Sunday,28,January,2018,18:04:28:28626
VCDS Version: 18.1.0.2 (x64)
VIN: WAUZZZ4G0FN094141 License Plate: S8DGB
Mileage: 51696km-32122mi Repair Order:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 20 28 3B 42 44 46 52 53 55 5F
62 69 6D 72 A9 AC C0
VIN: WAUZZZ4G0FN094141 Mileage: 51696km-32122miles
17-Instruments -- Status: Cannot be reached 0100
Address 01: Engine (J623-CVUA) Labels: None
Part No SW: 4G0 907 589 D HW: 4G0 907 589 B
Component: 3.0BTD EDC17 H23 0002
Revision: 54H23---
Coding: 122A4032253603030000
ASAM Dataset: EV_ECM30BTD0114G0907589D 001002
ROD: EV_ECM30BTD0114G0907589D.rod
VCID: 35671C0E942EA4ED56-8060
Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
Part No SW: 4G0 927 158 AK HW: 0BK 927 156 AM
Component: 0BK 30RTDIRdW H19 1003
Revision: --H19---
Coding: 000001
VCID: 77FBD606CEA296FD84-8022
Address 03: ABS Brakes (J104) Labels: Redir Fail!
Part No SW: 4G0 907 379 S HW: 4G0 907 379 S
Component: ESP9 Premium H01 0530
Coding: 49A79E4192E579829B00
ROD: EV_ESP9BOSCHAU57X.rod
VCID: 418F78DED0E6184DFA-8014
Part No SW: 4H0 907 064 FN HW: 4H0 907 064 EN
Component: BCM2 2.0 H36 0560
Coding: 01B9704E000000000000
VCID: 7AFDCF32F5B08B95FB-802E
Serial number: 3215000077200013
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-4Z.clb
Part No SW: 4G0 820 043 CD HW: 4G0 820 043 CD
Component: KLIMA 4 ZONEN H14 0112
Serial number: 24041500041105
Coding: 36221178210000
VCID: 63C392566A3A6A5DC8-8036
Address 09: Cent. Elect. (J519) Labels: Redir Fail!
Part No SW: 4H0 907 063 DH HW: 4H0 907 063 AH
Component: BCM1 2.0 H20 0311
Revision: 15020001 Serial number: 00001057617501
Coding: 0105001440349FE0410140C3000018000F9DE7082F08020100000894E100150200400024030000
VCID: 71EFE81EA8C6C8CD4A-8024
Component: WWS57X 150319 H37 0080
Serial number: 150326222926
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 23915170
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 BE HW: 4G0 941 531 BE
Component: E1 - LDS H07 0044
Serial number: 17 04 2015 00000475
Subsystem 4 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 002944A7000000000001
Address 15: Airbags (J234) Labels:| 4H0-959-655.clb
Component: Airbag10.43 H82 0086
Revision: -------- Serial number: 003P1004DVPG
Coding: 30333130313730323737554A305234473053
VCID: 3B730A36B20A729DA0-806E
Serial number: 3575HRB401A5312UGGH8
Serial number: 3585HRB404T3761S6PM$
Serial number: 3515JRB405P370PIIORC
Serial number: 3525JRB400U54Q465P7G
Serial number: 3554VRB400254Q46NGMQ
Serial number: 3564VRB400254Q46M0MA
Part No SW: 4H0 953 568 K HW: 4H0 953 568 K
Component: Lenks.Modul H06 0005
Revision: C0068538 Serial number: 90862ODI000RH
Coding: 000035
VCID: 3B730A36BA0A729DA0-806E
Serial number: 04 04 2015 A0012114
Address 17: Instruments (J285) Labels:. 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G8 920 985 L HW: 4G8 920 985 L
Component: TDieGb H08 0043
Revision: 04001037 Serial number: 658220415596032
Coding: 33A612000B412600010000
Shop #: WSC 63606 001 1048576
ASAM Dataset: EV_RBD4K 004048
ROD: EV_RBD4K_AU57.rod
VCID: 40897DDADBEC1145F5-8014
Part No SW: 4G8 907 468 HW: 4G8 907 468
Component: J533--Gateway H13 0075
Revision: -------- Serial number: 00000001818093
Coding: C0CD078118
ASAM Dataset: EV_GatewPkoUDS 001024
VCID: 75E7DC0ED4AEE4ED96-8020
Serial number: 9703916203
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663 F
Component: J532_DCDCStab H23 0022
Serial number: 1502080000000000019F
Address 20: High Beam Assist. (J844) Labels: None
Part No SW: 4H0 857 511 HW: 4H0 857 511
Component: FLA H04 0021
Revision: AA001002
Coding: 04028264747464545425363E00
VCID: 67DB86469602067D14-8032
Address 28: HVAC, Rear (E265) Labels:* 4G0-919-158.clb
