID: 3C21C9ECB6EDFC27469-8068
   Part No SW: 4G8 907 468 K    HW: 4G8 907 468
   Component: J533--Gateway H15 0110
   Revision: --------    Serial number: 00000002665750
   Coding: C0ED074814
   ASAM Dataset: EV_GatewPkoUDS 002011
   VCID: 40D9BD1CDA0598C71A1-8014
   Subsystem 1 - Part No SW: 8S0 915 181 B    HW: 8S0 915 181 B
   Serial number: 9275964504
   Voltage stabilizer:
5701 - High Beam Assistant Control Module
          U1070 00 [008] - No Communication
                    Reset counter: 63
                    Mileage: 348 km
                    Date: 2018.01.12
                    Time: 21:43:53
                    Voltage terminal 30: 12.7 V
                    Voltage terminal 15: 12.7 V
                    Control Module temperature: 21 °C
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
0258 - Extended CAN Bus (SAE Bus C)
          U0046 00 [008] - Malfunction
                    Reset counter: 63
                    Mileage: 348 km
                    Date: 2018.01.12
                    Time: 21:45:53
                    Voltage terminal 30: 12.5 V
                    Voltage terminal 15: 12.4 V
                    Control Module temperature: 23 °C
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
          U140B 00 [008] - -
                    Reset counter: 51
                    Mileage: 45 km
                    Date: 2017.12.09
                    Time: 15:26:47
                    Voltage terminal 30: 11.2 V
                    Voltage terminal 15: 11.2 V
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 1
   Part No SW: 8K0 907 144 N    HW: 8K0 907 144 N
   Component: DYNAMIKLENK.  H06 0740
   Coding: 0E0100
   VCID: 3A2DCFF4BC59C217545-806E
   Part No SW: 4H0 857 511     HW: 4H0 857 511
   Component: FLA           H04 0021
   Revision: AA001002
   VCID: 678B46809F6B8FFFFBB-8032
Address 22: AWD (J492)       Labels: 4H0-907-163.clb
   Part No SW: 4H0 907 163 B    HW: 4H0 907 163 A
   Component: 4 Wheel Drive H19 0200
   Serial number: 002806170001025
   ASAM Dataset: EV_AllWheelDiffeQSPFR 003026
   VCID: 280905BC52754087321-807C
   Part No SW: 4G0 919 158 Q    HW: 4G0 919 158 Q
   Component: KLIMA FOND    H08 0113
   Serial number: 20071700040181
   Coding: 20
   VCID: 3D27C4E8ADF7F52F717-8068
0075 - Button or Switch in Operating Unit
          B10C7 07 [008] - Mechanical Failure
                    Reset counter: 77
                    Mileage: 2100 km
                    Date: 2018.01.20
                    Time: 09:58:39
                    Outside air temperature: 13.5 °C
                    Left rear vent temperature: 37.0 °C
   Part No SW: 4G0 907 553 G    HW: 4G0 907 553 F
   Component: LUFE-DAEMPFER H19 0783
   Coding: 008006
   ASAM Dataset: EV_AirSuspe 003025
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2F3BEEA0779B17BFF3B-807A
          C10C8 00 [008] -  -
                    Reset counter: 62
                    Mileage: 85 km
                    Date: 2017.12.29
                    Time: 19:35:16
   Revision: AA000000    Serial number: 00000264708827
   VCID: 77AB16C0CFCB1F7F6BB-8022
   Component: SARA 6D red   H04 0056
   Revision: --------    Serial number: EJ1BPA7E02X9HX
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 372BD6C08FCBDF7FABB-8062
   Part No SW: 4G0 907 566 M    HW: 4H0 907 566 F
   Component: SWA Master    H08 0070
   Serial number: 0447460632
   Coding: 040211
   VCID: 392FD0F8B9DFC90F5DF-806C
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 4G0 907 568 M    HW: 4H0 907 568 F
   Component: SWA Slave  H08 0070
   Serial number: 0447830783
   Coding: 040211
512270 - Extended CAN Bus (SAE Bus C)
                    Reset counter: 63
                    Mileage: 348 km
                    Date: 2018.01.12
                    Time: 21:45:53
   Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
   Component: TSG FA        H04 0511
