Page 5 of 5 FirstFirst ... 345
Results 41 to 44 of 44
Thread: Several technical questions regarding VCDS on a 2018 Audi S6
  1. #41
    Dec 2016
    NL
    Quote Originally Posted by elp_jc View Post
    Here's the new scan after using the car 10 miles:
    Saturday,03,February,2018,15:33:59:26044
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x86
    VCDS Version: 18.1.0.2  HEX-V2 CB: 0.4411.4
    VIN: WAUFFAFC0JN024395   License Plate:
    Mileage: 3372km-2095mi   Repair Order:
    Chassis Type: FC-AU57 (4G8)
    Scan: 01 02 03 05 08 09 13 15 16 17 19 1B 20 22 28 34 36 3B 3C 42
              44 46 52 53 55 5F 62 6C 72 85 8B 8E 8F 90 A9 BA
    VIN: WAUFFAFC0JN024395   Mileage: 3372km-2095miles
    Address 01: Engine (------CTGE)       Labels: None
       Part No SW: 4G0 906 014 D    HW: 4H0 906 014
       Component: 4.0l V8TFSI / H63 0002
       Revision: NCH63---
       Coding: 0A2500326546010E3000
       Shop #: WSC 02391 785 00200
       ASAM Dataset: EV_ECM40TFS0114G0906014D 001002
       ROD: EV_ECM40TFS0114G0906014D.rod
       VCID: 231312902B53A3DF557-8076
    Readiness: 0010 0001
       Part No SW: 4G0 927 166 F    HW: 0B5 927 156 K
       Component: 0B5 40TFSINAR H06 0007
       Revision: --H06---
       ASAM Dataset: EV_TCMDL501021 001022
       ROD: EV_TCMDL501021.rod
       VCID: 3039EDDC6AA50847D85-8064
       Coding: 65BED449A67D2B921B00
       ROD: EV_ESP9BOSCHAU57X.rod
       VCID: 41DFB818D10F91CF27B-8014
       Part No SW: 4H0 907 064 HR    HW: 4H0 907 064 HR
       Component: BCM2 2.0      H61 0825
       Coding: 0DA86F4E000000000000
       VCID: 00597D1C9A0558C7685-8054
       Serial number: 3217000121943016
       Part No SW: 4G0 820 043 BL    HW: 4G0 820 043 BL
       Component: KLIMA 4 ZONEN H14 0113
       Serial number: 13071700041624
       Coding: 680130784D0000
       VCID: 6A8D3FB48CF9B297D61-803E
       Part No SW: 4H0 907 063 GM    HW: 4H0 907 063 AM
       Component: BCM1 2.0      H20 0368
       Revision: 2102003S    Serial number: 00001715237202
       Coding: 01050011043C9FF2F90048C7A0003800CF9CD208AE08022180000894F10017020060003D030000
       VCID: 79AF10F8F9DF090F2FB-802C
       Component: WWS57X 170522  H38 0080
       Serial number:         170622061250
       Coding: 0045F7
       Serial number: 20338411X81A955547A0
       Coding: 02006D
       Subsystem 3 - Part No SW: 4G0 941 531 AL    HW: 4G0 941 531 AL
       Component: E1 - LDS  H07 0044
       Serial number: 06 07 2017  00000294
       Component: USHL4.2  H30 0030
       Serial number: 00000000095Z030F96D3
       Subsystem 5 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0300
       Serial number: WA128226000035191519
       Coding: 020300
       Subsystem 6 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
       Component: AQ_Hum_Sensor  H01 0006
       Serial number: 054017B800PAG0MUFU03
       Component: ACC3          H21 0055
       Coding: 7E01010102
       ASAM Dataset: EV_AdaptCruisContrAU57X 002015
       VCID: 290F00B8497F798F1FB-807C
       Part No SW: 4G0 959 655 B    HW: 4G0 959 655 B
       Component: Airbag10.43   H62 0092
       Revision: --------    Serial number: 003G00049PZ6
       Coding: 303331343135303334354A55304C34473053
       VCID: 3431E1CC9EBD3467BCD-8060
       Serial number: 6940000Y170001LPCC03
       Serial number: 3575HRB400659LTKB9S2
       Serial number: 3585HRB400A5BCHAH1G7
       Serial number: 3515JRB400M59NFOQHCD
       Serial number: 3525JRB400859NFOE94F
       Serial number: 3554VRB40045BE5CGGHI
       Serial number: 3564VRB40045BE5CGQ9L
       Component: Lenks.Modul   H05 0005
       Revision: --------    Serial number: 90372QGE00058
       Coding: 0000FC
       VCID: 372BD6C08F4BDF7F99F-8062
