Page 1 of 5 123 ... LastLast
Results 1 to 10 of 44
Thread: Several technical questions regarding VCDS on a 2018 Audi S6
Hybrid View
    Jan 2018
    El Paso, TX USA
    1. This is the most important one for me. Do ANY of the modules available on VCDS can cause a 'TD1' flag? For those who don't know, that's the flag that voids your warranty when Audi detects the ECU was tampered with. And it's a royal (and expensive) battle for ANY warranty claim with this flag. Don't want to inadvertently triggered it by using VCDS, since my car is new.
    2. Read the VCDS user's manual and there was constant mentioning of both 'Gateway' and 'HEX' without explanation of any kind, or which cars have it. Do my S6 have either or both of those things? If yes, which one (or both), and what do I need to do differently when using VCDS?
    3. I've read several threads on this, and I didn't see mentioned 2 things I want to disable: auto door-lock (should be a freaking user menu option), and MMI auto-retract. The latter will crap out sooner or later after incessant ins and outs. I always use it, so want it permanently out. If I want to retract it, that's what the dash button is for.
    4. My MMI is not recognizing AudiConnect anymore, after I disabled the data module, trying to clear issues I was having. A forum member said I could fix that by going to module 5F and switching on SIM card recognition. Would like more detailed steps, but my question is VCDS manual only listed modules 5A and 5B. Why is not listed? Is it part of the 'hidden green menu'? Thx.
    5. Talking about the 'hidden green menu', would activating it triggers the 'TD1' flag? What parameters can be changed there? Couldn't find any info on that. Although not related to VCDS, if anybody has a link I'd appreciate it. Only found info on older systems, but not for my car, hence the question.
    6. Another big reason to buy this module is I want to lower the air suspension a little. Folks who have done it said it's supposedly not possible, but obviously it is. I want to hear from Ross-Tech's point of view why they don't support this function. What risks they're seeing, etc., to be able to make the decision if I should mess with it or not. Couldn't find out if altering the ride height also alters the shock settings or not. This is important since if it doesn't, car would bottom out easier if lowered, but shocks weren't adjusted accordingly. Maybe that's why.
    That's all for now. Thanks in advance for your help.
    JC
    1) It is not entirely clear what triggers the TD1 flag. One would think this is primarily for ECUs that have had their programming modified with a "tune" to increase power, and that's something VCDS simply does not do. However, it's possible that they might trigger it on other changes as well, for example the kinds of changes that you can make with VCDS.
    2) On modern cars, the "Gateway" is the module that routes data between the various buses (networks) in your car, including the dedicated diagnostic bus accessible on your car's OBD-II connector. "Hex" is a brand name for many of our interfaces.
    3) I would expect it's possible to turn off Auto-Lock. I'm not sure about auto-retract of the MMI screen.
    4) We'd need to see an Auto-Scan to even attempt to address this.
    5) See #1 with respect to the TD1 flag. None of us have an A6 or S6 as new as yours, so it's hard for us to say exactly what you'll be able to change using the engineering menu.
    6) I'm not sure anyone has figured out a procedure for altering the height on that generation of air-suspension control module.
  3. Likes Zenerdiode liked this post
    Jan 2018
    El Paso, TX USA
    Thanks Uwe. I'm not going to mess with the engine module other than just checking DTCs, so I shouldn't have any TD1 issues then. My MMI is not recognizing the SIM card; as simple as that. I expect the auto-scan to reveal that, but if not, is it as simple as the forum guy said? I'm ordering the cable now, so as soon as I get it will do an auto-scan. It wasn't clear from the instructions how to save the file (or change its name), but I'll ask for help if I need to. It'd be nice to rename it with easy titles, especially the first. I changed the SIM card with a new one I activated myself, and my MMI still said 'no SIM card inserted. Please insert one'. So can't even get in the menu now. And no, you cannot insert the SIM card wrong; it only 'clicks' when inserted properly (I tried all 4 possible ways). And it worked before on one that salesman put my wrong personal info, hence asking for a second one. Anyway, probably a bug, even after 7 years... exactly what I wanted to avoid with an old platform on its way out, but whatever. Hope it's an easy fix once I get the cable, and doesn't come back.
    If you're curious about how to lower the suspension in both 7.0 and 7.5 S6s, I can get you a link on that subject from Audizine, if you want (or just go find it; it's an active thread). Many, many folks have done it already with VCDS, and even with OBD11. FYI.