   Coding: 011F17015E00628002000013
   VCID: 45D7AC08C5A7BDEF297-8010
   Component: RCevo         H54 0202
   Revision: 00000002    Serial number: 0000882256
   Coding: 011001010001
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106_AU57.rod
   VCID: 3A2DCFF4BCD9C217545-806E
   Revision: 00002001    Serial number: 0444726645
   Coding: 0106063A00FA408580B0088402070E470000000000000000000000000000
   Component: GTO BF  H01 0081
   Serial number: 00000000000000407338
   Subsystem 2 - Part No: 1K0 951 605 F
   Component: LIN BACKUP HO  H01 0008
   Subsystem 3 - Part No SW: 4G8 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS40.402  H03 0004
   Serial number: 0000FST001OVAA400000
   Coding: 101F02
   Subsystem 4 - Part No SW: 4G0 947 135 G    HW: 4G0 947 135
   Serial number: 0000000AP00030640034
   Subsystem 5 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 6600<58:
01503 - Bulb for 3rd Brake Light (M25)
                    Fault Status: 00101100
                    Reset counter: 57
                    Mileage: 115 km
                    Date: 2017.12.30
                    Time: 16:29:27
03725 - Control Module for Seat Belt Tensioner; Left Front
                    Reset counter: 63
                    Mileage: 348 km
                    Date: 2018.01.12
                    Time: 21:45:54
   Coding: 011F17015E00628002000002
   VCID: 46D5AB04F8A1B6F720D-8012
   Part No SW: 4H0 907 801 M    HW: 4H0 907 801 M
   Component: EPB-4         H01 0018
   Revision: --------    Serial number: 00000002250703
   ROD: EV_ParkiBrake_AU57.rod
   VCID: 323DE7D464A93A579C5-8066
   Coding: 04FA0A1122600400
   Coding: E01E00
   Coding: E01E00
12600832 - Extended CAN Bus (SAE Bus C)
                    Reset counter: 63
                    Mileage: 348 km
                    Date: 2018.01.12
                    Time: 21:45:53
13705491 - Databus
                    Reset counter: 63
                    Mileage: 348 km
                    Date: 2018.01.12
                    Time: 21:43:56
   Part No SW: 4G1 035 025 G    HW: 4G1 035 025 C
   Component: MU-H-LNS-US   054 0980
   Serial number: A741G0HS005590
   Coding: 017551020000000013220002041A00102F0007E5F17001047E
   VCID: 221D17943449AAD76C5-8076
   Subsystem 1 - Part No SW: V03 959 801 PS    HW: -----------
   Component: NAR 2018  --- 0063
   Subsystem 2 - Part No SW: 4G1 919 605 B    HW: 4G1 919 605 B
   Serial number: AUZ8Z9HY808BNX
   Multimedia Operating Unit:
   Serial number: 90349QGA000ZC
   Component: Gracenote2---  --- 3012
7188 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 57
                    Mileage: 115 km
                    Date: 2017.12.29
                    Time: 21:15:45
                    Voltage terminal 30: 13.4 V
                    BAP-BAP_Function_ID: 11
   VCID: 49CFA038E9BF598FCDF-801C
Address 6C: Back-up Cam. (J772)       Labels:* None
   Part No SW: 4S0 980 556     HW: 4M0 980 556
   Component: RVC Compact   H08 0140
   Coding: 027500010A002003000040
   ASAM Dataset: EV_CamSysRVRVCPANAAU57X 001001
   ROD: EV_CamSysRVRVCPANAAU57X_001_AU57.rod
   VCID: 78A915FCC2551007621-802C
13762560 - Databus
          U1200 00 [008] - Defective
                    Reset counter: 63
                    Mileage: 348 km
                    Date: 2018.01.12
                    Time: 21:45:53
Address 85: On Board Cam. (J852)       Labels:* None
   Part No SW: 4H0 907 217 F    HW: 4H0 907 217 A
   Component: DPC-SG        H28 0081
   Coding: EA060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2C01F9AC468D6CA7D69-8078
0600 - Extended CAN Bus (SAE Bus C)
                    Reset counter: 63
                    Mileage: 348 km
                    Date: 2018.01.12
                    Time: 21:45:53
                    Outside air temperature: -41.5 °C
                    Voltage terminal 15: 12.5 V
                    Control Module temperature: 25.0 °C
