- Apr 9, 2014
- 2,304
- 2,252
- Tartu, Estonia
- C?ID=195131
This is not DIY, this is a guideline. This guide describes CCS for Stalk based cruise, not MFSW based.
1) Remove steering wheel and stalks.
2) Replace stalks with new one.
3) Replace Accelarator pedal
4) Check for CCS wire in pin5 of SWCM.
5) If not available use the wire in kit and run to ECU.
6) Assemble everything.
7) Start up ODIS
8) Make the login and basic identification
9) Use the FEC Clearing option in special functions. Select Function Enable.
10) Insert all needed stuff from paper from Cruise Kit
11) Follow ODIS commands. It will add FEC and update coding in 19, 16 and 01, in this order.
12) Enjoy Cruise.
PreCruise:
Autoscan:
19
After
19
Differences
01
16
19
Admap 19
7) Start up ODIS
12) Enjoy Cruise.
PreCruise:
Autoscan:
Saturday,13,January,2018,19:43:15:36026
VCDS Version: 17.11.0.0 (x64) HEX-NET CB: 0.4409.4
Data version: 20171026 DS285.1
Dealer/Shop Name: LeVWFreaks.eu
VIN: WVWZZZAUZGP114079 License Plate: GOLF7 CCS RETROFIT-OE
Mileage: 20269km-12594mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZGP Mileage: 20269km-12594miles
Address 01: Engine (J623-CYVA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 027 GP HW: 04E 907 309 BL
Component: R4 1.2l TFS H23 2396
Revision: R4H23---
Coding: 01110012230411082000
Shop #: WSC 00028 028 00028
ASAM Dataset: EV_ECM12TFS01104E906027GP 001005
ROD: EV_ECM12TFS01104E906027GR.rod
VCID: F8BCA3AC435F71EA7EF-80AC
CAN Converter 01:
Readiness: 1110 0001
Part No SW: 3Q0 907 379 AA HW: 3Q0 907 379 F
Component: ESC H42 0623
Revision: 00000000 Serial number: 90766000013395
Coding: 01FA6AA1142129700777060741CC2580562894E06082A4F300200078C002
Shop #: WSC 00028 028 00025
VCID: F9BAA6A8785568E2011-80AC
Part No SW: 5G0 907 426 AA HW: 5G0 907 426 AA
Component: AC Manuell H02 1001
Revision: 00001K06
Coding: 00020004200100001000000000000002
ROD: EV_ACManueBHBVW37X_003_VW37.rod
VCID: EA9889E40DF3D37AF8B-80BE
Part No SW: 5Q0 937 084 CL HW: 5Q0 937 084 AN
Component: BCM MQBAB H H24 0175
Serial number: 01061609102279
Coding: 00000846C24100534BE44000001C07081000000000000000000000000000
ROD: EV_BCMBOSCH_015.rod
VCID: 8444C75C0F97250A627-80D0
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 160320 043 0551
Serial number: 160330015519
Part No SW: 5Q0 959 655 D HW: 5Q0 959 655 D
Component: AirbagVW20 015 0388
Serial number: 003F6R1LZT19
Shop #: WSC 00028 028 00012
VCID: C1CA0E485005F022091-8094
Subsystem 1 - Part No SW: ----------- HW: 480 000 404 16
Serial number: 357670000001411CA91O
Subsystem 2 - Part No SW: ----------- HW: 480 000 404 16
Serial number: 35867000000AD41CA913
Subsystem 3 - Part No SW: ----------- HW: 480 400 504 16
Serial number: 3516502B120414F1635W
Subsystem 4 - Part No SW: ----------- HW: 480 400 404 16
Serial number: 3526502BB1FA34204222
Subsystem 5 - Part No SW: ----------- HW: 480 400 104 16
Serial number: 35565029F20414F460FF
9437211 - Igniter for Driver's Airbag
B1000 1B [137] - Resistance Too High
Mileage: 20268 km
Date: 2017.06.29
Time: 00:09:29
Part No SW: 5Q0 953 507 GB HW: 5Q0 953 549 F
Component: Lenks. Modul 003 0120
Revision: -------- Serial number: 30031604401139
Coding: 0600
ASAM Dataset: EV_SMLSKLOMQB 020001
ROD: EV_SMLSKLOMQB_VW37.rod
VCID: FCB4BFBC77675DCA1A7-80A8
Part No SW: 5G1 920 730 A HW: 5G1 920 730 A
Component: KOMBI 102 6420
Coding: 07A4020023000008010808000400000000000000
VCID: A306A4C0AA59C2327BD-80F6
Part No SW: 5Q0 907 530 AG HW: 5Q0 907 530 K
Component: GW MQB Low 210 2246
Revision: -------- Serial number: 27031610802138
Coding: 030000043F085700FB000048080E00010001050000000000000000000000
ROD: EV_GatewConti_013_VW37.rod
VCID: F6A0AD94494B079A6C3-80A2
Subsystem 2 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Component: J367-BDMHella H04 8050
Serial number: 9114489003
Part No SW: 5Q4 959 393 E HW: 5Q4 959 393 B
Component: TSG FS 010 0031
Serial number: 0000194620501
Coding: 003003208000020000001000
VCID: C5C21A58442DDC02359-8090
Serial number: 00000000000012473337
Part No SW: 3Q0 909 144 F HW: 3Q0 909 144 F
Component: EPS_MQB_ZFLS 503 5043
Coding: 0103
Shop #: WSC 73430 790 00121
ROD: EV_SteerAssisMQB_010.rod
VCID: B5226A9814CD4C82A59-80E0
Part No SW: 5Q4 959 392 E HW: 5Q4 959 392 B
Component: TSG BFS 010 0031
Serial number: 0000194631951
Coding: 003001208000020000801000
VCID: C4C4075C4F17E50A227-8090
Serial number: 00000000000012483026
Coding: 090000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
Part No SW: 5G0 035 867 C HW: 5G0 035 867 C
Component: MU-E--ER 851 6490
Serial number: 18031600011439
Coding: 02730000FF0000004011000100000000000000040000010000
ASAM Dataset: EV_MUEnt4CGen2LGE 001025
ROD: EV_MUEnt4CGen2LGE_VW37.rod
VCID: AC144FFCC7870D4ACA7-80F8
Internal ROD error:
EV_MUEnt4CGen2LGE_VW37.rod:FFMUX
End----------(Elapsed Time: 01:27, VBatt start/end: 14.8V/14.8V)-----------
19
;SW:5Q0-907-530-AG HW:5Q0-907-530-K --- CAN Gateway
;Component:GW MQB Low 210 2246, Coding:030000043F085700FB000048080E00010001050000000000000000000000
;EV_GatewConti,013020,EV_GatewConti_013_VW37.rod
;Saturday,13,January,2018,19:59:48:36026
;VCDS Version: Beta 17.11.0 (x64) Data version: 20171026 DS285.1
;VCID: F6A0AD94494B079A6C3-80A2
IDE00001-ENG124491-Production mode-p_mode_deactivate_mfl_keys,Deactivating ,3
IDE00001-ENG118694-Production mode-p_mode_deactivate_recuperation,Deactivating ,3
IDE00002-Transport mode,not active ,1
IDE00945-ENG118688-Hysteresis voltage-Voltage_elevation,12.1 V,2
IDE00945-ENG118687-Hysteresis voltage-Voltage_lowering,12.1 V,2
IDE01211-Static current measuring mode,not activated ,1
IDE01457-Energy management deactivation stage,Mode not active ,1
IDE01459-Energy management heat output control status,Mode not active ,1
IDE01844-Increase idle speed request,Mode not active ,1
IDE01847-ENG118685-Auxiliary heater activation restriction request-Set_point_target_time,-- ,3
IDE01847-ENG118684-Auxiliary heater activation restriction request-Switch_on_ban_activation,Mode not active ,3
IDE01860-Generator specified voltage value variable,10.6 V,1
IDE01996-SFT00001-Installation list: specified installations-Engine Control Module 1,coded ,32
IDE01996-SFT00002-Installation list: specified installations-Transmission Control Module,Not coded ,32
IDE01996-SFT00003-Installation list: specified installations-Brakes 1,coded ,32
IDE01996-SFT00006-Installation list: specified installations-Seat Adjustment Passenger Side,Not coded ,32
IDE01996-SFT00008-Installation list: specified installations-Air Conditioning,coded ,32
IDE01996-SFT00009-Installation list: specified installations-Central Electrics,coded ,32
IDE01996-SFT00011-Installation list: specified installations-Auxiliary Air Heater,Not coded ,32
IDE01996-SFT00014-Installation list: specified installations-Media Player Position 1,Not coded ,32
IDE01996-SFT00019-Installation list: specified installations-Adaptive Cruise Control,Not coded ,32
IDE01996-SFT00020-Installation list: specified installations-Wheel Dampening Electronics,Not coded ,32
IDE01996-SFT00021-Installation list: specified installations-Airbag,coded ,32
IDE01996-SFT00022-Installation list: specified installations-Steering Column Electronics,coded ,32
IDE01996-SFT00023-Installation list: specified installations-Dash Board,coded ,32
IDE01996-SFT00024-Installation list: specified installations-Auxiliary Parking Heater,Not coded ,32
IDE01996-SFT00025-Installation list: specified installations-Gateway,1 ,32
IDE01996-SFT00028-Installation list: specified installations-Vehicle Position Detection,Not coded ,32
IDE01996-SFT00032-Installation list: specified installations-High Beam Assistance,Not coded ,32
IDE01996-SFT00034-Installation list: specified installations-All Wheel Control,Not coded ,32
IDE01996-SFT00035-Installation list: specified installations-Brake Boost,Not coded ,32
IDE01996-SFT00038-Installation list: specified installations-Electronic Roof Control,Not coded ,32
IDE01996-SFT00043-Installation list: specified installations-Steering Column Locking,Not coded ,32
IDE01996-SFT00048-Installation list: specified installations-Special Function 2,Not coded ,32
IDE01996-SFT00050-Installation list: specified installations-Lock Electronics,Not coded ,32
IDE01996-SFT00054-Installation list: specified installations-Seat Adjustment Driver Side,Not coded ,32
IDE01996-SFT00060-Installation list: specified installations-Lane Change Assistant,Not coded ,32
IDE01996-SFT00061-Installation list: specified installations-Special Function,Not coded ,32
IDE01996-SFT00064-Installation list: specified installations-Air Conditioning Compressor,Not coded ,32
IDE01996-SFT00066-Installation list: specified installations-Door Electronics Driver Side,coded ,32
IDE01996-SFT00068-Installation list: specified installations-Steering Assistance,coded ,32
IDE01996-SFT00071-Installation list: specified installations-Sound System,Not coded ,32
IDE01996-SFT00075-Installation list: specified installations-Multifunction module,Not coded ,32
IDE01996-SFT00081-Installation list: specified installations-Drive Motor Control Module,Not coded ,32
IDE01996-SFT00082-Installation list: specified installations-Door Electronics Passenger Side,coded ,32
IDE01996-SFT00085-Installation list: specified installations-Headlight Regulation,Not coded ,32
IDE01996-SFT00086-Installation list: specified installations-Radio,Not coded ,32
IDE01996-SFT00087-Installation list: specified installations-TV Tuner,Not coded ,32
IDE01996-SFT00095-Installation list: specified installations-Information Control Unit 1,coded ,32
IDE01996-SFT00096-Installation list: specified installations-Tachograph,Not coded ,32
IDE01996-SFT00101-Installation list: specified installations-Tire Pressure Monitoring 1,Not coded ,32
IDE01996-SFT00105-Installation list: specified installations-Trailer Function,Not coded ,32
IDE01996-SFT00108-Installation list: specified installations-Camera System Rear View,Not coded ,32
IDE01996-SFT00109-Installation list: specified installations-Deck Lid Control Unit,Not coded ,32
IDE01996-SFT00117-Installation list: specified installations-Telematics Communication Unit,Not coded ,32
IDE01996-SFT00118-Installation list: specified installations-Parking Assistance,Not coded ,32
IDE01996-SFT00128-Installation list: specified installations-Battery Regulation Auxiliary Accumulator 1,Not coded ,32
IDE01996-SFT00130-Installation list: specified installations-Head Up Display,Not coded ,32
IDE01996-SFT00140-Installation list: specified installations-Battery Energy Control Module,Not coded ,32
IDE01996-SFT00165-Installation list: specified installations-Front Sensors Driver Assistance System,Not coded ,32
IDE01996-SFT00166-Installation list: specified installations-Microphone Control Unit,Not coded ,32
IDE01996-SFT00169-Installation list: specified installations-Actuator For Structure-borne Sound,Not coded ,32
IDE01996-SFT00183-Installation list: specified installations-Access Startsystem Interface,Not coded ,32
IDE01996-SFT00187-Installation list: specified installations-Door Electronics Rear Driver Side,Not coded ,32
IDE01996-SFT00188-Installation list: specified installations-Door Electronics Rear Passenger Side,Not coded ,32
IDE01996-SFT00189-Installation list: specified installations-High Voltage Battery Charge Management,Not coded ,32
IDE01996-SFT00190-Installation list: specified installations-Sliding Door Rear Left,Not coded ,32
IDE01996-SFT00191-Installation list: specified installations-Sliding Door Rear Right,Not coded ,32
IDE01996-SFT00192-Installation list: specified installations-Actuator For Exterior Noise,Not coded ,32
IDE01996-SFT00197-Installation list: specified installations-Thermal management,Not coded ,32
IDE01996-SFT00198-Installation list: specified installations-Battery Charger Control Module,Not coded ,32
IDE01996-SFT00202-Installation list: specified installations-Control module for sunroof,Not coded ,32
IDE01996-SFT00207-Installation list: specified installations-Control Unit Lane Change Assistant 2,Not coded ,32
IDE01996-ENG118226-Installation list: specified installations-Node_0x01,Not coded ,32
IDE01996-ENG118227-Installation list: specified installations-Node_0x02,Not coded ,32
IDE01996-ENG118228-Installation list: specified installations-Node_0x03,Not coded ,32
IDE01996-ENG118229-Installation list: specified installations-Node_0x04,Not coded ,32
IDE01996-ENG118230-Installation list: specified installations-Node_0x05,Not coded ,32
IDE01996-ENG118231-Installation list: specified installations-Node_0x06,Not coded ,32
IDE01996-ENG118232-Installation list: specified installations-Node_0x07,Not coded ,32
IDE01996-ENG118233-Installation list: specified installations-Node_0x08,Not coded ,32
IDE01996-ENG118235-Installation list: specified installations-Node_0x0D,Not coded ,32
IDE01996-ENG118236-Installation list: specified installations-Node_0x11,Not coded ,32
IDE01996-ENG118237-Installation list: specified installations-Node_0x16,Not coded ,32
IDE01996-ENG118238-Installation list: specified installations-Node_0x17,Not coded ,32
IDE01996-ENG118239-Installation list: specified installations-Node_0x1A,Not coded ,32
IDE01996-ENG118241-Installation list: specified installations-Node_0x1D,Not coded ,32
IDE01996-ENG118242-Installation list: specified installations-Node_0x1F,Not coded ,32
IDE01996-ENG118243-Installation list: specified installations-Node_0x20,Not coded ,32
IDE01996-ENG118244-Installation list: specified installations-Node_0x21,Not coded ,32
IDE01996-ENG118245-Installation list: specified installations-Node_0x22,Not coded ,32
IDE01996-ENG118246-Installation list: specified installations-Node_0x24,Not coded ,32
IDE01996-ENG118247-Installation list: specified installations-Node_0x25,Not coded ,32
IDE01996-ENG118248-Installation list: specified installations-Node_0x26,Not coded ,32
IDE01996-ENG118249-Installation list: specified installations-Node_0x27,Not coded ,32
IDE01996-ENG118250-Installation list: specified installations-Node_0x28,Not coded ,32
IDE01996-ENG118251-Installation list: specified installations-Node_0x29,Not coded ,32
IDE01996-ENG118252-Installation list: specified installations-Node_0x2A,Not coded ,32
IDE01996-ENG118253-Installation list: specified installations-Node_0x2E,Not coded ,32
IDE01996-ENG118254-Installation list: specified installations-Node_0x2F,Not coded ,32
IDE01996-ENG118255-Installation list: specified installations-Node_0x35,Not coded ,32
IDE01996-ENG118256-Installation list: specified installations-Node_0x36,Not coded ,32
IDE01996-ENG118257-Installation list: specified installations-Node_0x37,Not coded ,32
IDE01996-ENG118258-Installation list: specified installations-Node_0x38,Not coded ,32
IDE01996-ENG118259-Installation list: specified installations-Node_0x39,Not coded ,32
IDE01996-ENG118260-Installation list: specified installations-Node_0x3A,Not coded ,32
IDE01996-ENG118261-Installation list: specified installations-Node_0x3C,Not coded ,32
IDE01996-ENG118262-Installation list: specified installations-Node_0x3D,Not coded ,32
IDE01996-ENG118263-Installation list: specified installations-Node_0x40,Not coded ,32
IDE01996-ENG118264-Installation list: specified installations-Node_0x41,Not coded ,32
IDE01996-ENG118265-Installation list: specified installations-Node_0x43,Not coded ,32
IDE01996-ENG118266-Installation list: specified installations-Node_0x45,Not coded ,32
IDE01996-ENG118267-Installation list: specified installations-Node_0x48,Not coded ,32
IDE01996-ENG118268-Installation list: specified installations-Node_0x49,Not coded ,32
IDE01996-ENG118269-Installation list: specified installations-Node_0x51,Not coded ,32