    Jan 2018
    El Paso, TX USA
    Okay, getting my cable tomorrow. The first thing to do is getting a full scan. Will try to do that, but if I have trouble doing it, finding it, posting it here, or any of that, I come back here, correct? Will that file give me the suspension settings and the contents of the 5F module to verify the SIM card reader is turned off (and to turn it back on)? If not, then will write down the suspension settings, and just add 15mm to lower the car 15mm overall. Reportedly 17mm is the limit, so to play it safe, will do 15, like many other folks (reportedly the car won't go lower than 17mm, so it's protected from going lower than we should. A good thing). If I can't do either of those 2 things will report that on the main thread, correct?
    Before going, have 2 questions that couldn't find answers: 1. How do you know if the MMI resetted itself? Only found the 3 buttons to push, but when I tried that trying to get it to recognize the new SIM card, it didn't do anything I could notice except one of the times (like 1 out of 10) that the screen went completely blank. Was that it? I didn't notice in which menu I had it when that happened. Does it have to be in the main menu? And for how many seconds? Thx. 2. What's the 'engineering' menu? Is it the file posted where you can change the lap timer, D+S saying the gear, and all of that? If not, a link would be appreciated. Looking forward to do many changes tomorrow. Thanks for all your help again Uwe.
    I strongly urge you to post an Auto-Scan before you try to change anything at all. You need to be able to walk before you try to run.
    Jan 2018
    El Paso, TX USA
    That's sound advice. Should I post it here? Should be doing that later today.
    By all means, post it here.
  9. #8
    Jan 2018
    El Paso, TX USA
    FULL SCAN 2018 AUDI S6
    Here you go Uwe. Lots of 'Malfunction 0010' faults. Didn't do anything except the full scan, and exited. I'm probably going to hold off on the suspension lowering for now, so only want to do several little things like gear indicator in D/S, lap timer, etc., AND more importantly, correct the SIM card issue I have (let's see what you comment on that). Please let me know what you see and suggestions what to do next. Didn't clear anything, nor go to any modules. Just clicked 'auto scan' after the test was done. Thanks in advance for your help.
    Hey, how the hell do I attach a file from my computer here? There's no such option under 'go advanced'; just to insert a photo or video from a url. Man, didn't anticipate getting stuck so soon. Ha ha. Oh well. Will wait for your instrucitons then. Or PM me your email to send you the file. All other forums have the ability to attach photos and files.
    EDIT: Holy f**k. What the hell is wrong with my car? There're A TON of faults all over the place. The weird thing is nothing seems not to be working except the SIM card issue. The only fault I recognize is when I disconnected the 3rd brake light to tint the windows (had to move the car before reinstalling it). Damn. Hope there's nothing serious brewing. Waiting on instructions how to post the file. Tried every single icon and nothing points to browse on my computer. Oh well.
    JC
  10. #9
    Jan 2018
    El Paso, TX USA
    Guess will have to wait until tomorrow. Oh well. Another thing: I was prompted several times that I have '14 uses' to register my cable. First of all, WHERE? And second of all, where is the serial number? Don't find it anywhere on the cable, and neither on the scan. Maybe it's on that barcode, but should have freaking numbers too (for resale). Thanks.