       Serial number: 01 07 2017  D0000573
       Part No SW: 4G0 920 982 S    HW: 4G0 920 982 S
       Component: TBenUsaAccNv  H17 0225
       Revision: 18001312    Serial number: 658120717592019
       Coding: 03CD0905BF51CF05020200
       ASAM Dataset: EV_RBD4K 004060
       ROD: EV_RBD4K_AU57.rod
       VCID: 3C21C9ECB6EDFC2774D-8068
       Part No SW: 4G8 907 468 K    HW: 4G8 907 468
       Component: J533--Gateway H15 0110
       Revision: --------    Serial number: 00000002665750
       Coding: C0ED074814
       ASAM Dataset: EV_GatewPkoUDS 002011
       ROD: EV_GatewPkoUDS_002_VW51.rod
       VCID: 40D9BD1CDA0598C7285-8014
       Subsystem 1 - Part No SW: 8S0 915 181 B    HW: 8S0 915 181 B
       Serial number: 9275964504
       Voltage stabilizer:
       Serial number: 170429000000000007F9
       Part No SW: 8K0 907 144 N    HW: 8K0 907 144 N
       Component: DYNAMIKLENK.  H06 0740
       Coding: 0E0100
       VCID: 3A2DCFF4BC59C217661-806E
    Address 20: High Beam Assist. (J844)       Labels: None
       Part No SW: 4H0 857 511     HW: 4H0 857 511
       Component: FLA           H04 0021
       Revision: AA001002
       Coding: 04018264747464545425363E00
       VCID: 678B46809F6B8FFFC9F-8032
    Address 22: AWD (J492)       Labels: 4H0-907-163.clb
       Part No SW: 4H0 907 163 B    HW: 4H0 907 163 A
       Component: 4 Wheel Drive H19 0200
       Serial number: 002806170001025
       ASAM Dataset: EV_AllWheelDiffeQSPFR 003026
       VCID: 280905BC52754087005-807C
       Component: KLIMA FOND    H08 0113
       Serial number: 20071700040181
       Coding: 20
       VCID: 3D27C4E8ADF7F52F433-8068
       Part No SW: 4G0 907 553 G    HW: 4G0 907 553 F
       Coding: 008006
       ROD: EV_AirSuspe_VW51.rod
       VCID: 2F3BEEA0779B17BFC1F-807A
       Revision: AA000000    Serial number: 00000264708827
       VCID: 77AB16C0CFCB1F7F59F-8022
       Component: SARA 6D red   H04 0056
       Revision: --------    Serial number: EJ1BPA7E02X9HX
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 372BD6C08FCBDF7F99F-8062
       Component: SWA Master    H08 0070
       Serial number: 0447460632
       Coding: 040211
       VCID: 392FD0F8B9DFC90F6FB-806C
       Component: SWA Slave  H08 0070
       Serial number: 0447830783
       Coding: 040211
       Component: TSG FA        H04 0511
       Coding: 011F17015E00628002000013
       VCID: 45D7AC08C5A7BDEF1B3-8010
       Part No SW: 4G0 909 144 T    HW: 4G0 909 144 Q
       Component: RCevo         H54 0202
       Revision: 00000002    Serial number: 0000882256
       Coding: 011001010001
       ASAM Dataset: EV_RCEPS 106007
       ROD: EV_RCEPS_106.rod
       VCID: 3A2DCFF4BCD9C217661-806E
       Revision: 00002001    Serial number: 0444726645
       Coding: 0106063A00FA408580B0088402070E470000000000000000000000000000
       Component: GTO BF  H01 0081
       Serial number: 00000000000000407338
       Subsystem 2 - Part No: 1K0 951 605 F
       Component: LIN BACKUP HO  H01 0008
       Subsystem 3 - Part No SW: 4G8 959 591 A    HW: 8V3 959 591 A
       Component: J245 PS40.402  H03 0004
       Serial number: 0000FST001OVAA400000
       Coding: 101F02
       Subsystem 4 - Part No SW: 4G0 947 135 G    HW: 4G0 947 135
       Serial number: 0000000AP00030640034
       Subsystem 5 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
       Serial number: 6600<58:
       Coding: 011F17015E00628002000002
       VCID: 46D5AB04F8A1B6F7129-8012
       Part No SW: 4H0 907 801 M    HW: 4H0 907 801 M
       Component: EPB-4         H01 0018
       Revision: --------    Serial number: 00000002250703
       ASAM Dataset: EV_ParkiBrake 001033
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 323DE7D464A93A57AE1-8066