IDE01996-ENG118270-Installation list: specified installations-Node_0x52,Not coded ,32
IDE01996-ENG118271-Installation list: specified installations-Node_0x53,Not coded ,32
IDE01996-ENG118272-Installation list: specified installations-Node_0x55,Not coded ,32
IDE01996-ENG118273-Installation list: specified installations-Node_0x56,Not coded ,32
IDE01996-ENG118274-Installation list: specified installations-Node_0x58,Not coded ,32
IDE01996-ENG118275-Installation list: specified installations-Node_0x59,Not coded ,32
IDE01996-ENG118276-Installation list: specified installations-Node_0x5A,Not coded ,32
IDE01996-ENG118277-Installation list: specified installations-Node_0x5B,Not coded ,32
IDE01996-ENG118278-Installation list: specified installations-Node_0x5C,Not coded ,32
IDE01996-ENG118279-Installation list: specified installations-Node_0x5D,Not coded ,32
IDE01996-ENG118280-Installation list: specified installations-Node_0x5E,Not coded ,32
IDE01996-ENG118281-Installation list: specified installations-Node_0x5F,Not coded ,32
IDE01996-ENG118282-Installation list: specified installations-Node_0x60,Not coded ,32
IDE01996-ENG118283-Installation list: specified installations-Node_0x61,Not coded ,32
IDE01996-ENG118284-Installation list: specified installations-Node_0x62,Not coded ,32
IDE01996-ENG118285-Installation list: specified installations-Node_0x66,Not coded ,32
IDE01996-ENG118286-Installation list: specified installations-Node_0x68,Not coded ,32
IDE01996-ENG118287-Installation list: specified installations-Node_0x6B,Not coded ,32
IDE01996-ENG118288-Installation list: specified installations-Node_0x6C,Not coded ,32
IDE01996-ENG118289-Installation list: specified installations-Node_0x6E,Not coded ,32
IDE01996-ENG118290-Installation list: specified installations-Node_0x74,Not coded ,32
IDE01996-ENG118291-Installation list: specified installations-Node_0x75,Not coded ,32
IDE01996-ENG118292-Installation list: specified installations-Node_0x78,Not coded ,32
IDE01996-ENG118293-Installation list: specified installations-Node_0x79,Not coded ,32
IDE01996-ENG118294-Installation list: specified installations-Node_0x7A,Not coded ,32
IDE01996-ENG118295-Installation list: specified installations-Node_0x7D,Not coded ,32
IDE01996-ENG118296-Installation list: specified installations-Node_0x7E,Not coded ,32
IDE01996-ENG118297-Installation list: specified installations-Node_0x7F,Not coded ,32
IDE01996-ENG118298-Installation list: specified installations-Node_0x80,Not coded ,32
IDE01996-ENG118299-Installation list: specified installations-Node_0x81,Not coded ,32
IDE01996-ENG118300-Installation list: specified installations-Node_0x82,Not coded ,32
IDE01996-ENG118301-Installation list: specified installations-Node_0x83,Not coded ,32
IDE01996-ENG118302-Installation list: specified installations-Node_0x85,Not coded ,32
IDE01996-ENG118303-Installation list: specified installations-Node_0x86,Not coded ,32
IDE01996-ENG118304-Installation list: specified installations-Node_0x87,Not coded ,32
IDE01996-ENG118305-Installation list: specified installations-Node_0x88,Not coded ,32
IDE01996-ENG118306-Installation list: specified installations-Node_0x89,Not coded ,32
IDE01996-ENG118307-Installation list: specified installations-Node_0x8B,Not coded ,32
IDE01996-ENG118308-Installation list: specified installations-Node_0x8C,Not coded ,32
IDE01996-ENG118309-Installation list: specified installations-Node_0x8D,Not coded ,32
IDE01996-ENG118310-Installation list: specified installations-Node_0x8E,Not coded ,32
IDE01996-ENG118311-Installation list: specified installations-Node_0x8F,Not coded ,32
IDE01996-ENG118312-Installation list: specified installations-Node_0x90,Not coded ,32
IDE01996-ENG118313-Installation list: specified installations-Node_0x91,Not coded ,32
IDE01996-ENG118314-Installation list: specified installations-Node_0x92,Not coded ,32
IDE01996-ENG118315-Installation list: specified installations-Node_0x93,Not coded ,32
IDE01996-ENG118316-Installation list: specified installations-Node_0x94,Not coded ,32
IDE01996-ENG118317-Installation list: specified installations-Node_0x95,Not coded ,32
IDE01996-ENG118318-Installation list: specified installations-Node_0x96,Not coded ,32
IDE01996-ENG118319-Installation list: specified installations-Node_0x97,Not coded ,32
IDE01996-ENG118320-Installation list: specified installations-Node_0x98,Not coded ,32
IDE01996-ENG118321-Installation list: specified installations-Node_0x99,Not coded ,32
IDE01996-ENG118322-Installation list: specified installations-Node_0x9A,Not coded ,32
IDE01996-ENG118323-Installation list: specified installations-Node_0x9B,Not coded ,32
IDE01996-ENG118324-Installation list: specified installations-Node_0x9C,Not coded ,32
IDE01996-ENG118325-Installation list: specified installations-Node_0x9D,Not coded ,32
IDE01996-ENG118326-Installation list: specified installations-Node_0x9E,Not coded ,32
IDE01996-ENG118327-Installation list: specified installations-Node_0x9F,Not coded ,32
IDE01996-ENG118328-Installation list: specified installations-Node_0xA0,Not coded ,32
IDE01996-ENG118329-Installation list: specified installations-Node_0xA1,Not coded ,32
IDE01996-ENG118330-Installation list: specified installations-Node_0xA2,Not coded ,32
IDE01996-ENG118331-Installation list: specified installations-Node_0xA3,Not coded ,32
IDE01996-ENG118333-Installation list: specified installations-Node_0xA5,Not coded ,32
IDE01996-ENG118334-Installation list: specified installations-Node_0xA6,Not coded ,32
IDE01996-ENG118335-Installation list: specified installations-Node_0xA7,Not coded ,32
IDE01996-ENG118336-Installation list: specified installations-Node_0xA8,Not coded ,32
IDE01996-ENG118338-Installation list: specified installations-Node_0xAA,Not coded ,32
IDE01996-ENG118339-Installation list: specified installations-Node_0xAB,Not coded ,32
IDE01996-ENG118340-Installation list: specified installations-Node_0xAC,Not coded ,32
IDE01996-ENG118341-Installation list: specified installations-Node_0xAD,Not coded ,32
IDE01996-ENG118343-Installation list: specified installations-Node_0xAF,Not coded ,32
IDE01996-ENG118344-Installation list: specified installations-Node_0xB0,Not coded ,32
IDE01996-ENG118345-Installation list: specified installations-Node_0xB1,Not coded ,32
IDE01996-ENG118346-Installation list: specified installations-Node_0xB2,Not coded ,32
IDE01996-ENG118347-Installation list: specified installations-Node_0xB3,Not coded ,32
IDE01996-ENG118348-Installation list: specified installations-Node_0xB4,Not coded ,32
IDE01996-ENG118349-Installation list: specified installations-Node_0xB5,Not coded ,32
IDE01996-ENG118350-Installation list: specified installations-Node_0xB6,Not coded ,32
IDE01996-ENG118351-Installation list: specified installations-Node_0xB7,Not coded ,32
IDE01996-ENG118352-Installation list: specified installations-Node_0xB8,Not coded ,32
IDE01996-ENG118353-Installation list: specified installations-Node_0xB9,Not coded ,32
IDE01996-ENG118354-Installation list: specified installations-Node_0xBA,Not coded ,32
IDE01996-ENG118355-Installation list: specified installations-Node_0xBB,Not coded ,32
IDE01996-ENG118356-Installation list: specified installations-Node_0xBC,Not coded ,32
IDE01996-ENG118357-Installation list: specified installations-Node_0xBD,Not coded ,32
IDE01996-ENG118358-Installation list: specified installations-Node_0xBE,Not coded ,32
IDE01996-ENG118359-Installation list: specified installations-Node_0xBF,Not coded ,32
IDE01996-ENG118360-Installation list: specified installations-Node_0xC0,Not coded ,32
IDE01996-ENG118361-Installation list: specified installations-Node_0xC1,Not coded ,32
IDE01996-ENG118362-Installation list: specified installations-Node_0xC2,Not coded ,32
IDE01996-ENG118363-Installation list: specified installations-Node_0xC3,Not coded ,32
IDE01996-ENG118364-Installation list: specified installations-Node_0xC4,Not coded ,32
IDE01996-ENG118365-Installation list: specified installations-Node_0xC5,Not coded ,32
IDE01996-ENG118366-Installation list: specified installations-Node_0xC6,Not coded ,32
IDE01996-ENG118367-Installation list: specified installations-Node_0xC7,Not coded ,32
IDE01996-ENG118368-Installation list: specified installations-Node_0xC8,Not coded ,32
IDE01996-ENG118369-Installation list: specified installations-Node_0xC9,Not coded ,32
IDE01996-ENG118370-Installation list: specified installations-Node_0xCA,Not coded ,32
IDE01996-ENG118371-Installation list: specified installations-Node_0xCB,Not coded ,32
IDE01996-ENG118372-Installation list: specified installations-Node_0xCC,Not coded ,32
IDE01996-ENG118373-Installation list: specified installations-Node_0xCD,Not coded ,32
IDE01996-ENG118374-Installation list: specified installations-Node_0xCE,Not coded ,32
IDE01996-ENG118375-Installation list: specified installations-Node_0xCF,Not coded ,32
IDE01996-ENG118376-Installation list: specified installations-Node_0xD0,Not coded ,32
IDE01996-ENG118377-Installation list: specified installations-Node_0xD1,Not coded ,32
IDE01996-ENG118378-Installation list: specified installations-Node_0xD2,Not coded ,32
IDE01996-ENG118379-Installation list: specified installations-Node_0xD3,Not coded ,32
IDE01996-ENG118380-Installation list: specified installations-Node_0xD4,Not coded ,32
IDE01996-ENG118381-Installation list: specified installations-Node_0xD5,Not coded ,32
IDE01996-ENG118382-Installation list: specified installations-Node_0xD6,Not coded ,32
IDE01996-ENG118383-Installation list: specified installations-Node_0xD7,Not coded ,32
IDE01996-ENG118384-Installation list: specified installations-Node_0xD8,Not coded ,32
IDE01996-ENG118385-Installation list: specified installations-Node_0xD9,Not coded ,32
IDE01996-ENG118386-Installation list: specified installations-Node_0xDA,Not coded ,32
IDE01996-ENG118387-Installation list: specified installations-Node_0xDB,Not coded ,32
IDE01996-ENG118388-Installation list: specified installations-Node_0xDC,Not coded ,32
IDE01996-ENG118389-Installation list: specified installations-Node_0xDD,Not coded ,32
IDE01996-ENG118390-Installation list: specified installations-Node_0xDE,Not coded ,32
IDE01996-ENG118391-Installation list: specified installations-Node_0xDF,Not coded ,32
IDE01996-ENG118392-Installation list: specified installations-Node_0xE0,Not coded ,32
IDE01996-ENG118393-Installation list: specified installations-Node_0xE1,Not coded ,32
IDE01996-ENG118394-Installation list: specified installations-Node_0xE2,Not coded ,32
IDE01996-ENG118395-Installation list: specified installations-Node_0xE3,Not coded ,32
IDE01996-ENG118396-Installation list: specified installations-Node_0xE4,Not coded ,32
IDE01996-ENG118397-Installation list: specified installations-Node_0xE5,Not coded ,32
IDE01996-ENG118398-Installation list: specified installations-Node_0xE6,Not coded ,32
IDE01996-ENG118399-Installation list: specified installations-Node_0xE7,Not coded ,32
IDE01996-ENG118400-Installation list: specified installations-Node_0xE8,Not coded ,32
IDE01996-ENG118401-Installation list: specified installations-Node_0xE9,Not coded ,32
IDE01996-ENG118402-Installation list: specified installations-Node_0xEA,Not coded ,32
IDE01996-ENG118403-Installation list: specified installations-Node_0xEB,Not coded ,32
IDE01996-ENG118404-Installation list: specified installations-Node_0xEC,Not coded ,32
IDE01996-ENG118405-Installation list: specified installations-Node_0xED,Not coded ,32
IDE01996-ENG118406-Installation list: specified installations-Node_0xEE,Not coded ,32
IDE01996-ENG118407-Installation list: specified installations-Node_0xEF,Not coded ,32
IDE01996-ENG118408-Installation list: specified installations-Node_0xF0,Not coded ,32
IDE01996-ENG118409-Installation list: specified installations-Node_0xF1,Not coded ,32
IDE01996-ENG118410-Installation list: specified installations-Node_0xF2,Not coded ,32
IDE01996-ENG118411-Installation list: specified installations-Node_0xF3,Not coded ,32
IDE01996-ENG118412-Installation list: specified installations-Node_0xF4,Not coded ,32
IDE01996-ENG118413-Installation list: specified installations-Node_0xF5,Not coded ,32
IDE01996-ENG118414-Installation list: specified installations-Node_0xF6,Not coded ,32
IDE01996-ENG118415-Installation list: specified installations-Node_0xF7,Not coded ,32
IDE01996-ENG118416-Installation list: specified installations-Node_0xF8,Not coded ,32
IDE01996-ENG118417-Installation list: specified installations-Node_0xF9,Not coded ,32
IDE01996-ENG118418-Installation list: specified installations-Node_0xFA,Not coded ,32
IDE01996-ENG118419-Installation list: specified installations-Node_0xFB,Not coded ,32
IDE01996-ENG118420-Installation list: specified installations-Node_0xFC,Not coded ,32
IDE01996-ENG118421-Installation list: specified installations-Node_0xFD,Not coded ,32
IDE01996-ENG118422-Installation list: specified installations-Node_0xFE,Not coded ,32
IDE01996-ENG118423-Installation list: specified installations-Node_0xFF,Not coded ,32
IDE02200-Component protection showroom mode,not active ,1
IDE03256-MAS06105-Battery adaptation-Rated battery capacity,59 Ah,15
IDE03256-MAS06106-Battery adaptation-Battery technology,EFB ,15
IDE03256-MAS06107-Battery adaptation-Battery manufacturer,JCB ,15
IDE03256-MAS06108-Battery adaptation-Battery Serial Number,1111111111 ,15
IDE03903-Production process data 1,00 03 ,2
IDE04159-Deactivation of start-stop function,Mode not active ,1
IDE04186-Battery terminal recognition,connected ,1
IDE04330-Transfer of release code for a SWaP function,00 ,1
IDE06425-MAS06026-Roller test bench mode: functional-Activation stages,not activated ,1
IDE06425-MAS06277-Roller test bench mode: functional-Malfunction states,no error ,1
IDE06530-Distance left for deactivation of static current measuring mode,2 ,1
IDE06541-Distance left for deactivation of transport mode,50 ,1
IDE06753-MAS06278-Efficiency program display-Live tip air resistance: close window/sunroof,activated ,4
IDE06753-MAS06279-Efficiency program display-Live tip engine brake: uncouple not until below 1300 RPM,activated ,4
IDE06753-MAS06280-Efficiency program display-Live tip do not operate gas pedal during engine start,activated ,4
IDE06753-MAS06281-Efficiency program display-Live tip adhere to switch display (only manual switch),activated ,4
IDE06753-MAS06282-Efficiency program display-Live tip use start-stop-system,activated ,4
IDE06753-MAS06283-Efficiency program display-Live tip switch on start-stop-system,activated ,4
IDE06753-MAS06284-Efficiency program display-Live tip air conditioning: close window/sunroof,not activated ,4
IDE06753-MAS06285-Efficiency program display-Live tip use gearshift position D,activated ,4
IDE06753-MAS06286-Efficiency program display-Live tip Do not press accelerator pedal at standstill,activated ,4
IDE06753-MAS06287-Efficiency program display-Live tip sunroof open: switch of A/C (AC button),activated ,4
IDE06753-MAS06288-Efficiency program display-Live tip avoid engine warm-up at standstill,activated ,4
IDE06753-MAS06289-Efficiency program display-Comfort use A/C,activated ,4
IDE06753-MAS06290-Efficiency program display-Comfort use parking heater,activated ,4
IDE06753-MAS06291-Efficiency program display-Comfort use rear window heater,activated ,4
IDE06753-MAS06292-Efficiency program display-Comfort use front seat heater,activated ,4
IDE06753-MAS06293-Efficiency program display-Comfort use front seat ventilation,activated ,4
IDE06753-MAS06294-Efficiency program display-Comfort use rear heater,activated ,4
IDE06753-MAS06295-Efficiency program display-Comfort use fog light,activated ,4