  11. #10
    Jan 2018
    El Paso, TX USA
    Okay, figured it out by analyzing other threads with files that said 'code'. Found the icon with that, and just copied the entire file and seems to be what others did. Here it goes:
    Tuesday,30,January,2018,00:16:35:26044
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x86
    VCDS Version: 17.8.1.0  HEX-V2 CB: 0.4409.4
    VIN: WAUFFAFC0JN024395   License Plate:
    Mileage: 3357km-2085mi   Repair Order:
    Chassis Type: FC-AU57 (4G8)
    Scan: 01 02 03 05 08 09 13 15 16 17 19 1B 20 22 28 34 36 3B 3C 42
              44 46 52 53 55 5F 62 6C 72 85 8B 8E 8F 90 A9 BA
    VIN: WAUFFAFC0JN024395   Mileage: 3357km-2085miles
    8F-Pretens. Frt Left -- Status: Malfunction 0010
    90-Pretens. Frt Right -- Status: Malfunction 0010
    BA-Motor Mounts -- Status: Malfunction 0010
    Address 01: Engine (------CTGE)       Labels: None
       Part No SW: 4G0 906 014 D    HW: 4H0 906 014
       Component: 4.0l V8TFSI / H63 0002
       Revision: NCH63---
       Coding: 0A2500326546010E3000
       Shop #: WSC 02391 785 00200
       ASAM Dataset: EV_ECM40TFS0114G0906014D 001002
       ROD: EV_ECM40TFS0114G0906014D.rod
       VCID: 231312902B53A3DF673-8076
       Part No SW: 4G0 927 166 F    HW: 0B5 927 156 K
       Component: 0B5 40TFSINAR H06 0007
       Revision: --H06---
       ASAM Dataset: EV_TCMDL501021 001022
       ROD: EV_TCMDL501021.rod
       VCID: 3039EDDC6AA50847EA1-8064
       Coding: 65BED449A67D2B921B00
       ROD: EV_ESP9BOSCHAU57X.rod
       VCID: 41DFB818D10F91CF15F-8014
       Part No SW: 4H0 907 064 HR    HW: 4H0 907 064 HR
       Component: BCM2 2.0      H61 0825
       Coding: 0DA86F4E000000000000
       VCID: 00597D1C9A0558C75A1-8054
       Serial number: 3217000121943016
       Part No SW: 4G0 820 043 BL    HW: 4G0 820 043 BL
       Component: KLIMA 4 ZONEN H14 0113
       Serial number: 13071700041624
       Coding: 680130784D0000
       VCID: 6A8D3FB48CF9B297E45-803E
       Part No SW: 4H0 907 063 GM    HW: 4H0 907 063 AM
       Component: BCM1 2.0      H20 0368
       Revision: 2102003S    Serial number: 00001715237202
       Coding: 01050011043C9FF2F90048C7A0003800CF9CD208AE08022180000894F10017020060003D030000
       VCID: 79AF10F8F9DF090F1DF-802C
       Component: WWS57X 170522  H38 0080
       Serial number:         170622061250
       Coding: 0045F7
       Serial number: 20338411X81A955547A0
       Coding: 02006D
       Subsystem 3 - Part No SW: 4G0 941 531 AL    HW: 4G0 941 531 AL
       Component: E1 - LDS  H07 0044
       Serial number: 06 07 2017  00000294
       Component: USHL4.2  H30 0030
       Serial number: 00000000095Z030F96D3
       Subsystem 5 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0300
       Serial number: WA128226000035191519
       Coding: 020300
       Subsystem 6 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
       Component: AQ_Hum_Sensor  H01 0006
       Serial number: 054017B800PAG0MUFU03
    03455 - Function Restriction due to Faults in Other Modules
                000 -  -  - Intermittent
                        Reset counter: 63
                        Mileage: 348 km
                        Date: 2018.01.12
                        Time: 21:43:59
       Component: ACC3          H21 0055
       Coding: 7E01010102
       ASAM Dataset: EV_AdaptCruisContrAU57X 002015
       VCID: 290F00B8497F798F2DF-807C
    34816 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 63
                        Mileage: 348 km
                        Date: 2018.01.12
                        Time: 21:45:54
                        Control Module temperature: 19 C
                        Voltage terminal 15: 12.514 V
                        Velocity_vehicle_reference: -0.01 m/s
                        Longitudinal_acceleration_vehicle_reference: 0.00 m/s
    35072 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 63
                        Mileage: 348 km
                        Date: 2018.01.12
                        Time: 21:45:54
    35328 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 63
                        Mileage: 348 km
                        Date: 2018.01.12
                        Time: 21:45:54
    35584 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 63
                        Mileage: 348 km
                        Date: 2018.01.12
                        Time: 21:45:54
    93440 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
                        Reset counter: 63
                        Mileage: 348 km