   Part No SW: 4G0 907 541 B    HW: 4G0 907 541
   Coding: 7E01010102
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002013
   ROD: EV_AdaptCruisContr2AU57X_002.rod
   VCID: 270B06805F6B4FFF3BB-8072
          U1111 00 [008] - -
                    Reset counter: 63
                    Mileage: 348 km
                    Date: 2018.01.12
                    Time: 21:45:54
                    Voltage terminal 15: 12.535 V
                    Velocity_vehicle_reference: -0.00 m/s
          U1111 00 [008] - -
                    Reset counter: 63
                    Mileage: 348 km
                    Date: 2018.01.12
                    Time: 21:45:54
                    Voltage terminal 15: 12.534 V
          U1111 00 [008] - -
                    Reset counter: 63
                    Mileage: 348 km
                    Date: 2018.01.12
                    Time: 21:45:54
          U1111 00 [008] - -
                    Reset counter: 63
                    Mileage: 348 km
                    Date: 2018.01.12
                    Time: 21:45:54
   Part No SW: 4H0 907 107 H    HW: 4H0 907 107
   Component: BV-SG         H34 0090
   Serial number: 005002451805177
   Coding: 04C1BA1B0111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
0061 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 63
                    Mileage: 348 km
                    Date: 2018.01.12
                    Time: 21:45:54
                    Outside air temperature: 17.5 °C
                    Control Module temperature: 23.0 °C
0091 - Function Limitation due to Missing Video Data
          C1108 00 [008] -  -
                    Reset counter: 63
                    Mileage: 348 km
                    Date: 2018.01.12
                    Time: 21:45:54
Address 8F: Pretens. Frt Left (J854)       Labels:. 4H0-980-94x-RGS.clb
   Component: RGS-VL        H16 0080
   Coding: 0066E608031F0376070308014240C0010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 313FE8D861AF014FE5F-8064
12583168 - Extended CAN Bus (SAE Bus C)
                    Reset counter: 63
                    Mileage: 348 km
                    Date: 2018.01.12
                    Time: 21:45:53
Address 90: Pretens. Frt Right (J855)       Labels:. 4H0-980-94x-RGS.clb
   Component: RGS-VR        H16 0080
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
                    Reset counter: 63
                    Mileage: 348 km
                    Date: 2018.01.12
                    Time: 21:45:53
   Part No SW: 4G0 907 159 B    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0010
   Serial number: 170514200712
   ROD: EV_SoundActuaGen2AU64X_VW26.rod
Address BA: Motor Mounts (J931)       Labels: 4H0-907-145.clb
   Part No SW: 4H0 907 145 B    HW: 4H0 907 145
   Component: AEM - LEAR    H10 0008
   Revision: 00001001    Serial number: 97813008680901
   ASAM Dataset: EV_AEMLearAU64X 002016
   ROD: EV_AEMLearAU64X.rod
0512 - Extended CAN Bus (SAE Bus C)
                    Reset counter: 63
                    Mileage: 348 km
                    Date: 2018.01.12
                    Time: 21:45:53
1648 - Extended CAN Bus (SAE Bus C)
          U0047 00 [008] - Performance
                    Reset counter: 63
                    Mileage: 348 km
                    Date: 2018.01.12
                    Time: 21:45:53
End----------(Elapsed Time: 03:01, VBatt start/end: 12.3V/12.3V)-----------
Gateway Installation List:  4G8 907 468 K
I see a lot of "Extended CAN Bus (SAE Bus C) - Malfunction", which probably explains the many "missing messages" fault codes.
You bought this car new and haven't modified anything yet, right? If so, I wouldn't even think about making any changes to it until this problem is addressed. The question is, what's the best strategy to get the Audi dealer to fix this? Handing them a scan from VCDS likely isn't it...