IDE06753-MAS06296-Efficiency program display-Comfort use rear fog light,not activated ,4
IDE06753-MAS06297-Efficiency program display-Comfort use parking heater consumption emission,activated ,4
IDE06753-MAS06298-Efficiency program display-Comfort use windshield heater,activated ,4
IDE06753-MAS06299-Efficiency program display-Comfort use steering wheel heater,activated ,4
IDE06753-MAS06300-Efficiency program display-Comfort use mirror heater,activated ,4
IDE06753-MAS06301-Efficiency program display-Comfort use rear seat heater,not activated ,4
IDE06753-MAS06302-Efficiency program display-Comfort use rear seat ventilation,activated ,4
IDE06753-MAS14430-Efficiency program display-Dependence of ECO tips on driver profile selection,ECO tips independent of driver profile selection ,4
IDE06753-MAS19094-Efficiency program display-Convenience_consumption_air_condition_ventilation_rear,activated ,4
IDE06753-MAS19095-Efficiency program display-Convenience_consumption_mirror_heating_dependency,Until_temperature_threshold_with_after-run_with_switch ,4
IDE07838-Counter for inconsistent states,78 ,2
IDE08348-Start/stop start voltage limit,7.6 V,1
IDE08624-MKE Check box,activated ,1
IDE10735-Number requests autonomous recharging,3 ,1
IDE10736-Cyclization limitation request battery service,0 ,1
IDE10748-MAS11262-Range gain-Range gain AC system,activated ,3
IDE10748-MAS11263-Range gain-Range gain auxiliary heater,activated ,3
IDE10748-MAS11264-Range gain-Range gain window defogger,activated ,3
IDE10748-MAS11265-Range gain-Range gain seat heater front,activated ,3
IDE10748-MAS11266-Range gain-Range gain front set ventilation,activated ,3
IDE10748-MAS11267-Range gain-Range gain rear heater,activated ,3
IDE10748-MAS11268-Range gain-Range gain fog light,activated ,3
IDE10748-MAS11269-Range gain-Range gain rear fog light,activated ,3
IDE10748-MAS11270-Range gain-Range gain windshield heating,activated ,3
IDE10748-MAS11271-Range gain-Range gain steering wheel heater,activated ,3
IDE10748-MAS11272-Range gain-Range gain mirror heater,activated ,3
IDE10748-MAS11273-Range gain-Range gain rear seat heater,not activated ,3
IDE10748-MAS11274-Range gain-Range gain rear seat heater,activated ,3
IDE10748-MAS11275-Range gain-Windshield heater consumption in AC system,not activated ,3
IDE10748-MAS11276-Range gain-Windshield heater range gain in AC system,activated ,3
IDE10748-MAS11277-Range gain-PTC(low voltage) consumption,not activated ,3
IDE10748-MAS11278-Range gain-PTC(low voltage) range gain,activated ,3
IDE10748-MAS11279-Range gain-List at engine still stand,activated ,3
IDE10748-MAS12689-Range gain-Catalogue range display,activated ,3
IDE10748-MAS12690-Range gain-Loading condition catalogue range display,activated ,3
IDE10748-MAS13161-Range gain-List display absolute values with weighting,activated ,3
IDE10748-MAS19099-Range gain-Convenience_consumption_means_plug,activated ,3
IDE10748-MAS19100-Range gain-Convenience_consumption_air_condition_ventilation_manually,activated ,3
IDE10748-MAS19132-Range gain-Consumption_mirror_heating_in_heated_rear_window,activated ,3
ENG125878-ENG125896-AGW_Calibration-AGW_Brightness_Start_Sequence,100 %,10
ENG125878-ENG126255-AGW_Calibration-AGW_fade_in_deactivation_threshold,100 ,10
ENG125878-ENG125890-AGW_Calibration-AGW_Time_Fade_In,0 ms,10
ENG125878-ENG125892-AGW_Calibration-AGW_Time_Fade_In_Start,0 ms,10
ENG125878-ENG125891-AGW_Calibration-AGW_Time_Fade_Out,0 ms,10
ENG125878-ENG125893-AGW_Calibration-AGW_Time_Fade_Out_Start,0 ms,10
ENG125878-ENG125895-AGW_Calibration-AGW_Time_Start_Delay,0 ms,10
ENG125878-ENG125894-AGW_Calibration-AGW_Time_Start_Sequence,0 ms,10
ENG125879-ENG125897-AGW_Function_Releases-AGW_Enabling_Brightness,active ,3
ENG125879-ENG125898-AGW_Function_Releases-AGW_Enabling_Flash_Frequency,active ,3
ENG125879-ENG125899-AGW_Function_Releases-AGW_Enabling_Supression_Symbol,active ,3
ENG118777-ENG118712-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Counter_Master_Reset,active ,12
ENG118777-ENG118710-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Limit_Adaptation,100 ,12
ENG118777-ENG118711-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Lock_Adaptation,60000 ms,12
ENG118777-ENG118709-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Time_Adaptation,10000 ms,12
ENG118777-ENG118705-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Indication_Control_Adaption,3000 ms,12
ENG118777-ENG118706-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Kombi_Offset_Adaption,0 ms,12
ENG118777-ENG118708-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Request_Repetition_Time_Adaptation,180000 ms,12
ENG118777-ENG118707-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Sync_Time_Adaptation,1500 ms,12
ENG118777-ENG118703-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation,800 ms,12
ENG118777-ENG118704-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Touch_Contact_Time_Adaption,2500 ms,12
ENG137060-ENG113874-EM_energy_management_warning_displays-Batteriemeldungen,Mode not active ,4
ENG137060-ENG98711-EM_energy_management_warning_displays-Charge level,Mode not active ,4
ENG137060-ENG113873-EM_energy_management_warning_displays-Generatormeldungen,Mode not active ,4
ENG137060-ENG118686-EM_energy_management_warning_displays-MMI Vorwarnungen,Mode not active ,4
ENG137075-EM_heating_power_quota_adjustment,1000 W,1
ENG137061-EM_nominal_voltage_limitation_low_beams,12.1 V,1
ENG137064-EM_requirement_cyclic_time_voltage_measurement,0 s,1
ENG137063-EM_requirement_reduction_air_blowers,Mode not active ,1
ENG137062-ENG100689-EM_start_stop_requirement_ambient_temperature-Maximum_temperature,-50.0 °C,2
ENG137062-ENG137099-EM_start_stop_requirement_ambient_temperature-Minimum_temperature,-50.0 °C,2
ENG137058-SFT00001-GW_Enable_CAN_Timeout_DTC-Engine Control Module 1,Enabled ,32
ENG137058-SFT00002-GW_Enable_CAN_Timeout_DTC-Transmission Control Module,Enabled ,32
ENG137058-SFT00003-GW_Enable_CAN_Timeout_DTC-Brakes 1,not enabled ,32
ENG137058-SFT00006-GW_Enable_CAN_Timeout_DTC-Seat Adjustment Passenger Side,Enabled ,32
ENG137058-SFT00008-GW_Enable_CAN_Timeout_DTC-Air Conditioning,Enabled ,32
ENG137058-SFT00009-GW_Enable_CAN_Timeout_DTC-Central Electrics,Enabled ,32
ENG137058-SFT00011-GW_Enable_CAN_Timeout_DTC-Auxiliary Air Heater,Enabled ,32
ENG137058-SFT00014-GW_Enable_CAN_Timeout_DTC-Media Player Position 1,Enabled ,32
ENG137058-SFT00019-GW_Enable_CAN_Timeout_DTC-Adaptive Cruise Control,Enabled ,32
ENG137058-SFT00020-GW_Enable_CAN_Timeout_DTC-Wheel Dampening Electronics,Enabled ,32
ENG137058-SFT00021-GW_Enable_CAN_Timeout_DTC-Airbag,not enabled ,32
ENG137058-SFT00022-GW_Enable_CAN_Timeout_DTC-Steering Column Electronics,Enabled ,32
ENG137058-SFT00023-GW_Enable_CAN_Timeout_DTC-Dash Board,Enabled ,32
ENG137058-SFT00024-GW_Enable_CAN_Timeout_DTC-Auxiliary Parking Heater,Enabled ,32
ENG137058-SFT00025-GW_Enable_CAN_Timeout_DTC-Gateway,Enabled ,32
ENG137058-SFT00028-GW_Enable_CAN_Timeout_DTC-Vehicle Position Detection,Enabled ,32
ENG137058-SFT00032-GW_Enable_CAN_Timeout_DTC-High Beam Assistance,Enabled ,32
ENG137058-SFT00034-GW_Enable_CAN_Timeout_DTC-All Wheel Control,Enabled ,32
ENG137058-SFT00035-GW_Enable_CAN_Timeout_DTC-Brake Boost,Enabled ,32
ENG137058-SFT00038-GW_Enable_CAN_Timeout_DTC-Electronic Roof Control,Enabled ,32
ENG137058-SFT00043-GW_Enable_CAN_Timeout_DTC-Steering Column Locking,Enabled ,32
ENG137058-SFT00048-GW_Enable_CAN_Timeout_DTC-Special Function 2,Enabled ,32
ENG137058-SFT00050-GW_Enable_CAN_Timeout_DTC-Lock Electronics,Enabled ,32
ENG137058-SFT00054-GW_Enable_CAN_Timeout_DTC-Seat Adjustment Driver Side,Enabled ,32
ENG137058-SFT00060-GW_Enable_CAN_Timeout_DTC-Lane Change Assistant,Enabled ,32
ENG137058-SFT00061-GW_Enable_CAN_Timeout_DTC-Special Function,Enabled ,32
ENG137058-SFT00064-GW_Enable_CAN_Timeout_DTC-Air Conditioning Compressor,Enabled ,32
ENG137058-SFT00066-GW_Enable_CAN_Timeout_DTC-Door Electronics Driver Side,Enabled ,32
ENG137058-SFT00068-GW_Enable_CAN_Timeout_DTC-Steering Assistance,Enabled ,32
ENG137058-SFT00071-GW_Enable_CAN_Timeout_DTC-Sound System,Enabled ,32
ENG137058-SFT00075-GW_Enable_CAN_Timeout_DTC-Multifunction module,Enabled ,32
ENG137058-SFT00081-GW_Enable_CAN_Timeout_DTC-Drive Motor Control Module,Enabled ,32
ENG137058-SFT00082-GW_Enable_CAN_Timeout_DTC-Door Electronics Passenger Side,Enabled ,32
ENG137058-SFT00085-GW_Enable_CAN_Timeout_DTC-Headlight Regulation,Enabled ,32
ENG137058-SFT00086-GW_Enable_CAN_Timeout_DTC-Radio,Enabled ,32
ENG137058-SFT00087-GW_Enable_CAN_Timeout_DTC-TV Tuner,Enabled ,32
ENG137058-SFT00095-GW_Enable_CAN_Timeout_DTC-Information Control Unit 1,Enabled ,32
ENG137058-SFT00096-GW_Enable_CAN_Timeout_DTC-Tachograph,Enabled ,32
ENG137058-SFT00101-GW_Enable_CAN_Timeout_DTC-Tire Pressure Monitoring 1,Enabled ,32
ENG137058-SFT00105-GW_Enable_CAN_Timeout_DTC-Trailer Function,Enabled ,32
ENG137058-SFT00108-GW_Enable_CAN_Timeout_DTC-Camera System Rear View,Enabled ,32
ENG137058-SFT00109-GW_Enable_CAN_Timeout_DTC-Deck Lid Control Unit,Enabled ,32
ENG137058-SFT00117-GW_Enable_CAN_Timeout_DTC-Telematics Communication Unit,Enabled ,32
ENG137058-SFT00118-GW_Enable_CAN_Timeout_DTC-Parking Assistance,Enabled ,32
ENG137058-SFT00128-GW_Enable_CAN_Timeout_DTC-Battery Regulation Auxiliary Accumulator 1,Enabled ,32
ENG137058-SFT00130-GW_Enable_CAN_Timeout_DTC-Head Up Display,Enabled ,32
ENG137058-SFT00140-GW_Enable_CAN_Timeout_DTC-Battery Energy Control Module,Enabled ,32
ENG137058-SFT00165-GW_Enable_CAN_Timeout_DTC-Front Sensors Driver Assistance System,Enabled ,32
ENG137058-SFT00166-GW_Enable_CAN_Timeout_DTC-Microphone Control Unit,Enabled ,32
ENG137058-SFT00169-GW_Enable_CAN_Timeout_DTC-Actuator For Structure-borne Sound,Enabled ,32
ENG137058-SFT00183-GW_Enable_CAN_Timeout_DTC-Access Startsystem Interface,Enabled ,32
ENG137058-SFT00187-GW_Enable_CAN_Timeout_DTC-Door Electronics Rear Driver Side,Enabled ,32
ENG137058-SFT00188-GW_Enable_CAN_Timeout_DTC-Door Electronics Rear Passenger Side,Enabled ,32
ENG137058-SFT00189-GW_Enable_CAN_Timeout_DTC-High Voltage Battery Charge Management,Enabled ,32
ENG137058-SFT00190-GW_Enable_CAN_Timeout_DTC-Sliding Door Rear Left,Enabled ,32
ENG137058-SFT00191-GW_Enable_CAN_Timeout_DTC-Sliding Door Rear Right,Enabled ,32
ENG137058-SFT00192-GW_Enable_CAN_Timeout_DTC-Actuator For Exterior Noise,Enabled ,32
ENG137058-SFT00197-GW_Enable_CAN_Timeout_DTC-Thermal management,Enabled ,32
ENG137058-SFT00198-GW_Enable_CAN_Timeout_DTC-Battery Charger Control Module,Enabled ,32
ENG137058-SFT00202-GW_Enable_CAN_Timeout_DTC-Control module for sunroof,Enabled ,32
ENG137058-SFT00207-GW_Enable_CAN_Timeout_DTC-Control Unit Lane Change Assistant 2,Enabled ,32
ENG137058-ENG118664-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x00,Enabled ,32
ENG137058-ENG118466-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x01,Enabled ,32
ENG137058-ENG118467-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x02,Enabled ,32
ENG137058-ENG118468-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x03,Enabled ,32
ENG137058-ENG118469-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x04,Enabled ,32
ENG137058-ENG118470-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x05,Enabled ,32
ENG137058-ENG118471-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x06,Enabled ,32
ENG137058-ENG118472-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x07,Enabled ,32
ENG137058-ENG118473-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x08,Enabled ,32
ENG137058-ENG118474-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x09,Enabled ,32
ENG137058-ENG118475-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x0D,Enabled ,32
ENG137058-ENG118476-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x11,Enabled ,32
ENG137058-ENG118477-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x16,Enabled ,32
ENG137058-ENG118478-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x17,Enabled ,32
ENG137058-ENG118479-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1A,Enabled ,32
ENG137058-ENG118481-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1D,Enabled ,32
ENG137058-ENG118482-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1F,Enabled ,32
ENG137058-ENG118483-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x20,Enabled ,32
ENG137058-ENG118484-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x21,Enabled ,32
ENG137058-ENG118485-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x22,Enabled ,32
ENG137058-ENG118486-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x24,Enabled ,32
ENG137058-ENG118487-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x25,Enabled ,32
ENG137058-ENG118488-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x26,Enabled ,32
ENG137058-ENG118489-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x27,Enabled ,32
ENG137058-ENG118490-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x28,Enabled ,32
ENG137058-ENG118491-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x29,Enabled ,32
ENG137058-ENG118492-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2A,Enabled ,32
ENG137058-ENG118493-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2E,Enabled ,32
ENG137058-ENG118494-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2F,Enabled ,32
ENG137058-ENG118495-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x35,Enabled ,32
ENG137058-ENG118496-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x36,Enabled ,32
ENG137058-ENG118497-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x37,Enabled ,32
ENG137058-ENG118498-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x38,Enabled ,32
ENG137058-ENG118499-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x39,Enabled ,32
ENG137058-ENG118500-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3A,Enabled ,32
ENG137058-ENG118501-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3C,Enabled ,32
ENG137058-ENG118502-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3D,Enabled ,32
ENG137058-ENG118503-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x40,Enabled ,32
ENG137058-ENG118504-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x41,Enabled ,32
ENG137058-ENG118505-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x43,Enabled ,32
ENG137058-ENG118506-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x45,Enabled ,32
ENG137058-ENG118507-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x48,Enabled ,32
ENG137058-ENG118508-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x49,Enabled ,32
ENG137058-ENG118509-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x51,Enabled ,32
ENG137058-ENG118510-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x52,Enabled ,32
ENG137058-ENG118511-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x53,Enabled ,32
ENG137058-ENG118512-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x55,Enabled ,32
ENG137058-ENG118513-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x56,Enabled ,32
ENG137058-ENG118514-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x58,Enabled ,32
ENG137058-ENG118515-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x59,Enabled ,32
ENG137058-ENG118516-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5A,Enabled ,32
ENG137058-ENG118517-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5B,Enabled ,32
ENG137058-ENG118518-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5C,Enabled ,32
ENG137058-ENG118519-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5D,Enabled ,32
ENG137058-ENG118520-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5E,Enabled ,32