       Coding: 04FA0A1122600400
       Coding: E01E00
       Coding: E01E00
       Part No SW: 4G1 035 025 G    HW: 4G1 035 025 C
       Component: MU-H-LNS-US   054 0980
       Serial number: A741G0HS005590
       Coding: 017551020000000013220002041A00102F0007E5F17001047E
       ROD: EV_MUHig6C3Gen2HBAS_AU49.rod
       VCID: 221D17943449AAD75E1-8076
       Subsystem 1 - Part No SW: V03 959 801 PS    HW: -----------
       Component: NAR 2018  --- 0063
       Subsystem 2 - Part No SW: 4G1 919 605 B    HW: 4G1 919 605 B
       Serial number: AUZ8Z9HY808BNX
       Multimedia Operating Unit:
       Serial number: 90349QGA000ZC
       Component: Gracenote2---  --- 3012
       Component: TSG HL        H03 0511
       VCID: 49CFA038E9BF598FFFB-801C
    Address 6C: Back-up Cam. (J772)       Labels:* None
       Part No SW: 4S0 980 556     HW: 4M0 980 556
       Component: RVC Compact   H08 0140
       Coding: 027500010A002003000040
       ASAM Dataset: EV_CamSysRVRVCPANAAU57X 001001
       ROD: EV_CamSysRVRVCPANAAU57X.rod
       VCID: 78A915FCC2551007505-802C
       Component: TSG HR        H03 0511
    Address 85: On Board Cam. (J852)       Labels:* None
       Component: DPC-SG        H28 0081
       Coding: EA060000
       ROD: EV_OnBoardCamerDPC.rod
       VCID: 2C01F9AC468D6CA7E4D-8078
       Coding: 7E01010102
       ASAM Dataset: EV_AdaptCruisContr2AU57X 002013
       VCID: 270B06805F6B4FFF09F-8072
       Component: BV-SG         H34 0090
       Serial number: 005002451805177
       Coding: 04C1BA1B0111
       ASAM Dataset: EV_BC7 001001
       ROD: EV_BC7.rod
    Address 8F: Pretens. Frt Left (J854)       Labels:. 4H0-980-94x-RGS.clb
       Component: RGS-VL        H16 0080
       Coding: 0066E608031F0376070308014240C0010000
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: 313FE8D861AF014FD7B-8064
    Address 90: Pretens. Frt Right (J855)       Labels:. 4H0-980-94x-RGS.clb
       Component: RGS-VR        H16 0080
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
       Part No SW: 4G0 907 159 B    HW: 4H0 907 159 A
       Component: SAS-GEN 2     H06 0010
       Serial number: 170514200712
    Address BA: Motor Mounts (J931)       Labels: 4H0-907-145.clb
       Part No SW: 4H0 907 145 B    HW: 4H0 907 145
       Component: AEM - LEAR    H10 0008
       Revision: 00001001    Serial number: 97813008680901
       ROD: EV_AEMLearAU64X.rod
    End----------(Elapsed Time: 02:57, VBatt start/end: 12.2V/12.2V)-----------
    Looks like no faults, even though MMI still doesn't let me into AudiConnect. Will mess with module 5F in a little bit. But all is well then??? Only 10 miles, but if I had a canbus issue, or some other crap, that'd be enough, correct? Only messed with module 17 (instruments), making changes nobody has posted (like changing pressure from kPa to PSI), but since my car doesn't have TPMS sensors, maybe it's irrelevant, but changed it anyway. He he. Have other questions/concerns that I saw, but you're probably not going to know since they're Audi S6 7.5 specific, so will have to ask at the Audi forum. For instance, saw 'cruise control system installed' not checked, and was wondering if I click it, if I could have both, like on my other cars. On this one, it's only adaptive or nothing. Also saw byte 2, bit 3-5 checked as 'Audi A6/S6 limousine', which makes no sense, but the other choices are avant, allroad, so maybe it's the correct one. Do you know what that particular bit range is for? Thx. Oh, also byte 10, bit 0 'brake pad warning active' was unchecked, which would be fine with me, but why? My main concers was with the codes. Hopefully you'll give my car a clean bill of health. Ha ha. Thanks Uwe.
