OK so I have an end to my story.
Swivel Bar off Ebay. £200
Westfalia Electrics kit for 13 pin electrics (facelift version) £170. It comes with the exact same module Audi will sell you for £250 but with the Audi branding removed. It was a gamble, VCDS proves the guts are identical.
Wibutec Harness (only required if you really want the light on the release handle to work and don't want to cut connectors off the OEM harness and Westfalia harness and solder them together. I didn't really want to do that. I wasn't really bothered about the LED working.
So, I tried coding it all with VCDS and although the guides I got off another forum gave the correct byte/bit info I was unable to code the ABS module as the security login didn't work in the current version of VCDS, the light on the release handle didn't work and I got no indication on the dash that the bar was hanging down (not locked in either position).
Being a bit impatient I took the car to a Westfalia dealer whose coding attempt was shocking. The only thing they did was to add the trailer module at address 69 and change the trunk module code. No change to engine, brakes, central convenience of central electrical. The trailer board lights worked but it didn't disable the reversing sensors etc. I got a refund then put it back to as before.
I bit the bullet and took it to AUDI. They charged me £120 and it was 100% successful. If the bar is swinging I get a "check tow bracket" warning on the instruments. I get a trailer behind the car on the MMI when I select reverse (as did I with VCDS), and the release bracket lights work. Best of all I'm confident that all the other functions such as trailer stability program etc will now work if I need it.
I really don't get why the VCDS coding did not get the release bracket lights working. Clearly the wiring was all correct, so something in the way AUDI code it makes a difference, even off all the bits are the same as vcds suggest it should be afterwards. Plus the database for my car at AUDI now has the changes stored and my warranty is intact. It cost me a bit more in the long run but as I only paid £170 for the control module rather than £250-ish Audi would charge, it offset the coding cost a bit.
Hope this helps others with choosing a path if they choose to give this a go. Incidentally I saw someone selling 3 brand new swivelling bars for £200 each last week on ebay.
Dave
Dave