ENG137058-ENG118521-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5F,Enabled ,32
ENG137058-ENG118522-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x60,Enabled ,32
ENG137058-ENG118523-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x61,Enabled ,32
ENG137058-ENG118524-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x62,Enabled ,32
ENG137058-ENG118525-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x66,Enabled ,32
ENG137058-ENG118526-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x68,Enabled ,32
ENG137058-ENG118527-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6B,Enabled ,32
ENG137058-ENG118528-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6C,Enabled ,32
ENG137058-ENG118529-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6E,Enabled ,32
ENG137058-ENG118530-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x74,Enabled ,32
ENG137058-ENG118531-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x75,Enabled ,32
ENG137058-ENG118532-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x78,Enabled ,32
ENG137058-ENG118533-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x79,Enabled ,32
ENG137058-ENG118534-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7A,Enabled ,32
ENG137058-ENG118535-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7D,Enabled ,32
ENG137058-ENG118536-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7E,Enabled ,32
ENG137058-ENG118537-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7F,Enabled ,32
ENG137058-ENG118538-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x80,Enabled ,32
ENG137058-ENG118539-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x81,Enabled ,32
ENG137058-ENG118540-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x82,Enabled ,32
ENG137058-ENG118541-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x83,Enabled ,32
ENG137058-ENG118542-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x85,Enabled ,32
ENG137058-ENG118543-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x86,Enabled ,32
ENG137058-ENG118544-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x87,Enabled ,32
ENG137058-ENG118545-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x88,Enabled ,32
ENG137058-ENG118546-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x89,Enabled ,32
ENG137058-ENG118547-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8B,Enabled ,32
ENG137058-ENG118548-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8C,Enabled ,32
ENG137058-ENG118549-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8D,Enabled ,32
ENG137058-ENG118550-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8E,Enabled ,32
ENG137058-ENG118551-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8F,Enabled ,32
ENG137058-ENG118552-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x90,Enabled ,32
ENG137058-ENG118553-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x91,Enabled ,32
ENG137058-ENG118554-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x92,Enabled ,32
ENG137058-ENG118555-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x93,Enabled ,32
ENG137058-ENG118556-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x94,Enabled ,32
ENG137058-ENG118557-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x95,Enabled ,32
ENG137058-ENG118558-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x96,Enabled ,32
ENG137058-ENG118559-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x97,Enabled ,32
ENG137058-ENG118560-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x98,Enabled ,32
ENG137058-ENG118561-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x99,Enabled ,32
ENG137058-ENG118562-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9A,Enabled ,32
ENG137058-ENG118563-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9B,Enabled ,32
ENG137058-ENG118564-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9C,Enabled ,32
ENG137058-ENG118565-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9D,Enabled ,32
ENG137058-ENG118566-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9E,Enabled ,32
ENG137058-ENG118567-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9F,Enabled ,32
ENG137058-ENG118568-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA0,Enabled ,32
ENG137058-ENG118569-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA1,Enabled ,32
ENG137058-ENG118570-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA2,Enabled ,32
ENG137058-ENG118571-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA3,Enabled ,32
ENG137058-ENG118573-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA5,Enabled ,32
ENG137058-ENG118574-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA6,Enabled ,32
ENG137058-ENG118575-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA7,Enabled ,32
ENG137058-ENG118576-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA8,Enabled ,32
ENG137058-ENG118578-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAA,Enabled ,32
ENG137058-ENG118579-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAB,Enabled ,32
ENG137058-ENG118580-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAC,Enabled ,32
ENG137058-ENG118581-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAD,Enabled ,32
ENG137058-ENG118583-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAF,Enabled ,32
ENG137058-ENG118584-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB0,Enabled ,32
ENG137058-ENG118585-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB1,Enabled ,32
ENG137058-ENG118586-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB2,Enabled ,32
ENG137058-ENG118587-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB3,Enabled ,32
ENG137058-ENG118588-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB4,Enabled ,32
ENG137058-ENG118589-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB5,Enabled ,32
ENG137058-ENG118590-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB6,Enabled ,32
ENG137058-ENG118591-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB7,Enabled ,32
ENG137058-ENG118592-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB8,Enabled ,32
ENG137058-ENG118593-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB9,Enabled ,32
ENG137058-ENG118594-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBA,Enabled ,32
ENG137058-ENG118595-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBB,Enabled ,32
ENG137058-ENG118596-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBC,Enabled ,32
ENG137058-ENG118597-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBD,Enabled ,32
ENG137058-ENG118598-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBE,Enabled ,32
ENG137058-ENG118599-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBF,Enabled ,32
ENG137058-ENG118600-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC0,Enabled ,32
ENG137058-ENG118601-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC1,Enabled ,32
ENG137058-ENG118602-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC2,Enabled ,32
ENG137058-ENG118603-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC3,Enabled ,32
ENG137058-ENG118604-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC4,Enabled ,32
ENG137058-ENG118605-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC5,Enabled ,32
ENG137058-ENG118606-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC6,Enabled ,32
ENG137058-ENG118607-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC7,Enabled ,32
ENG137058-ENG118608-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC8,Enabled ,32
ENG137058-ENG118609-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC9,Enabled ,32
ENG137058-ENG118610-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCA,Enabled ,32
ENG137058-ENG118611-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCB,Enabled ,32
ENG137058-ENG118612-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCC,Enabled ,32
ENG137058-ENG118613-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCD,Enabled ,32
ENG137058-ENG118614-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCE,Enabled ,32
ENG137058-ENG118615-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCF,Enabled ,32
ENG137058-ENG118616-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD0,Enabled ,32
ENG137058-ENG118617-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD1,Enabled ,32
ENG137058-ENG118618-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD2,Enabled ,32
ENG137058-ENG118619-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD3,Enabled ,32
ENG137058-ENG118620-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD4,Enabled ,32
ENG137058-ENG118621-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD5,Enabled ,32
ENG137058-ENG118622-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD6,Enabled ,32
ENG137058-ENG118623-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD7,Enabled ,32
ENG137058-ENG118624-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD8,Enabled ,32
ENG137058-ENG118625-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD9,Enabled ,32
ENG137058-ENG118626-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDA,Enabled ,32
ENG137058-ENG118627-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDB,Enabled ,32
ENG137058-ENG118628-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDC,Enabled ,32
ENG137058-ENG118629-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDD,Enabled ,32
ENG137058-ENG118630-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDE,Enabled ,32
ENG137058-ENG118631-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDF,Enabled ,32
ENG137058-ENG118632-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE0,Enabled ,32
ENG137058-ENG118633-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE1,Enabled ,32
ENG137058-ENG118634-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE2,Enabled ,32
ENG137058-ENG118635-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE3,Enabled ,32
ENG137058-ENG118636-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE4,Enabled ,32
ENG137058-ENG118637-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE5,Enabled ,32
ENG137058-ENG118638-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE6,Enabled ,32
ENG137058-ENG118639-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE7,Enabled ,32
ENG137058-ENG118640-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE8,Enabled ,32
ENG137058-ENG118641-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE9,Enabled ,32
ENG137058-ENG118642-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEA,Enabled ,32
ENG137058-ENG118643-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEB,Enabled ,32
ENG137058-ENG118644-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEC,Enabled ,32
ENG137058-ENG118645-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xED,Enabled ,32
ENG137058-ENG118646-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEE,Enabled ,32
ENG137058-ENG118647-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEF,Enabled ,32
ENG137058-ENG118648-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF0,Enabled ,32
ENG137058-ENG118649-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF1,Enabled ,32
ENG137058-ENG118650-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF2,Enabled ,32
ENG137058-ENG118651-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF3,Enabled ,32
ENG137058-ENG118652-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF4,Enabled ,32
ENG137058-ENG118653-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF5,Enabled ,32
ENG137058-ENG118654-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF6,Enabled ,32
ENG137058-ENG118655-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF7,Enabled ,32
ENG137058-ENG118656-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF8,Enabled ,32
ENG137058-ENG118657-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF9,Enabled ,32
ENG137058-ENG118658-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFA,Enabled ,32
ENG137058-ENG118659-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFB,Enabled ,32
ENG137058-ENG118660-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFC,Enabled ,32
ENG137058-ENG118661-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFD,Enabled ,32
ENG137058-ENG118662-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFE,Enabled ,32
ENG137058-ENG118663-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFF,Enabled ,32
ENG137059-ENG118464-GW_mirror_mode-mirror_mode_bus,Databus drivetrain ,2
ENG137059-ENG118465-GW_mirror_mode-mirror_mode_typ,not active ,2
ENG137065-GW_routing_0,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137066-GW_routing_1,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137067-GW_routing_2,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137068-GW_routing_3,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137069-GW_routing_4,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137070-GW_routing_5,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137071-GW_routing_6,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137072-GW_routing_7,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137073-GW_routing_8,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137074-GW_routing_9,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG118774-ENG98345-WakeUpMonitor_Activation-Activation,activated ,1
ENG118774-ENG152567-WakeUpMonitor_Activation-Open_Filter_Activate,not activated ,1
ENG118773-ENG99074-WakeUpMonitor_Configuration-Max_Num_Keeping_Awake_Events,100 ,5
ENG118773-ENG103852-WakeUpMonitor_Configuration-Sample_Time_Keeping_Awake_Events,12 s,5
ENG118773-ENG127936-WakeUpMonitor_Configuration-WakeUpMonitor_Start_Delay,0 s,5
Elapsed Time: 00:22
After
Monday,22,January,2018,09:05:21:44043
VCDS Version: 17.8.1.0 (x64) HEX-NET CB: 0.4407.4
Dealer/Shop Name: Tarfor OÜ
VIN: WVWZZZAUZGP License Plate: MMN-366
Mileage: 20394km-12672mi Repair Order: 2612
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZGP Mileage: 20394km-12672miles
Address 01: Engine (J623-CYVA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 027 GP HW: 04E 907 309 BL
Component: R4 1.2l TFS H23 2396
Revision: R4H23---
Coding: 01110012232415082000
Shop #: WSC 63672 002 1048576
ASAM Dataset: EV_ECM12TFS01104E906027GP 001005
ROD: EV_ECM12TFS01104E906027GR.rod
VCID: 78BC3A19C37F4086A9-802C
CAN Converter 01:
Readiness: 1110 0001
Part No SW: 3Q0 907 379 AA HW: 3Q0 907 379 F
Component: ESC H42 0623
Revision: 00000000 Serial number: 90766000013395
Coding: 01FA6AA1142129700777060741CC2580562894E06082A4F300200078C008
Shop #: WSC 00028 028 00025
VCID: 79BA3F1DF875598ED6-802C
Part No SW: 5G0 907 426 AA HW: 5G0 907 426 AA
Component: AC Manuell H02 1001
Revision: 00001K06
Coding: 00020004200100001000000000000002
ROD: EV_ACManueBHBVW37X_003.rod
VCID: 6A9810518DD3E2162F-803E
Part No SW: 5Q0 937 084 CL HW: 5Q0 937 084 AN
Component: BCM MQBAB H H24 0175
Serial number: 01061609102279
Coding: 00000846C24100534BE44000001C07081000000000000000000000000000
ROD: EV_BCMBOSCH_015_VW37.rod
VCID: 04445EE98FB71466B5-8050
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 160320 043 0551
Serial number: 160330015519
787462 - Relay for Headlight Washer System
B1262 15 [009] - Open or Short to Plus
Reset counter: 123
Mileage: 20394 km
Date: 2018.01.22
Time: 08:51:20
Part No SW: 5Q0 959 655 D HW: 5Q0 959 655 D
Component: AirbagVW20 015 0388
Serial number: 003F6R1LZT19
Shop #: WSC 00028 028 00012
VCID: 41CA97FDD025C14EDE-8014
Subsystem 1 - Part No SW: ----------- HW: 480 000 404 16
Serial number: 357670000001411CA91O
Subsystem 2 - Part No SW: ----------- HW: 480 000 404 16
Serial number: 35867000000AD41CA913
Subsystem 3 - Part No SW: ----------- HW: 480 400 504 16
