Golf 5 driver's seat belt warning light
Fredrick Awuor
Kenya
C?ID=309834
Hello guys, I'm unable to activate this light after numerous attempts,owner claims his friend could have tinkered with it while enabling coming home,leaving home features for him,ive tried the long coding helper in instruments but can't find its checkbox anywhere in the bits/bytes,I'm thinking it could have something to do with coding the cluster but wary of venturing into uncharted territory,I changed the value from 0 to 1 in instrument adaptation but it wont come on,anyone with clues please
Friday,26,January,2018,07:19:50:48669
VCDS Version: 17.8.1.0 (x64)  HEX-V2 CB: 0.4401.4
Dealer/Shop Name: FREDRICK'S VWAUDI
VIN: WVWZZZ1KZ8U025818   License Plate:xxxx
Mileage: 117750km-73166mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ8U025818   Mileage: 117750km-73166miles
Address 01: Engine (CAX)       Labels: 03C-906-022-CAX.clb
   Part No SW: 03C 906 022 AL    HW: 03C 906 022 J
   Component: MED17.5.20          5936
   Revision: D5H03---    Serial number: VWX7Z0GD2411BP
   Coding: 0000077
   Shop #: WSC 66020 981 94185
   VCID: 6696BF75B46C2CE7C0D-8032
   Part No SW: 0AM 300 048 L    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 2669
   Revision: 00043014    Serial number: CU501306046781
   Shop #: WSC 66020 981 115161
   VCID: 392C24099552731F5DF-806C
Address 03: ABS Brakes        Labels: 1K0-614-517-MK60AT.clb
   Part No SW: 1K0 614 517 AC    HW: 1K0 614 517 AC
   Component: ESP FRONT MK60-AT   0102
   Revision: 00H14001
   Coding: 0019074
   Shop #: WSC 00046 000 00000
   VCID: 688AB14DBE783A97F21-803C
   Part No SW: 1K0 820 047 HB    HW: 1K0 820 047 HB
   Component: Climatic PQ35   141 1010
   Revision: 00141028    Serial number: 00000000000000
   VCID: 6B80CE41AF8E118F9F3-803E
   Part No SW: 3C0 937 049 AH    HW: 3C0 937 049 AH
   Revision: 00H54000    Serial number: 00000008031669
   Coding: A08D0F27000415005F1400001400000000097B0F5C000110000000000000
   Shop #: WSC 00046 412 12345
   VCID: 6FB8DA519B96EDAFB3B-803A
   Component: Wischer 290208 020  0501
   Coding: 00049141
   Shop #: WSC 00046
   Component: 15 AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6D0A95W3
   Coding: 0012597
   Shop #: WSC 00046 412 00000
   VCID: 6C82CD5DAA8016B7969-8038
   Subsystem 1 - Serial number: 6332MSME344144483
   Subsystem 2 - Serial number: 6342MSME2C25746AK
   Subsystem 3 - Serial number: 6352QSME510434352
   Subsystem 4 - Serial number: 6362QSME4C2B2639R
   Part No SW: 1K0 953 549 BF    HW: 1K0 953 549 BF
   Component: J0527           752 0100
   Coding: 0010012
   VCID: 77A8E231E3C6A56F6BB-8022
00576 - Terminal 15
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
   Part No SW: 1K0 920 864 A    HW: 1K0 920 864 A
   Component: KOMBIINSTRUMENT 3HL 1212
   Revision: V0002000    Serial number: VWX7Z0GD2411BP
   Shop #: WSC 49837 000 104857
   VCID: 2A0E0B4560F4C887245-807E
   Component: J533__Gateway   H15 0180
   Revision:   H15       Serial number: 1400K081050028
   Coding: ED807F060002020003
   Shop #: WSC 00046 123 12345
   VCID: 303A192D4628B257EA1-8064
                    Reset counter: 237
                    Mileage: 117259 km
                    Time: 11:25:50
01304 - Radio
                    Reset counter: 237
                    Mileage: 117259 km
                    Time: 11:25:55
   Component: IMMO            3HL 1212
   Part No SW: 1K0 959 701 N    HW: 1K0 959 701 N
   Component: Tuer-SG         006 1210
   Coding: 0000694
   Part No: 1K2 909 144 M
   Component: EPS_ZFLS Kl.069 H08 1901
   VCID: 36362F35A44C9C67B0D-8062
   Part No SW: 1K0 959 433 CA    HW: 1K0 959 433 CA
   Coding: 999002005103087F2D0484057008DF03E0FCA0
   VCID: 71BCDC298DA2FB5FA5F-8024
   Part No SW: 1K0 959 702 N    HW: 1K0 959 702 N
   Coding: 0000950
   VCID: 3A2E3B0590547807545-806E
Address 56: Radio
   Component: Tuer-SG         006 1301
   Coding: 0000144
   Shop #: WSC 00046 412 1012544
   VCID: 382A210DAE586A17A21-806C
   Coding: 0000144
End----------(Elapsed Time: 01:09, VBatt start/end: 13.5V/13.5V)-----------
akersgarage
C?ID=179893
I have coded the seat belt warning light out on a few golfs over the years, I have always recoded the 17 dash panel to do this.
When recoding it, it should have a drop down menu listing the options the car has.
Fredrick Awuor
Kenya
C?ID=309834
Hi,this is where matters got murkier for me especially when I saw 0000000 in the soft coding and I couldn't bring myself to click the 'do it' given the warning about recoding a module incorrectly,I didn't what could be the result,maybe you can point me in the right way to go about it,ie which numbers to add or just go with the zeroes in that field
Fredrick Awuor
Kenya
C?ID=309834
i found a solution to this problem today,car came in to my workshop and 10 minutes i was done with it'''' i must admit that in january this year when i first met client,my eyes were still not opened and im thinking UWE,JACK,IICHEL and others must have been laughing at me silently....just looking at cluster coding set at 0000001, i changed it to 0003501,and brake light wear warning plus drivers safety belt warning lights came to life on dash display and voila i could now brag to client how my legit copy of VCDS is mighty......VCDS has been a revelation!
