Results 1 to 5 of 5
Thread: HELLO EVERYONE I,AM IAN AND HOPE I HELP/GET HELP
    Aug 2015
    I HAVE NOW HIT A BRICK WALL SO TO SPEAK The problem I have is not fully understanding and experienced enough to use/understand vcds how to navigate etc so please be patient . iam trying my best to repair my wifes mk6 1k golf 1.6tdi as its got a fault with I thought required a new egr so have had that fitted and both solenoid vacuum control valves replaced and still no luck and now the dpf light has come on and wont let me re set it or go into regeneration when I ask it too using vcds please could you advise as iam a beginner be patient please with me thanks Ian
    Monday,22,January,2018,09:41:01:24771
    VCDS Version: 17.8.1.0 (x64)
    VIN: WVWZZZ1KZBW136513   License Plate: PJ60EFL
    Mileage: 58430km-36306mi   Repair Order:
    Chassis Type: 1K-VW36 (7N0)
    Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 42 44 46 52 56 62 72 77
    VIN: WVWZZZ1KZBW136513   Mileage: 58430km-36306miles
    Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
       Part No SW: 03L 906 023 H    HW: 03L 906 023 A
       Component: 1,6l R4 CR td H23 6916
       Coding: 00254014032500080000
       ASAM Dataset: EV_ECM16TDI02103L906023H 003003
       ROD: EV_ECM16TDI02103L906023DB.rod
       VCID: 2B529D7D4265F31E14-807E
    7344 - EGR Sensor 2
              P0408 00 [173] - Signal too High
                        Mileage: 58404 km
                        Date: 2018.01.19
                        Time: 16:24:08
                        Engine speed: 2477.75 /min
                        Normed load value: 14.5 %
                        Coolant temperature: 55 C
                        Intake air temperature: 27 C
                        Voltage terminal 30: 13.779 V
                        EGR Solen.val.: actual value-ANG_EGRV[0]: 99.997 %
                        EGR Vacuum Regulator Solen.val.: activation-ANG_SP_EGRV[0]: 0.000 %
                        High pressure EGR actuator: activation-PWM_HBR_EGRV[0]: -100.000 %
                        High press EGR actuator: actual unconditioned volt val-V_EGRV[0]: 4.980 V
                        EGR valve: offset closed-V_EGRV_BOL[0]: 1.001 V
                        EGR valve: offset open-V_EGRV_TOL[0]: 3.999 V
                        Actuator for high pressure EGR: status-LF_STATE_EGRV_DISP[0]: 0
    16856 - Diesel Particle Filter
              P2463 00 [173] - Excessive Soot Accumulation
                        Mileage: 58404 km
                        Date: 2018.01.19
                        Time: 16:24:08
                        Engine speed: 2478.25 /min
                        Particle filter: soot mass measured-MASS_SOOT_PHY_PF: 12.81 g
                        Particle filter: soot mass calculated-MASS_SOOT_SIM_PF: 51.08 g
                        Particle filter kilometers since last regeneration_1-DIST_RGN_ENVD_H: 1020 km
                        Counter for regeneration time of diesel particle filter-T_INT_RGN_ACT_INI_PF_ENVD_H: 275.2512 s
                        Particle filter: difference pressure-DIP_PF: 0.00 hPa
                        Service regeneration: Release conditions 3-FRF_STATE_RGN: 9
                        Sensor for temp after charge air cooler: raw value-TBA_MES: 8 C
    Readiness: 1110 0000
       Part No SW: 0AM 300 049 K    HW: 0AM 927 769 D
       Component: GSG DSG AG7     403 2101
       Revision: 00040034    Serial number: 000010102
       VCID: 397EB7357039518E96-806C
       Subsystem 1 - Part No: 0AM 300 049 K
    No Faults Found
       Part No SW: 1K0 907 379 BE    HW: 1K0 907 379 BE
       Component: ESP MK60EC1   H31 0108
       Revision: 00H31001
       Coding: 133B200D09250000C81004E5901C0081310000
       VCID: 76E47C09C1A7FEF6BB-8022
       Part No SW: 3C8 907 336 AB    HW: 3C8 907 336 AB
       Component: Climatic      H14 0305
       Revision: 00009001
       Coding: 0000000002
       ROD: EV_ClimaBasis_VW36.rod
       VCID: 6DD65365BCF13D2E4A-8038
       Part No SW: 1K0 937 084 D    HW: 1K0 937 084 D
       Component: BCM PQ35  B   103 0615
       Revision: 00103 AD
       Coding: 46180A3A8825F1C040080080340000E443510088536D8160648000200040
       VCID: 2F6A896D7E7D8F3E38-807A
       Subsystem 1 - Part No: 1K2 955 119 F  Labels: 1KX-955-119.CLB
       Component: Wischer 08101  26  0512
       Coding: 009795
       Component: RLS 231010 05  54  0403
       Coding: 0330AD
       Subsystem 4 - Part No: 1K8 951 605 A
       Component: LIN BACKUP HO  H11 9004
       Part No SW: 5K0 919 475 C    HW: 5K0 919 475
       Component: PARKHILFE 8K  H07 0008
       Revision: --------    Serial number: 12941025318064
       Coding: 100101