Serial number: 3516502B120414F1635W
Subsystem 4 - Part No SW: ----------- HW: 480 400 404 16
Serial number: 3526502BB1FA34204222
Subsystem 5 - Part No SW: ----------- HW: 480 400 104 16
Serial number: 35565029F20414F460FF
Address 16: Steering wheel (J527) Labels:. 5Q0-953-549.clb
Part No SW: 5Q0 953 507 GB HW: 5Q0 953 549 F
Component: Lenks. Modul 003 0120
Revision: -------- Serial number: 30031604401139
Coding: 1604
ASAM Dataset: EV_SMLSKLOMQB 020001
VCID: 7CB42609F7476CA6CD-8028
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb
Part No SW: 5G1 920 730 A HW: 5G1 920 730 A
Component: KOMBI 102 6420
Coding: 07A4020023000008010808000400000000000000
VCID: 23063D752A79F35EAC-8076
Part No SW: 5Q0 907 530 AG HW: 5Q0 907 530 K
Component: GW MQB Low 210 2246
Revision: -------- Serial number: 27031610802138
Coding: 030000043F085700FB000048080E00010001050000000000000000000000
ROD: EV_GatewConti_013_VW37.rod
VCID: 76A03421C96B36F6BB-8022
Subsystem 2 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Component: J367-BDMHella H04 8050
Serial number: 9114489003
Part No SW: 5Q4 959 393 E HW: 5Q4 959 393 B
Component: TSG FS 010 0031
Serial number: 0000194620501
Coding: 003003208000020000001000
VCID: 45C283EDC40DED6EE2-8010
Serial number: 00000000000012473337
Part No SW: 3Q0 909 144 F HW: 3Q0 909 144 F
Component: EPS_MQB_ZFLS 503 5043
Coding: 0103
Shop #: WSC 73430 790 00121
ROD: EV_SteerAssisMQB_010.rod
VCID: 3522F32D94ED7DEE72-8060
Part No SW: 5Q4 959 392 E HW: 5Q4 959 392 B
Component: TSG BFS 010 0031
Serial number: 0000194631951
Coding: 003001208000020000801000
VCID: 44C49EE9CF37D466F5-8010
Serial number: 00000000000012483026
Coding: 090000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
Part No SW: 5G0 035 867 C HW: 5G0 035 867 C
Component: MU-E--ER 851 6490
Serial number: 18031600011439
Coding: 02730000FF0000004011000100000000000000040000010000
ASAM Dataset: EV_MUEnt4CGen2LGE 001025
VCID: 2C14D64947A73C261D-8078
End(Elapsed Time: 08:40, VBatt start/end: 12.1V/12.0V. VIgn 12.0V, Deb=2)--
19
;SW:5Q0-907-530-AG HW:5Q0-907-530-K --- CAN Gateway
;Component:GW MQB Low 210 2246, Coding:030000043F085700FB000048080E00010001050000000000000000000000
;EV_GatewConti,013020,EV_GatewConti_013_VW37.rod
;Monday,22,January,2018,08:57:12:44043
;VCDS Version: Release 17.8.1 (x64) Data version: 20171130 DS276.6
;VCID: 76A03421C96B36F6BB-8022
IDE00001-ENG124491-Production mode-p_mode_deactivate_mfl_keys,Deactivating ,3
IDE00001-ENG118694-Production mode-p_mode_deactivate_recuperation,Deactivating ,3
IDE00002-Transport mode,not active ,1
IDE00945-ENG118688-Hysteresis voltage-Voltage_elevation,12.1 V,2
IDE00945-ENG118687-Hysteresis voltage-Voltage_lowering,12.1 V,2
IDE01211-Static current measuring mode,not activated ,1
IDE01457-Energy management deactivation stage,Mode not active ,1
IDE01459-Energy management heat output control status,Mode not active ,1
IDE01844-Increase idle speed request,Mode not active ,1
IDE01847-ENG118685-Auxiliary heater activation restriction request-Set_point_target_time,-- ,3
IDE01847-ENG118684-Auxiliary heater activation restriction request-Switch_on_ban_activation,Mode not active ,3
IDE01860-Generator specified voltage value variable,10.6 V,1
IDE01996-SFT00001-Installation list: specified installations-Engine Control Module 1,coded ,32
IDE01996-SFT00002-Installation list: specified installations-Transmission Control Module,Not coded ,32
IDE01996-SFT00003-Installation list: specified installations-Brakes 1,coded ,32
IDE01996-SFT00006-Installation list: specified installations-Seat Adjustment Passenger Side,Not coded ,32
IDE01996-SFT00008-Installation list: specified installations-Air Conditioning,coded ,32
IDE01996-SFT00009-Installation list: specified installations-Central Electrics,coded ,32
IDE01996-SFT00011-Installation list: specified installations-Auxiliary Air Heater,Not coded ,32
IDE01996-SFT00014-Installation list: specified installations-Media Player Position 1,Not coded ,32
IDE01996-SFT00019-Installation list: specified installations-Adaptive Cruise Control,Not coded ,32
IDE01996-SFT00020-Installation list: specified installations-Wheel Dampening Electronics,Not coded ,32
IDE01996-SFT00021-Installation list: specified installations-Airbag,coded ,32
IDE01996-SFT00022-Installation list: specified installations-Steering Column Electronics,coded ,32
IDE01996-SFT00023-Installation list: specified installations-Dash Board,coded ,32
IDE01996-SFT00024-Installation list: specified installations-Auxiliary Parking Heater,Not coded ,32
IDE01996-SFT00025-Installation list: specified installations-Gateway,1 ,32
IDE01996-SFT00028-Installation list: specified installations-Vehicle Position Detection,Not coded ,32
IDE01996-SFT00032-Installation list: specified installations-High Beam Assistance,Not coded ,32
IDE01996-SFT00034-Installation list: specified installations-All Wheel Control,Not coded ,32
IDE01996-SFT00035-Installation list: specified installations-Brake Boost,Not coded ,32
IDE01996-SFT00038-Installation list: specified installations-Electronic Roof Control,Not coded ,32
IDE01996-SFT00043-Installation list: specified installations-Steering Column Locking,Not coded ,32
IDE01996-SFT00048-Installation list: specified installations-Special Function 2,Not coded ,32
IDE01996-SFT00050-Installation list: specified installations-Lock Electronics,Not coded ,32
IDE01996-SFT00054-Installation list: specified installations-Seat Adjustment Driver Side,Not coded ,32
IDE01996-SFT00060-Installation list: specified installations-Lane Change Assistant,Not coded ,32
IDE01996-SFT00061-Installation list: specified installations-Special Function,Not coded ,32
IDE01996-SFT00064-Installation list: specified installations-Air Conditioning Compressor,Not coded ,32
IDE01996-SFT00066-Installation list: specified installations-Door Electronics Driver Side,coded ,32
IDE01996-SFT00068-Installation list: specified installations-Steering Assistance,coded ,32
IDE01996-SFT00071-Installation list: specified installations-Sound System,Not coded ,32
IDE01996-SFT00075-Installation list: specified installations-Multifunction module,Not coded ,32
IDE01996-SFT00081-Installation list: specified installations-Drive Motor Control Module,Not coded ,32
IDE01996-SFT00082-Installation list: specified installations-Door Electronics Passenger Side,coded ,32
IDE01996-SFT00085-Installation list: specified installations-Headlight Regulation,Not coded ,32
IDE01996-SFT00086-Installation list: specified installations-Radio,Not coded ,32
IDE01996-SFT00087-Installation list: specified installations-TV Tuner,Not coded ,32
IDE01996-SFT00095-Installation list: specified installations-Information Control Unit 1,coded ,32
IDE01996-SFT00096-Installation list: specified installations-Tachograph,Not coded ,32
IDE01996-SFT00101-Installation list: specified installations-Tire Pressure Monitoring 1,Not coded ,32
IDE01996-SFT00105-Installation list: specified installations-Trailer Function,Not coded ,32
IDE01996-SFT00108-Installation list: specified installations-Camera System Rear View,Not coded ,32
IDE01996-SFT00109-Installation list: specified installations-Deck Lid Control Unit,Not coded ,32
IDE01996-SFT00117-Installation list: specified installations-Telematics Communication Unit,Not coded ,32
IDE01996-SFT00118-Installation list: specified installations-Parking Assistance,Not coded ,32
IDE01996-SFT00128-Installation list: specified installations-Battery Regulation Auxiliary Accumulator 1,Not coded ,32
IDE01996-SFT00130-Installation list: specified installations-Head Up Display,Not coded ,32
IDE01996-SFT00140-Installation list: specified installations-Battery Energy Control Module,Not coded ,32
IDE01996-SFT00165-Installation list: specified installations-Front Sensors Driver Assistance System,Not coded ,32
IDE01996-SFT00166-Installation list: specified installations-Microphone Control Unit,Not coded ,32
IDE01996-SFT00169-Installation list: specified installations-Actuator For Structure-borne Sound,Not coded ,32
IDE01996-SFT00183-Installation list: specified installations-Access Startsystem Interface,Not coded ,32
IDE01996-SFT00187-Installation list: specified installations-Door Electronics Rear Driver Side,Not coded ,32
IDE01996-SFT00188-Installation list: specified installations-Door Electronics Rear Passenger Side,Not coded ,32
IDE01996-SFT00189-Installation list: specified installations-High Voltage Battery Charge Management,Not coded ,32
IDE01996-SFT00190-Installation list: specified installations-Sliding Door Rear Left,Not coded ,32
IDE01996-SFT00191-Installation list: specified installations-Sliding Door Rear Right,Not coded ,32
IDE01996-SFT00192-Installation list: specified installations-Actuator For Exterior Noise,Not coded ,32
IDE01996-SFT00197-Installation list: specified installations-Thermal management,Not coded ,32
IDE01996-SFT00198-Installation list: specified installations-Battery Charger Control Module,Not coded ,32
IDE01996-SFT00202-Installation list: specified installations-Control module for sunroof,Not coded ,32
IDE01996-SFT00207-Installation list: specified installations-Control Unit Lane Change Assistant 2,Not coded ,32
IDE01996-ENG118226-Installation list: specified installations-Node_0x01,Not coded ,32
IDE01996-ENG118227-Installation list: specified installations-Node_0x02,Not coded ,32
IDE01996-ENG118228-Installation list: specified installations-Node_0x03,Not coded ,32
IDE01996-ENG118229-Installation list: specified installations-Node_0x04,Not coded ,32
IDE01996-ENG118230-Installation list: specified installations-Node_0x05,Not coded ,32
IDE01996-ENG118231-Installation list: specified installations-Node_0x06,Not coded ,32
IDE01996-ENG118232-Installation list: specified installations-Node_0x07,Not coded ,32
IDE01996-ENG118233-Installation list: specified installations-Node_0x08,Not coded ,32
IDE01996-ENG118234-Installation list: specified installations-Node_0x09,Not coded ,32
IDE01996-ENG118235-Installation list: specified installations-Node_0x0D,Not coded ,32
IDE01996-ENG118236-Installation list: specified installations-Node_0x11,Not coded ,32
IDE01996-ENG118237-Installation list: specified installations-Node_0x16,Not coded ,32
IDE01996-ENG118238-Installation list: specified installations-Node_0x17,Not coded ,32
IDE01996-ENG118239-Installation list: specified installations-Node_0x1A,Not coded ,32
IDE01996-ENG118241-Installation list: specified installations-Node_0x1D,Not coded ,32
IDE01996-ENG118242-Installation list: specified installations-Node_0x1F,Not coded ,32
IDE01996-ENG118243-Installation list: specified installations-Node_0x20,Not coded ,32
IDE01996-ENG118244-Installation list: specified installations-Node_0x21,Not coded ,32
IDE01996-ENG118245-Installation list: specified installations-Node_0x22,Not coded ,32
IDE01996-ENG118246-Installation list: specified installations-Node_0x24,Not coded ,32
IDE01996-ENG118247-Installation list: specified installations-Node_0x25,Not coded ,32
IDE01996-ENG118248-Installation list: specified installations-Node_0x26,Not coded ,32
IDE01996-ENG118249-Installation list: specified installations-Node_0x27,Not coded ,32
IDE01996-ENG118250-Installation list: specified installations-Node_0x28,Not coded ,32
IDE01996-ENG118251-Installation list: specified installations-Node_0x29,Not coded ,32
IDE01996-ENG118252-Installation list: specified installations-Node_0x2A,Not coded ,32
IDE01996-ENG118253-Installation list: specified installations-Node_0x2E,Not coded ,32
IDE01996-ENG118254-Installation list: specified installations-Node_0x2F,Not coded ,32
IDE01996-ENG118255-Installation list: specified installations-Node_0x35,Not coded ,32
IDE01996-ENG118256-Installation list: specified installations-Node_0x36,Not coded ,32
IDE01996-ENG118257-Installation list: specified installations-Node_0x37,Not coded ,32
IDE01996-ENG118258-Installation list: specified installations-Node_0x38,Not coded ,32
IDE01996-ENG118259-Installation list: specified installations-Node_0x39,Not coded ,32
IDE01996-ENG118260-Installation list: specified installations-Node_0x3A,Not coded ,32
IDE01996-ENG118261-Installation list: specified installations-Node_0x3C,Not coded ,32
IDE01996-ENG118262-Installation list: specified installations-Node_0x3D,Not coded ,32
IDE01996-ENG118263-Installation list: specified installations-Node_0x40,Not coded ,32
IDE01996-ENG118264-Installation list: specified installations-Node_0x41,Not coded ,32
IDE01996-ENG118265-Installation list: specified installations-Node_0x43,Not coded ,32
IDE01996-ENG118266-Installation list: specified installations-Node_0x45,Not coded ,32
IDE01996-ENG118267-Installation list: specified installations-Node_0x48,Not coded ,32
IDE01996-ENG118268-Installation list: specified installations-Node_0x49,Not coded ,32
IDE01996-ENG118269-Installation list: specified installations-Node_0x51,Not coded ,32
IDE01996-ENG118270-Installation list: specified installations-Node_0x52,Not coded ,32
IDE01996-ENG118271-Installation list: specified installations-Node_0x53,Not coded ,32
IDE01996-ENG118272-Installation list: specified installations-Node_0x55,Not coded ,32
IDE01996-ENG118273-Installation list: specified installations-Node_0x56,Not coded ,32
IDE01996-ENG118274-Installation list: specified installations-Node_0x58,Not coded ,32
IDE01996-ENG118275-Installation list: specified installations-Node_0x59,Not coded ,32
IDE01996-ENG118276-Installation list: specified installations-Node_0x5A,Not coded ,32
IDE01996-ENG118277-Installation list: specified installations-Node_0x5B,Not coded ,32
IDE01996-ENG118278-Installation list: specified installations-Node_0x5C,Not coded ,32
IDE01996-ENG118279-Installation list: specified installations-Node_0x5D,Not coded ,32
IDE01996-ENG118280-Installation list: specified installations-Node_0x5E,Not coded ,32
IDE01996-ENG118281-Installation list: specified installations-Node_0x5F,Not coded ,32
IDE01996-ENG118282-Installation list: specified installations-Node_0x60,Not coded ,32
IDE01996-ENG118283-Installation list: specified installations-Node_0x61,Not coded ,32
IDE01996-ENG118284-Installation list: specified installations-Node_0x62,Not coded ,32
IDE01996-ENG118285-Installation list: specified installations-Node_0x66,Not coded ,32
IDE01996-ENG118286-Installation list: specified installations-Node_0x68,Not coded ,32
IDE01996-ENG118287-Installation list: specified installations-Node_0x6B,Not coded ,32
IDE01996-ENG118288-Installation list: specified installations-Node_0x6C,Not coded ,32
IDE01996-ENG118289-Installation list: specified installations-Node_0x6E,Not coded ,32
IDE01996-ENG118290-Installation list: specified installations-Node_0x74,Not coded ,32
IDE01996-ENG118291-Installation list: specified installations-Node_0x75,Not coded ,32
IDE01996-ENG118292-Installation list: specified installations-Node_0x78,Not coded ,32
IDE01996-ENG118293-Installation list: specified installations-Node_0x79,Not coded ,32
IDE01996-ENG118294-Installation list: specified installations-Node_0x7A,Not coded ,32
IDE01996-ENG118295-Installation list: specified installations-Node_0x7D,Not coded ,32
IDE01996-ENG118296-Installation list: specified installations-Node_0x7E,Not coded ,32
IDE01996-ENG118297-Installation list: specified installations-Node_0x7F,Not coded ,32
IDE01996-ENG118298-Installation list: specified installations-Node_0x80,Not coded ,32
IDE01996-ENG118299-Installation list: specified installations-Node_0x81,Not coded ,32
IDE01996-ENG118300-Installation list: specified installations-Node_0x82,Not coded ,32
IDE01996-ENG118301-Installation list: specified installations-Node_0x83,Not coded ,32