    Some coding bits do not match their description or are 'illogically' set, because:
    - The model is too new. Ross-Tech basically has to 'reverse engineer' stuff to make it available to all us handy people. That does mean that some time goes by between a new model launching and all the coding- and adaptation descriptions matching again, or in some cases even having basic communication with a previously unknown control unit.
    - The coding bits match, but the function is done by a different module. Example:
    You have a sound system and a radio/navigation unit in your car. You are looking at the long coding helper of the radio/navigation unit with VCDS. You come across a bit that says '8 Speakers installed'. You look around and you count 8 speakers in your car. In this case somewhere else inside the radio, be it in the coding, adaptations or rarely the parameterization (invisible), the radio is set to output any audio directly to the sound system controller/amplifier. That unit is then controlling the speakers and all speaker settings in the radio will be off.
    - The coding bit description is wrong. Example:
    A bit could also just enable a certain 'pin' on the control module. Lets say you have a door control module. In the previous 100 car models that came before, pin 16 on this module supplied power to the door warning light (one of those red lights visible when you open your door). Byte 1 bit 2 is called 'Door warning light, installed'. Now you scan your new car, look at the coding of this door module and see said bit activated. You look at your door, but see you don't have a door warning light, just a reflector. Now after the panic has subsided, you uncheck that bit, save the coding and voila. Your inside door handle light/speaker illumination/illuminated door sill/whatever goes off. Thats because the coding bits on simpler modules usually just enable or disable a certain pin on the module. Because in the previous 100 years this bit and matching pin have always served the purpose of door warning light, thats a pretty big hint, but doesnt guarantee anything. After all, sometimes they like to mix things up.
    It's just as feasible that your ABS module is guarding the brake pad wear sensors and just puts a message on the databus for the instrument panel to throw a warning. In a different model, the sensor might be hooked up to the instrument cluster directly or to a slave of the cluster. In which case the instrument cluster has to be told to enable a certain 'pin' or watch out for a specific message.
    Current:
  2. Likes PetrolDave liked this post
  3. #42
    Jan 2018
    El Paso, TX USA
    Very good points, thank you. And another example is being able to perform 2 tasks at different modules. I found one. To disable start/stop, you had to substract 4 to the value on channel 34 of the Central Electronics module (09). But I also found it on plain english on bit 2 of byte 11 of the central convenience module (46). My car already remembers the last setting, so no issue there (you can also program that by adding 32 to the value, if not set by the factory that way). But what annoyed the heck out of me was the 'off' bright LED constantly on, so reversed that by adding 64 to the value on that same channel 34, and worked perfectly, so best of both worlds (have S/S active in case I ever need it, and LED is on when 'on'). The good news is 'tree huggers' might think I'm cool because they think it's on. Ha ha.