       VCID: 3664BC098127BEF67B-8062
       Part No SW: 5K0 959 655 D    HW: 5K0 959 655 D
       Component: AirbagVW10    037 0606
       Serial number: 003FKRAEJL44
       Coding: 00003133
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 3B72AD3DB205639E84-806E
       Serial number: 3572MSME58110559ZZZR
       Serial number: 3582MSME62094657ZZZX
       Serial number: 3512QSME12526D5FZZZ/
       Serial number: 3522QSME28066D65ZZZ
       Part No SW: 5K0 953 507 AH    HW: 5K0 953 549 B
       Component: Lenks.Modul   007 0080
       Revision: --------    Serial number:  90422JJL000GF
       Coding: 1882140000
       ROD: EV_SMLSNGKUDS_A05.rod
       VCID: 76E47C09C9A7FEF6BB-8022
       Serial number: 70000000000000083619
       Coding: E20000
    365080 - Controls in Steering Wheel
              U108E 00 [008] - No Communications
                        Reset counter: 81
                        Mileage: 58393 km
                        Date: 2018.01.19
                        Time: 09:40:56
       Part No SW: 5K0 920 971 A    HW: 5K0 920 971 A
       Component: KOMBI         H20 0420
       Coding: 470B00
       VCID: 2D5693657C71FD2E0A-8078
    Address 19: CAN Gateway        Labels:. 7N0-907-530-V1.clb
       Part No SW: 7N0 907 530     HW: 1K0 907 951
       Component: J533  Gateway   H27 5603
       Revision:   H27       Serial number: 221010F2000420
       Coding: EDA07F0600061200000003
       VCID: 6DD6536574F13D2E4A-8038
                        Reset counter: 36
                        Mileage: 58271 km
                        Date: 2012.06.02
                        Time: 14:24:31
       Component: IMMO          H20 0420
       VCID: 6ADC58798D1F2A162F-803E
       Revision: A1001003    Serial number: 7668819578
       VCID: 275A614D568DD77EF0-8072
       Component: Tuer-SG         009 2120
       Coding: 0000692
       VCID: 316E8F15A84999CE2E-8064
       Part No: 1K0 909 144 J
       Component: EPS_ZFLS Kl. 70     3001
       Revision: 00H17000
       Part No SW: 5K0 959 702 C    HW: 5K0 959 702 C
       Coding: 0000948
       VCID: 3362851D5255ABDE5C-8066
       Part No SW: 3C8 035 195 A    HW: 3C8 035 195 A
       Component: Radio RCD510  040 0166
       Revision: 00000001    Serial number: VWZ1Z3K9799592
       Coding: 0100040004
       VCID: 26446C495187CE76CB-8072
                        Reset counter: 36
                        Mileage: 58271 km
                        Date: 2012.06.02
                        Time: 14:24:34
       Coding: 0000144
       Shop #: WSC 01357 011 1012552
       VCID: 3566BB055C21B5EE72-8060
       Coding: 0000144
       VCID: 3664BC094127BEF67B-8062
    Address 77: Telephone
    End-------------------------(Elapsed Time: 03:27)--------------------------
                    Address 01: Engine       Labels: 03L-906-023-CAY.clb
    Control Module Part Number: 03L 906 023 H    HW: 03L 906 023 A
      Component and/or Version: 1,6l R4 CR td H23 6916
               Software Coding: 00254014032500080000
                Work Shop Code: WSC 01357 011 00200
                  ASAM Dataset: EV_ECM16TDI02103L906023H 003003 (VW36)
    7344 - EGR Sensor 2
                        Mileage: 58404 km
                        Date: 2018.01.19
                        Time: 16:24:08
                        Mileage: 58404 km
                        Date: 2018.01.19
                        Time: 16:24:08
    7344 - EGR Sensor 2
                        Mileage: 58404 km
                        Date: 2018.01.19
                        Time: 16:24:08
                        Mileage: 58404 km
                        Date: 2018.01.19
                        Time: 16:24:08
    7344 - EGR Sensor 2
                        Mileage: 58404 km
                        Date: 2018.01.19
                        Time: 16:24:08
                        Mileage: 58404 km
                        Date: 2018.01.19
                        Time: 16:24:08
    Monday,22,January,2018,09:46:34:24771
    7344 - EGR Sensor 2
              P0408 00 [165] - Signal too High
                        Mileage: 58433 km
                        Date: 2018.01.22
                        Time: 09:43:06
                        Coolant temperature: 7 C
                        Intake air temperature: 8 C
                        Voltage terminal 30: 11.746 V
                        High pressure EGR actuator: activation-PWM_HBR_EGRV[0]: 0.000 %
              P2463 00 [165] - Excessive Soot Accumulation
                        Mileage: 58433 km
                        Date: 2018.01.22
                        Time: 09:43:06
                        Voltage terminal 30: 11.633 V
    Readiness: 1110 1000