                        Date: 2018.01.12
                        Time: 21:45:54
                        Voltage terminal 15: 12.517 V
       Part No SW: 4G0 959 655 B    HW: 4G0 959 655 B
       Component: Airbag10.43   H62 0092
       Revision: --------    Serial number: 003G00049PZ6
       Coding: 303331343135303334354A55304C34473053
       VCID: 3431E1CC9EBD34678E9-8060
       Serial number: 6940000Y170001LPCC03
       Serial number: 3575HRB400659LTKB9S2
       Serial number: 3585HRB400A5BCHAH1G7
       Serial number: 3515JRB400M59NFOQHCD
       Serial number: 3525JRB400859NFOE94F
       Serial number: 3554VRB40045BE5CGGHI
       Serial number: 3564VRB40045BE5CGQ9L
       Component: Lenks.Modul   H05 0005
       Revision: --------    Serial number: 90372QGE00058
       Coding: 0000FC
       VCID: 372BD6C08F4BDF7FABB-8062
       Serial number: 01 07 2017  D0000573
    Address 17: Instruments (J285)       Labels:| 4H0-920-xxx-17.clb
       Part No SW: 4G0 920 982 S    HW: 4G0 920 982 S
       Component: TBenUsaAccNv  H17 0225
       Revision: 18001312    Serial number: 658120717592019
       Coding: 0BC70905BF51D705020200
       ASAM Dataset: EV_RBD4K 004060
       ROD: EV_RBD4K.rod
       VCID: 3C21C9ECB6EDFC27469-8068
       Part No SW: 4G8 907 468 K    HW: 4G8 907 468
       Component: J533--Gateway H15 0110
       Revision: --------    Serial number: 00000002665750
       Coding: C0ED074814
       ASAM Dataset: EV_GatewPkoUDS 002011
       VCID: 40D9BD1CDA0598C71A1-8014
       Subsystem 1 - Part No SW: 8S0 915 181 B    HW: 8S0 915 181 B
       Serial number: 9275964504
       Voltage stabilizer:
    5701 - High Beam Assistant Control Module
              U1070 00 [008] - No Communication
                        Reset counter: 63
                        Mileage: 348 km
                        Date: 2018.01.12
                        Time: 21:43:53
                        Voltage terminal 30: 12.7 V
                        Voltage terminal 15: 12.7 V
                        Control Module temperature: 21 C
                        System status: Terminal 15 on
                        Engine running: OFF
                        IN ZAS_Te_X: On
                        Terminal 15 status: On
                        Datenfeld: 0
    0258 - Extended CAN Bus (SAE Bus C)
              U0046 00 [008] - Malfunction
                        Reset counter: 63
                        Mileage: 348 km
                        Date: 2018.01.12
                        Time: 21:45:53
                        Voltage terminal 30: 12.5 V
                        Voltage terminal 15: 12.4 V
                        Control Module temperature: 23 C
                        Engine running: OFF
                        IN ZAS_Te_X: On
                        Datenfeld: 0
              U140B 00 [008] - -
                        Reset counter: 51
                        Mileage: 45 km
                        Date: 2017.12.09
                        Time: 15:26:47
                        Voltage terminal 30: 11.2 V
                        Voltage terminal 15: 11.2 V
                        Engine running: OFF
                        IN ZAS_Te_X: On
                        Datenfeld: 1
       Part No SW: 8K0 907 144 N    HW: 8K0 907 144 N
       Component: DYNAMIKLENK.  H06 0740
       Coding: 0E0100
       VCID: 3A2DCFF4BC59C217545-806E
    Address 20: High Beam Assist. (J844)       Labels: None
       Part No SW: 4H0 857 511     HW: 4H0 857 511
       Component: FLA           H04 0021
       Revision: AA001002
       Coding: 04018264747464545425363E00
       VCID: 678B46809F6B8FFFFBB-8032
    Address 22: AWD (J492)       Labels: 4H0-907-163.clb
       Part No SW: 4H0 907 163 B    HW: 4H0 907 163 A
       Component: 4 Wheel Drive H19 0200
       Serial number: 002806170001025
       ASAM Dataset: EV_AllWheelDiffeQSPFR 003026
       VCID: 280905BC52754087321-807C
       Component: KLIMA FOND    H08 0113
       Serial number: 20071700040181
       Coding: 20
       VCID: 3D27C4E8ADF7F52F717-8068
    0075 - Button or Switch in Operating Unit
              B10C7 07 [008] - Mechanical Failure
                        Reset counter: 77
                        Mileage: 2100 km
                        Date: 2018.01.20
                        Time: 09:58:39
                        Outside air temperature: 13.5 C
                        Left rear vent temperature: 37.0 C
       Part No SW: 4G0 907 553 G    HW: 4G0 907 553 F
       Coding: 008006