IDE01996-ENG118302-Installation list: specified installations-Node_0x85,Not coded ,32
IDE01996-ENG118303-Installation list: specified installations-Node_0x86,Not coded ,32
IDE01996-ENG118304-Installation list: specified installations-Node_0x87,Not coded ,32
IDE01996-ENG118305-Installation list: specified installations-Node_0x88,Not coded ,32
IDE01996-ENG118306-Installation list: specified installations-Node_0x89,Not coded ,32
IDE01996-ENG118307-Installation list: specified installations-Node_0x8B,Not coded ,32
IDE01996-ENG118308-Installation list: specified installations-Node_0x8C,Not coded ,32
IDE01996-ENG118309-Installation list: specified installations-Node_0x8D,Not coded ,32
IDE01996-ENG118310-Installation list: specified installations-Node_0x8E,Not coded ,32
IDE01996-ENG118311-Installation list: specified installations-Node_0x8F,Not coded ,32
IDE01996-ENG118312-Installation list: specified installations-Node_0x90,Not coded ,32
IDE01996-ENG118313-Installation list: specified installations-Node_0x91,Not coded ,32
IDE01996-ENG118314-Installation list: specified installations-Node_0x92,Not coded ,32
IDE01996-ENG118315-Installation list: specified installations-Node_0x93,Not coded ,32
IDE01996-ENG118316-Installation list: specified installations-Node_0x94,Not coded ,32
IDE01996-ENG118317-Installation list: specified installations-Node_0x95,Not coded ,32
IDE01996-ENG118318-Installation list: specified installations-Node_0x96,Not coded ,32
IDE01996-ENG118319-Installation list: specified installations-Node_0x97,Not coded ,32
IDE01996-ENG118320-Installation list: specified installations-Node_0x98,Not coded ,32
IDE01996-ENG118321-Installation list: specified installations-Node_0x99,Not coded ,32
IDE01996-ENG118322-Installation list: specified installations-Node_0x9A,Not coded ,32
IDE01996-ENG118323-Installation list: specified installations-Node_0x9B,Not coded ,32
IDE01996-ENG118324-Installation list: specified installations-Node_0x9C,Not coded ,32
IDE01996-ENG118325-Installation list: specified installations-Node_0x9D,Not coded ,32
IDE01996-ENG118326-Installation list: specified installations-Node_0x9E,Not coded ,32
IDE01996-ENG118327-Installation list: specified installations-Node_0x9F,Not coded ,32
IDE01996-ENG118328-Installation list: specified installations-Node_0xA0,Not coded ,32
IDE01996-ENG118329-Installation list: specified installations-Node_0xA1,Not coded ,32
IDE01996-ENG118330-Installation list: specified installations-Node_0xA2,Not coded ,32
IDE01996-ENG118331-Installation list: specified installations-Node_0xA3,Not coded ,32
IDE01996-ENG118333-Installation list: specified installations-Node_0xA5,Not coded ,32
IDE01996-ENG118334-Installation list: specified installations-Node_0xA6,Not coded ,32
IDE01996-ENG118335-Installation list: specified installations-Node_0xA7,Not coded ,32
IDE01996-ENG118336-Installation list: specified installations-Node_0xA8,Not coded ,32
IDE01996-ENG118338-Installation list: specified installations-Node_0xAA,Not coded ,32
IDE01996-ENG118339-Installation list: specified installations-Node_0xAB,Not coded ,32
IDE01996-ENG118340-Installation list: specified installations-Node_0xAC,Not coded ,32
IDE01996-ENG118341-Installation list: specified installations-Node_0xAD,Not coded ,32
IDE01996-ENG118343-Installation list: specified installations-Node_0xAF,Not coded ,32
IDE01996-ENG118344-Installation list: specified installations-Node_0xB0,Not coded ,32
IDE01996-ENG118345-Installation list: specified installations-Node_0xB1,Not coded ,32
IDE01996-ENG118346-Installation list: specified installations-Node_0xB2,Not coded ,32
IDE01996-ENG118347-Installation list: specified installations-Node_0xB3,Not coded ,32
IDE01996-ENG118348-Installation list: specified installations-Node_0xB4,Not coded ,32
IDE01996-ENG118349-Installation list: specified installations-Node_0xB5,Not coded ,32
IDE01996-ENG118350-Installation list: specified installations-Node_0xB6,Not coded ,32
IDE01996-ENG118351-Installation list: specified installations-Node_0xB7,Not coded ,32
IDE01996-ENG118352-Installation list: specified installations-Node_0xB8,Not coded ,32
IDE01996-ENG118353-Installation list: specified installations-Node_0xB9,Not coded ,32
IDE01996-ENG118354-Installation list: specified installations-Node_0xBA,Not coded ,32
IDE01996-ENG118355-Installation list: specified installations-Node_0xBB,Not coded ,32
IDE01996-ENG118356-Installation list: specified installations-Node_0xBC,Not coded ,32
IDE01996-ENG118357-Installation list: specified installations-Node_0xBD,Not coded ,32
IDE01996-ENG118358-Installation list: specified installations-Node_0xBE,Not coded ,32
IDE01996-ENG118359-Installation list: specified installations-Node_0xBF,Not coded ,32
IDE01996-ENG118360-Installation list: specified installations-Node_0xC0,Not coded ,32
IDE01996-ENG118361-Installation list: specified installations-Node_0xC1,Not coded ,32
IDE01996-ENG118362-Installation list: specified installations-Node_0xC2,Not coded ,32
IDE01996-ENG118363-Installation list: specified installations-Node_0xC3,Not coded ,32
IDE01996-ENG118364-Installation list: specified installations-Node_0xC4,Not coded ,32
IDE01996-ENG118365-Installation list: specified installations-Node_0xC5,Not coded ,32
IDE01996-ENG118366-Installation list: specified installations-Node_0xC6,Not coded ,32
IDE01996-ENG118367-Installation list: specified installations-Node_0xC7,Not coded ,32
IDE01996-ENG118368-Installation list: specified installations-Node_0xC8,Not coded ,32
IDE01996-ENG118369-Installation list: specified installations-Node_0xC9,Not coded ,32
IDE01996-ENG118370-Installation list: specified installations-Node_0xCA,Not coded ,32
IDE01996-ENG118371-Installation list: specified installations-Node_0xCB,Not coded ,32
IDE01996-ENG118372-Installation list: specified installations-Node_0xCC,Not coded ,32
IDE01996-ENG118373-Installation list: specified installations-Node_0xCD,Not coded ,32
IDE01996-ENG118374-Installation list: specified installations-Node_0xCE,Not coded ,32
IDE01996-ENG118375-Installation list: specified installations-Node_0xCF,Not coded ,32
IDE01996-ENG118376-Installation list: specified installations-Node_0xD0,Not coded ,32
IDE01996-ENG118377-Installation list: specified installations-Node_0xD1,Not coded ,32
IDE01996-ENG118378-Installation list: specified installations-Node_0xD2,Not coded ,32
IDE01996-ENG118379-Installation list: specified installations-Node_0xD3,Not coded ,32
IDE01996-ENG118380-Installation list: specified installations-Node_0xD4,Not coded ,32
IDE01996-ENG118381-Installation list: specified installations-Node_0xD5,Not coded ,32
IDE01996-ENG118382-Installation list: specified installations-Node_0xD6,Not coded ,32
IDE01996-ENG118383-Installation list: specified installations-Node_0xD7,Not coded ,32
IDE01996-ENG118384-Installation list: specified installations-Node_0xD8,Not coded ,32
IDE01996-ENG118385-Installation list: specified installations-Node_0xD9,Not coded ,32
IDE01996-ENG118386-Installation list: specified installations-Node_0xDA,Not coded ,32
IDE01996-ENG118387-Installation list: specified installations-Node_0xDB,Not coded ,32
IDE01996-ENG118388-Installation list: specified installations-Node_0xDC,Not coded ,32
IDE01996-ENG118389-Installation list: specified installations-Node_0xDD,Not coded ,32
IDE01996-ENG118390-Installation list: specified installations-Node_0xDE,Not coded ,32
IDE01996-ENG118391-Installation list: specified installations-Node_0xDF,Not coded ,32
IDE01996-ENG118392-Installation list: specified installations-Node_0xE0,Not coded ,32
IDE01996-ENG118393-Installation list: specified installations-Node_0xE1,Not coded ,32
IDE01996-ENG118394-Installation list: specified installations-Node_0xE2,Not coded ,32
IDE01996-ENG118395-Installation list: specified installations-Node_0xE3,Not coded ,32
IDE01996-ENG118396-Installation list: specified installations-Node_0xE4,Not coded ,32
IDE01996-ENG118397-Installation list: specified installations-Node_0xE5,Not coded ,32
IDE01996-ENG118398-Installation list: specified installations-Node_0xE6,Not coded ,32
IDE01996-ENG118399-Installation list: specified installations-Node_0xE7,Not coded ,32
IDE01996-ENG118400-Installation list: specified installations-Node_0xE8,Not coded ,32
IDE01996-ENG118401-Installation list: specified installations-Node_0xE9,Not coded ,32
IDE01996-ENG118402-Installation list: specified installations-Node_0xEA,Not coded ,32
IDE01996-ENG118403-Installation list: specified installations-Node_0xEB,Not coded ,32
IDE01996-ENG118404-Installation list: specified installations-Node_0xEC,Not coded ,32
IDE01996-ENG118405-Installation list: specified installations-Node_0xED,Not coded ,32
IDE01996-ENG118406-Installation list: specified installations-Node_0xEE,Not coded ,32
IDE01996-ENG118407-Installation list: specified installations-Node_0xEF,Not coded ,32
IDE01996-ENG118408-Installation list: specified installations-Node_0xF0,Not coded ,32
IDE01996-ENG118409-Installation list: specified installations-Node_0xF1,Not coded ,32
IDE01996-ENG118410-Installation list: specified installations-Node_0xF2,Not coded ,32
IDE01996-ENG118411-Installation list: specified installations-Node_0xF3,Not coded ,32
IDE01996-ENG118412-Installation list: specified installations-Node_0xF4,Not coded ,32
IDE01996-ENG118413-Installation list: specified installations-Node_0xF5,Not coded ,32
IDE01996-ENG118414-Installation list: specified installations-Node_0xF6,Not coded ,32
IDE01996-ENG118415-Installation list: specified installations-Node_0xF7,Not coded ,32
IDE01996-ENG118416-Installation list: specified installations-Node_0xF8,Not coded ,32
IDE01996-ENG118417-Installation list: specified installations-Node_0xF9,Not coded ,32
IDE01996-ENG118418-Installation list: specified installations-Node_0xFA,Not coded ,32
IDE01996-ENG118419-Installation list: specified installations-Node_0xFB,Not coded ,32
IDE01996-ENG118420-Installation list: specified installations-Node_0xFC,Not coded ,32
IDE01996-ENG118421-Installation list: specified installations-Node_0xFD,Not coded ,32
IDE01996-ENG118422-Installation list: specified installations-Node_0xFE,Not coded ,32
IDE01996-ENG118423-Installation list: specified installations-Node_0xFF,Not coded ,32
IDE02200-Component protection showroom mode,not active ,1
IDE03256-MAS06105-Battery adaptation-Rated battery capacity,59 Ah,15
IDE03256-MAS06106-Battery adaptation-Battery technology,EFB ,15
IDE03256-MAS06107-Battery adaptation-Battery manufacturer,JCB ,15
IDE03256-MAS06108-Battery adaptation-Battery Serial Number,1111111111 ,15
IDE03903-Production process data 1,00 03 ,2
IDE04159-Deactivation of start-stop function,Mode not active ,1
IDE04186-Battery terminal recognition,connected ,1
IDE04330-Transfer of release code for a SWaP function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
IDE06425-MAS06026-Roller test bench mode: functional-Activation stages,not activated ,1
IDE06425-MAS06277-Roller test bench mode: functional-Malfunction states,no error ,1
IDE06530-Distance left for deactivation of static current measuring mode,2 ,1
IDE06541-Distance left for deactivation of transport mode,50 ,1
IDE06753-MAS06278-Efficiency program display-Live tip air resistance: close window/sunroof,activated ,4
IDE06753-MAS06279-Efficiency program display-Live tip engine brake: uncouple not until below 1300 RPM,activated ,4
IDE06753-MAS06280-Efficiency program display-Live tip do not operate gas pedal during engine start,activated ,4
IDE06753-MAS06281-Efficiency program display-Live tip adhere to switch display (only manual switch),activated ,4
IDE06753-MAS06282-Efficiency program display-Live tip use start-stop-system,activated ,4
IDE06753-MAS06283-Efficiency program display-Live tip switch on start-stop-system,activated ,4
IDE06753-MAS06284-Efficiency program display-Live tip air conditioning: close window/sunroof,not activated ,4
IDE06753-MAS06285-Efficiency program display-Live tip use gearshift position D,activated ,4
IDE06753-MAS06286-Efficiency program display-Live tip Do not press accelerator pedal at standstill,activated ,4
IDE06753-MAS06287-Efficiency program display-Live tip sunroof open: switch of A/C (AC button),activated ,4
IDE06753-MAS06288-Efficiency program display-Live tip avoid engine warm-up at standstill,activated ,4
IDE06753-MAS06289-Efficiency program display-Comfort use A/C,activated ,4
IDE06753-MAS06290-Efficiency program display-Comfort use parking heater,activated ,4
IDE06753-MAS06291-Efficiency program display-Comfort use rear window heater,activated ,4
IDE06753-MAS06292-Efficiency program display-Comfort use front seat heater,activated ,4
IDE06753-MAS06293-Efficiency program display-Comfort use front seat ventilation,activated ,4
IDE06753-MAS06294-Efficiency program display-Comfort use rear heater,activated ,4
IDE06753-MAS06295-Efficiency program display-Comfort use fog light,activated ,4
IDE06753-MAS06296-Efficiency program display-Comfort use rear fog light,not activated ,4
IDE06753-MAS06297-Efficiency program display-Comfort use parking heater consumption emission,activated ,4
IDE06753-MAS06298-Efficiency program display-Comfort use windshield heater,activated ,4
IDE06753-MAS06299-Efficiency program display-Comfort use steering wheel heater,activated ,4
IDE06753-MAS06300-Efficiency program display-Comfort use mirror heater,activated ,4
IDE06753-MAS06301-Efficiency program display-Comfort use rear seat heater,not activated ,4
IDE06753-MAS06302-Efficiency program display-Comfort use rear seat ventilation,activated ,4
IDE07838-Counter for inconsistent states,78 ,2
IDE08348-Start/stop start voltage limit,7.6 V,1
IDE08624-MKE Check box,activated ,1
IDE10735-Number requests autonomous recharging,3 ,1
IDE10736-Cyclization limitation request battery service,0 ,1
IDE10748-MAS11262-Range gain-Range gain AC system,activated ,3
IDE10748-MAS11263-Range gain-Range gain auxiliary heater,activated ,3
IDE10748-MAS11264-Range gain-Range gain window defogger,activated ,3
IDE10748-MAS11265-Range gain-Range gain seat heater front,activated ,3
IDE10748-MAS11266-Range gain-Range gain front set ventilation,activated ,3
IDE10748-MAS11267-Range gain-Range gain rear heater,activated ,3
IDE10748-MAS11268-Range gain-Range gain fog light,activated ,3
IDE10748-MAS11269-Range gain-Range gain rear fog light,activated ,3
IDE10748-MAS11270-Range gain-Range gain windshield heating,activated ,3
IDE10748-MAS11271-Range gain-Range gain steering wheel heater,activated ,3
IDE10748-MAS11272-Range gain-Range gain mirror heater,activated ,3
IDE10748-MAS11273-Range gain-Range gain rear seat heater,not activated ,3
IDE10748-MAS11274-Range gain-Range gain rear seat heater,activated ,3
IDE10748-MAS11275-Range gain-Windshield heater consumption in AC system,not activated ,3
IDE10748-MAS11276-Range gain-Windshield heater range gain in AC system,activated ,3
IDE10748-MAS11277-Range gain-PTC(low voltage) consumption,not activated ,3
IDE10748-MAS11278-Range gain-PTC(low voltage) range gain,activated ,3
IDE10748-MAS11279-Range gain-List at engine still stand,activated ,3
IDE10748-MAS12689-Range gain-Catalogue range display,activated ,3
IDE10748-MAS12690-Range gain-Loading condition catalogue range display,activated ,3
IDE10748-MAS13161-Range gain-List display absolute values with weighting,activated ,3
ENG125878-ENG125896-AGW_Calibration-AGW_Brightness_Start_Sequence,100 %,10
ENG125878-ENG126255-AGW_Calibration-AGW_fade_in_deactivation_threshold,100 ,10
ENG125878-ENG125890-AGW_Calibration-AGW_Time_Fade_In,0 ms,10