    One question for you though: I plan to find out how to solve my MMI issue, AND how to disable the MMI screen auto-retract, and I'm convinced both things are somewhere on the freaking module 5F. If I change something on that module, I cannot permanently damage anything, correct? I wouldn't mess with blind stuff, like bytes not coded at all; only with stuff that could make sense. I can always just go back to the previous value, no? In fact, I can just 'test' it, without saving it if it doesn't work. For instance, will try changing that channel 'IDE 10668' about the SIM card to 'always', and if it doesn't work either, put it back to 'never', like it was when I found it. Maybe it's something different, like an internal SIM card, although it triggered something when changed to 'auto' since MMI went thru several screens after clicking AudiConnect, before finally going to the same blue screen error screen about 'No data support. Please insert a SIM card'. Hopefully I can find how to enable the AudiConnect menu, or enable the data module which I turned off. I'm almost sure that would resolve the issue. It's always fun to play with stuff like this. He he. Hopefully I can help other Audi owners in the future. I already found some new stuff, like how to disable the auto-door lock and unlock that I wanted disabled. Thanks again for your great help.
  4. #43
    Dec 2016
    NL
    Well, sometimes those units freak out when you change certain channels. I'm not really into the Audi variant of these 5F units, but if they're anything like VW's 5F units, the following applies:
    - If the channel doesn't make sense to you, don't touch it.
    - If the value of the channel doesn't make sense to you, don't touch it.
    Worst case I believe you're looking at a trip to the dealer for an online reset, but still the adaptation channel list on these units is huge. If you want my help doing anything, at bare minimum I'd need to see an Admap of that unit.
    This could just as well be a case of misunderstanding it. This channel could also refer so a SIM card slot that isn't on your car (hence why it was deactivated). The slot you have now could just as well be activated in any other way. If it was deactivated from the factory, thats your baseline. If it worked with that setting off, as illogical as it may seem, you need to turn it back off and look somewhere else.
    Again, without an Admap...
    See above
    Remember the MMI unit also has a 'Green Menu', which is also used in enabling various things, aside from coding and adaptation channels.
    Fix the thing you broke first.
    Then log the adaptation channels, coding and (if you're gonna mess with that) green menu options BEFORE changing anything else. This is a very important step that helps you to prevent having to retrace your steps in fixing something that you broke. You don't work on anything without doing that first.
    Current:
  5. #44
    Jan 2018
    El Paso, TX USA
    Good points again, but I need to make some more that you might not have understood.
    1. First, I didn't know about 'Admaps', so need to research how to do that, so you can see it. Is that for each module, so in this case the 5F module? And thanks for the offer to help.
    2. On the SIM channel I changed, I knew perfectly that it might not be where the SIM card is, but that wouldn't hurt anything, hence my decision to change it. I'll still try putting it to 'always', and if it doesn't work (as expected), will just put it back to 'never', like it was. I only change one thing at a time, and that's it so far. I won't touch another until I put it back to 'never'. Now, what you're not understanding is my AudiConnect USED to work, but stopped working. So for all I know, a channel must have been changed, and THAT is why it might be turned off when it should be on. This is not something I'm trying to change, like from auto-door-lock from on to off. It's something I'm trying to fix that was probably changed from what it should be by an electronic gremlin that struck my car. Makes sense now?
    3. I was told repeatedly that 7.5 cars DO NOT have a green or hidden menu anymore. Or that you can't access it anymore (don't know which is true). If you know something I don't, please enlighten me, and tell me how to access it. It'd be awesome. There're several things I wanted to change, but required the infamous green menu, and couldn't do it. To be honest, didn't even try to access it, for fear of permanently blocking something. Tried the security code of my 5F module, as a matter of fact, based on instructions for 7.0 cars, and failed. There was only 1 change, according to a warning, so probably blocked it forever. Hope I don't need a security code if I ever find the solution to both my AudiConnect issue and to stop the MMI screen from retracting every time ignition is cycled. Asked for the code but nobody replied. Also need the security code of the level control module (34) to be able to lower the car, but nobody has given it to me yet. I should be able to get it since many 7.5 owners already lowered their cars. If you have it, I'd like to have it, please. Thanks again for all your great help.