       ROD: EV_AirSuspe_VW51.rod
       VCID: 2F3BEEA0779B17BFF3B-807A
    403200 - Function Shut-Off Active
              C10C8 00 [008] -  -
                        Reset counter: 62
                        Mileage: 85 km
                        Date: 2017.12.29
                        Time: 19:35:16
       Revision: AA000000    Serial number: 00000264708827
       VCID: 77AB16C0CFCB1F7F6BB-8022
       Component: SARA 6D red   H04 0056
       Revision: --------    Serial number: EJ1BPA7E02X9HX
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 372BD6C08FCBDF7FABB-8062
       Component: SWA Master    H08 0070
       Serial number: 0447460632
       Coding: 040211
       VCID: 392FD0F8B9DFC90F5DF-806C
       Component: SWA Slave  H08 0070
       Serial number: 0447830783
       Coding: 040211
    512270 - Extended CAN Bus (SAE Bus C)
                        Reset counter: 63
                        Mileage: 348 km
                        Date: 2018.01.12
                        Time: 21:45:53
       Component: TSG FA        H04 0511
       Coding: 011F17015E00628002000013
       VCID: 45D7AC08C5A7BDEF297-8010
       Part No SW: 4G0 909 144 T    HW: 4G0 909 144 Q
       Component: RCevo         H54 0202
       Revision: 00000002    Serial number: 0000882256
       Coding: 011001010001
       ASAM Dataset: EV_RCEPS 106007
       ROD: EV_RCEPS_106_AU57.rod
       VCID: 3A2DCFF4BCD9C217545-806E
       Revision: 00002001    Serial number: 0444726645
       Coding: 0106063A00FA408580B0088402070E470000000000000000000000000000
       Component: GTO BF  H01 0081
       Serial number: 00000000000000407338
       Subsystem 2 - Part No: 1K0 951 605 F
       Component: LIN BACKUP HO  H01 0008
       Subsystem 3 - Part No SW: 4G8 959 591 A    HW: 8V3 959 591 A
       Component: J245 PS40.402  H03 0004
       Serial number: 0000FST001OVAA400000
       Coding: 101F02
       Subsystem 4 - Part No SW: 4G0 947 135 G    HW: 4G0 947 135
       Serial number: 0000000AP00030640034
       Subsystem 5 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
       Serial number: 6600<58:
    01503 - Bulb for 3rd Brake Light (M25)
                        Fault Status: 00101100
                        Reset counter: 57
                        Mileage: 115 km
                        Date: 2017.12.30
                        Time: 16:29:27
    03725 - Control Module for Seat Belt Tensioner; Left Front
                        Reset counter: 63
                        Mileage: 348 km
                        Date: 2018.01.12
                        Time: 21:45:54
       Coding: 011F17015E00628002000002
       VCID: 46D5AB04F8A1B6F720D-8012
       Part No SW: 4H0 907 801 M    HW: 4H0 907 801 M
       Component: EPB-4         H01 0018
       Revision: --------    Serial number: 00000002250703
       ASAM Dataset: EV_ParkiBrake 001033
       ROD: EV_ParkiBrake_AU57.rod
       VCID: 323DE7D464A93A579C5-8066
       Coding: 04FA0A1122600400
       Coding: E01E00
       Coding: E01E00
    12600832 - Extended CAN Bus (SAE Bus C)
                        Reset counter: 63
                        Mileage: 348 km
                        Date: 2018.01.12
                        Time: 21:45:53
    13705491 - Databus
                        Reset counter: 63
                        Mileage: 348 km
                        Date: 2018.01.12
                        Time: 21:43:56
       Part No SW: 4G1 035 025 G    HW: 4G1 035 025 C
       Component: MU-H-LNS-US   054 0980
       Serial number: A741G0HS005590
       Coding: 017551020000000013220002041A00102F0007E5F17001047E
       VCID: 221D17943449AAD76C5-8076
       Subsystem 1 - Part No SW: V03 959 801 PS    HW: -----------
       Component: NAR 2018  --- 0063
       Subsystem 2 - Part No SW: 4G1 919 605 B    HW: 4G1 919 605 B
       Serial number: AUZ8Z9HY808BNX
       Multimedia Operating Unit:
       Serial number: 90349QGA000ZC
       Component: Gracenote2---  --- 3012
    7188 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 57
                        Mileage: 115 km
                        Date: 2017.12.29
                        Time: 21:15:45
                        Voltage terminal 30: 13.4 V
                        BAP-BAP_Function_ID: 11
       Component: TSG HL        H03 0511
       VCID: 49CFA038E9BF598FCDF-801C
    Address 6C: Back-up Cam. (J772)       Labels:* None
       Part No SW: 4S0 980 556     HW: 4M0 980 556
       Component: RVC Compact   H08 0140
       Coding: 027500010A002003000040