ENG125878-ENG125892-AGW_Calibration-AGW_Time_Fade_In_Start,0 ms,10
ENG125878-ENG125891-AGW_Calibration-AGW_Time_Fade_Out,0 ms,10
ENG125878-ENG125893-AGW_Calibration-AGW_Time_Fade_Out_Start,0 ms,10
ENG125878-ENG125895-AGW_Calibration-AGW_Time_Start_Delay,0 ms,10
ENG125878-ENG125894-AGW_Calibration-AGW_Time_Start_Sequence,0 ms,10
ENG125879-ENG125897-AGW_Function_Releases-AGW_Enabling_Brightness,active ,3
ENG125879-ENG125898-AGW_Function_Releases-AGW_Enabling_Flash_Frequency,active ,3
ENG125879-ENG125899-AGW_Function_Releases-AGW_Enabling_Supression_Symbol,active ,3
ENG118777-ENG118712-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Counter_Master_Reset,active ,12
ENG118777-ENG118710-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Limit_Adaptation,100 ,12
ENG118777-ENG118711-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Lock_Adaptation,60000 ms,12
ENG118777-ENG118709-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Time_Adaptation,10000 ms,12
ENG118777-ENG118705-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Indication_Control_Adaption,3000 ms,12
ENG118777-ENG118706-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Kombi_Offset_Adaption,0 ms,12
ENG118777-ENG118708-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Request_Repetition_Time_Adaptation,180000 ms,12
ENG118777-ENG118707-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Sync_Time_Adaptation,1500 ms,12
ENG118777-ENG118703-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation,800 ms,12
ENG118777-ENG118704-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Touch_Contact_Time_Adaption,2500 ms,12
ENG137060-ENG113874-EM_energy_management_warning_displays-Batteriemeldungen,Mode not active ,4
ENG137060-ENG98711-EM_energy_management_warning_displays-Charge level,Mode not active ,4
ENG137060-ENG113873-EM_energy_management_warning_displays-Generatormeldungen,Mode not active ,4
ENG137060-ENG118686-EM_energy_management_warning_displays-MMI Vorwarnungen,Mode not active ,4
ENG137075-EM_heating_power_quota_adjustment,1000 W,1
ENG137061-EM_nominal_voltage_limitation_low_beams,12.1 V,1
ENG137064-EM_requirement_cyclic_time_voltage_measurement,0 s,1
ENG137063-EM_requirement_reduction_air_blowers,Mode not active ,1
ENG137062-ENG100689-EM_start_stop_requirement_ambient_temperature-Maximum_temperature,-50.0 °C,2
ENG137062-ENG137099-EM_start_stop_requirement_ambient_temperature-Minimum_temperature,-50.0 °C,2
ENG137058-SFT00001-GW_Enable_CAN_Timeout_DTC-Engine Control Module 1,Enabled ,32
ENG137058-SFT00002-GW_Enable_CAN_Timeout_DTC-Transmission Control Module,Enabled ,32
ENG137058-SFT00003-GW_Enable_CAN_Timeout_DTC-Brakes 1,not enabled ,32
ENG137058-SFT00006-GW_Enable_CAN_Timeout_DTC-Seat Adjustment Passenger Side,Enabled ,32
ENG137058-SFT00008-GW_Enable_CAN_Timeout_DTC-Air Conditioning,Enabled ,32
ENG137058-SFT00009-GW_Enable_CAN_Timeout_DTC-Central Electrics,Enabled ,32
ENG137058-SFT00014-GW_Enable_CAN_Timeout_DTC-Media Player Position 1,Enabled ,32
ENG137058-SFT00019-GW_Enable_CAN_Timeout_DTC-Adaptive Cruise Control,Enabled ,32
ENG137058-SFT00020-GW_Enable_CAN_Timeout_DTC-Wheel Dampening Electronics,Enabled ,32
ENG137058-SFT00021-GW_Enable_CAN_Timeout_DTC-Airbag,not enabled ,32
ENG137058-SFT00022-GW_Enable_CAN_Timeout_DTC-Steering Column Electronics,Enabled ,32
ENG137058-SFT00023-GW_Enable_CAN_Timeout_DTC-Dash Board,Enabled ,32
ENG137058-SFT00024-GW_Enable_CAN_Timeout_DTC-Auxiliary Parking Heater,Enabled ,32
ENG137058-SFT00025-GW_Enable_CAN_Timeout_DTC-Gateway,Enabled ,32
ENG137058-SFT00028-GW_Enable_CAN_Timeout_DTC-Vehicle Position Detection,Enabled ,32
ENG137058-SFT00032-GW_Enable_CAN_Timeout_DTC-High Beam Assistance,Enabled ,32
ENG137058-SFT00034-GW_Enable_CAN_Timeout_DTC-All Wheel Control,Enabled ,32
ENG137058-SFT00035-GW_Enable_CAN_Timeout_DTC-Brake Boost,Enabled ,32
ENG137058-SFT00038-GW_Enable_CAN_Timeout_DTC-Electronic Roof Control,Enabled ,32
ENG137058-SFT00043-GW_Enable_CAN_Timeout_DTC-Steering Column Locking,Enabled ,32
ENG137058-SFT00048-GW_Enable_CAN_Timeout_DTC-Special Function 2,Enabled ,32
ENG137058-SFT00050-GW_Enable_CAN_Timeout_DTC-Lock Electronics,Enabled ,32
ENG137058-SFT00054-GW_Enable_CAN_Timeout_DTC-Seat Adjustment Driver Side,Enabled ,32
ENG137058-SFT00060-GW_Enable_CAN_Timeout_DTC-Lane Change Assistant,Enabled ,32
ENG137058-SFT00061-GW_Enable_CAN_Timeout_DTC-Special Function,Enabled ,32
ENG137058-SFT00064-GW_Enable_CAN_Timeout_DTC-Air Conditioning Compressor,Enabled ,32
ENG137058-SFT00066-GW_Enable_CAN_Timeout_DTC-Door Electronics Driver Side,Enabled ,32
ENG137058-SFT00068-GW_Enable_CAN_Timeout_DTC-Steering Assistance,Enabled ,32
ENG137058-SFT00071-GW_Enable_CAN_Timeout_DTC-Sound System,Enabled ,32
ENG137058-SFT00081-GW_Enable_CAN_Timeout_DTC-Drive Motor Control Module,Enabled ,32
ENG137058-SFT00082-GW_Enable_CAN_Timeout_DTC-Door Electronics Passenger Side,Enabled ,32
ENG137058-SFT00085-GW_Enable_CAN_Timeout_DTC-Headlight Regulation,Enabled ,32
ENG137058-SFT00086-GW_Enable_CAN_Timeout_DTC-Radio,Enabled ,32
ENG137058-SFT00087-GW_Enable_CAN_Timeout_DTC-TV Tuner,Enabled ,32
ENG137058-SFT00095-GW_Enable_CAN_Timeout_DTC-Information Control Unit 1,Enabled ,32
ENG137058-SFT00096-GW_Enable_CAN_Timeout_DTC-Tachograph,Enabled ,32
ENG137058-SFT00101-GW_Enable_CAN_Timeout_DTC-Tire Pressure Monitoring 1,Enabled ,32
ENG137058-SFT00105-GW_Enable_CAN_Timeout_DTC-Trailer Function,Enabled ,32
ENG137058-SFT00108-GW_Enable_CAN_Timeout_DTC-Camera System Rear View,Enabled ,32
ENG137058-SFT00109-GW_Enable_CAN_Timeout_DTC-Deck Lid Control Unit,Enabled ,32
ENG137058-SFT00117-GW_Enable_CAN_Timeout_DTC-Telematics Communication Unit,Enabled ,32
ENG137058-SFT00118-GW_Enable_CAN_Timeout_DTC-Parking Assistance,Enabled ,32
ENG137058-SFT00140-GW_Enable_CAN_Timeout_DTC-Battery Energy Control Module,Enabled ,32
ENG137058-SFT00165-GW_Enable_CAN_Timeout_DTC-Front Sensors Driver Assistance System,Enabled ,32
ENG137058-SFT00166-GW_Enable_CAN_Timeout_DTC-Microphone Control Unit,Enabled ,32
ENG137058-SFT00169-GW_Enable_CAN_Timeout_DTC-Actuator For Structure-borne Sound,Enabled ,32
ENG137058-SFT00183-GW_Enable_CAN_Timeout_DTC-Access Startsystem Interface,Enabled ,32
ENG137058-SFT00187-GW_Enable_CAN_Timeout_DTC-Door Electronics Rear Driver Side,Enabled ,32
ENG137058-SFT00188-GW_Enable_CAN_Timeout_DTC-Door Electronics Rear Passenger Side,Enabled ,32
ENG137058-SFT00189-GW_Enable_CAN_Timeout_DTC-High Voltage Battery Charge Management,Enabled ,32
ENG137058-SFT00190-GW_Enable_CAN_Timeout_DTC-Sliding Door Rear Left,Enabled ,32
ENG137058-SFT00191-GW_Enable_CAN_Timeout_DTC-Sliding Door Rear Right,Enabled ,32
ENG137058-SFT00192-GW_Enable_CAN_Timeout_DTC-Actuator For Exterior Noise,Enabled ,32
ENG137058-SFT00197-GW_Enable_CAN_Timeout_DTC-Thermal management,Enabled ,32
ENG137058-SFT00198-GW_Enable_CAN_Timeout_DTC-Battery Charger Control Module,Enabled ,32
ENG137058-SFT00202-GW_Enable_CAN_Timeout_DTC-Control module for sunroof,Enabled ,32
ENG137058-SFT271931-GW_Enable_CAN_Timeout_DTC-Lane Change Assistant 2,Enabled ,32
ENG137058-ENG118664-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x00,Enabled ,32
ENG137058-ENG118466-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x01,Enabled ,32
ENG137058-ENG118467-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x02,Enabled ,32
ENG137058-ENG118468-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x03,Enabled ,32
ENG137058-ENG118469-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x04,Enabled ,32
ENG137058-ENG118470-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x05,Enabled ,32
ENG137058-ENG118471-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x06,Enabled ,32
ENG137058-ENG118472-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x07,Enabled ,32
ENG137058-ENG118473-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x08,Enabled ,32
ENG137058-ENG118474-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x09,Enabled ,32
ENG137058-ENG118475-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x0D,Enabled ,32
ENG137058-ENG118476-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x11,Enabled ,32
ENG137058-ENG118477-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x16,Enabled ,32
ENG137058-ENG118478-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x17,Enabled ,32
ENG137058-ENG118479-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1A,Enabled ,32
ENG137058-ENG118480-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1B,Enabled ,32
ENG137058-ENG118481-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1D,Enabled ,32
ENG137058-ENG118482-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1F,Enabled ,32
ENG137058-ENG118483-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x20,Enabled ,32
ENG137058-ENG118484-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x21,Enabled ,32
ENG137058-ENG118485-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x22,Enabled ,32
ENG137058-ENG118486-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x24,Enabled ,32
ENG137058-ENG118487-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x25,Enabled ,32
ENG137058-ENG118488-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x26,Enabled ,32
ENG137058-ENG118489-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x27,Enabled ,32
ENG137058-ENG118490-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x28,Enabled ,32
ENG137058-ENG118491-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x29,Enabled ,32
ENG137058-ENG118492-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2A,Enabled ,32
ENG137058-ENG118493-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2E,Enabled ,32
ENG137058-ENG118494-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2F,Enabled ,32
ENG137058-ENG118495-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x35,Enabled ,32
ENG137058-ENG118496-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x36,Enabled ,32
ENG137058-ENG118497-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x37,Enabled ,32
ENG137058-ENG118498-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x38,Enabled ,32
ENG137058-ENG118499-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x39,Enabled ,32
ENG137058-ENG118500-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3A,Enabled ,32
ENG137058-ENG118501-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3C,Enabled ,32
ENG137058-ENG118502-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3D,Enabled ,32
ENG137058-ENG118503-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x40,Enabled ,32
ENG137058-ENG118504-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x41,Enabled ,32
ENG137058-ENG118505-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x43,Enabled ,32
ENG137058-ENG118506-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x45,Enabled ,32
ENG137058-ENG118507-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x48,Enabled ,32
ENG137058-ENG118508-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x49,Enabled ,32
ENG137058-ENG118509-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x51,Enabled ,32
ENG137058-ENG118510-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x52,Enabled ,32
ENG137058-ENG118511-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x53,Enabled ,32
ENG137058-ENG118512-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x55,Enabled ,32
ENG137058-ENG118513-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x56,Enabled ,32
ENG137058-ENG118514-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x58,Enabled ,32
ENG137058-ENG118515-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x59,Enabled ,32
ENG137058-ENG118516-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5A,Enabled ,32
ENG137058-ENG118517-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5B,Enabled ,32
ENG137058-ENG118518-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5C,Enabled ,32
ENG137058-ENG118519-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5D,Enabled ,32
ENG137058-ENG118520-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5E,Enabled ,32
ENG137058-ENG118521-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5F,Enabled ,32
ENG137058-ENG118522-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x60,Enabled ,32
ENG137058-ENG118523-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x61,Enabled ,32
ENG137058-ENG118524-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x62,Enabled ,32
ENG137058-ENG118525-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x66,Enabled ,32
ENG137058-ENG118526-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x68,Enabled ,32
ENG137058-ENG118527-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6B,Enabled ,32
ENG137058-ENG118528-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6C,Enabled ,32
ENG137058-ENG118529-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6E,Enabled ,32
ENG137058-ENG118530-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x74,Enabled ,32
ENG137058-ENG118531-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x75,Enabled ,32
ENG137058-ENG118532-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x78,Enabled ,32
ENG137058-ENG118533-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x79,Enabled ,32
ENG137058-ENG118534-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7A,Enabled ,32
ENG137058-ENG118535-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7D,Enabled ,32
ENG137058-ENG118536-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7E,Enabled ,32
ENG137058-ENG118537-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7F,Enabled ,32
ENG137058-ENG118538-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x80,Enabled ,32
ENG137058-ENG118539-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x81,Enabled ,32
ENG137058-ENG118540-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x82,Enabled ,32
ENG137058-ENG118541-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x83,Enabled ,32
ENG137058-ENG118542-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x85,Enabled ,32
ENG137058-ENG118543-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x86,Enabled ,32
ENG137058-ENG118544-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x87,Enabled ,32
ENG137058-ENG118545-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x88,Enabled ,32
ENG137058-ENG118546-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x89,Enabled ,32
ENG137058-ENG118547-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8B,Enabled ,32
ENG137058-ENG118548-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8C,Enabled ,32
ENG137058-ENG118549-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8D,Enabled ,32
ENG137058-ENG118550-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8E,Enabled ,32
ENG137058-ENG118551-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8F,Enabled ,32
ENG137058-ENG118552-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x90,Enabled ,32
ENG137058-ENG118553-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x91,Enabled ,32
ENG137058-ENG118554-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x92,Enabled ,32
ENG137058-ENG118555-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x93,Enabled ,32
ENG137058-ENG118556-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x94,Enabled ,32
ENG137058-ENG118557-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x95,Enabled ,32
ENG137058-ENG118558-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x96,Enabled ,32
ENG137058-ENG118559-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x97,Enabled ,32
ENG137058-ENG118560-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x98,Enabled ,32
ENG137058-ENG118561-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x99,Enabled ,32