       Revision: 00040034    Serial number: 00001010255554
       Revision: 00H31001
       Revision: 00009001
       Coding: 0000000002
       Revision: 00103 AD
       Coding: 009795
       Coding: 0330AD
       Coding: 100101
       Coding: 00003133
       Coding: 1882140000
       Coding: E20000
       Coding: 470B00
                        Reset counter: 41
                        Mileage: 58433 km
                        Date: 2012.06.14
                        Time: 09:43:12
       Coding: 0000692
       Revision: 00H17000
       Coding: 0000948
       Coding: 0100040004
                        Reset counter: 41
                        Mileage: 58433 km
                        Date: 2012.06.14
                        Time: 09:43:15
       Coding: 0000144
       Coding: 0000144
    End-------------------------(Elapsed Time: 02:57)--------------------------
    Jul 2017
    Kenya
    Quote Originally Posted by ian roby View Post
    7344 - EGR Sensor 2
                        Mileage: 58404 km
                        Date: 2018.01.19
                        Time: 16:24:08
                        Mileage: 58404 km
                        Date: 2018.01.19
                        Time: 16:24:08
    No Faults Found
       Revision: 00H31001
       Revision: 00009001
       Coding: 0000000002
       Revision: 00103 AD
       Coding: 009795
       Coding: 0330AD
       Coding: 100101
       Coding: 00003133
       Coding: 1882140000
       Coding: E20000
                        Reset counter: 81
                        Mileage: 58393 km
                        Date: 2018.01.19
                        Time: 09:40:56
       Coding: 470B00
                        Reset counter: 36
                        Mileage: 58271 km
                        Date: 2012.06.02
                        Time: 14:24:31
       Coding: 0000692
       Revision: 00H17000
       Coding: 0000948
       Coding: 0100040004
                        Reset counter: 36
                        Mileage: 58271 km
                        Date: 2012.06.02
                        Time: 14:24:34
       Coding: 0000144
       Coding: 0000144
    7344 - EGR Sensor 2
                        Mileage: 58404 km
                        Date: 2018.01.19
                        Time: 16:24:08
                        Mileage: 58404 km
                        Date: 2018.01.19
                        Time: 16:24:08
    7344 - EGR Sensor 2
                        Mileage: 58404 km
                        Date: 2018.01.19
                        Time: 16:24:08
                        Mileage: 58404 km
                        Date: 2018.01.19
                        Time: 16:24:08
    7344 - EGR Sensor 2
                        Mileage: 58404 km
                        Date: 2018.01.19
                        Time: 16:24:08
                        Mileage: 58404 km
                        Date: 2018.01.19
                        Time: 16:24:08
    7344 - EGR Sensor 2
                        Mileage: 58433 km
                        Date: 2018.01.22
                        Time: 09:43:06
                        Mileage: 58433 km
                        Date: 2018.01.22
                        Time: 09:43:06
       Revision: 00H31001
       Revision: 00009001
       Coding: 0000000002
       Revision: 00103 AD
       Coding: 009795
       Coding: 0330AD
       Coding: 100101
       Coding: 00003133
       Coding: 1882140000
       Coding: E20000
       Coding: 470B00
                        Reset counter: 41
                        Mileage: 58433 km
                        Date: 2012.06.14
                        Time: 09:43:12
       Coding: 0000692
       Revision: 00H17000
       Coding: 0000948
       Coding: 0100040004
                        Reset counter: 41
                        Mileage: 58433 km
                        Date: 2012.06.14
                        Time: 09:43:15
       Coding: 0000144
       Coding: 0000144
    Hello newbie,I think this should interest you http://wiki.ross-tech.com/wiki/index...mon_Procedures
    Nov 2015
    Has the car had the emissions fix done? If so, take it to VW and let them honour their promise to repair any faults related to the fix.
    Moving to Car Repair Support.
    Hello OP welcome to the VCDS forum.
    You will have to remediate the soot in the DPF chemically or manually then while observing PSI sensors in VCDS blocks to determine soot level, then reset in adaption and perform the EGR and DPF calibrations.
    Go have campaign performed.........
    Component: 1,6l R4 CR td H23 6916 <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< Firmware update needed 9971 of higher!
  6. Likes Uwe liked this post