       ASAM Dataset: EV_CamSysRVRVCPANAAU57X 001001
       ROD: EV_CamSysRVRVCPANAAU57X_001_AU57.rod
       VCID: 78A915FCC2551007621-802C
    13762560 - Databus
              U1200 00 [008] - Defective
                        Reset counter: 63
                        Mileage: 348 km
                        Date: 2018.01.12
                        Time: 21:45:53
       Component: TSG HR        H03 0511
    Address 85: On Board Cam. (J852)       Labels:* None
       Component: DPC-SG        H28 0081
       Coding: EA060000
       ROD: EV_OnBoardCamerDPC.rod
       VCID: 2C01F9AC468D6CA7D69-8078
    0600 - Extended CAN Bus (SAE Bus C)
                        Reset counter: 63
                        Mileage: 348 km
                        Date: 2018.01.12
                        Time: 21:45:53
                        Outside air temperature: -41.5 C
                        Voltage terminal 15: 12.5 V
                        Control Module temperature: 25.0 C
       Coding: 7E01010102
       ASAM Dataset: EV_AdaptCruisContr2AU57X 002013
       VCID: 270B06805F6B4FFF3BB-8072
              U1111 00 [008] - -
                        Reset counter: 63
                        Mileage: 348 km
                        Date: 2018.01.12
                        Time: 21:45:54
                        Voltage terminal 15: 12.535 V
                        Velocity_vehicle_reference: -0.00 m/s
              U1111 00 [008] - -
                        Reset counter: 63
                        Mileage: 348 km
                        Date: 2018.01.12
                        Time: 21:45:54
                        Voltage terminal 15: 12.534 V
              U1111 00 [008] - -
                        Reset counter: 63
                        Mileage: 348 km
                        Date: 2018.01.12
                        Time: 21:45:54
              U1111 00 [008] - -
                        Reset counter: 63
                        Mileage: 348 km
                        Date: 2018.01.12
                        Time: 21:45:54
       Component: BV-SG         H34 0090
       Serial number: 005002451805177
       Coding: 04C1BA1B0111
       ASAM Dataset: EV_BC7 001001
       ROD: EV_BC7.rod
    0061 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 63
                        Mileage: 348 km
                        Date: 2018.01.12
                        Time: 21:45:54
                        Outside air temperature: 17.5 C
                        Control Module temperature: 23.0 C
    0091 - Function Limitation due to Missing Video Data
              C1108 00 [008] -  -
                        Reset counter: 63
                        Mileage: 348 km
                        Date: 2018.01.12
                        Time: 21:45:54
    Address 8F: Pretens. Frt Left (J854)       Labels:. 4H0-980-94x-RGS.clb
       Component: RGS-VL        H16 0080
       Coding: 0066E608031F0376070308014240C0010000
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: 313FE8D861AF014FE5F-8064
    12583168 - Extended CAN Bus (SAE Bus C)
                        Reset counter: 63
                        Mileage: 348 km
                        Date: 2018.01.12
                        Time: 21:45:53
    Address 90: Pretens. Frt Right (J855)       Labels:. 4H0-980-94x-RGS.clb
       Component: RGS-VR        H16 0080
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
                        Reset counter: 63
                        Mileage: 348 km
                        Date: 2018.01.12
                        Time: 21:45:53
       Part No SW: 4G0 907 159 B    HW: 4H0 907 159 A
       Component: SAS-GEN 2     H06 0010
       Serial number: 170514200712
    Address BA: Motor Mounts (J931)       Labels: 4H0-907-145.clb
       Part No SW: 4H0 907 145 B    HW: 4H0 907 145
       Component: AEM - LEAR    H10 0008
       Revision: 00001001    Serial number: 97813008680901
       ROD: EV_AEMLearAU64X.rod
    0512 - Extended CAN Bus (SAE Bus C)
                        Reset counter: 63
                        Mileage: 348 km
                        Date: 2018.01.12
                        Time: 21:45:53
    1648 - Extended CAN Bus (SAE Bus C)
              U0047 00 [008] - Performance
                        Reset counter: 63
                        Mileage: 348 km
                        Date: 2018.01.12
                        Time: 21:45:53
    End----------(Elapsed Time: 03:01, VBatt start/end: 12.3V/12.3V)-----------
    Gateway Installation List:  4G8 907 468 K
  12. Likes Uwe liked this post