ENG137058-ENG118562-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9A,Enabled ,32
ENG137058-ENG118563-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9B,Enabled ,32
ENG137058-ENG118564-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9C,Enabled ,32
ENG137058-ENG118565-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9D,Enabled ,32
ENG137058-ENG118566-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9E,Enabled ,32
ENG137058-ENG118567-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9F,Enabled ,32
ENG137058-ENG118568-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA0,Enabled ,32
ENG137058-ENG118569-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA1,Enabled ,32
ENG137058-ENG118570-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA2,Enabled ,32
ENG137058-ENG118571-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA3,Enabled ,32
ENG137058-ENG118572-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA4,Enabled ,32
ENG137058-ENG118573-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA5,Enabled ,32
ENG137058-ENG118574-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA6,Enabled ,32
ENG137058-ENG118575-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA7,Enabled ,32
ENG137058-ENG118576-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA8,Enabled ,32
ENG137058-ENG118577-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA9,Enabled ,32
ENG137058-ENG118578-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAA,Enabled ,32
ENG137058-ENG118579-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAB,Enabled ,32
ENG137058-ENG118580-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAC,Enabled ,32
ENG137058-ENG118581-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAD,Enabled ,32
ENG137058-ENG118582-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAE,Enabled ,32
ENG137058-ENG118583-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAF,Enabled ,32
ENG137058-ENG118584-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB0,Enabled ,32
ENG137058-ENG118585-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB1,Enabled ,32
ENG137058-ENG118586-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB2,Enabled ,32
ENG137058-ENG118587-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB3,Enabled ,32
ENG137058-ENG118588-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB4,Enabled ,32
ENG137058-ENG118589-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB5,Enabled ,32
ENG137058-ENG118590-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB6,Enabled ,32
ENG137058-ENG118591-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB7,Enabled ,32
ENG137058-ENG118592-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB8,Enabled ,32
ENG137058-ENG118593-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB9,Enabled ,32
ENG137058-ENG118594-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBA,Enabled ,32
ENG137058-ENG118595-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBB,Enabled ,32
ENG137058-ENG118596-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBC,Enabled ,32
ENG137058-ENG118597-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBD,Enabled ,32
ENG137058-ENG118598-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBE,Enabled ,32
ENG137058-ENG118599-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBF,Enabled ,32
ENG137058-ENG118600-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC0,Enabled ,32
ENG137058-ENG118601-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC1,Enabled ,32
ENG137058-ENG118602-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC2,Enabled ,32
ENG137058-ENG118603-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC3,Enabled ,32
ENG137058-ENG118604-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC4,Enabled ,32
ENG137058-ENG118605-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC5,Enabled ,32
ENG137058-ENG118606-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC6,Enabled ,32
ENG137058-ENG118607-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC7,Enabled ,32
ENG137058-ENG118608-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC8,Enabled ,32
ENG137058-ENG118609-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC9,Enabled ,32
ENG137058-ENG118610-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCA,Enabled ,32
ENG137058-ENG118611-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCB,Enabled ,32
ENG137058-ENG118612-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCC,Enabled ,32
ENG137058-ENG118613-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCD,Enabled ,32
ENG137058-ENG118614-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCE,Enabled ,32
ENG137058-ENG118615-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCF,Enabled ,32
ENG137058-ENG118616-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD0,Enabled ,32
ENG137058-ENG118617-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD1,Enabled ,32
ENG137058-ENG118618-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD2,Enabled ,32
ENG137058-ENG118619-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD3,Enabled ,32
ENG137058-ENG118620-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD4,Enabled ,32
ENG137058-ENG118621-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD5,Enabled ,32
ENG137058-ENG118622-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD6,Enabled ,32
ENG137058-ENG118623-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD7,Enabled ,32
ENG137058-ENG118624-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD8,Enabled ,32
ENG137058-ENG118625-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD9,Enabled ,32
ENG137058-ENG118626-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDA,Enabled ,32
ENG137058-ENG118627-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDB,Enabled ,32
ENG137058-ENG118628-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDC,Enabled ,32
ENG137058-ENG118629-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDD,Enabled ,32
ENG137058-ENG118630-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDE,Enabled ,32
ENG137058-ENG118631-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDF,Enabled ,32
ENG137058-ENG118632-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE0,Enabled ,32
ENG137058-ENG118633-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE1,Enabled ,32
ENG137058-ENG118634-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE2,Enabled ,32
ENG137058-ENG118635-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE3,Enabled ,32
ENG137058-ENG118636-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE4,Enabled ,32
ENG137058-ENG118637-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE5,Enabled ,32
ENG137058-ENG118638-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE6,Enabled ,32
ENG137058-ENG118639-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE7,Enabled ,32
ENG137058-ENG118640-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE8,Enabled ,32
ENG137058-ENG118641-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE9,Enabled ,32
ENG137058-ENG118642-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEA,Enabled ,32
ENG137058-ENG118643-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEB,Enabled ,32
ENG137058-ENG118644-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEC,Enabled ,32
ENG137058-ENG118645-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xED,Enabled ,32
ENG137058-ENG118646-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEE,Enabled ,32
ENG137058-ENG118647-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEF,Enabled ,32
ENG137058-ENG118648-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF0,Enabled ,32
ENG137058-ENG118649-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF1,Enabled ,32
ENG137058-ENG118650-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF2,Enabled ,32
ENG137058-ENG118651-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF3,Enabled ,32
ENG137058-ENG118652-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF4,Enabled ,32
ENG137058-ENG118653-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF5,Enabled ,32
ENG137058-ENG118654-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF6,Enabled ,32
ENG137058-ENG118655-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF7,Enabled ,32
ENG137058-ENG118656-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF8,Enabled ,32
ENG137058-ENG118657-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF9,Enabled ,32
ENG137058-ENG118658-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFA,Enabled ,32
ENG137058-ENG118659-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFB,Enabled ,32
ENG137058-ENG118660-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFC,Enabled ,32
ENG137058-ENG118661-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFD,Enabled ,32
ENG137058-ENG118662-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFE,Enabled ,32
ENG137058-ENG118663-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFF,Enabled ,32
ENG137059-ENG118464-GW_mirror_mode-mirror_mode_bus,Databus drivetrain ,2
ENG137059-ENG118465-GW_mirror_mode-mirror_mode_typ,not active ,2
ENG137065-GW_routing_0,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137066-GW_routing_1,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137067-GW_routing_2,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137068-GW_routing_3,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137069-GW_routing_4,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137070-GW_routing_5,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137071-GW_routing_6,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137072-GW_routing_7,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137073-GW_routing_8,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG137074-GW_routing_9,00 00 00 00 00 00 00 00 00 00 00 00 ,12
ENG118774-WakeUpMonitor_Activation,activated ,1
ENG118773-ENG99074-WakeUpMonitor_Configuration-Max_Num_Keeping_Awake_Events,100 ,5
ENG118773-ENG103852-WakeUpMonitor_Configuration-Sample_Time_Keeping_Awake_Events,12 s,5
ENG118773-ENG127936-WakeUpMonitor_Configuration-WakeUpMonitor_Start_Delay,0 s,5
Elapsed Time: 00:22
Differences
01
Address 01: Engine (J623-CYVA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 027 GP HW: 04E 907 309 BL
Component: R4 1.2l TFS H23 2396
Revision: R4H23---
Coding: 01110012230411082000
Shop #: WSC 00028 028 00028
ASAM Dataset: EV_ECM12TFS01104E906027GP 001005
ROD: EV_ECM12TFS01104E906027GR.rod
VCID: F8BCA3AC435F71EA7EF-80AC
CAN Converter 01:
Readiness: 1110 0001
Revision: R4H23---
Coding: 01110012232415082000
Shop #: WSC 63672 002 1048576
VCID: 78BC3A19C37F4086A9-802C
CAN Converter 01:
16
Part No SW: 5Q0 953 507 GB HW: 5Q0 953 549 F
Component: Lenks. Modul 003 0120
Revision: -------- Serial number: 30031604401139
Coding: 0600
Shop #: WSC 00028 028 00025
ASAM Dataset: EV_SMLSKLOMQB 020001
ROD: EV_SMLSKLOMQB_VW37.rod
VCID: FCB4BFBC77675DCA1A7-80A8
Address 16: Steering wheel (J527) Labels:. 5Q0-953-549.clb
Coding: 1604
VCID: 7CB42609F7476CA6CD-8028
Part No SW: 5Q0 907 530 AG HW: 5Q0 907 530 K
Component: GW MQB Low 210 2246
Revision: -------- Serial number: 27031610802138
Coding: 030000043F085700FB000048080E00010001050000000000000000000000
ROD: EV_GatewConti_013_VW37.rod
VCID: F6A0AD94494B079A6C3-80A2
Subsystem 2 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Component: J367-BDMHella H04 8050
Serial number: 9114489003
Admap 19
diff --git a/G7 CCS retrofitted/adpmap-19-5Q0-907-530-AG.CSV b/golf7 ccs retro/adpmap-19-5Q0-907-530-AG.CSV
index 9ce9405..c836d66 100644
--- a/G7 CCS retrofitted/adpmap-19-5Q0-907-530-AG.CSV
+++ b/golf7 ccs retro/adpmap-19-5Q0-907-530-AG.CSV
@@ -1,9 +1,9 @@
;SW:5Q0-907-530-AG HW:5Q0-907-530-K --- CAN Gateway
;Component:GW MQB Low 210 2246, Coding:030000043F085700FB000048080E00010001050000000000000000000000
;EV_GatewConti,013020,EV_GatewConti_013_VW37.rod
-;Monday,22,January,2018,08:57:12:44043
-;VCDS Version: Release 17.8.1 (x64) Data version: 20171130 DS276.6
-;VCID: 76A03421C96B36F6BB-8022
+;Saturday,13,January,2018,19:59:48:36026
+;VCDS Version: Beta 17.11.0 (x64) Data version: 20171026 DS285.1
+;VCID: F6A0AD94494B079A6C3-80A2
IDE00001-ENG124491-Production mode-p_mode_deactivate_mfl_keys,Deactivating ,3
IDE00001-ENG118694-Production mode-p_mode_deactivate_recuperation,Deactivating ,3
@@ -49,6 +49,7 @@ IDE01996-SFT00066-Installation list: specified installations-Door Electronics Dr
+IDE01996-SFT00075-Installation list: specified installations-Multifunction module,Not coded ,32
@@ -87,7 +88,6 @@ IDE01996-ENG118230-Installation list: specified installations-Node_0x05,Not code
-IDE01996-ENG118234-Installation list: specified installations-Node_0x09,Not coded ,32
@@ -282,7 +282,7 @@ IDE03256-MAS06108-Battery adaptation-Battery Serial Number,1111111111 ,15
-IDE04330-Transfer of release code for a SWaP function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
+IDE04330-Transfer of release code for a SWaP function,00 ,1
@@ -313,6 +313,9 @@ IDE06753-MAS06299-Efficiency program display-Comfort use steering wheel heater,a
+IDE06753-MAS14430-Efficiency program display-Dependence of ECO tips on driver profile selection,ECO tips independent of driver profile selection ,4
+IDE06753-MAS19094-Efficiency program display-Convenience_consumption_air_condition_ventilation_rear,activated ,4
+IDE06753-MAS19095-Efficiency program display-Convenience_consumption_mirror_heating_dependency,Until_temperature_threshold_with_after-run_with_switch ,4
@@ -339,6 +342,9 @@ IDE10748-MAS11279-Range gain-List at engine still stand,activated ,3
+IDE10748-MAS19099-Range gain-Convenience_consumption_means_plug,activated ,3
+IDE10748-MAS19100-Range gain-Convenience_consumption_air_condition_ventilation_manually,activated ,3
+IDE10748-MAS19132-Range gain-Consumption_mirror_heating_in_heated_rear_window,activated ,3
@@ -376,6 +382,7 @@ ENG137058-SFT00003-GW_Enable_CAN_Timeout_DTC-Brakes 1,not enabled ,32
+ENG137058-SFT00011-GW_Enable_CAN_Timeout_DTC-Auxiliary Air Heater,Enabled ,32
@@ -399,6 +406,7 @@ ENG137058-SFT00064-GW_Enable_CAN_Timeout_DTC-Air Conditioning Compressor,Enabled
+ENG137058-SFT00075-GW_Enable_CAN_Timeout_DTC-Multifunction module,Enabled ,32
@@ -412,6 +420,8 @@ ENG137058-SFT00108-GW_Enable_CAN_Timeout_DTC-Camera System Rear View,Enabled ,32
+ENG137058-SFT00128-GW_Enable_CAN_Timeout_DTC-Battery Regulation Auxiliary Accumulator 1,Enabled ,32
+ENG137058-SFT00130-GW_Enable_CAN_Timeout_DTC-Head Up Display,Enabled ,32
@@ -426,7 +436,7 @@ ENG137058-SFT00192-GW_Enable_CAN_Timeout_DTC-Actuator For Exterior Noise,Enabled
-ENG137058-SFT271931-GW_Enable_CAN_Timeout_DTC-Lane Change Assistant 2,Enabled ,32
+ENG137058-SFT00207-GW_Enable_CAN_Timeout_DTC-Control Unit Lane Change Assistant 2,Enabled ,32
@@ -442,7 +452,6 @@ ENG137058-ENG118476-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mas
-ENG137058-ENG118480-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1B,Enabled ,32
@@ -534,17 +543,14 @@ ENG137058-ENG118568-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mas
-ENG137058-ENG118572-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA4,Enabled ,32
-ENG137058-ENG118577-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA9,Enabled ,32
-ENG137058-ENG118582-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAE,Enabled ,32
@@ -638,7 +644,8 @@ ENG137071-GW_routing_6,00 00 00 00 00 00 00 00 00 00 00 00 ,12
-ENG118774-WakeUpMonitor_Activation,activated ,1
+ENG118774-ENG98345-WakeUpMonitor_Activation-Activation,activated ,1
+ENG118774-ENG152567-WakeUpMonitor_Activation-Open_Filter_Activate,not activated ,1