Eric
HC800000
FWIW you would probably get more info by using the current release 18.1 . You have lots of "missing message" and "restricted function" DTCs. Also put a charger on your battery.
elp_jc
El Paso, TX USA
C?ID=323850
Bought the car new but it had been sitting inside the showroom floor probably for months... with the keys inside the car. Several cars inside had the battery dead, so it probably died in my car too... or was too weak at some point. Car had 30+ miles before my test drive, so was obviously used for a few test drives. My guess is battery got pretty low at some point. I've been charging it religiously since I bought it, via the hood jump points, since the battery is buried under the trunk. Maybe that has something to do with it? Well, I agree not to change anything right now. But I also think I should erase all codes, and see if they emerge again, to see if it's a current problem, or an old one, no? I have the excuse to take the car for the MMI issue, if it doesn't get fixed and the codes return. Open to suggestionsl, but I think there's no foul in erasing codes, no? If all the other problems are there, they will return, correct? Is it a problem erasing them??? By the way, car functions perfectly now except the AudiConnect. And my guess is car wasn't hooked up to the computer before I took delivery, since I just drove it off the lot after my test drive.
Well, if it were mine, yes, I'd clear the codes and see what happen. But the dealers we deal with know what we do for a living. :cool:
Most of your fault codes seem to be due to a one-time even at, "Mileage: 348 km / Date: 2018.01.12". I gather that's after you took delivery?
Oh, and I missed your registration question. Please see:
http://forums.ross-tech.com/showthread.php?8824
elp_jc
El Paso, TX USA
C?ID=323850
Yeah, bought the car on Dec 29, and that fateful day was when the MMI acted up, so guess it's all related to that? Hope so. Should I erase all codes and see if the AudiConnect recognizes the SIM card??? And if not, would it be any issue trying to go to the module 5F (if correct), and try to enable that part manually? There's nothing that prohibits an owner (for warranty purposes) from erasing codes, is it? Finally, should I use the car a little bit and do another scan after clearing all codes, and see if anything got recorded again? If I can't correct the MMI issue, and want dealer to fix it, the code would have a date later than when it happened, but don't think it'd matter, no? I could just tell them MMI is not recognizing the SIM and it shouldn't matter when it happened, right? Car is fully stock. And that's why I asked if VCDS would 'violate' the ECU with a TD1 code and the answer was no, so there shouldn't be any issues, I hope.
elp_jc
El Paso, TX USA
C?ID=323850
Hey Uwe, my 'dongle' doesn't have any readable serial number; only a barcode sticker. EuropaParts is saying it should have a label with a serial number. I told them it doesn't have one. They asked for pictures, but before wasting time on that, the registration video doesn't show a S/N sticker either, so maybe that's the way they come??? Let me know, please, before I register the unit (in case I need to get it replaced). Thanks.
elp_jc
El Paso, TX USA
C?ID=323850
I just downloaded the software a few days ago from the Ross-Tech website, to make sure it worked on my old computer (it did), since it wasn't supported. Is there a new version??? Guess will need to check again. If I download another, will the software just update the files or erase everything I did yesterday? Guess will do the registration now.
EDIT: Never mind. Connected the cable to register it, and it prompted me to install the new revision, and I'm doing that right now. Will register it, then clear the codes, use the car to do an errand, then do another scan and I'll post it here to see what you guys suggest after that. Hopefully all will be well, but somehow I doubt the MMI SIM issue will go away by itself, but you never know. Thank you.
It should not affect what's in your Logs sub-folder, but you could always make a backup of that folder before you update (belt & suspenders approach).
elp_jc
El Paso, TX USA
C?ID=323850
The update was downloaded quickly, then proceeded to the main page, and after pressing 'options', the config menu opened by itself with the 'update' tab, so clicked on 'download update', and it's taking forever to apply it. It's still going after like hour and a half. Is that normal??? Waiting for that to end to click 'registration'. There're 2 green bars 'applying update' and 'transferring', that keep going back and forth, so no idea how long more it'll take. If it doesn't finish soon, might have to abort it and just download the correct file again, no? And no, didn't backed up anything, but copied the first scan on my personal folder. I also checked the VCDS folder and was there as well, but I changed the name. Should be enough, I hope.
Oh, and is the serial number of the cable the 'H11-002361' listed on the HEX-V2 sticker? Thanks.
No, the update for the interface should only take a few minutes.
I'd restart it.
ETA: You don't need to download new files. Just re-start the update in VCIConfig. You may also need to reboot the interface (by removing all power from it).