Part No SW: 4G0 919 158 Q HW: 4G0 919 158 Q
Component: KLIMA FOND H08 0112
Serial number: 28041500041962
Coding: 22
VCID: 3D77042EAC1E7CAD9E-8068
Part No SW: 4G0 907 637 H HW: 4G0 907 637 D
Component: SARA 3D H04 0056
Revision: -------- Serial number: EJ1BPA720H16ZJ
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 336322169A5ABADD78-8066
Component: TSG FA H03 0507
Coding: 011C16014001620002080002
VCID: 479B66C6F6C2267D34-8012
Part No SW: 4G0 909 144 S HW: 4G0 909 144 G
Component: RCEPS H43 0012
Revision: 00001000 Serial number: 0013709395
Coding: 101000010001
ASAM Dataset: EV_RCEPS 009013
ROD: EV_RCEPS_009.rod
VCID: 397F103EB836408DB2-806C
Revision: 00002001 Serial number: 0367213645
Coding: 013B0622A0B93000C320090420010F470000000000000000000000000000
Component: DWA-Sensor H01 0010
Component: TSG BF H03 0507
Coding: 011C16014401620002080002
VCID: 46856BC2F1C83F75CF-8012
Part No SW: 4H0 907 801 H HW: 4H0 907 801 A
Component: EPB-4 H04 0015
Revision: -------- Serial number: 00000001443451
ROD: EV_ParkiBrake_VW51.rod
VCID: 2D57346E7C7EEC2D2E-8078
Address 55: Headlight Range (J745) Labels:| 4H4-907-357-V2.clb
Component: MxB-ECU 001 0100
Coding: 04FE02102A630200
VCID: 3461210A9F54BDE561-8060
Subsystem 1 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H07 7560
Coding: E01E00
Subsystem 2 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H07 7560
Coding: E01E00
Part No SW: 4G1 035 021 H HW: 4G1 035 021
Component: MU-H-LND-EU 041 0924
Serial number: A588D0F7511415
Coding: 017502010000000013111102000A00132F0006E7F1700100DF
ROD: EV_MUHig6C3Gen2HBAS_AU49.rod
VCID: 1F4BDEA606D20EBDAC-804A
Subsystem 1 - Part No SW: V03 959 801 FD HW: -----------
Component: ECE 2017/2018 --- 0161
Subsystem 2 - Part No SW: 4G1 919 605 A HW: 4G1 919 605 A
Component: DU8 C7 SV H63 0007
Serial number: AUZ8Z9FY801EKQ
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 4G2 919 610 F HW: 4G2 919 610 F
Serial number: 90349ODM0007G
Component: Gracenote2 --- 1012
3083 - GSM antenna 2
B1533 11 [009] - Short to Ground
Reset counter: 79
Mileage: 51696 km
Date: 2018.01.28
Time: 17:56:41
Voltage terminal 30: 11.7 V
3086 - Antenna for Telephone Mount
B1564 01 [009] - Electrical Failure
Reset counter: 79
Mileage: 51696 km
Date: 2018.01.28
Time: 17:56:39
Status of telephone-Antenna diagnostic: OK
Status of telephone-Telephone baseplate diagnostic: not connected
Status of telephone-Handset in handset holder (cradle): not selected
Status of telephone-Handset holder (cradle): not connected
Component: TSG HL H03 0507
VCID: 499F60FEE0D6D00D22-801C
Address 69: Trailer (J345) Labels:| 4H0-907-383-V2.clb
Part No SW: 4G8 907 383 B HW: 4G8 907 383 B
Component: Anhaenger H20 0160
Revision: 7B001003 Serial number: 0439624912
Coding: 0100000202000000
Address 6D: Trunk Elect. (----) Labels:* Redir Fail!
Part No SW: 4G9 959 107 C HW: 4G9 959 107 B
Component: HDSG-Modul H05 0151
Revision: 14005001 Serial number: 102500545
Coding: 093205C011
ROD: EV_HDSGAu571.rod
VCID: 36651B028928AFF55F-8062
Component: TSG HR H03 0507
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 4G0 907 159 D HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0007
Serial number: 150408200359
VCID: 2E5533627178973517-807A
Part No SW: 4H0 907 355 D HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0012
Revision: 00000000 Serial number: 150980914
ROD: EV_RDCMA00100_008.rod
Address C0: Act. for Ext. Noise (J943) Labels: 4G0-907-160.clb
Part No SW: 4G0 907 160 E HW: 4G0 907 160 B
Component: SAS-GEN 2 AGA H09 0011
Serial number: 150416200006
VCID: 275BC6465E82C67DD4-8072
End-------------------------(Elapsed Time: 05:02)--------------------------
